[PATCH v5] doc: Moving M68K BSP Content to User Manual (#3905)
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Fri Apr 3 07:48:43 UTC 2020
On Fri, Apr 3, 2020 at 3:24 AM Chris Johns <chrisj at rtems.org> wrote:
> Pushed and again thank you for doing this.
> Chris
> All thanks to such enthusiastic and passionate mentors. Perhaps this task
is giving me more
chills than Netflix :)
Mritunjay
On 2020-04-02 19:49, Mritunjay wrote:
> > Fixed trailing spaces.
> > user/bsps/bsps-m68k.rst | 190 +++++++++++++++++++++++++++++++++++++++-
> > 1 file changed, 188 insertions(+), 2 deletions(-)
> > diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> > index 60882fb..bdb516b 100644
> > --- a/user/bsps/bsps-m68k.rst
> > +++ b/user/bsps/bsps-m68k.rst
> > @@ -53,7 +53,19 @@ TODO.
> > mcf5329
> > -TODO.
> > +Overview
> > +This BSP is heavily based on the MCF5235 BSP. The MCF5329EVB is a
> Motorola
> > +evaluation board (Zoom) with a LogicPD MCF5329-10 SODIMM-144 card. The
> > +development kit features the MCF5329 based Fire Engine, as well as a
> plug-in
> > +system-on-module containing 32 MB of DDR-SDRAM. The board also includes
> 2 MB of
> > +boot flash, 16 MB of NAND flash, a core frequency of 240MHz, an onboard
> 800x600
> > +LCD controller, FEC, USB, uarts, CAN bus, QSPI, I2C, and 10/100
> Ethernet.
> > +You can find the link to MCF5329 Reference Manual below:
> > +* `MCF5329 Reference Manual <
> https://www.nxp.com/docs/en/reference-manual/MCF5329RM.pdf>`_
> > mrm332
> > @@ -73,7 +85,181 @@ TODO.
> > mvme162
> > -TODO.
> > +Overview
> > +The MVME162 family provides OEMs and solution developers an ideal
> platform for
> > +embedded monitoring and control apllications it allows an OEM to
> minimize
> > +engineering expenses while integrating value-added hardware and software
> > +applications onto an off-the-shelf product. In order to provide the
> wide range
> > +of solutions, the MVME162 allows a variety of MPU, memory, and interface
> > +options such as floating-point, Ethernet, SCSI, and VME. The result is a
> > +variation of the MVME162 which most closely fits the application
> requirement.
> > +There are a large number of model variations on this board. This was
> the first
> > +user submitted BSP and continues to be a fairly popular simply because
> at one
> > +point it was the highest selling VMEBus board of all time.
> > +Board Setup
> > +We will setup the RTEMS Lab Board initally to proceed further for the
> setup
> > +of TFTP transfer.
> > +The env settings are:
> > +.. code-block:: none
> > + MPU Clock Speed =25Mhz
> > + 162-Bug>env
> > + Bug or System environment [B/S] = B?
> > + Field Service Menu Enable [Y/N] = N?
> > + Remote Start Method Switch [G/M/B/N] = B?
> > + Probe System for Supported I/O Controllers [Y/N] = Y?
> > + Negate VMEbus SYSFAIL* Always [Y/N] = N?
> > + Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> > + Local SCSI Bus Negotiations Type [A/S/N] = A?
> > + Industry Pack Reset on Debugger Startup [Y/N] = Y?
> > + Ignore CFGA Block on a Hard Disk Boot [Y/N] = Y?
> > + Auto Boot Enable [Y/N] = N?
> > + Auto Boot at power-up only [Y/N] = Y?
> > + Auto Boot Controller LUN = 00?
> > + Auto Boot Device LUN = 00?
> > + Auto Boot Abort Delay = 15?
> > + Auto Boot Default String [NULL for a empty string] = ?
> > + ROM Boot Enable [Y/N] = N?
> > + ROM Boot at power-up only [Y/N] = Y?
> > + ROM Boot Enable search of VMEbus [Y/N] = N?
> > + ROM Boot Abort Delay = 0?
> > + ROM Boot Direct Starting Address = FF800000?
> > + ROM Boot Direct Ending Address = FFDFFFFC?
> > + Network Auto Boot Enable [Y/N] = N?
> > + Network Auto Boot at power-up only [Y/N] = Y?
> > + Network Auto Boot Controller LUN = 00?
> > + Network Auto Boot Device LUN = 00?
> > + Network Auto Boot Abort Delay = 5?
> > + Network Auto Boot Configuration Parameters Pointer (NVRAM) =
> FFE0FF00?
> > + Memory Search Starting Address = 00000000?
> > + Memory Search Ending Address = 01000000?
> > + Memory Search Increment Size = 00010000?
> > + Memory Search Delay Enable [Y/N] = N?
> > + Memory Search Delay Address = FFFFD20F?
> > + Memory Size Enable [Y/N] = Y?
> > + Memory Size Starting Address = 00000000?
> > + Memory Size Ending Address = 01000000?
> > + Base Address of Dynamic Memory = 00000000?
