[PATCH v3] riscv: add freedom E310 Arty A7 bsp
Hesham Almatary
hesham.almatary at cl.cam.ac.uk
Mon Sep 30 06:32:43 UTC 2019
Hi Pragnesh,
That's a so much better refined patch, thanks! Please find my minor
comments inlined below.
After the patch gets merged, could you please add a new section about
that BSP to the RISC-V chapter doc here [1]?
[1] https://docs.rtems.org/branches/master/user/bsps/bsps-riscv.html
On Fri, 27 Sep 2019 at 12:20, Pragnesh Patel <pragnesh.patel at sifive.com> wrote:
> Added support for Sifive Freedom FE310 soc on Arty A7 FPGA board.
> Update #3785.
> Signed-off-by: Pragnesh Patel <pragnesh.patel at sifive.com>
> Changes in v3:
> - Remove bsps/riscv/frdme310arty/ directory and added support for
> Freedom FE310 soc in common bsps/riscv/riscv/ directory
> - Added #define RISCV_ENABLE_FRDME310ARTY_SUPPORT in configure.ac
> to enable support for FE310
> - Change the RISCV_RAM_REGION_SIZE to 256 MB for riscv
> Changes in v2:
> bsps/riscv/frdme310arty/btimer/btimer.c
> - Remove the read_csr() function from btimer.c
> - Remove CONFIG_BTIMER_RISCV_GET_MCYCLES macro to get time in
> microseconds
> bsps/riscv/frdme310arty/clock/clockdrv.c
> bsps/riscv/riscv/clock/clockdrv.c
> - Delete both files and Add bsps/riscv/shared/clock/clockdrv.c
> - riscv_clock_get_timebase_frequency(): Get timebase-frequency from
> cpus or cpu at 0 devicetree node because riscv uses "cpus" node and
> frdme310arty uses "cpu at 0" node to look for timebase-frequency
> - Remove rtems_counter_initialize_converter() and
> rtems_timecounter_simple_install() functions
> bsps/riscv/frdme310arty/include/bsp/riscv.h
> - Remove unused frdme310arty_l2c_base;
> bsps/riscv/frdme310arty/start/bsp_fatal_halt.c
> bsps/riscv/riscv/start/bsp_fatal_halt.c
> - Delete this file and Add bsps/riscv/shared/start/bsp_fatal_halt.c
> bsps/riscv/frdme310arty/start/bspstart.c
> - Remove unused function riscv_get_node_byname()
> bsps/riscv/frdme310arty/start/linkcmds.in
> - Use @RISCV_RAM_REGION_BEGIN@ and @RISCV_RAM_REGION_SIZE@ instead of
> hard coded values
> c/src/lib/libbsp/riscv/frdme310arty/Makefile.am
> - librtemsbsp_a_SOURCES -> bsps/riscv/shared/start/bsp_fatal_halt.c
> - librtemsbsp_a_SOURCES -> bsps/riscv/shared/clock/clockdrv.c
> c/src/lib/libbsp/riscv/frdme310arty/configure.ac
> - change RISCV_RAM_REGION_SIZE to default 256MiB
> bsps/riscv/riscv/irq/irq.c
> - Delete this irq.c and it will now use bsps/riscv/shared/irq/irq.c
> c/src/lib/libbsp/riscv/riscv/Makefile.am
> - librtemsbsp_a_SOURCES -> bsps/riscv/shared/irq/irq.c
> bsps/include/bsp/fatal.h | 3 +-
> bsps/riscv/riscv/clock/clockdrv.c | 16 ++--
> bsps/riscv/riscv/console/console-config.c | 57 +++++++++++++
> bsps/riscv/riscv/console/fe310-uart.c | 100 +++++++++++++++++++++++
> bsps/riscv/riscv/dts/frdme310arty.dts | 130 ++++++++++++++++++++++++++++++
> bsps/riscv/riscv/include/bsp/fe310-uart.h | 42 ++++++++++
> bsps/riscv/riscv/include/bsp/riscv.h | 4 +
> bsps/riscv/riscv/start/bspstart.c | 52 ++++++++++++
> c/src/lib/libbsp/riscv/riscv/Makefile.am | 8 ++
> c/src/lib/libbsp/riscv/riscv/configure.ac | 7 +-
> 10 files changed, 411 insertions(+), 8 deletions(-)
> create mode 100644 bsps/riscv/riscv/console/fe310-uart.c
> create mode 100644 bsps/riscv/riscv/dts/frdme310arty.dts
Why do you need to add the .dts file? Is it just for reference?
