Use YAML configuration files for the build?
Joel Sherrill
joel at rtems.org
Fri Oct 4 17:56:35 UTC 2019
On Fri, Oct 4, 2019 at 12:50 PM Sebastian Huber <
> ----- Am 4. Okt 2019 um 19:41 schrieb joel joel at rtems.org:
> > On Fri, Oct 4, 2019 at 12:25 PM Sebastian Huber <
> >> ----- Am 4. Okt 2019 um 16:15 schrieb joel joel at rtems.org:
> >> > On Fri, Oct 4, 2019 at 8:29 AM Sebastian Huber <
> >> >> Hello,
> >> >> I would like to use YAML configuration files for the new build
> system.
> >> > For what purpose?
> >> To store the items which define what and how the build is done, e.g.
> BSPs,
> >> BSP options, libraries, file groups for libraries, test programs.
> > pkgconfig type information?
> No, not pkgconfig type information.
> > Would this all be generated or a manually prepared input?
> The YAML files are not generated, they have to be filled manually with the
> help of Doorstop.
> >> > To achieve what end?
> >> Make it possible to re-use the build specification, e.g. generate
> >> documentation of the BSP options for the user manual.
> > Sounds like pkgconfig in Yaml format.
> > Is it different?
> I don't know why you picked up pkgconfig. The pkgconfig support for a BSP
> could be an artefact of the build process.
I said pkgconfig type information -- not pkgconfig. You mentioned compile
settings like flags, libraries, etc which is the type of information in
pkgconfig.
> At the moment I just would like to know if a PyYAML dependency would be an
> issue. I will try to explain later in detail why I would like to use it.
I'm not the Python expert but it is supported by 2.7 and newer so that's
good. And it installs via pip which is good.
I don't think it's part of the base Python libraries but as long as it is
packaged via pip, that meets the same level of support Sphinx has.
I can't speak to the stability of its APIs.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191004/512d5d3f/attachment.html>
