[PATCH] 5/packages: Add curl and update all packages with RTEMS 5 and LiobBSD
chrisj at rtems.org chrisj at rtems.org
Sat Jul 6 09:30:22 UTC 2019
- Update rtems-bsp support to correctly handle hosts for BSP.
- Clean up the options for a BSP.
- Check all RTEMS 5 packages and add 5/rtems-packages for all that build.
- Update download locations and checksum of all packages.
- The work requires the kernel and Libbsd hacve the same prefix.
 rtems/config/5/rtems-packages.bset            | 24 ++++++
 rtems/config/databases/sqlite-3.8.8.1-1.cfg   |  2 +-
 rtems/config/ftp/curl-7.65.1-1.cfg            | 21 +++++
 rtems/config/ftp/curl.bset                    | 20 +++++
 rtems/config/graphics/freetype-2.4.10-1.cfg   |  2 +-
 rtems/config/graphics/graphics-all.bset       |  5 +-
 rtems/config/graphics/libjpeg-9a-1.cfg        |  2 +-
 rtems/config/graphics/libpng-1.6.37-1.cfg     | 21 +++++
 rtems/config/graphics/libpng.bset             |  2 +-
 rtems/config/graphics/libtiff-4.0.10-1.cfg    | 21 +++++
 rtems/config/graphics/libtiff-4.0.6-1.cfg     |  2 +-
 rtems/config/graphics/libtiff.bset            |  2 +-
 .../graphics/microwindows-0.93-dev-1.cfg      | 12 +--
 rtems/config/graphics/t1lib-5.1.2-1.cfg       |  4 +-
 rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg  |  6 +-
 rtems/config/net/lwip-1-1.cfg                 | 12 ++-
 rtems/config/net/ntp-4.2.6p5-1.cfg            |  6 +-
 rtems/config/net/protobuf-2.6.1-1.cfg         |  2 +-
 rtems/config/rtems-bsp.cfg                    | 83 +++++++++++++++----
 source-builder/config/curl-1.cfg              | 81 ++++++++++++++++++
 source-builder/config/libpng-1.cfg            |  4 +-
 source-builder/config/libtiff-1.cfg           |  2 +-
 source-builder/config/lwip-1.cfg              | 11 +--
 source-builder/config/microwindows-1.cfg      | 10 +--
 source-builder/config/net-snmp-5-1.cfg        |  1 +
 source-builder/config/t1lib-1.cfg             |  2 +-
 source-builder/defaults.mc                    | 34 +++++---
 source-builder/sb/options.py                  | 12 ++-
 source-builder/sb/rtems-build-dep             |  2 +-
 29 files changed, 335 insertions(+), 73 deletions(-)
 create mode 100644 rtems/config/5/rtems-packages.bset
 create mode 100644 rtems/config/ftp/curl-7.65.1-1.cfg
 create mode 100644 rtems/config/ftp/curl.bset
 create mode 100644 rtems/config/graphics/libpng-1.6.37-1.cfg
 create mode 100644 rtems/config/graphics/libtiff-4.0.10-1.cfg
 create mode 100644 source-builder/config/curl-1.cfg
diff --git a/rtems/config/5/rtems-packages.bset b/rtems/config/5/rtems-packages.bset
new file mode 100644
index 0000000..edc7e6b
--- /dev/null
+++ b/rtems/config/5/rtems-packages.bset
@@ -0,0 +1,24 @@
+# RTEMS Packages that build for this release.
+# Databases
+databases/sqlite
+# Graphics
+graphics/freetype2
+graphics/libjpeg
+graphics/libpng
+graphics/libtiff
+graphics/t1lib
+# Networking
+ftp/curl
+net/lwip
+net/protobuf
diff --git a/rtems/config/databases/sqlite-3.8.8.1-1.cfg b/rtems/config/databases/sqlite-3.8.8.1-1.cfg
index 609d4c1..aac06be 100644
--- a/rtems/config/databases/sqlite-3.8.8.1-1.cfg
+++ b/rtems/config/databases/sqlite-3.8.8.1-1.cfg
@@ -19,7 +19,7 @@
 %define sqlite_src_version 3080801
 %define sqlite_src_year    2015
-%hash md5 sqlite-src-%{sqlite_src_version}.zip 9dde57c312da00cbe791bcba42d1e96a
+%hash sha512 sqlite-src-%{sqlite_src_version}.zip 4f09228cb0c9c608e492da6e480afe3d27a63e27ccdcf33a88d5e56427f0846efab8930c81026b8e608f1bbb8d63e8d937dd26571deb828617f7efa27a765950
 # Sqlite configuration
diff --git a/rtems/config/ftp/curl-7.65.1-1.cfg b/rtems/config/ftp/curl-7.65.1-1.cfg
index 0000000..abc7e9d
--- /dev/null
+++ b/rtems/config/ftp/curl-7.65.1-1.cfg
@@ -0,0 +1,21 @@
+# Curl 7.65.1
+%if %{release} == %{nil}
+ %define release 1
+%endif
+%include %{_configdir}/rtems-bsp.cfg
+# Curl Version
+%define curl_version 7.65.1
+%hash sha512 curl-%{curl_version}.tar.xz aba2d979a416d14a0f0852d595665e49fc4f7bff3bee31f3a52b90ba9dc5ffdb09c092777f124215470b72c47ebca7ddb47844cbf5c0e9142099272b6ac55df4
+# Curl Build configuration
+%include %{_configdir}/curl-1.cfg
diff --git a/rtems/config/ftp/curl.bset b/rtems/config/ftp/curl.bset
index 0000000..84cac39
--- /dev/null
+++ b/rtems/config/ftp/curl.bset
@@ -0,0 +1,20 @@
+# Build set for Curl
+%define release 1
+# RTEMS Version
+%define rtems_version 5
+# The RTEMS URL paths.
