[PATCH] 5/packages: Add curl and update all packages with RTEMS 5 and LiobBSD
Joel Sherrill
joel at rtems.org
Sat Jul 6 13:47:04 UTC 2019
Libbsd typo in subject
On Sat, Jul 6, 2019, 4:33 AM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - Update rtems-bsp support to correctly handle hosts for BSP.
> - Clean up the options for a BSP.
> - Check all RTEMS 5 packages and add 5/rtems-packages for all that build.
> - Update download locations and checksum of all packages.
> - The work requires the kernel and Libbsd hacve the same prefix.
> rtems/config/5/rtems-packages.bset | 24 ++++++
> rtems/config/databases/sqlite-3.8.8.1-1.cfg | 2 +-
> rtems/config/ftp/curl-7.65.1-1.cfg | 21 +++++
> rtems/config/ftp/curl.bset | 20 +++++
> rtems/config/graphics/freetype-2.4.10-1.cfg | 2 +-
> rtems/config/graphics/graphics-all.bset | 5 +-
> rtems/config/graphics/libjpeg-9a-1.cfg | 2 +-
> rtems/config/graphics/libpng-1.6.37-1.cfg | 21 +++++
> rtems/config/graphics/libpng.bset | 2 +-
> rtems/config/graphics/libtiff-4.0.10-1.cfg | 21 +++++
> rtems/config/graphics/libtiff-4.0.6-1.cfg | 2 +-
> rtems/config/graphics/libtiff.bset | 2 +-
> .../graphics/microwindows-0.93-dev-1.cfg | 12 +--
> rtems/config/graphics/t1lib-5.1.2-1.cfg | 4 +-
> rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg | 6 +-
> rtems/config/net/lwip-1-1.cfg | 12 ++-
> rtems/config/net/ntp-4.2.6p5-1.cfg | 6 +-
> rtems/config/net/protobuf-2.6.1-1.cfg | 2 +-
> rtems/config/rtems-bsp.cfg | 83 +++++++++++++++----
> source-builder/config/curl-1.cfg | 81 ++++++++++++++++++
> source-builder/config/libpng-1.cfg | 4 +-
> source-builder/config/libtiff-1.cfg | 2 +-
> source-builder/config/lwip-1.cfg | 11 +--
> source-builder/config/microwindows-1.cfg | 10 +--
> source-builder/config/net-snmp-5-1.cfg | 1 +
> source-builder/config/t1lib-1.cfg | 2 +-
> source-builder/defaults.mc | 34 +++++---
> source-builder/sb/options.py | 12 ++-
> source-builder/sb/rtems-build-dep | 2 +-
> 29 files changed, 335 insertions(+), 73 deletions(-)
> create mode 100644 rtems/config/5/rtems-packages.bset
> create mode 100644 rtems/config/ftp/curl-7.65.1-1.cfg
> create mode 100644 rtems/config/ftp/curl.bset
> create mode 100644 rtems/config/graphics/libpng-1.6.37-1.cfg
> create mode 100644 rtems/config/graphics/libtiff-4.0.10-1.cfg
> create mode 100644 source-builder/config/curl-1.cfg
> diff --git a/rtems/config/5/rtems-packages.bset
> b/rtems/config/5/rtems-packages.bset
> new file mode 100644
> index 0000000..edc7e6b
> --- /dev/null
> +++ b/rtems/config/5/rtems-packages.bset
> @@ -0,0 +1,24 @@
> +# RTEMS Packages that build for this release.
> +# Databases
> +databases/sqlite
> +# Graphics
> +graphics/freetype2
> +graphics/libjpeg
> +graphics/libpng
> +graphics/libtiff
> +graphics/t1lib
> +# Networking
> +ftp/curl
> +net/lwip
> +net/protobuf
> diff --git a/rtems/config/databases/sqlite-3.8.8.1-1.cfg
> b/rtems/config/databases/sqlite-3.8.8.1-1.cfg
> index 609d4c1..aac06be 100644
> --- a/rtems/config/databases/sqlite-3.8.8.1-1.cfg
> +++ b/rtems/config/databases/sqlite-3.8.8.1-1.cfg
> @@ -19,7 +19,7 @@
> %define sqlite_src_version 3080801
> %define sqlite_src_year 2015
> -%hash md5 sqlite-src-%{sqlite_src_version}.zip
> 9dde57c312da00cbe791bcba42d1e96a
> +%hash sha512 sqlite-src-%{sqlite_src_version}.zip
> 4f09228cb0c9c608e492da6e480afe3d27a63e27ccdcf33a88d5e56427f0846efab8930c81026b8e608f1bbb8d63e8d937dd26571deb828617f7efa27a765950
> # Sqlite configuration
> diff --git a/rtems/config/ftp/curl-7.65.1-1.cfg
> b/rtems/config/ftp/curl-7.65.1-1.cfg
> index 0000000..abc7e9d
> --- /dev/null
> +++ b/rtems/config/ftp/curl-7.65.1-1.cfg
> @@ -0,0 +1,21 @@
> +# Curl 7.65.1
> +%if %{release} == %{nil}
> + %define release 1
> +%endif
> +%include %{_configdir}/rtems-bsp.cfg
> +# Curl Version
> +%define curl_version 7.65.1
> +%hash sha512 curl-%{curl_version}.tar.xz
> aba2d979a416d14a0f0852d595665e49fc4f7bff3bee31f3a52b90ba9dc5ffdb09c092777f124215470b72c47ebca7ddb47844cbf5c0e9142099272b6ac55df4
> +# Curl Build configuration
> +%include %{_configdir}/curl-1.cfg
> diff --git a/rtems/config/ftp/curl.bset b/rtems/config/ftp/curl.bset
> index 0000000..84cac39
> --- /dev/null
> +++ b/rtems/config/ftp/curl.bset
> @@ -0,0 +1,20 @@
> +# Build set for Curl
> +%define release 1
> +# RTEMS Version
> +%define rtems_version 5
> +# The RTEMS URL paths.
