sparc-erc32 testsuites failures
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Mon Nov 18 06:35:54 UTC 2019
On Mon, Nov 18, 2019, 11:12 AM Niteesh <gsnb.gn at gmail.com> wrote:
> On Mon, Nov 18, 2019 at 3:17 AM Joel Sherrill <joel at rtems.org> wrote:
>> The instructions are out of date by a couple of months. The SPARC
>> Instruction Simulator (sis) has seen significant enhancements and it's now
>> a standalone program. It is not enabled as a built-in with gdb because
>> that's some very old version of sis. The new version has symmetric
>> multiprocessing and support for the RISC-V.
>> Those instructions worked for a LONG time but need to be updated to
>> reflect the recent changes with SIS.
>> If you used rtems-tester, it should work. And looking at the .ini file
>> for this bsp will sure you have to just run programs with the simulator. My
>> recollection is that by adding -gdb argument, you can attached to it as a
>> remote debugger.
> Yes. And I also faced this problem (in my case it was riscv)and i guess
this question was asked by others also on devel.
I simply used these steps:
Open Terminal 1:
$ sparc-rtems5-sis -gdb
# It will print 'gdb: listening on port 1234'.
# Note you can define port number with '-port' option.
Open Terminal 2:
$ sparc-rtems5-gdb hello.exe
# gdb asks for several inputs
$ target extended-remote localhost:1234
$ load
$ r
You will see output in Terminal 1.
> I would like to update the docs for this, Can I proceed? I am planning to
> change the cmd to use erc-sis instead of erc. And also the build your
> application section is incomplete, can I add the instruction to modify a
> test program and build it in this section?
>> BTW I know it's a way too early for GSOC but I have anyway attached the
>>> patch for hello world.
>> What type projects are you interested in?
> I am interested in driver development and BSP support.
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191118/586ad71e/attachment.html>