+%include rtems-urls.bset
+# Build Curl
+ftp/curl-7.65.1-1
diff --git a/rtems/config/graphics/freetype-2.4.10-1.cfg b/rtems/config/graphics/freetype-2.4.10-1.cfg
index 524dc3a..3963c98 100644
--- a/rtems/config/graphics/freetype-2.4.10-1.cfg
+++ b/rtems/config/graphics/freetype-2.4.10-1.cfg
@@ -13,7 +13,7 @@
 %define freetype_version 2.4.10
-%hash md5 freetype-%{freetype_version}.tar.gz 4f255c6ee5d5cc2b5c3d423a07386fcb
+%hash sha512 freetype-%{freetype_version}.tar.gz 507d1c03d394b695b5a96041ad7ee03b375964c89f007678db864a7e5bd2ee69d83e6c638f4aadaf348c921d37c16741a03ef9bee03196bda2b94ceea409b688
 # freetype Build configuration
diff --git a/rtems/config/graphics/graphics-all.bset b/rtems/config/graphics/graphics-all.bset
index 5527ca3..b0ea5fe 100644
--- a/rtems/config/graphics/graphics-all.bset
+++ b/rtems/config/graphics/graphics-all.bset
@@ -2,8 +2,11 @@
 # All RTEMS Graphics Build Sets
+graphics/freetype2
 graphics/libjpeg
 graphics/libpng
 graphics/libtiff
 graphics/t1lib
-graphics/microwindows.bset
+# Remove as microwindows does not build. Please fix and provide a patch.
+# graphics/microwindows
diff --git a/rtems/config/graphics/libjpeg-9a-1.cfg b/rtems/config/graphics/libjpeg-9a-1.cfg
index a366da9..fef32d6 100644
--- a/rtems/config/graphics/libjpeg-9a-1.cfg
+++ b/rtems/config/graphics/libjpeg-9a-1.cfg
@@ -13,7 +13,7 @@
 %define libjpeg_version 9a
-%hash md5 jpegsrc.v%{libjpeg_version}.tar.gz 3353992aecaee1805ef4109aadd433e7
+%hash sha512 jpegsrc.v%{libjpeg_version}.tar.gz 9b21cc115e22c68bea46db462263c5c7a0d10beb192a919ecccbd801a25982b518ce44d8c301dd582ecaba1850e0e0f20e322be82b0e24ae917b9949b4f10d3b
 # libjpeg Build configuration
diff --git a/rtems/config/graphics/libpng-1.6.37-1.cfg b/rtems/config/graphics/libpng-1.6.37-1.cfg
index 0000000..f4717f4
--- /dev/null
+++ b/rtems/config/graphics/libpng-1.6.37-1.cfg
@@ -0,0 +1,21 @@
+# libpng 1.6.37
+ %define release 1
+%endif
+# libpng Version
+%define libpng_version 1.6.37
+%hash sha512 libpng-%{libpng_version}.tar.xz 59e8c1059013497ae616a14c3abbe239322d3873c6ded0912403fc62fb260561768230b6ab997e2cccc3b868c09f539fd13635616b9fa0dd6279a3f63ec7e074
+# libpng Build configuration
+%include %{_configdir}/libpng-1.cfg
diff --git a/rtems/config/graphics/libpng.bset b/rtems/config/graphics/libpng.bset