> +%include rtems-urls.bset
> +# Build Curl
> +ftp/curl-7.65.1-1
> diff --git a/rtems/config/graphics/freetype-2.4.10-1.cfg
> b/rtems/config/graphics/freetype-2.4.10-1.cfg
> index 524dc3a..3963c98 100644
> --- a/rtems/config/graphics/freetype-2.4.10-1.cfg
> +++ b/rtems/config/graphics/freetype-2.4.10-1.cfg
> @@ -13,7 +13,7 @@
> %define freetype_version 2.4.10
> -%hash md5 freetype-%{freetype_version}.tar.gz
> 4f255c6ee5d5cc2b5c3d423a07386fcb
> +%hash sha512 freetype-%{freetype_version}.tar.gz
> 507d1c03d394b695b5a96041ad7ee03b375964c89f007678db864a7e5bd2ee69d83e6c638f4aadaf348c921d37c16741a03ef9bee03196bda2b94ceea409b688
> # freetype Build configuration
> diff --git a/rtems/config/graphics/graphics-all.bset
> b/rtems/config/graphics/graphics-all.bset
> index 5527ca3..b0ea5fe 100644
> --- a/rtems/config/graphics/graphics-all.bset
> +++ b/rtems/config/graphics/graphics-all.bset
> @@ -2,8 +2,11 @@
> # All RTEMS Graphics Build Sets
> +graphics/freetype2
> graphics/libjpeg
> graphics/libpng
> graphics/libtiff
> graphics/t1lib
> -graphics/microwindows.bset
> +# Remove as microwindows does not build. Please fix and provide a patch.
> +# graphics/microwindows
> diff --git a/rtems/config/graphics/libjpeg-9a-1.cfg
> b/rtems/config/graphics/libjpeg-9a-1.cfg
> index a366da9..fef32d6 100644
> --- a/rtems/config/graphics/libjpeg-9a-1.cfg
> +++ b/rtems/config/graphics/libjpeg-9a-1.cfg
> @@ -13,7 +13,7 @@
> %define libjpeg_version 9a
> -%hash md5 jpegsrc.v%{libjpeg_version}.tar.gz
> 3353992aecaee1805ef4109aadd433e7
> +%hash sha512 jpegsrc.v%{libjpeg_version}.tar.gz
> 9b21cc115e22c68bea46db462263c5c7a0d10beb192a919ecccbd801a25982b518ce44d8c301dd582ecaba1850e0e0f20e322be82b0e24ae917b9949b4f10d3b
> # libjpeg Build configuration
> diff --git a/rtems/config/graphics/libpng-1.6.37-1.cfg
> b/rtems/config/graphics/libpng-1.6.37-1.cfg
> index 0000000..f4717f4
> --- /dev/null
> +++ b/rtems/config/graphics/libpng-1.6.37-1.cfg
> @@ -0,0 +1,21 @@
> +# libpng 1.6.37
> + %define release 1
> +%endif
> +# libpng Version
> +%define libpng_version 1.6.37
> +%hash sha512 libpng-%{libpng_version}.tar.xz
> 59e8c1059013497ae616a14c3abbe239322d3873c6ded0912403fc62fb260561768230b6ab997e2cccc3b868c09f539fd13635616b9fa0dd6279a3f63ec7e074
> +# libpng Build configuration
> +%include %{_configdir}/libpng-1.cfg
> diff --git a/rtems/config/graphics/libpng.bset
> b/rtems/config/graphics/libpng.bset
> index 4e6db7d..57abeaf 100644
> --- a/rtems/config/graphics/libpng.bset
> +++ b/rtems/config/graphics/libpng.bset
> @@ -12,4 +12,4 @@
> # Build libpng.
> -graphics/libpng-1.6.21-1.cfg
> +graphics/libpng-1.6.37-1.cfg
> diff --git a/rtems/config/graphics/libtiff-4.0.10-1.cfg
> b/rtems/config/graphics/libtiff-4.0.10-1.cfg
> index 0000000..901eed1
> --- /dev/null
> +++ b/rtems/config/graphics/libtiff-4.0.10-1.cfg
> @@ -0,0 +1,21 @@
> +# libtiff 4.0.10
> + %define release 1
> +%endif
> +# tiff Version
> +%define tiff_version 4.0.10
> +%hash sha512 tiff-%{tiff_version}.tar.gz
> d213e5db09fd56b8977b187c5a756f60d6e3e998be172550c2892dbdb4b2a8e8c750202bc863fe27d0d1c577ab9de1710d15e9f6ed665aadbfd857525a81eea8
> +# tiff Build configuration
> +%include %{_configdir}/libtiff-1.cfg
> diff --git a/rtems/config/graphics/libtiff-4.0.6-1.cfg
> b/rtems/config/graphics/libtiff-4.0.6-1.cfg
> index 946daef..bcd7c5b 100644
> --- a/rtems/config/graphics/libtiff-4.0.6-1.cfg
> +++ b/rtems/config/graphics/libtiff-4.0.6-1.cfg
> @@ -13,7 +13,7 @@
> %define tiff_version 4.0.6
> -%hash md5 tiff-%{tiff_version}.tar.gz d1d2e940dea0b5ad435f21f03d96dd72
> 2c8dbaaaab9f82a7722bfe8cb6fcfcf67472beb692f1b7dafaf322759e7016dad1bc58457c0f03db50aa5bd088fef2b37358fcbc1524e20e9e14a9620373fdf8
> diff --git a/rtems/config/graphics/libtiff.bset
> b/rtems/config/graphics/libtiff.bset
> index 434cdbc..f10e60e 100644
> --- a/rtems/config/graphics/libtiff.bset
> +++ b/rtems/config/graphics/libtiff.bset
> @@ -12,4 +12,4 @@
> # Build libtiff.
