BBB Framebuffer driver : Project status
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Tue Jun 25 11:38:12 UTC 2019
On Tue, Jun 25, 2019 at 5:04 PM Vijay Kumar Banerjee <
vijaykumar9597 at gmail.com> wrote:
> Hello,
> The First Evaluation is going on and I here I would summarize all the
> progress
> that the project has made in the first Phase.
> 1. The major progress is the completion of the I2C adaptation layer in the
> libbsd
> along with the iicbus driver imports. The v4 of the driver [1] has
> been tested to be
> working with the bbb-i2c driver patch [2]. After the RTEMS driver is
> updated in the
> master, the adaptation layer will be mergeable.
> [1] : https://lists.rtems.org/pipermail/devel/2019-June/026320.html
[2] : https://lists.rtems.org/pipermail/devel/2019-June/026308.html
> 2. I am getting EDID reading from the imported tda drivers. I have checked
> this using
> the ti_i2c driver but now as we have an updated version of the
> driver, I'll pull this all
> with the adaptation layer and will continue from there.
> 3. I found a sample app from the freebsd mailing list, that draws a basic
> shape on the
> screen. I have made it a standalone app with only single source and
> have tested it
> to be working with the FreeBSD. The only issue with the code is that
> it uses mmap
> and RTEMS doesn't use mmap so I'm rewriting the app with pread and
> pwrtie on
> to write to the /dev/fb0 directly. This app work is ongoing.
> Next Up:
> 1. merge the ported TDA driver and using it with the adaptation layer.
> 2. Import and port the fbd dirver to create an fb0 device.
> 3. complete the sample app and convert it into a libbsd sample app to test
> the device.
> Thanks,
> Vijay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190625/a54fb004/attachment.html>