index 4e6db7d..57abeaf 100644
--- a/rtems/config/graphics/libpng.bset
+++ b/rtems/config/graphics/libpng.bset
@@ -12,4 +12,4 @@
 # Build libpng.
-graphics/libpng-1.6.21-1.cfg
+graphics/libpng-1.6.37-1.cfg
diff --git a/rtems/config/graphics/libtiff-4.0.10-1.cfg b/rtems/config/graphics/libtiff-4.0.10-1.cfg
index 0000000..901eed1
--- /dev/null
+++ b/rtems/config/graphics/libtiff-4.0.10-1.cfg
@@ -0,0 +1,21 @@
+# libtiff 4.0.10
+ %define release 1
+%endif
+# tiff Version
+%define tiff_version 4.0.10
+%hash sha512 tiff-%{tiff_version}.tar.gz d213e5db09fd56b8977b187c5a756f60d6e3e998be172550c2892dbdb4b2a8e8c750202bc863fe27d0d1c577ab9de1710d15e9f6ed665aadbfd857525a81eea8
+# tiff Build configuration
+%include %{_configdir}/libtiff-1.cfg
diff --git a/rtems/config/graphics/libtiff-4.0.6-1.cfg b/rtems/config/graphics/libtiff-4.0.6-1.cfg
index 946daef..bcd7c5b 100644
--- a/rtems/config/graphics/libtiff-4.0.6-1.cfg
+++ b/rtems/config/graphics/libtiff-4.0.6-1.cfg
@@ -13,7 +13,7 @@
 %define tiff_version 4.0.6
-%hash md5 tiff-%{tiff_version}.tar.gz d1d2e940dea0b5ad435f21f03d96dd72
+%hash sha512 tiff-%{tiff_version}.tar.gz 2c8dbaaaab9f82a7722bfe8cb6fcfcf67472beb692f1b7dafaf322759e7016dad1bc58457c0f03db50aa5bd088fef2b37358fcbc1524e20e9e14a9620373fdf8
diff --git a/rtems/config/graphics/libtiff.bset b/rtems/config/graphics/libtiff.bset
index 434cdbc..f10e60e 100644
--- a/rtems/config/graphics/libtiff.bset
+++ b/rtems/config/graphics/libtiff.bset
@@ -12,4 +12,4 @@
 # Build libtiff.
-graphics/libtiff-4.0.6-1.cfg
+graphics/libtiff-4.0.10-1.cfg
diff --git a/rtems/config/graphics/microwindows-0.93-dev-1.cfg b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
index 0ab9da4..7ca8968 100644
--- a/rtems/config/graphics/microwindows-0.93-dev-1.cfg
+++ b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
@@ -11,15 +11,17 @@
 # microwindows Version
-%define microwindows_version 0.93-dev
+%define microwindows_version 56041759161132a94df3e575ae995e53d6b6e1d8
 %define rtems_git_tools_4_11 %{rtems_http_git}/rtems-tools/plain/tools/4.11
-%source set microwindows git://github.com/ghaerr/microwindows.git
+%hash sha512 microwindows-%{microwindows_version}.tar.gz cf29a9d966a8a5b3926aab7f911c47890c9b1a589ff0ecf098e6be45ae1555958b0e437270fb26e353b8c58f261834a3a7f0fce84bea0fdb9138fc38c8703ddc
 %patch add microwindows %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev.diff
-%hash md5 microwindows-0.93-dev.diff 5b06e77d9ee42c8ff0032bba07d01c1a
-%patch add microwindows %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev-without-keyboard.diff
-%hash md5 microwindows-0.93-dev-without-keyboard.diff a675f55750754e1cd82a17496f0e8fab
+%hash sha512 microwindows-0.93-dev.diff 2f575f603ce9ccff5c98e9c434d72fb9952d1385903495bf818d50de6568c57c9ca1d3320388e3bae384388d192a389012baf4d734d2cc8481d56f231d2a93d0
+#%patch add microwindows %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev-without-keyboard.diff
+#%hash sha512 microwindows-0.93-dev-without-keyboard.diff c235177fa80035ec70957aee1daa9232c9050abddac08e5f7b2977bd58703224367b4262a2ddc2999b1ac64b5ab838ad3ad740ee1490741293cffe7c16575fb2
 # microwindows Build configuration
diff --git a/rtems/config/graphics/t1lib-5.1.2-1.cfg b/rtems/config/graphics/t1lib-5.1.2-1.cfg
index 58eaa3b..27de3cf 100644
--- a/rtems/config/graphics/t1lib-5.1.2-1.cfg
+++ b/rtems/config/graphics/t1lib-5.1.2-1.cfg
@@ -13,13 +13,13 @@
 %define t1lib_version 5.1.2
-%hash md5 t1lib-%{t1lib_version}.tar.gz a5629b56b93134377718009df1435f3c
+%hash sha512 t1lib-%{t1lib_version}.tar.gz 9f424b19c6f35cc4f194ff7351a4c2352216462c7d1b1d9650ad3a05cf48c6e90c89ccbcda5ecc47a4169a39a850cf84a1fcbf88b3b15614860c27364b631ae3
 # Patch for RTEMS.
 %patch add t1lib https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/t1lib/t1lib-5.1.2.diff
-%hash md5 t1lib-5.1.2.diff 98eeed85780227adf8525deab3679877
+%hash sha512 t1lib-5.1.2.diff 1afd18182350d7d2426a910c61537f8532e149bf37c616f3a4a84ae0767c4549a2be857db6fd1b1994ed86f8a2e2d4cdfb2abdf67053c8ca1ee83893f4b56d23
 # t1lib Build configuration
diff --git a/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg b/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
index 7527871..e4fe63e 100644
--- a/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
+++ b/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
@@ -13,7 +13,7 @@
 %define net_snmp_version 5.7.2.1
-%hash md5 net-snmp-%{net_snmp_version}.tar.gz 7db683faba037249837b226f64d566d4
+%hash sha512 net-snmp-%{net_snmp_version}.tar.gz 6c4dadd145cab9572e2559ad99d6794469685086771c6d757d3667da1a061ab86746d53c28d48381c59a90d92b1812b813f3176cff156c41929177fb585299d0