> -graphics/libtiff-4.0.6-1.cfg
> +graphics/libtiff-4.0.10-1.cfg
> diff --git a/rtems/config/graphics/microwindows-0.93-dev-1.cfg
> b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
> index 0ab9da4..7ca8968 100644
> --- a/rtems/config/graphics/microwindows-0.93-dev-1.cfg
> +++ b/rtems/config/graphics/microwindows-0.93-dev-1.cfg
> @@ -11,15 +11,17 @@
> # microwindows Version
> -%define microwindows_version 0.93-dev
> +%define microwindows_version 56041759161132a94df3e575ae995e53d6b6e1d8
> %define rtems_git_tools_4_11
> %{rtems_http_git}/rtems-tools/plain/tools/4.11
> -%source set microwindows git://github.com/ghaerr/microwindows.git
> +%hash sha512 microwindows-%{microwindows_version}.tar.gz
> cf29a9d966a8a5b3926aab7f911c47890c9b1a589ff0ecf098e6be45ae1555958b0e437270fb26e353b8c58f261834a3a7f0fce84bea0fdb9138fc38c8703ddc
> %patch add microwindows
> %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev.diff
> -%hash md5 microwindows-0.93-dev.diff 5b06e77d9ee42c8ff0032bba07d01c1a
> -%patch add microwindows
> %{rtems_git_tools_4_11}/microwindows/microwindows-0.93-dev-without-keyboard.diff
> -%hash md5 microwindows-0.93-dev-without-keyboard.diff
> a675f55750754e1cd82a17496f0e8fab
> +%hash sha512 microwindows-0.93-dev.diff
> 2f575f603ce9ccff5c98e9c434d72fb9952d1385903495bf818d50de6568c57c9ca1d3320388e3bae384388d192a389012baf4d734d2cc8481d56f231d2a93d0
> +#%patch add microwindows
> +#%hash sha512 microwindows-0.93-dev-without-keyboard.diff
> c235177fa80035ec70957aee1daa9232c9050abddac08e5f7b2977bd58703224367b4262a2ddc2999b1ac64b5ab838ad3ad740ee1490741293cffe7c16575fb2
> # microwindows Build configuration
> diff --git a/rtems/config/graphics/t1lib-5.1.2-1.cfg
> b/rtems/config/graphics/t1lib-5.1.2-1.cfg
> index 58eaa3b..27de3cf 100644
> --- a/rtems/config/graphics/t1lib-5.1.2-1.cfg
> +++ b/rtems/config/graphics/t1lib-5.1.2-1.cfg
> @@ -13,13 +13,13 @@
> %define t1lib_version 5.1.2
> -%hash md5 t1lib-%{t1lib_version}.tar.gz a5629b56b93134377718009df1435f3c
> +%hash sha512 t1lib-%{t1lib_version}.tar.gz
> 9f424b19c6f35cc4f194ff7351a4c2352216462c7d1b1d9650ad3a05cf48c6e90c89ccbcda5ecc47a4169a39a850cf84a1fcbf88b3b15614860c27364b631ae3
> # Patch for RTEMS.
> %patch add t1lib
> https://raw.githubusercontent.com/yangqiao/rtems-tools/graphics/tools/4.11/t1lib/t1lib-5.1.2.diff
> -%hash md5 t1lib-5.1.2.diff 98eeed85780227adf8525deab3679877
> +%hash sha512 t1lib-5.1.2.diff
> 1afd18182350d7d2426a910c61537f8532e149bf37c616f3a4a84ae0767c4549a2be857db6fd1b1994ed86f8a2e2d4cdfb2abdf67053c8ca1ee83893f4b56d23
> # t1lib Build configuration
> diff --git a/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
> b/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
> index 7527871..e4fe63e 100644
> --- a/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
> +++ b/rtems/config/net-mgmt/net-snmp-5.7.2.1-1.cfg
> @@ -13,7 +13,7 @@
> %define net_snmp_version 5.7.2.1
> -%hash md5 net-snmp-%{net_snmp_version}.tar.gz
> 7db683faba037249837b226f64d566d4
> +%hash sha512 net-snmp-%{net_snmp_version}.tar.gz
> 6c4dadd145cab9572e2559ad99d6794469685086771c6d757d3667da1a061ab86746d53c28d48381c59a90d92b1812b813f3176cff156c41929177fb585299d0
> # We need some special flags to build this version.