Doesn't the bootrom and/or u-boot pass its to RTEMS in a1 register?
> create mode 100644 bsps/riscv/riscv/include/bsp/fe310-uart.h
> diff --git a/bsps/include/bsp/fatal.h b/bsps/include/bsp/fatal.h
> index fae5461..3f8e1eb 100644
> --- a/bsps/include/bsp/fatal.h
> +++ b/bsps/include/bsp/fatal.h
> @@ -152,7 +152,8 @@ typedef enum {
> RISCV_FATAL_INVALID_PLIC_NDEV_IN_DEVICE_TREE,
> RISCV_FATAL_TOO_LARGE_PLIC_NDEV_IN_DEVICE_TREE,
> RISCV_FATAL_INVALID_INTERRUPT_AFFINITY,
> - RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE
> + RISCV_FATAL_NO_NS16550_INTERRUPTS_IN_DEVICE_TREE,
> + RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE
> } bsp_fatal_code;
> RTEMS_NO_RETURN static inline void
> diff --git a/bsps/riscv/riscv/clock/clockdrv.c b/bsps/riscv/riscv/clock/clockdrv.c
> index 7e6034d..7f32dcf 100644
> --- a/bsps/riscv/riscv/clock/clockdrv.c
> +++ b/bsps/riscv/riscv/clock/clockdrv.c
> @@ -130,15 +130,21 @@ static uint32_t riscv_clock_get_timecount(struct timecounter *base)
> static uint32_t riscv_clock_get_timebase_frequency(const void *fdt)
> int node;
> - const uint32_t *val;
> - int len;
> + fdt32_t *val;
Any reason why did you get rid of the const?
> + int len=0;
> node = fdt_path_offset(fdt, "/cpus");
> - val = fdt_getprop(fdt, node, "timebase-frequency", &len);
> + val = (fdt32_t *) fdt_getprop(fdt, node, "timebase-frequency", &len);
> if (val == NULL || len < 4) {
> - bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
> + int cpu0 = fdt_subnode_offset(fdt, node, "cpu at 0");
> + val = (fdt32_t *) fdt_getprop(fdt, cpu0, "timebase-frequency", &len);
> + if (val == NULL || len < 4) {
> + bsp_fatal(RISCV_FATAL_NO_TIMEBASE_FREQUENCY_IN_DEVICE_TREE);
> return fdt32_to_cpu(*val);
> diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
> index 464b4b0..8a3472d 100644
> --- a/bsps/riscv/riscv/console/console-config.c
> +++ b/bsps/riscv/riscv/console/console-config.c
> @@ -28,6 +28,11 @@
> #include <libfdt.h>
> #include <string.h>
> +#if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
> +#include <bsp/fe310-uart.h>
> +fe310_uart_context driver_context;
> +#endif
> #if RISCV_ENABLE_HTIF_SUPPORT != 0
> static htif_console_context htif_console_instance;
> #endif
> @@ -59,7 +64,18 @@ static int riscv_get_console_node(const void *fdt)
> stdout_path = "";
> +#if RISCV_ENABLE_FRDME310ARTY_SUPPORT > 0
Could you please be consistent with this and write it all over the patch as:
> + int root;
> + int soc;
> + root = fdt_path_offset(fdt, "/");
> + soc = fdt_subnode_offset(fdt, root, "soc");
> + int offset=fdt_subnode_offset(fdt, soc,stdout_path);
> + return offset;
> +#else
> return fdt_path_offset(fdt, stdout_path);
> +#endif
> #if RISCV_CONSOLE_MAX_NS16550_DEVICES > 0