 # We need some special flags to build this version.
@@ -23,8 +23,8 @@
 # Patch for RTEMS support.
-%patch add net-snmp %{rtems_git_tools}/net-snmp/rtems-net-snmp-5.7.2.1-20140623.patch
-%hash  md5 rtems-net-snmp-5.7.2.1-20140623.patch 9a22fb4366a113f5df71ed2acd672b2b
+%patch add net-snmp %{rtems_git_tools}/net-snmp/rtems-net-snmp-5.7.2.1-20190704.patch
+#%hash  sha512 rtems-net-snmp-5.7.2.1-20140623.patch 4eb987d88c6414f2e07d725c2ebb3e88a40191c7befce879cae9ef67143dc25aa88942cfc525d36cd3683476d1cc0f5882d4a730d3bb9c53be2c7a079874d7dd
 # NetSNMP Build configuration
diff --git a/rtems/config/net/lwip-1-1.cfg b/rtems/config/net/lwip-1-1.cfg
index cf25963..8605f1c 100644
--- a/rtems/config/net/lwip-1-1.cfg
+++ b/rtems/config/net/lwip-1-1.cfg
@@ -11,15 +11,19 @@
 # LWIP Version
-%define lwip_version lwip-c2ebf5544b4268eac9b32c7f3a689ff646d96eef
+%define lwip_version c2ebf5544b4268eac9b32c7f3a689ff646d96eef
+%hash sha512 lwip-%{lwip_version}.tar.gz bfa93e050133ca591c628f0e3a04f5082f55a655b099cdd49138ebf74494354a4cbbee56839f5939174b4c965b29ec648c24b7479c73393ac94ec536cb578b70
-#Will be modified to be pointing to RTEMS repo
+# Will be modified to be pointing to RTEMS repo
 %define rtems_ragu_git https://raw.githubusercontent.com/ragunath3252/lwip-nodrv/master
-%patch add lwip %{rtems_ragu_git}/rtems.patch
-%hash  md5 rtems.patch 489c0def3a89e538fb526a5396bf27ca
+%patch add lwip --rsb-file=lwip-nodrv-rtems.patch %{rtems_ragu_git}/rtems.patch
+%hash sha512 lwip-nodrv-rtems.patch ba49163e11069cb036280023db064625e5d1aed3a6cf3e51c64e59639580e9f758434e60853242fb924eb5cebc73b478f01ff51f24505e85d4c21bb1963415e1
 # LWIP Build configuration
diff --git a/rtems/config/net/ntp-4.2.6p5-1.cfg b/rtems/config/net/ntp-4.2.6p5-1.cfg
index 43afbf3..34676b6 100644
--- a/rtems/config/net/ntp-4.2.6p5-1.cfg
+++ b/rtems/config/net/ntp-4.2.6p5-1.cfg
@@ -13,13 +13,13 @@
 %define ntp_version 4.2.6p5
-%hash md5 ntp-%{ntp_version}.tar.gz 00df80a84ec9528fcfb09498075525bc
+%hash sha512 ntp-%{ntp_version}.tar.gz 8d76fc7e92b2ea6dd5031e6030a7aba4ff6fb3e19d3bc0153852509861be5d0960e70604814163caedb81f8315a451d78371f99634a50b55cfe1cbd2c69e3046
-%patch add ntp %{rtems_git_tools}/ntp/rtems-ntp-4.2.6p5.diff
-%hash  md5 rtems-ntp-4.2.6p5.diff 6fce685a73873f924a48b19d6b1700fc
+%patch add ntp %{rtems_http_git}/rtems-tools/plain/tools/4.11/ntp/rtems-ntp-4.2.6p5.diff
+%hash  sha512 rtems-ntp-4.2.6p5.diff 257223d207d0b77cde2b9d7add22e3b9d657b58998411d2e20d0b1adf36910be21f1277386c54c34f5d9616fccd29f721d007295708047ea7ae0270a00be25a0
 # NTP Build configuration
diff --git a/rtems/config/net/protobuf-2.6.1-1.cfg b/rtems/config/net/protobuf-2.6.1-1.cfg
index 5218eac..2e507f6 100644
--- a/rtems/config/net/protobuf-2.6.1-1.cfg
+++ b/rtems/config/net/protobuf-2.6.1-1.cfg
@@ -13,7 +13,7 @@
 %define protobuf_version 2.6.1
-%hash md5 protobuf-%{protobuf_version}.tar.gz f3916ce13b7fcb3072a1fa8cf02b2423
+%hash sha512 protobuf-%{protobuf_version}.tar.gz 818ac4ad24aca84d214d14ac860a75c14494528821af144d3cb603f69c94d4500512814be6d62cc82973804ebfa99eb94d9f034b309f53cadb622603a7886a3e
 # Protocol Buffers configuration
diff --git a/rtems/config/rtems-bsp.cfg b/rtems/config/rtems-bsp.cfg
index 28d250f..1c2b2e6 100644
--- a/rtems/config/rtems-bsp.cfg
+++ b/rtems/config/rtems-bsp.cfg
@@ -3,13 +3,21 @@
-# The RTEMS BSP support requires the host turple, the RTEMS BSP and the path to
+# The RTEMS BSP support requires the host tuple, the RTEMS BSP and the path to
 # the tools. The prefix is set to an installed RTEMS. The built package is
 # installed into the prefix.
 # Keeping the package's installed path in the RTEMS install path and separate
-# to the tools lets the tools version vary independently. If --rtems-tools
-# (--with-tools) is not provided use the prefix.