> @@ -23,8 +23,8 @@
> # Patch for RTEMS support.
> -%patch add net-snmp
> %{rtems_git_tools}/net-snmp/rtems-net-snmp-5.7.2.1-20140623.patch
> -%hash md5 rtems-net-snmp-5.7.2.1-20140623.patch
> 9a22fb4366a113f5df71ed2acd672b2b
> +%patch add net-snmp
> %{rtems_git_tools}/net-snmp/rtems-net-snmp-5.7.2.1-20190704.patch
> +#%hash sha512 rtems-net-snmp-5.7.2.1-20140623.patch
> 4eb987d88c6414f2e07d725c2ebb3e88a40191c7befce879cae9ef67143dc25aa88942cfc525d36cd3683476d1cc0f5882d4a730d3bb9c53be2c7a079874d7dd
> # NetSNMP Build configuration
> diff --git a/rtems/config/net/lwip-1-1.cfg b/rtems/config/net/lwip-1-1.cfg
> index cf25963..8605f1c 100644
> --- a/rtems/config/net/lwip-1-1.cfg
> +++ b/rtems/config/net/lwip-1-1.cfg
> @@ -11,15 +11,19 @@
> # LWIP Version
> -%define lwip_version lwip-c2ebf5544b4268eac9b32c7f3a689ff646d96eef
> +%define lwip_version c2ebf5544b4268eac9b32c7f3a689ff646d96eef
> +%hash sha512 lwip-%{lwip_version}.tar.gz
> bfa93e050133ca591c628f0e3a04f5082f55a655b099cdd49138ebf74494354a4cbbee56839f5939174b4c965b29ec648c24b7479c73393ac94ec536cb578b70
> -#Will be modified to be pointing to RTEMS repo
> +# Will be modified to be pointing to RTEMS repo
> %define rtems_ragu_git
> https://raw.githubusercontent.com/ragunath3252/lwip-nodrv/master
> -%patch add lwip %{rtems_ragu_git}/rtems.patch
> -%hash md5 rtems.patch 489c0def3a89e538fb526a5396bf27ca
> +%patch add lwip --rsb-file=lwip-nodrv-rtems.patch
> +%hash sha512 lwip-nodrv-rtems.patch
> ba49163e11069cb036280023db064625e5d1aed3a6cf3e51c64e59639580e9f758434e60853242fb924eb5cebc73b478f01ff51f24505e85d4c21bb1963415e1
> # LWIP Build configuration
> diff --git a/rtems/config/net/ntp-4.2.6p5-1.cfg
> b/rtems/config/net/ntp-4.2.6p5-1.cfg
> index 43afbf3..34676b6 100644
> --- a/rtems/config/net/ntp-4.2.6p5-1.cfg
> +++ b/rtems/config/net/ntp-4.2.6p5-1.cfg
> @@ -13,13 +13,13 @@
> %define ntp_version 4.2.6p5
> -%hash md5 ntp-%{ntp_version}.tar.gz 00df80a84ec9528fcfb09498075525bc
> +%hash sha512 ntp-%{ntp_version}.tar.gz
> 8d76fc7e92b2ea6dd5031e6030a7aba4ff6fb3e19d3bc0153852509861be5d0960e70604814163caedb81f8315a451d78371f99634a50b55cfe1cbd2c69e3046
> -%patch add ntp %{rtems_git_tools}/ntp/rtems-ntp-4.2.6p5.diff
> -%hash md5 rtems-ntp-4.2.6p5.diff 6fce685a73873f924a48b19d6b1700fc
> +%patch add ntp
> %{rtems_http_git}/rtems-tools/plain/tools/4.11/ntp/rtems-ntp-4.2.6p5.diff
> +%hash sha512 rtems-ntp-4.2.6p5.diff
> 257223d207d0b77cde2b9d7add22e3b9d657b58998411d2e20d0b1adf36910be21f1277386c54c34f5d9616fccd29f721d007295708047ea7ae0270a00be25a0
> # NTP Build configuration
> diff --git a/rtems/config/net/protobuf-2.6.1-1.cfg
> b/rtems/config/net/protobuf-2.6.1-1.cfg
> index 5218eac..2e507f6 100644
> --- a/rtems/config/net/protobuf-2.6.1-1.cfg
> +++ b/rtems/config/net/protobuf-2.6.1-1.cfg
> @@ -13,7 +13,7 @@
> %define protobuf_version 2.6.1
> -%hash md5 protobuf-%{protobuf_version}.tar.gz
> f3916ce13b7fcb3072a1fa8cf02b2423
> +%hash sha512 protobuf-%{protobuf_version}.tar.gz
> 818ac4ad24aca84d214d14ac860a75c14494528821af144d3cb603f69c94d4500512814be6d62cc82973804ebfa99eb94d9f034b309f53cadb622603a7886a3e
> # Protocol Buffers configuration
> diff --git a/rtems/config/rtems-bsp.cfg b/rtems/config/rtems-bsp.cfg
> index 28d250f..1c2b2e6 100644
> --- a/rtems/config/rtems-bsp.cfg
> +++ b/rtems/config/rtems-bsp.cfg
> @@ -3,13 +3,21 @@
> -# The RTEMS BSP support requires the host turple, the RTEMS BSP and the
> path to
> +# The RTEMS BSP support requires the host tuple, the RTEMS BSP and the
> path to
> # the tools. The prefix is set to an installed RTEMS. The built package is
> # installed into the prefix.
