sparc-rtems-gdb doesn't recognize target "sim"
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Wed Nov 13 08:48:03 UTC 2019
You can also use "sis"
1- Open Terminal 1 and write:
$ sparc-rtems5-sis -gdb
# It will print 'gdb: listening on port 1234'.
# Note you can define port number with '-port' option.
2-Open Terminal 2 and write:
$ sparc-rtems5-gdb hello.exe
# gdb asks for several inputs
$ target extended-remote localhost:1234
$ load
$ r
Use the notes here:
https://github.com/VARoDeK/MyNotes/blob/master/RTEMS/run_a_testsuite.md
On Wed, Nov 13, 2019, 1:06 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Wed, Nov 13, 2019 at 12:39 AM Shubham Bhagat <
> shubhambhagat111 at yahoo.com> wrote:
>> Hello everyone,
>> I've been trying to run the hello world example in source tree
>> <https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start#Running> to get
>> started with sparc/erc32 but after building all that is required ( followed POSIX
>> Compliance (Getting started challenge for RTEMS beginners)
>> <https://rmeena840.github.io/Third-Post/>). I
>> followed all the commands. But, when gdb starts and I set "tar sim" it
>> says:
>> Undefined target command: "sim". Try "help target".
>> I also tried running hello.exe from the testsuites sample using
>> sparc-rtems5-run but it doesn't recognize the command.
>> NOTE: The make and make install steps didn't finish with a "SUCCESS" or
>> anything. They exited without showing any error.
>> Am I missing out anything here?
>> I guess this thread will be helpful for you:
> https://lists.rtems.org/pipermail/devel/2019-September/055671.html
>> POSIX Compliance (Getting started challenge for RTEMS beginners)
>> Ravindra Kumar Meena
>> POSIX stands for Portable Operating System Interface for uni-X. POSIX
>> Compliance allows us to port the source co...
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191113/7800a5b3/attachment.html>