+# to the tools lets the tools version vary independently.
+# Provide the path to the RTEMS tools is not in the prefix with the
+# --with-tools option. If --with-tools is not provided use the prefix.
+# Provide the path to the installed RTEMS kernel is not in the prefix with the
+# --with-rtems option. If --with-rtems is not provided use the prefix.
+# Note, only a single path (--with-rtems) for the RTEMS kernel and any other
+# add on or 3rd party libraries is supported.
@@ -23,14 +31,24 @@
  %define rtems_bsp_error 1
 %endif
-%if %{_target} == %{nil} && %{rtems_bsp_error}
- %error No RTEMS target specified: --rtems-bsp=arch/bsp (or --target=target)
+# The target is used by compilers or Cxc builds.
+%if %{_target} != %{nil}
+ %error RTEMS BSP builds use --host and not --target
 %endif
-%if %{_host} != %{_build}
- %error Canadian cross building for BSP is not supported.
+# We need a host from the user to specifiy the RTEMS architecture and major
+# version.
+%if %{_host} == %{nil} && %{rtems_bsp_error}
+ %error No RTEMS host or BSP specified: --rtems-bsp=arch/bsp and --host=<arch>-rtems<ver>
 %endif
+# We need a BSP from the user.
 %ifn %{defined with_rtems_bsp}
  %if %{rtems_bsp_error}
   %error No RTEMS BSP specified: --rtems-bsp=arch/bsp (or --with-rtems-bsp=bsp)
@@ -38,14 +56,16 @@
  %define with_rtems_bsp sparc/erc32
 %endif
+# Is on tools or RTEMS provided use the prefix.
 %ifn %{defined with_tools}
  %define with_tools %{_prefix}
 %endif
-# Set the host to the target.
-%define _host %{_target}
+%ifn %{defined with_rtems}
+ %define with_rtems %{_prefix}
+%endif
 # Set the path to the tools.
@@ -57,27 +77,54 @@
 # enable support when crosscompiling, and filter specific optimisation and
 # warning from the flags that RTEMS exports.
-%{pkgconfig prefix %{_prefix}/lib/pkgconfig}
+%{pkgconfig prefix %{with_rtems}/lib/pkgconfig}
 %{pkgconfig crosscompile yes}
 %{pkgconfig filter-flags yes}
 # The RTEMS BSP Flags
-%define rtems_bsp           %{with_rtems_bsp}
-%define rtems_bsp_ccflags   %{pkgconfig ccflags %{_host}-%{rtems_bsp}}
-%define rtems_bsp_cflags    %{pkgconfig cflags  %{_host}-%{rtems_bsp}}
-%define rtems_bsp_ldflags   %{pkgconfig ldflags %{_host}-%{rtems_bsp}}
-%define rtems_bsp_libs      %{pkgconfig libs    %{_host}-%{rtems_bsp}}
+%define rtems_bsp         %{with_rtems_bsp}
+%define rtems_bsp_ccflags %{pkgconfig ccflags %{_host}-%{rtems_bsp}}
+%define rtems_bsp_cflags  %{pkgconfig cflags  %{_host}-%{rtems_bsp}}
+%define rtems_bsp_ldflags %{pkgconfig ldflags %{_host}-%{rtems_bsp}}
+%define rtems_bsp_libs    %{pkgconfig libs    %{_host}-%{rtems_bsp}}
 %if %{rtems_bsp_cflags} == %{nil} && %{rtems_bsp_error}
- %error No RTEMS target CFLAGS found; Please check the --rtems-bsp option.
+ %error No RTEMS BSP CFLAGS found; Please check the --rtems-bsp option.
 %endif
 %if %{rtems_bsp_ccflags} == %{nil}
  %define rtems_bsp_ccflags %{rtems_bsp_cflags}
 %endif
+# RTEMS BSP paths
+%define rtems_bsp_cc      %{_host}-gcc
+%define rtems_bsp_incpath %{with_rtems}/%{_host}/%{rtems_bsp}/include
+%define rtems_bsp_libpath %{with_rtems}/%{_host}/%{rtems_bsp}/lib
+# Check for installed libraries.
+# - Check is LibBSD is install
+# - Add librtemsdefaultconfig so configure scripts work.
+# Note: default BSP flags include the standard RTEMS libraries.