> # Keeping the package's installed path in the RTEMS install path and
> separate
> -# to the tools lets the tools version vary independently. If --rtems-tools
> -# (--with-tools) is not provided use the prefix.
> +# to the tools lets the tools version vary independently.
> +# Provide the path to the RTEMS tools is not in the prefix with the
> +# --with-tools option. If --with-tools is not provided use the prefix.
> +# Provide the path to the installed RTEMS kernel is not in the prefix
> with the
> +# --with-rtems option. If --with-rtems is not provided use the prefix.
> +# Note, only a single path (--with-rtems) for the RTEMS kernel and any
> other
> +# add on or 3rd party libraries is supported.
> @@ -23,14 +31,24 @@
> %define rtems_bsp_error 1
> %endif
> -%if %{_target} == %{nil} && %{rtems_bsp_error}
> - %error No RTEMS target specified: --rtems-bsp=arch/bsp (or
> --target=target)
> +# The target is used by compilers or Cxc builds.
> +%if %{_target} != %{nil}
> + %error RTEMS BSP builds use --host and not --target
> %endif
> -%if %{_host} != %{_build}
> - %error Canadian cross building for BSP is not supported.
> +# We need a host from the user to specifiy the RTEMS architecture and
> major
> +# version.
> +%if %{_host} == %{nil} && %{rtems_bsp_error}
> + %error No RTEMS host or BSP specified: --rtems-bsp=arch/bsp and
> --host=<arch>-rtems<ver>
> %endif
> +# We need a BSP from the user.
> %ifn %{defined with_rtems_bsp}
> %if %{rtems_bsp_error}
> %error No RTEMS BSP specified: --rtems-bsp=arch/bsp (or
> --with-rtems-bsp=bsp)
> @@ -38,14 +56,16 @@
> %define with_rtems_bsp sparc/erc32
> %endif
> +# Is on tools or RTEMS provided use the prefix.
> %ifn %{defined with_tools}
> %define with_tools %{_prefix}
> %endif
> -# Set the host to the target.
> -%define _host %{_target}
> +%ifn %{defined with_rtems}
> + %define with_rtems %{_prefix}
> +%endif
> # Set the path to the tools.
> @@ -57,27 +77,54 @@
> # enable support when crosscompiling, and filter specific optimisation and
> # warning from the flags that RTEMS exports.
> -%{pkgconfig prefix %{_prefix}/lib/pkgconfig}
> +%{pkgconfig prefix %{with_rtems}/lib/pkgconfig}
> %{pkgconfig crosscompile yes}
> %{pkgconfig filter-flags yes}
> # The RTEMS BSP Flags
> -%define rtems_bsp %{with_rtems_bsp}
> -%define rtems_bsp_ccflags %{pkgconfig ccflags %{_host}-%{rtems_bsp}}
> -%define rtems_bsp_cflags %{pkgconfig cflags %{_host}-%{rtems_bsp}}
> -%define rtems_bsp_ldflags %{pkgconfig ldflags %{_host}-%{rtems_bsp}}
> -%define rtems_bsp_libs %{pkgconfig libs %{_host}-%{rtems_bsp}}
> +%define rtems_bsp %{with_rtems_bsp}
> +%define rtems_bsp_ccflags %{pkgconfig ccflags %{_host}-%{rtems_bsp}}
> +%define rtems_bsp_cflags %{pkgconfig cflags %{_host}-%{rtems_bsp}}
> +%define rtems_bsp_ldflags %{pkgconfig ldflags %{_host}-%{rtems_bsp}}
> +%define rtems_bsp_libs %{pkgconfig libs %{_host}-%{rtems_bsp}}
> %if %{rtems_bsp_cflags} == %{nil} && %{rtems_bsp_error}
> - %error No RTEMS target CFLAGS found; Please check the --rtems-bsp option.
> + %error No RTEMS BSP CFLAGS found; Please check the --rtems-bsp option.
> %endif
> %if %{rtems_bsp_ccflags} == %{nil}
> %define rtems_bsp_ccflags %{rtems_bsp_cflags}
> %endif
> +# RTEMS BSP paths
> +%define rtems_bsp_cc %{_host}-gcc
> +%define rtems_bsp_incpath %{with_rtems}/%{_host}/%{rtems_bsp}/include
> +%define rtems_bsp_libpath %{with_rtems}/%{_host}/%{rtems_bsp}/lib
> +# Check for installed libraries.
> +# - Check is LibBSD is install
> +# - Add librtemsdefaultconfig so configure scripts work.
> +# Note: default BSP flags include the standard RTEMS libraries.
> +%define rtems-dep-check %(%{_sbdir}/sb/rtems-build-dep -c
> %{with_tools}/bin/%{rtems_bsp_cc}
> +%define rtems-libbsd %{rtems-dep-check} -L %{rtems_bsp_libpath} -l
> libbsd.a)
> +%if %{rtems-libbsd} == found
> + %define rtems_bsp_libs %{rtems_bsp_libs} -lbsd -lm -lz
> +%endif
> +%define rtems-defaultconfig %{rtems-dep-check} -L %{rtems_bsp_libpath} -l
> librtemsdefaultconfig.a)
> +%if %{rtems-defaultconfig} == found
> + %define rtems_bsp_libs %{rtems_bsp_libs} -lrtemsdefaultconfig
> +%endif
> # Update the configure paths to be BSP specific.
