SIS with coverage support
Jiri Gaisler
jiri at gaisler.se
Thu Jan 24 08:33:15 UTC 2019
On 1/24/19 12:45 AM, Joel Sherrill wrote:
> On Wed, Jan 23, 2019 at 4:45 PM Chris Johns <chrisj at rtems.org <mailto:chrisj at rtems.org>> wrote:
> On 24/1/19 9:12 am, Jiri Gaisler wrote:
> > After some trial and error, I got covoar to run with:
> Great.
> > However, the coverage is always 0% in the summary report:
> Does adding -v to the command line provide any more detail? Repeating -v
> increases the level but things can become rather verbose and if you trip full
> DWARF tracing there is a lot of output.
> I would be suspicious of the code that is invoked around
> CoverageReaderTSIM.cc:83 as a starting point. For some method you
> know you should be analyzed, there should be aCoverageMap. Since you
> are looking at only one executable, you could hard-code a test with
> address range of a single method under test to see what happens.
Well, the problem is that covoar in rtems-tools is hard-coded to use the QEMU format, and the -f switch to change format is not used. I have attached a patch to fix that. After that, covoar works fine with the coverage data from sis:
cat coverage/summary.txt
Bytes Analyzed : 20034
Bytes Not Executed : 11734
Percentage Executed : 41.43
Percentage Not Executed : 58.57
Uncovered ranges found : 242
Total branches found : 443
Uncovered branches found : 167
68 branches always taken
99 branches never taken
If you approve to the patch, then I will check it in (now that I know how ... :-))
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190124/a2314f2f/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190124/a2314f2f/attachment.bin>