+%define rtems-dep-check %(%{_sbdir}/sb/rtems-build-dep -c %{with_tools}/bin/%{rtems_bsp_cc}
+%define rtems-libbsd %{rtems-dep-check} -L %{rtems_bsp_libpath} -l libbsd.a)
+%if %{rtems-libbsd} == found
+ %define rtems_bsp_libs %{rtems_bsp_libs} -lbsd -lm -lz
+%endif
+%define rtems-defaultconfig %{rtems-dep-check} -L %{rtems_bsp_libpath} -l librtemsdefaultconfig.a)
+%if %{rtems-defaultconfig} == found
+ %define rtems_bsp_libs %{rtems_bsp_libs} -lrtemsdefaultconfig
+%endif
 # Update the configure paths to be BSP specific.
diff --git a/source-builder/config/curl-1.cfg b/source-builder/config/curl-1.cfg
index 0000000..16ff3f7
--- /dev/null
+++ b/source-builder/config/curl-1.cfg
@@ -0,0 +1,81 @@
+# Curl (https://curl.haxx.se)
+# This configuration file configure's, make's and install's libcurl.
+%define release 1
+%endif
+Name:      curl-v%{curl_version}-%{_host}-%{release}
+Summary:   Curl provides libcurl, a package to manage http etc protocols.
+Version:   %{curl_version}
+Release:   %{release}
+URL:       https://curl.haxx.se
+# Curl Source
+%source set curl https://curl.haxx.se/download/curl-%{curl_version}.tar.xz
+# Curl's configures requires includes are in the CPPFLAGS.
+%define host_cflags_no_includes 1
+# Prepare the source code.
+%prep
+  build_top=$(pwd)
+  source_dir_curl="curl-%{curl_version}"
+  %source setup curl -q -n curl-%{curl_version}
+  cd ${build_top}
+# Build the source code.
+# The configure should be run in the source dir
+%build
+  build_top=$(pwd)
+  %{build_directory}
+  mkdir -p ${build_dir}
+  cd ${build_dir}
+  %{host_build_flags}
+  ../${source_dir_curl}/configure \
+    --host=%{_host} \
+    --prefix=%{_prefix} \
+    --bindir=%{_bindir} \
+    --exec_prefix=%{_exec_prefix} \
+    --includedir=%{_includedir} \
+    --libdir=%{_libdir} \
+    --libexecdir=%{_libexecdir} \
+    --mandir=%{_mandir} \
+    --infodir=%{_infodir} \
+    --datadir=%{_datadir}
+  %{__make} %{?_smp_mflags} all
+  cd ${build_top}
+%install
+  build_top=$(pwd)
+  %{__rmdir} ${SB_BUILD_ROOT}
+  cd ${build_dir}
+  %{__make} DESTDIR=${SB_BUILD_ROOT} install
+  cd ${build_top}
+  # Remove any executables created in the build
+  %{__rmdir} ${SB_BUILD_ROOT}/%{_bindir}
+  %{__rmdir} ${SB_BUILD_ROOT}/%{_mandir}/man1
diff --git a/source-builder/config/libpng-1.cfg b/source-builder/config/libpng-1.cfg
index 2644948..dac60fc 100644
--- a/source-builder/config/libpng-1.cfg
+++ b/source-builder/config/libpng-1.cfg
@@ -17,7 +17,9 @@ URL:       http://www.libpng.org/
 # libpng Source
-%source set libpng ftp://ftp.simplesystems.org/pub/libpng/png/src/libpng%{libpng_src_dir_revision}/libpng-%{libpng_version}.tar.gz
+#%source set libpng ftp://ftp.simplesystems.org/pub/libpng/png/src/libpng%{libpng_src_dir_revision}/libpng-%{libpng_version}.tar.gz
+%source set libpng --rsb-file=libpng-%{libpng_version}.tar.xz http://prdownloads.sourceforge.net/libpng/libpng-%{libpng_version}.tar.xz?download
diff --git a/source-builder/config/libtiff-1.cfg b/source-builder/config/libtiff-1.cfg
index f7fa893..c9da951 100644
--- a/source-builder/config/libtiff-1.cfg
+++ b/source-builder/config/libtiff-1.cfg
@@ -17,7 +17,7 @@ URL:     http://www.libtiff.org/
 # libtiff Source
-%source set libtiff ftp://ftp.remotesensing.org/pub/libtiff/tiff-%{tiff_version}.tar.gz
+%source set libtiff http://download.osgeo.org/libtiff/tiff-%{tiff_version}.tar.gz
diff --git a/source-builder/config/lwip-1.cfg b/source-builder/config/lwip-1.cfg
index 1dd3bb7..ef736c1 100644
--- a/source-builder/config/lwip-1.cfg
+++ b/source-builder/config/lwip-1.cfg
@@ -17,15 +17,16 @@ URL: 	   http://git.savannah.gnu.org/cgit/lwip.git
 # LWIP Source
-%source set lwip git://git.sv.gnu.org/lwip.git?fetch?reset=hard?branch=master?checkout=c2ebf5544b4268eac9b32c7f3a689ff646d96eef
+%source set lwip http://git.savannah.gnu.org/cgit/lwip.git/snapshot/lwip-%{lwip_version}.tar.gz
 %prep
