sqlite build failure on BSP bsets
Gedare Bloom
gedare at rtems.org
Thu Apr 2 20:00:17 UTC 2020
On Thu, Apr 2, 2020 at 1:57 PM Jonathan Brandmeyer
<jbrandmeyer at planetiq.com> wrote:
> On Thu, Apr 2, 2020 at 1:43 PM Joel Sherrill <joel at rtems.org> wrote:
>> Thank you for the detailed feedback.
>> I am torn between:
>> + deleting sqlite from the BSP bset's
>> + requiring tclsh to be installed
>> + updating the RSB recipe for sqlite.
>> Given the desire to get a release out the door. I am prone to the first
>> option with a ticket for 5.2 to update sqlite and re-add it to the BSP
>> bsets.
> I can see where you're coming from. That said, even having an obsolete bset in the RSB served as a helpful hint that it worked for someone once upon a time.
>> Since you obviously use sqlite, if you could tackle updating the RSB
>> recipe, that would be great and avoid having to do something expedient
>> to get the release out the door.
> I can make a pass at it. What's the quickest way to iterate on a BSET's rules? I'd rather not have to wait on GCC and crew to rebuild when I get it wrong the first time.
Use --dry-run option
>> Chris will eventually wake up in Sydney and chime in. :)
> Jonathan Brandmeyer
> devel mailing list
> devel at rtems.org