> @@ -193,6 +209,27 @@ static void riscv_console_probe(void)
> #endif
> + if (RISCV_CONSOLE_IS_COMPATIBLE(compat, compat_len, "sifive,uart0")) {
> + fe310_uart_context *ctx ;
> + ctx=&driver_context;
> + ctx->regs = (uintptr_t) riscv_fdt_get_address(fdt, node);
> + if (ctx->regs == 0)
> + bsp_fatal(RISCV_FATAL_NO_NS16550_REG_IN_DEVICE_TREE);
> + if (node == console_node) {
> + riscv_console.context = &ctx->base;
> + riscv_console.putchar = fe310_console_putchar;
> + riscv_console.getchar = fe310_uart_read;
> + rtems_termios_device_context_initialize(&ctx->base, "FE310UART");
> +#endif
> node = fdt_next_node(fdt, node, NULL);
> @@ -224,6 +261,10 @@ rtems_status_code console_initialize(
> size_t i;
> #endif
> + char path[] = "/dev/ttyS0";
> +#endif
> rtems_termios_initialize();
> @@ -255,6 +296,22 @@ rtems_status_code console_initialize(
> #endif
> + fe310_uart_context * ctx = &driver_context;
> + rtems_termios_device_install(
> + path,
> + &fe310_uart_handler,
> + NULL,
> + &ctx->base
> + if (&ctx->base == riscv_console.context) {
> + link(path, CONSOLE_DEVICE_NAME);
> +#endif
> return RTEMS_SUCCESSFUL;
> diff --git a/bsps/riscv/riscv/console/fe310-uart.c b/bsps/riscv/riscv/console/fe310-uart.c
> new file mode 100644
> index 0000000..06b312f
> --- /dev/null
> +++ b/bsps/riscv/riscv/console/fe310-uart.c
> @@ -0,0 +1,100 @@
> + * Copyright (c) 2019 Sachin Ghadi <sachin.ghadi at sifive.com>
> + * Copyright (c) 2019 Pragnesh Patel <pragnesh.patel at sifive.com>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +#include <bsp/riscv.h>
> +#include <assert.h>
> +static void irq_handler(void *arg)
> + /*TODO*/
> +int fe310_uart_read(rtems_termios_device_context *base)
> + fe310_uart_context * ctx = (fe310_uart_context*) base;
> + size_t i;
> + if (((ctx->regs->rxdata) & TXRXREADY) != 0) {
> + return -1;
> + } else {
> + return ctx->regs->rxdata;
> +static ssize_t fe310_uart_write (
> + rtems_termios_device_context *base,
> + const char *buf,
> + size_t n
> + size_t i;
> + rtems_status_code sc;
> + (ctx->regs)->div = riscv_get_core_frequency()/ 115200 - 1;
> + (ctx->regs)->txctrl |= 1;
> + (ctx->regs)->rxctrl |= 1;
> + for (i = 0; i < n; ++i) {
> + while (((ctx->regs->txdata) & TXRXREADY) != 0) {
> + ctx->regs->txdata = buf[i];
> + return n;
> +void fe310_console_putchar(rtems_termios_device_context * context,char c)
> + fe310_uart_write ( context, &c,1);
> +void console_context_init(
> + int device_tree_node
> + /*TODO*/
> +static bool fe310_uart_first_open (
> + rtems_termios_tty *tty,
> + struct termios *term,
> + rtems_libio_open_close_args_t *args
> + fe310_uart_context * ctx;
> + /* Configure GPIO to be UART */
> + sc = rtems_termios_set_initial_baud (tty, B115200);