   build_top=$(pwd)
-  source_dir_lwip="%{lwip_version}"
-  %source setup lwip -q -n %{lwip_version}
+  source_dir_lwip="lwip-%{lwip_version}"
+  %source setup lwip -q -n lwip-%{lwip_version}
   %patch setup lwip -p1
   cd ${build_top}
@@ -40,13 +41,13 @@ URL: 	   http://git.savannah.gnu.org/cgit/lwip.git
   %{host_build_flags}
-  cd ${build_top}/%{lwip_version}
+  cd ${build_top}/lwip-%{lwip_version}
   export RTEMS_MAKEFILE_PATH=%{_exec_prefix}
   %{__make} all
 #  cd ${build_top}
 #%install
-  build_top=$(pwd)/%{lwip_version}
+  build_top=$(pwd)/lwip-%{lwip_version}
   %{__make} install
diff --git a/source-builder/config/microwindows-1.cfg b/source-builder/config/microwindows-1.cfg
index d6cfab5..6ec3f30 100644
--- a/source-builder/config/microwindows-1.cfg
+++ b/source-builder/config/microwindows-1.cfg
@@ -8,16 +8,16 @@
 %define release 1
 %endif
-Name:      microwindows-v%{microwindows_version}-%{_host}-%{release}
+Name:      microwindows-%{microwindows_version}-%{_host}-%{release}
 Summary:   microwindows is an Open Source Window System
 Version:   %{microwindows_version}
 Release:   %{release}
-URL:     http://www.microwindows.org/
+URL:       http://www.microwindows.org/
 # microwindows Source
-%source set microwindows ftp://microwindows.censoft.com/pub/microwindows/microwindows-src-%{microwindows_version}.tar.gz
+%source set microwindows --rsb-file=microwindows-%{microwindows_version}.tar.gz https://codeload.github.com/ghaerr/microwindows/tar.gz/%{microwindows_version}
@@ -25,8 +25,8 @@ URL:     http://www.microwindows.org/
 %prep
   build_top=$(pwd)
-  source_dir_microwindows="microwin"
-  %source setup microwindows -q -n microwin
+  source_dir_microwindows="microwindows-%{microwindows_version}"
+  %source setup microwindows -q -n microwindows-%{microwindows_version}
   %patch setup microwindows -p1
   cd ${build_top}
diff --git a/source-builder/config/net-snmp-5-1.cfg b/source-builder/config/net-snmp-5-1.cfg
index bffe430..c82e310 100644
--- a/source-builder/config/net-snmp-5-1.cfg
+++ b/source-builder/config/net-snmp-5-1.cfg
@@ -43,6 +43,7 @@ URL: 	   http://www.net-snmp.org/
   CFLAGS="${CFLAGS} %{net_snmp_cflags}"
+  LIBS="-lbsd -lm -lz -lrtemsdefaultconfig" \
   ../${source_dir_net_snmp}/configure \
     --host=%{_host} \
diff --git a/source-builder/config/t1lib-1.cfg b/source-builder/config/t1lib-1.cfg
index 3cb02c5..6202306 100644
--- a/source-builder/config/t1lib-1.cfg
+++ b/source-builder/config/t1lib-1.cfg
@@ -17,7 +17,7 @@ URL:       http://www.t1lib.org/
 # t1lib Source
-%source set t1lib ftp://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-%{t1lib_version}.tar.gz
+%source set t1lib http://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-%{t1lib_version}.tar.gz
diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
index 3508877..646be78 100644
--- a/source-builder/defaults.mc
+++ b/source-builder/defaults.mc
@@ -64,14 +64,16 @@ _uid:                none,    convert,  '%(%{__id_u} -n)'
 # Default flags that can be overridded to supply specific host or build
 # flags and include paths to the tools. The host is the final platform
 # the tools will run on and build is the host building the tools.
-host_cflags:         none,    convert,  '-O2 -pipe'
-host_cxxflags:       none,    convert,  '-O2 -pipe'
+host_cflags:         none,    convert,  '-O2 -g -pipe'
+host_cxxflags:       none,    convert,  '-O2 -g -pipe'
 host_ldflags:        none,    convert,  ''
 host_includes:       none,    convert,  ''
-build_cflags:        none,    convert,  '-O2 -pipe'
-build_cxxflags:      none,    convert,  '-O2 -pipe'
+host_libs:           none,    convert,  ''
+build_cflags:        none,    convert,  '-O2 -g -pipe'
+build_cxxflags:      none,    convert,  '-O2 -g -pipe'
 build_ldflags:       none,    convert,  ''
 build_includes:      none,    convert,  ''
+build_libs:          none,    convert,  ''
