GSoC Project | Basic Support for Trace Compass
Wed Jun 19 09:23:41 UTC 2019
On 19/06/2019 11:21, Sebastian Huber wrote:
> On 19/06/2019 11:13, Ravindra Kumar Meena wrote:
>> Hi,
>> I asked the babeltrace community about the difference between binary
>> packetized and the simple text metadata file. They say both will work
>> the way.
>> Here is the response:
>> https://lists.lttng.org/pipermail/lttng-dev/2019-June/029059.html
> I think we have now enough information to start with the task outlined
> here:
> https://lists.rtems.org/pipermail/devel/2019-June/026210.html
> Is it clear enough for you or do you need more information to start with
> this task?
Just to make sure we have a common understanding of the task. Could you
please explain the task with your ideas to implement it in your own works?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