> + if ( sc != RTEMS_SUCCESSFUL ) {
> + return false;
> + /* Set up a baud rate and enable tx and rx */
> + ctx = (fe310_uart_context *) base;
> + return true;
> +const rtems_termios_device_handler fe310_uart_handler = {
> + .first_open = fe310_uart_first_open,
> + .write = fe310_uart_write,
> + .poll_read = fe310_uart_read,
> + .mode = TERMIOS_POLLED
> diff --git a/bsps/riscv/riscv/dts/frdme310arty.dts b/bsps/riscv/riscv/dts/frdme310arty.dts
> index 0000000..a7a216d
> --- /dev/null
> +++ b/bsps/riscv/riscv/dts/frdme310arty.dts
> @@ -0,0 +1,130 @@
> +/dts-v1/;
> + #address-cells = <1>;
> + #size-cells = <1>;
> + compatible = "SiFive,FE310G-dev", "fe310-dev", "sifive-dev";
> + model = "SiFive,FE310G";
> + L20: chosen {
> + stdout-path = "serial at 20000000";
> + L17: cpus {
> + #size-cells = <0>;
> + L6: cpu at 0 {
> + clocks = <&refclk>;
> + compatible = "sifive,rocket0", "riscv";
> + device_type = "cpu";
> + i-cache-block-size = <64>;
> + i-cache-sets = <128>;
> + i-cache-size = <16384>;
> + next-level-cache = <&L12>;
> + reg = <0>;
> + riscv,isa = "rv32imac";
> + sifive,dtim = <&L5>;
> + sifive,itim = <&L4>;
> + status = "okay";
> + timebase-frequency = <1000000>;
> + L3: interrupt-controller {
> + #interrupt-cells = <1>;
> + compatible = "riscv,cpu-intc";
> + interrupt-controller;
> + L16: soc {
> + compatible = "SiFive,FE310G-soc", "fe310-soc", "sifive-soc", "simple-bus";
> + ranges;
> + L19: tlclk {
> + #clock-cells = <0>;
> + clock-frequency = <32500000>;
> + clock-output-names = "tlclk";
> + compatible = "fixed-clock";
> + refclk: refclk {
> + clock-frequency = <66666666>;
> + clock-output-names = "refclk";
> + L1: clint at 2000000 {
> + compatible = "riscv,clint0";
> + interrupts-extended = <&L3 3 &L3 7>;
> + reg = <0x2000000 0x10000>;
> + reg-names = "control";
> + L2: debug-controller at 0 {
> + compatible = "sifive,debug-013", "riscv,debug-013";
> + interrupts-extended = <&L3 65535>;
> + reg = <0x0 0x1000>;
> + L5: dtim at 80000000 {
> + compatible = "sifive,dtim0";
> + reg = <0x80000000 0x10000>;
> + reg-names = "mem";
> + L8: error-device at 3000 {
> + compatible = "sifive,error0";
> + reg = <0x3000 0x1000>;
> + L9: global-external-interrupts {
> + interrupt-parent = <&L0>;
> + interrupts = <1 2 3 4>;
> + L13: gpio at 20002000 {
> + compatible = "sifive,gpio0";
> + interrupts = <7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22>;
> + reg = <0x20002000 0x1000>;
> + L0: interrupt-controller at c000000 {
> + compatible = "riscv,plic0";
> + interrupts-extended = <&L3 11>;
> + reg = <0xc000000 0x4000000>;
> + riscv,max-priority = <7>;
> + riscv,ndev = <26>;
> + L4: itim at 8000000 {
> + compatible = "sifive,itim0";
> + reg = <0x8000000 0x4000>;
> + L10: local-external-interrupts-0 {