> diff --git a/source-builder/config/curl-1.cfg
> b/source-builder/config/curl-1.cfg
> index 0000000..16ff3f7
> --- /dev/null
> +++ b/source-builder/config/curl-1.cfg
> @@ -0,0 +1,81 @@
> +# Curl (https://curl.haxx.se)
> +# This configuration file configure's, make's and install's libcurl.
> +%define release 1
> +%endif
> +Name: curl-v%{curl_version}-%{_host}-%{release}
> +Summary: Curl provides libcurl, a package to manage http etc protocols.
> +Version: %{curl_version}
> +Release: %{release}
> +URL: https://curl.haxx.se
> +# Curl Source
> +%source set curl
> https://curl.haxx.se/download/curl-%{curl_version}.tar.xz
> +# Curl's configures requires includes are in the CPPFLAGS.
> +%define host_cflags_no_includes 1
> +# Prepare the source code.
> +%prep
> + build_top=$(pwd)
> + source_dir_curl="curl-%{curl_version}"
> + %source setup curl -q -n curl-%{curl_version}
> + cd ${build_top}
> +# Build the source code.
> +# The configure should be run in the source dir
> +%build
> + build_top=$(pwd)
> + %{build_directory}
> + mkdir -p ${build_dir}
> + cd ${build_dir}
> + %{host_build_flags}
> + ../${source_dir_curl}/configure \
> + --host=%{_host} \
> + --prefix=%{_prefix} \
> + --bindir=%{_bindir} \
> + --exec_prefix=%{_exec_prefix} \
> + --includedir=%{_includedir} \
> + --libdir=%{_libdir} \
> + --libexecdir=%{_libexecdir} \
> + --mandir=%{_mandir} \
> + --infodir=%{_infodir} \
> + --datadir=%{_datadir}
> + %{__make} %{?_smp_mflags} all
> + cd ${build_top}
> +%install
> + build_top=$(pwd)
> + %{__rmdir} ${SB_BUILD_ROOT}
> + cd ${build_dir}
> + %{__make} DESTDIR=${SB_BUILD_ROOT} install
> + cd ${build_top}
> + # Remove any executables created in the build
> + %{__rmdir} ${SB_BUILD_ROOT}/%{_bindir}
> + %{__rmdir} ${SB_BUILD_ROOT}/%{_mandir}/man1
> diff --git a/source-builder/config/libpng-1.cfg
> b/source-builder/config/libpng-1.cfg
> index 2644948..dac60fc 100644
> --- a/source-builder/config/libpng-1.cfg
> +++ b/source-builder/config/libpng-1.cfg
> @@ -17,7 +17,9 @@ URL: http://www.libpng.org/
> # libpng Source
> -%source set libpng
> ftp://ftp.simplesystems.org/pub/libpng/png/src/libpng%{libpng_src_dir_revision}/libpng-%{libpng_version}.tar.gz
> +#%source set libpng
> +%source set libpng --rsb-file=libpng-%{libpng_version}.tar.xz
> http://prdownloads.sourceforge.net/libpng/libpng-%{libpng_version}.tar.xz?download
> diff --git a/source-builder/config/libtiff-1.cfg
> b/source-builder/config/libtiff-1.cfg
> index f7fa893..c9da951 100644
> --- a/source-builder/config/libtiff-1.cfg
> +++ b/source-builder/config/libtiff-1.cfg
> @@ -17,7 +17,7 @@ URL: http://www.libtiff.org/
> # libtiff Source
> -%source set libtiff
> ftp://ftp.remotesensing.org/pub/libtiff/tiff-%{tiff_version}.tar.gz
> +%source set libtiff
> http://download.osgeo.org/libtiff/tiff-%{tiff_version}.tar.gz
> diff --git a/source-builder/config/lwip-1.cfg
> b/source-builder/config/lwip-1.cfg
> index 1dd3bb7..ef736c1 100644
> --- a/source-builder/config/lwip-1.cfg
> +++ b/source-builder/config/lwip-1.cfg
> @@ -17,15 +17,16 @@ URL:
> http://git.savannah.gnu.org/cgit/lwip.git
> # LWIP Source
> -%source set lwip git://
> git.sv.gnu.org/lwip.git?fetch?reset=hard?branch=master?checkout=c2ebf5544b4268eac9b32c7f3a689ff646d96eef
> +%source set lwip
> http://git.savannah.gnu.org/cgit/lwip.git/snapshot/lwip-%{lwip_version}.tar.gz
> %prep
> build_top=$(pwd)
> - source_dir_lwip="%{lwip_version}"
> - %source setup lwip -q -n %{lwip_version}
> + source_dir_lwip="lwip-%{lwip_version}"
> + %source setup lwip -q -n lwip-%{lwip_version}
> %patch setup lwip -p1
