GSoC 2019 | POSIX Compliance - RSB patch generated ndbm library (lib_a-ndbm.o) successfully in RTEMS Toolchain
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Fri Jul 12 03:00:43 UTC 2019
Sounds good to me.
On Thu, Jul 11, 2019 at 6:47 PM Joel Sherrill <joel at rtems.org> wrote:
> On Thu, Jul 11, 2019 at 2:12 AM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Hello,
>> After Joel pointed out in an offlist discussion,
>> I made a new patch for ndbm port.
>> To send the changes to Newlib, i had to place `ndbm.h` , `ndbm.c` in
>> their respective places and make changes in Makefile.am.
>> Before, I applied same patch to RSB hence ndbm library was not generated.
> In my local build yesterday, I saw the symbols in the installed libc.a. I
> have not run the tests.
>> This time I also added files generated by `autoreconf -fvi` in the patch.
>> This patch is 10MB in size hence cannot be send in raw format on mailing
>> list.
> The person committing is supposed to do the autoreconf and commit that.
> No one has answered if it is OK to commit. That was the last message in
> the thread.
I will ping on that thread again for confirmation.
>> This patch worked with RSB and ndbm library (lib_a-ndbm.o) was generated
>> successfully in RTEMS Toolchain.
> I'm hoping we can avoid this by pushing the patch to newlib, then bumping
> the hash for
> newlib in the RSB, then adding your ndbm test patch to RTEMS.
Yeah, meanwhile testsuite can be verified.
Also, please look at the sources I send on devel for fenv. Should I ignore
architectures
which are not having FreeBSD source? or Should i pick from NetBSD and
FreeBSD
both?
> --joel
>> Thank you
>> Vaibhav Gupta
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190712/49d2d687/attachment.html>