> + interrupt-parent = <&L3>;
> + interrupts = <16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31>;
> + L14: pwm at 20005000 {
> + compatible = "sifive,pwm0";
> + interrupts = <23 24 25 26>;
> + reg = <0x20005000 0x1000>;
> + L11: serial at 20000000 {
> + compatible = "sifive,uart0";
> + interrupts = <5>;
> + reg = <0x20000000 0x1000>;
> + L12: spi at 20004000 {
> + compatible = "sifive,spi0";
> + interrupts = <6>;
> + reg = <0x20004000 0x1000 0x40000000 0x20000000>;
> + reg-names = "control", "mem";
> + L7: teststatus at 4000 {
> + compatible = "sifive,test0";
> + reg = <0x4000 0x1000>;
> diff --git a/bsps/riscv/riscv/include/bsp/fe310-uart.h b/bsps/riscv/riscv/include/bsp/fe310-uart.h
> index 0000000..065e12a
> --- /dev/null
> +++ b/bsps/riscv/riscv/include/bsp/fe310-uart.h
> @@ -0,0 +1,42 @@
> +#ifndef FE310_UART_H
> +#define FE310_UART_H
> +#define TXRXREADY (1 << 31)
> +#include <rtems/termiostypes.h>
> +#include <rtems/irq.h>
> +typedef struct {
> + uint32_t txdata;
> + uint32_t rxdata;
> + uint32_t txctrl;
> + uint32_t rxctrl;
> + uint32_t ie;
> + uint32_t ip;
> + uint32_t div;
> +} fe310_uart_t;
> +/* Low-level driver specific data structure */
> +typedef struct {
> + rtems_termios_device_context base;
> + const char *device_name;
> + volatile fe310_uart_t *regs;
> +} fe310_uart_context;
> +int fe310_uart_read(rtems_termios_device_context *base);
> +void fe310_console_putchar(rtems_termios_device_context * context,char c);
> +extern const rtems_termios_device_handler fe310_uart_handler;
> +extern fe310_uart_context driver_context;
> +#endif /* FE310_UART_H */
> diff --git a/bsps/riscv/riscv/include/bsp/riscv.h b/bsps/riscv/riscv/include/bsp/riscv.h
> index 374d5f7..f2f1a59 100644
> --- a/bsps/riscv/riscv/include/bsp/riscv.h
> +++ b/bsps/riscv/riscv/include/bsp/riscv.h
> @@ -38,6 +38,10 @@ extern volatile RISCV_CLINT_regs *riscv_clint;
> void *riscv_fdt_get_address(const void *fdt, int node);
> +uint32_t riscv_get_core_frequency(void);
> +#endif
> #ifdef RTEMS_SMP
> extern uint32_t riscv_hart_count;
> #else
> diff --git a/bsps/riscv/riscv/start/bspstart.c b/bsps/riscv/riscv/start/bspstart.c
> index d4c4e1f..b3b33b5 100644
> --- a/bsps/riscv/riscv/start/bspstart.c
> +++ b/bsps/riscv/riscv/start/bspstart.c
> @@ -30,6 +30,11 @@
> #include <libfdt.h>
> +#include <string.h>
> +unsigned int riscv_core_freq;
> +#endif
> @@ -161,8 +166,55 @@ uint32_t riscv_get_hart_index_by_phandle(uint32_t phandle)
> return UINT32_MAX;
> +static uint32_t get_core_frequency(void)
> + uint32_t node;
> + const char *fdt=bsp_fdt_get();
> + char *tlclk;
> + uint32_t len;
> + do
> + node=fdt_node_offset_by_compatible(fdt, -1,"fixed-clock");
> + uint32_t *val=NULL;
> + if(node>0)
Spaces?