> cd ${build_top}
> @@ -40,13 +41,13 @@ URL:
> %{host_build_flags}
> - cd ${build_top}/%{lwip_version}
> + cd ${build_top}/lwip-%{lwip_version}
> export RTEMS_MAKEFILE_PATH=%{_exec_prefix}
> %{__make} all
> # cd ${build_top}
> #%install
> - build_top=$(pwd)/%{lwip_version}
> + build_top=$(pwd)/lwip-%{lwip_version}
> %{__make} install
> diff --git a/source-builder/config/microwindows-1.cfg
> b/source-builder/config/microwindows-1.cfg
> index d6cfab5..6ec3f30 100644
> --- a/source-builder/config/microwindows-1.cfg
> +++ b/source-builder/config/microwindows-1.cfg
> @@ -8,16 +8,16 @@
> %define release 1
> %endif
> -Name: microwindows-v%{microwindows_version}-%{_host}-%{release}
> +Name: microwindows-%{microwindows_version}-%{_host}-%{release}
> Summary: microwindows is an Open Source Window System
> Version: %{microwindows_version}
> Release: %{release}
> -URL: http://www.microwindows.org/
> +URL: http://www.microwindows.org/
> # microwindows Source
> ftp://microwindows.censoft.com/pub/microwindows/microwindows-src-%{microwindows_version}.tar.gz
> +%source set microwindows
> --rsb-file=microwindows-%{microwindows_version}.tar.gz
> https://codeload.github.com/ghaerr/microwindows/tar.gz/%{microwindows_version}
> @@ -25,8 +25,8 @@ URL: http://www.microwindows.org/
> %prep
> build_top=$(pwd)
> - source_dir_microwindows="microwin"
> - %source setup microwindows -q -n microwin
> + source_dir_microwindows="microwindows-%{microwindows_version}"
> + %source setup microwindows -q -n microwindows-%{microwindows_version}
> %patch setup microwindows -p1
> cd ${build_top}
> diff --git a/source-builder/config/net-snmp-5-1.cfg
> b/source-builder/config/net-snmp-5-1.cfg
> index bffe430..c82e310 100644
> --- a/source-builder/config/net-snmp-5-1.cfg
> +++ b/source-builder/config/net-snmp-5-1.cfg
> @@ -43,6 +43,7 @@ URL: http://www.net-snmp.org/
> CFLAGS="${CFLAGS} %{net_snmp_cflags}"
> + LIBS="-lbsd -lm -lz -lrtemsdefaultconfig" \
> ../${source_dir_net_snmp}/configure \
> --host=%{_host} \
> diff --git a/source-builder/config/t1lib-1.cfg
> b/source-builder/config/t1lib-1.cfg
> index 3cb02c5..6202306 100644
> --- a/source-builder/config/t1lib-1.cfg
> +++ b/source-builder/config/t1lib-1.cfg
> @@ -17,7 +17,7 @@ URL: http://www.t1lib.org/
> # t1lib Source
> -%source set t1lib
> ftp://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-%{t1lib_version}.tar.gz
> +%source set t1lib
> http://ftp.netbsd.org/pub/pkgsrc/distfiles/t1lib-%{t1lib_version}.tar.gz
> diff --git a/source-builder/defaults.mc b/source-builder/defaults.mc
> index 3508877..646be78 100644
> --- a/source-builder/defaults.mc
> +++ b/source-builder/defaults.mc
> @@ -64,14 +64,16 @@ _uid: none, convert, '%(%{__id_u}
> -n)'
> # Default flags that can be overridded to supply specific host or build
> # flags and include paths to the tools. The host is the final platform
> # the tools will run on and build is the host building the tools.
> -host_cflags: none, convert, '-O2 -pipe'
> -host_cxxflags: none, convert, '-O2 -pipe'
> +host_cflags: none, convert, '-O2 -g -pipe'
> +host_cxxflags: none, convert, '-O2 -g -pipe'
> host_ldflags: none, convert, ''
> host_includes: none, convert, ''
> -build_cflags: none, convert, '-O2 -pipe'
> -build_cxxflags: none, convert, '-O2 -pipe'
> +host_libs: none, convert, ''
> +build_cflags: none, convert, '-O2 -g -pipe'
> +build_cxxflags: none, convert, '-O2 -g -pipe'
> build_ldflags: none, convert, ''
> build_includes: none, convert, ''
> +build_libs: none, convert, ''
> # Extra path a platform can override.