> > + Size of Parity Memory = 00000000?
> > + Size of ECC Memory Board #0 = 01000000?
> > + Size of ECC Memory Board #1 = 00000000?
> > + Base Address of Static Memory = FFE00000?
> > + Size of Static Memory = 00020000?
> > + Slave Enable #1 [Y/N] = Y?
> > + Slave Starting Address #1 = 00000000?
> > + Slave Ending Address #1 = 00FFFFFF?
> > + Slave Address Translation Address #1 = 00000000?
> > + Slave Address Translation Select #1 = 00000000?
> > + Slave Control #1 = 03FF?
> > + Slave Enable #2 [Y/N] = N?
> > + Slave Starting Address #2 = 00000000?
> > + Slave Ending Address #2 = 00000000?
> > + Slave Address Translation Address #2 = 00000000?
> > + Slave Address Translation Select #2 = 00000000?
> > + Slave Control #2 = 0000?
> > + Master Enable #1 [Y/N] = Y?
> > + Master Starting Address #1 = 01000000?
> > + Master Ending Address #1 = EFFFFFFF?
> > + Master Control #1 = 0D?
> > + Master Enable #2 [Y/N] = N?
> > + Master Starting Address #2 = 00000000?
> > + Master Ending Address #2 = 00000000?
> > + Master Control #2 = 00?
> > + Master Enable #3 [Y/N] = N?
> > + Master Starting Address #3 = 00000000?
> > + Master Ending Address #3 = 00000000?
> > + Master Control #3 = 00?
> > + Master Enable #4 [Y/N] = N?
> > + Master Starting Address #4 = 00000000?
> > + Master Ending Address #4 = 00000000?
> > + Master Address Translation Address #4 = 00000000?
> > + Master Address Translation Select #4 = 00000000?
> > + Master Control #4 = 00?
> > + Short I/O (VMEbus A16) Enable [Y/N] = Y?
> > + Short I/O (VMEbus A16) Control = 01?
> > + F-Page (VMEbus A24) Enable [Y/N] = Y?
> > + F-Page (VMEbus A24) Control = 02?
> > + ROM Access Time Code = 03?
> > + FLASH Access Time Code = 02?
> > + MCC Vector Base = 05?
> > + VMEC2 Vector Base #1 = 06?
> > + VMEC2 Vector Base #2 = 07?
> > + VMEC2 GCSR Group Base Address = D2?
> > + VMEC2 GCSR Board Base Address = 00?
> > + VMEbus Global Time Out Code = 01?
> > + Local Bus Time Out Code = 02?
> > + VMEbus Access Time Out Code = 02?
> > + IP A Base Address = 00000000?
> > + IP B Base Address = 00000000?
> > + IP C Base Address = 00000000?
> > + IP D Base Address = 00000000?
> > + IP D/C/B/A Memory Size = 00000000?
> > + IP D/C/B/A General Control = 00000000?
> > + IP D/C/B/A Interrupt 0 Control = 00000000?
> > + IP D/C/B/A Interrupt 1 Control = 00000000?
> > +To setup the Server/Client IP Addresses for the TFTP Transfer, we will
> use the
> > +NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command
> commonly
> > +used to setup the Server/Client IP Addresses for the TFTP Transfer.
> > +The NIOT command goes something like this:
> > + 162-Bug>niot
> > + Controller LUN =00?
> > + Device LUN =00?
> > + Node Control Memory Address =FFE10000?
> > + Client IP Address =192.168.1.245?
> > + Server IP Address =192.168.1.92?
> > + Subnet IP Address Mask =255.255.255.0?
> > + Broadcast IP Address =192.168.1.255?
> > + Gateway IP Address =0.0.0.0?
> > + Boot File Name ("NULL" for None) =/mvme162.img?
> > + Argument File Name ("NULL" for None) =?
> > + Boot File Load Address =00020000?
> > + Boot File Execution Address =00020000?
> > + Boot File Execution Delay =00000000?
> > + Boot File Length =00000000?
> > + Boot File Byte Offset =00000000?
> > + BOOTP/RARP Request Retry =00?
> > + TFTP/ARP Request Retry =00?
> > + Trace Character Buffer Address =00000000?
> > + BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> > + BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
> > +Downloading and Executing
> > +Download from the TFTP server using the 162-Bug's "NBO"
> > +(Network Boot Operating System) command:
> > + 162-Bug>nbo
> > + Network Booting from: VME162, Controller 0, Device 0
> > + Loading: /mvme162.img
> > + Client IP Address = 192.168.1.245
> > + Server IP Address = 192.168.1.92
> > + Gateway IP Address = 0.0.0.0
> > + Subnet IP Address Mask = 255.255.255.0
> > + Boot File Name = /mvme162.img
> > + Argument File Name =
> > + Network Boot File load in progress... To abort hit <BREAK>
> > + Bytes Received =&356528, Bytes Loaded =&356528
> > + Bytes/Second =&89132, Elapsed Time =4 Second(s)
> > +The program will automatically run when download is complete.
> > mvme167
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200403/4a509f27/attachment.html>