 # Extra path a platform can override.
 _extra_path:         none,    none,     '%{_sbdir}'
@@ -203,19 +205,22 @@ SB_SOURCE_DIR="%{_sourcedir}"
 SB_BUILD_DIR="%{_builddir}"
 # host == build, use build; host != build, host uses host and build uses build
 SB_HOST_CPPFLAGS="%{host_includes}"
-SB_HOST_CFLAGS="%{host_cflags} %{host_includes}"
-SB_HOST_CXXFLAGS="%{host_cxxflags} %{host_includes}"
+# Optionally do not add includes to c/cxx flags as newer configure's complain
+SB_HOST_CFLAGS="%{host_cflags} %{!?host_cflags_no_includes %{host_includes}}"
+SB_HOST_CXXFLAGS="%{host_cxxflags} %{!?host_cflags_no_includes %{host_includes}}"
 SB_HOST_LDFLAGS="%{host_ldflags} %{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
+SB_HOST_LIBS="%{host_libs}"
 SB_BUILD_CFLAGS="%{build_cflags} %{?_tmproot:-I%{_tmproot}/${SB_PREFIX_CLEAN}/include}"
 SB_BUILD_CXXFLAGS="%{build_cxxflags} %{?_tmproot:-I%{_tmproot}/${SB_PREFIX_CLEAN}/include}"
 SB_BUILD_LDFLAGS="%{build_ldflags} %{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
+SB_BUILD_LBS="%{build_libs}"
 SB_CFLAGS="${SB_BUILD_CFLAGS} %{build_includes}"
 SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} %{build_includes}"
 SB_ARCH="%{_arch}"
 SB_OS="%{_os}"
 export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
-export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
-export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
+export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
+export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
 export SB_CFLAGS SB_CXXFLAGS
 # Documentation
 SB_DOC_DIR="%{_docdir}"
@@ -326,11 +331,13 @@ if test "%{_build}" != "%{_host}" ; then
   CFLAGS="${SB_HOST_CFLAGS}"
   CXXFLAGS="${SB_HOST_CXXFLAGS}"
   LDFLAGS="${SB_HOST_LDFLAGS}"
+  LIBS="${SB_HOST_LIBS}"
   # Host
   CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
   CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
   CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
   LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
+  LIBS_FOR_HOST="${SB_HOST_LIBS}"
   CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
   CC_FOR_HOST=$(echo "%{_host_cc} ${SB_HOST_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CXX_FOR_HOST=$(echo "%{_host_cxx} ${SB_HOST_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
@@ -338,30 +345,33 @@ if test "%{_build}" != "%{_host}" ; then
   CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
   CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
   LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
+  LIBS_FOR_BUILD="${SB_BUILD_LIBS}"
   CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
   CC_FOR_BUILD=$(echo "%{__cc} ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CXX_FOR_BUILD=$(echo "%{__cxx} ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
 else
   LDFLAGS="${SB_BUILD_LDFLAGS}"
+  LIBS="${SB_BUILD_LIBS}"
   CC=$(echo "%{__cc} ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CXX=$(echo "%{__cxx} ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
   CC_FOR_BUILD=${CC}
   CXX_FOR_BUILD=${CXX}
 fi
-export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS
-export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
-export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD'''
+export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS
+export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LIBS_FOR_HOST
+export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LIBS_FOR_BUILS'''
 # Build/build flags.
 build_build_flags:    none,    none,     '''
 # Build and build flags means force build == host
 # gcc is not ready to be compiled with -std=gnu99
+LIBS="${SB_HOST_LIBS}"
 CC=$(echo "%{__cc} ${SB_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
 CXX=$(echo "%{__cxx} ${SB_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
 CC_FOR_BUILD=${CC}
-export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS'''
+export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS LIBS'''
 # Default package settings
 _forced_static:     none,         none, '-Xlinker -Bstatic ${LIBS_STATIC} -Xlinker -Bdynamic'
diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
index ae67eeb..d8e7a88 100644
--- a/source-builder/sb/options.py
+++ b/source-builder/sb/options.py
@@ -420,10 +420,14 @@ class command_line:
         _host = self.defaults.expand('%{_host}')
         _build = self.defaults.expand('%{_build}')
         _target = self.defaults.expand('%{_target}')
-        if len(_target):
-            return len(_host) and len(_build) and (_target) and \
-                _host != _build and _host != _target
-        return len(_host) and len(_build) and _host != _build
+        # This has been removed to fix how RTEMS 3rd party libraries
+        # are built. This may break Cxc tools builds.
+        # if len(_target):
+        #     return len(_host) and len(_build) and (_target) and \
+        #         _host != _build and _host != _target
+        return len(_target) and len(_host) and len(_build) and _host != _build
     def user_macros(self):
diff --git a/source-builder/sb/rtems-build-dep b/source-builder/sb/rtems-build-dep
index 1f795d3..48a0823 100755
--- a/source-builder/sb/rtems-build-dep
+++ b/source-builder/sb/rtems-build-dep
@@ -141,7 +141,7 @@ fi
 # Library file
 if [ ${op} = "library" ]; then
-    if [ "${OS}" = "Windows_NT" -a "${OSTYPE}" -ne "cygwin" ]; then
+    if [ "${OS}" = "Windows_NT" -a "${OSTYPE}" != "cygwin" ]; then
 	sep=';'
     else
 	sep=':'
2.20.1 (Apple Git-117)