> + tlclk = fdt_getprop(fdt, node, "clock-output-names", &len);
> + if (strcmp(tlclk,"tlclk") == 0)
> + val = fdt_getprop(fdt, node, "clock-frequency", &len);
> + if(val !=NULL)
> + riscv_core_freq=fdt32_to_cpu(*val);
> + break;
> + }else
> + bsp_fatal(RISCV_FATAL_NO_TLCLOCK_FREQUENCY_IN_DEVICE_TREE);
> + } while (node > 0);
> + return riscv_core_freq;
> +inline uint32_t riscv_get_core_frequency(void)
> +#endif
> void bsp_start(void)
> riscv_find_harts();
> bsp_interrupt_initialize();
> + riscv_core_freq=get_core_frequency();
> +#endif
> diff --git a/c/src/lib/libbsp/riscv/riscv/Makefile.am b/c/src/lib/libbsp/riscv/riscv/Makefile.am
> index 34bedf8..15b0865 100644
> --- a/c/src/lib/libbsp/riscv/riscv/Makefile.am
> +++ b/c/src/lib/libbsp/riscv/riscv/Makefile.am
> @@ -46,7 +46,11 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/start/bspgetworkarea-defa
> librtemsbsp_a_SOURCES +=../../../../../../bsps/riscv/riscv/clock/clockdrv.c
> # Timer
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-cpucounter.c
> +#else
> librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/btimer/btimer-stub.c
> +#endif
> # IRQ
> librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/irq/irq-default-handler.c
> @@ -60,6 +64,10 @@ librtemsbsp_a_SOURCES += ../../../../../../bsps/shared/dev/serial/console-termio
> librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/console-config.c
> librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/htif.c
> +librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/console/fe310-uart.c
> +#endif
> if HAS_SMP
> librtemsbsp_a_SOURCES += ../../../../../../bsps/riscv/riscv/start/bspsmp.c
> endif
> diff --git a/c/src/lib/libbsp/riscv/riscv/configure.ac b/c/src/lib/libbsp/riscv/riscv/configure.ac
> index b01dee2..e6473ccd 100644
> --- a/c/src/lib/libbsp/riscv/riscv/configure.ac
> +++ b/c/src/lib/libbsp/riscv/riscv/configure.ac
> @@ -36,9 +36,12 @@ RTEMS_BSPOPTS_HELP([RISCV_MAXIMUM_EXTERNAL_INTERRUPTS],[maximum number of extern
> RTEMS_BSPOPTS_SET([RISCV_ENABLE_HTIF_SUPPORT],[*],[])
> RTEMS_BSPOPTS_HELP([RISCV_ENABLE_HTIF_SUPPORT],[enables the HTIF support if defined to a non-zero value, otherwise it is disabled (disabled by default)])
> -RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[2])
> +RTEMS_BSPOPTS_SET([RISCV_CONSOLE_MAX_NS16550_DEVICES],[*],[])
Can you please leave this as 2 as our default QEMU platform relies on it?
> RTEMS_BSPOPTS_HELP([RISCV_CONSOLE_MAX_NS16550_DEVICES],[maximum number of NS16550 devices supported by the console driver (2 by default)])
> +RTEMS_BSPOPTS_SET([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[*],[1])
This needs to be [] to be disabled by default.
> +RTEMS_BSPOPTS_HELP([RISCV_ENABLE_FRDME310ARTY_SUPPORT],[enables support sifive Freedom E310 Arty board if defined to a non-zero value,otherwise it is disabled (disabled by default)])
> RTEMS_BSP_CLEANUP_OPTIONS
> case "${RTEMS_BSP}" in
> @@ -59,7 +62,7 @@ AC_ARG_VAR([$1],[$2])dnl
> RISCV_LINKCMD([RISCV_RAM_REGION_BEGIN],[begin of the RAM region for linker command file (default is 0x70000000 for 64-bit with -mcmodel=medlow and 0x80000000 for all other)],[${RISCV_RAM_REGION_BEGIN_DEFAULT}])
> -RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 64MiB)],[0x04000000])
> +RISCV_LINKCMD([RISCV_RAM_REGION_SIZE],[size of the RAM region for linker command file (default 256MiB)],[0x10000000])
Is there a good reason to change the memory size to 256MiB? Does
Freedom have this amount of memory? Do any tests/applications fail
with only 64MiB and not 256MiB?
> AC_CONFIG_FILES([
> Makefile
> 2.7.4
> devel mailing list
> devel at rtems.org