> _extra_path: none, none, '%{_sbdir}'
> @@ -203,19 +205,22 @@ SB_SOURCE_DIR="%{_sourcedir}"
> SB_BUILD_DIR="%{_builddir}"
> # host == build, use build; host != build, host uses host and build uses
> build
> SB_HOST_CPPFLAGS="%{host_includes}"
> -SB_HOST_CFLAGS="%{host_cflags} %{host_includes}"
> -SB_HOST_CXXFLAGS="%{host_cxxflags} %{host_includes}"
> +# Optionally do not add includes to c/cxx flags as newer configure's
> complain
> +SB_HOST_CFLAGS="%{host_cflags} %{!?host_cflags_no_includes
> %{host_includes}}"
> +SB_HOST_CXXFLAGS="%{host_cxxflags} %{!?host_cflags_no_includes
> %{host_includes}}"
> SB_HOST_LDFLAGS="%{host_ldflags}
> %{?_tmproot:-L%{_tmproot}/${SB_PREFIX_CLEAN}/lib}"
> +SB_HOST_LIBS="%{host_libs}"
> SB_BUILD_CFLAGS="%{build_cflags}
> %{?_tmproot:-I%{_tmproot}/${SB_PREFIX_CLEAN}/include}"
> SB_BUILD_CXXFLAGS="%{build_cxxflags}
> SB_BUILD_LDFLAGS="%{build_ldflags}
> +SB_BUILD_LBS="%{build_libs}"
> SB_CFLAGS="${SB_BUILD_CFLAGS} %{build_includes}"
> SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} %{build_includes}"
> SB_ARCH="%{_arch}"
> SB_OS="%{_os}"
> export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
> -export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
> -export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS
> +export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS
> SB_HOST_LIBS
> +export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
> export SB_CFLAGS SB_CXXFLAGS
> # Documentation
> SB_DOC_DIR="%{_docdir}"
> @@ -326,11 +331,13 @@ if test "%{_build}" != "%{_host}" ; then
> CFLAGS="${SB_HOST_CFLAGS}"
> CXXFLAGS="${SB_HOST_CXXFLAGS}"
> LDFLAGS="${SB_HOST_LDFLAGS}"
> + LIBS="${SB_HOST_LIBS}"
> # Host
> CPPFLAGS_FOR_HOST="${SB_HOST_CPPFLAGS}"
> CFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
> CXXFLAGS_FOR_HOST="${SB_HOST_CXXFLAGS}"
> LDFLAGS_FOR_HOST="${SB_HOST_LDFLAGS}"
> + LIBS_FOR_HOST="${SB_HOST_LIBS}"
> CXXFLAGS_FOR_HOST="${SB_HOST_CFLAGS}"
> CC_FOR_HOST=$(echo "%{_host_cc} ${SB_HOST_CFLAGS}" | sed -e
> 's,-std=gnu99 ,,')
> CXX_FOR_HOST=$(echo "%{_host_cxx} ${SB_HOST_CXXFLAGS}" | sed -e
> 's,-std=gnu99 ,,')
> @@ -338,30 +345,33 @@ if test "%{_build}" != "%{_host}" ; then
> CFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
> CXXFLAGS_FOR_BUILD="${SB_BUILD_CXXFLAGS}"
> LDFLAGS_FOR_BUILD="${SB_BUILD_LDFLAGS}"
> + LIBS_FOR_BUILD="${SB_BUILD_LIBS}"
> CXXFLAGS_FOR_BUILD="${SB_BUILD_CFLAGS}"
> CC_FOR_BUILD=$(echo "%{__cc} ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99
> CXX_FOR_BUILD=$(echo "%{__cxx} ${SB_BUILD_CXXFLAGS}" | sed -e
> 's,-std=gnu99 ,,')
> else
> LDFLAGS="${SB_BUILD_LDFLAGS}"
> + LIBS="${SB_BUILD_LIBS}"
> CC=$(echo "%{__cc} ${SB_BUILD_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
> CXX=$(echo "%{__cxx} ${SB_BUILD_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
> CC_FOR_BUILD=${CC}
> CXX_FOR_BUILD=${CXX}
> fi
> -export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS
> -export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
> CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST
> -export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
> LDFLAGS_FOR_BUILD'''
> +export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS
> +export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST
> CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LIBS_FOR_HOST
> +export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD
> LDFLAGS_FOR_BUILD LIBS_FOR_BUILS'''
> # Build/build flags.
> build_build_flags: none, none, '''
> # Build and build flags means force build == host
> # gcc is not ready to be compiled with -std=gnu99
> +LIBS="${SB_HOST_LIBS}"
> CC=$(echo "%{__cc} ${SB_CFLAGS}" | sed -e 's,-std=gnu99 ,,')
> CXX=$(echo "%{__cxx} ${SB_CXXFLAGS}" | sed -e 's,-std=gnu99 ,,')
> CC_FOR_BUILD=${CC}
> -export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS'''
> +export CC CXX CC_FOR_BUILD CXX_FOR_BUILD CFLAGS LDFLAGS LIBS'''
> # Default package settings
> _forced_static: none, none, '-Xlinker -Bstatic ${LIBS_STATIC}
> -Xlinker -Bdynamic'
> diff --git a/source-builder/sb/options.py b/source-builder/sb/options.py
> index ae67eeb..d8e7a88 100644
> --- a/source-builder/sb/options.py
> +++ b/source-builder/sb/options.py
> @@ -420,10 +420,14 @@ class command_line:
> _host = self.defaults.expand('%{_host}')
> _build = self.defaults.expand('%{_build}')
> _target = self.defaults.expand('%{_target}')
> - if len(_target):
> - return len(_host) and len(_build) and (_target) and \
> - _host != _build and _host != _target
> - return len(_host) and len(_build) and _host != _build
> + # This has been removed to fix how RTEMS 3rd party libraries
> + # are built. This may break Cxc tools builds.
> + # if len(_target):
> + # return len(_host) and len(_build) and (_target) and \
> + # _host != _build and _host != _target
> + return len(_target) and len(_host) and len(_build) and _host !=
> _build
> def user_macros(self):
> diff --git a/source-builder/sb/rtems-build-dep
> b/source-builder/sb/rtems-build-dep
> index 1f795d3..48a0823 100755
> --- a/source-builder/sb/rtems-build-dep
> +++ b/source-builder/sb/rtems-build-dep
> @@ -141,7 +141,7 @@ fi
> # Library file
> if [ ${op} = "library" ]; then
> - if [ "${OS}" = "Windows_NT" -a "${OSTYPE}" -ne "cygwin" ]; then
> + if [ "${OS}" = "Windows_NT" -a "${OSTYPE}" != "cygwin" ]; then
> sep=';'
> else
> sep=':'
> 2.20.1 (Apple Git-117)
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190706/b375f082/attachment-0001.html>
