[PATCH rtems-docs] user/bsps: Moving all other M68K BSPs from Wiki to User
Mritunjay Sharma mritunjaysharma394 at gmail.com
Mon Apr 6 21:32:54 UTC 2020
Hi all,
After this patch, you can safely remove all the Motorola M68xxx and
Coldfire BSPs
from the wiki except probably mvme162lx (It was not mentioned in the
user/bsps/bsps-m68k.rst , does it also has to be added?)
Thanks
-Mritunjay
On Tue, Apr 7, 2020 at 2:56 AM Mritunjay <mritunjaysharma394 at gmail.com>
wrote:
>  user/bsps/bsps-m68k.rst | 829 +++++++++++++++++++++++++++++++++++++++-
>  1 file changed, 818 insertions(+), 11 deletions(-)
> diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> index bdb516b..a035137 100644
> --- a/user/bsps/bsps-m68k.rst
> +++ b/user/bsps/bsps-m68k.rst
> @@ -8,7 +8,22 @@ m68k (Motorola 68000 / ColdFire)
>  av5282
> -TODO.
> +Overview
> +The Freescale ColdFire? Evaluation Board provides a reference platform for
> +engineers to develop a variety of embedded processing applications
> requiring
> +networking connectivity. The board hosts all the necessary hardware and
> firmware
> +needed to implement a networked interface using the Freescale MCF5282
> processor.
> +By including all the necessary physical layer (PHY) devices, memory and
> external
> +expansion capability the designer can implement any bridging application
> that
> +requires 10/100 Ethernet, UARTs, CAN interface, QSPI, analog inputs and/or
> +memory-mapped peripherals. The AvBus expansion connector allows for user
> defined
> +add-on hardware, or can be utilized with over 20 compatible evaluation and
> +development boards from Avnet Electronics Marketing. These boards can be
> mixed
> +and matched to provide a variety of additional hardware and firmware
> capability
> +from PCI and PCI-X connectivity, RapidIO, memory and communications and
> +video/audio functions.
>  csb360
> @@ -18,27 +33,372 @@ TODO.
>  gen68340
> -TODO.
> +Overview
> +The MC68340 is a high-performance 32-bit integrated processor with direct
> memory
> +access (DMA), combining an enhanced M68000-compatible processor, 32-bit
> DMA, and
> +other peripheral subsystems on a single integrated circuit. The MC68340
> CPU32
> +delivers 32-bit CISC processor performance from a lower cost 16-bit memory
> +system. The combination of peripherals offered in the MC68340 can be
> found in a
> +diverse range of microprocessor-based systems.Systems requiring very
> high-speed
> +block transfers of data can benefit from the MC68340.
> +Organization
> +The M68300 family of integrated processors and controllers is built on an
> M68000
> +core processor, an on-chip bus, and a selection of intelligent peripherals
> +appropriate for a set of applications. The CPU32 is a powerful central
> +processor with nearly the performance of the MC68020. A system integration
> +module incorporates the external bus interface and many of the smaller
> circuits
> +that typically surround a microprocessor for address decoding, wait-state
> +insertion, interrupt prioritization, clock generation, arbitration,
> watchdog
> +timing, and power-on reset timing. Each member of the M68300 family is
> +distinguished by its selection of peripherals. Peripherals are chosen to
> address
> +specific applications but are often useful in a wide variety of
> applications.
> +The peripherals may be highly sophisticated timing or protocol engines
> that have
> +their own processors, or they may be more traditional peripheral
> functions, such
> +as UARTs and timers. Since each major function is designed in a standalone
> +module, each module might be found in many different M68300 family parts.
> +Architecture
> +The CPU32 is upward source- and object-code compatible with the MC68000
> and
> +MC68010. It is downward source- and object-code compatible with the
> MC68020.
> +Within the M68000 family, architectural differences are limited to the
> +supervisory operating state. User state programs can be executed
> unchanged on
> +upward-compatible devices. The major CPU32 features are as follows:
> +* 32-Bit Internal Data Path and Arithmetic Hardware
> +* 32-Bit Address Bus Supported by 32-Bit Calculations
> +* Rich Instruction Set
> +* Eight 32-Bit General-Purpose Data Registers
> +* Seven 32-Bit General-Purpose Address Registers
> +* Separate User and Supervisor Stack Pointers
> +* Separate User and Supervisor State Address Spaces
> +* Separate Program and Data Address Spaces
> +* Many Data Types
> +* Flexible Addressing Modes
> +* Full Interrupt Processing
> +* Expansion Capability
> +The CPU32 is an M68000 family processor specially designed for use as a
> 32-bit
> +core processor and for operation over the intermodule bus (IMB).
> Designers used
> +the MC68020 as a model and included advances of the later M68000 family
> +processors, resulting in an instruction execution performance of 4 MIPS
> +(VAX-equivalent) at 25.16 MHz. The powerful and flexible M68000
> architecture is
> +the basis of the CPU32. MC68000 (including the MC68HC000 and the
> MC68EC000) and
> +MC68010 user programs will run unmodified on the CPU32. The programmer
> can use
> +any of the eight 32-bit data registers for fast manipulation of data and
> any of
> +the eight 32-bit address registers for indexing data in memory. The CPU32
> can
> +operate on data types of single bits, binary-coded decimal (BCD)digits,
> and 8,
> +16, and 32 bits. Peripherals and data in memory can reside anywhere in the
> +4-Gbyte linear address space. A supervisor operating mode protects
> system-level
> +resources from the more restricted user mode, allowing a true virtual
> +environment to be developed.
> +Physical
> +The MC68340 is available as 0–16.78 MHz and 0–25.16 MHz, 0°C to +70°C and
> +-40°C to +85°C, and 5.0 V ±5% and 3.3 V ±0.3 supply voltages (reduced
> +frequencies at 3.3 V). Thirty-two power and ground leads minimize ground
> bounce
> +and ensure proper isolation of different sections of the chip, including
> the
> +clock oscillator. A 144 pins are used for signals and power. The MC68340
> is
> +available in a gull-wing ceramic quad flat pack (CQFP) with 25.6-mil
> (0.001-in)
> +lead spacing or a 15 ´ 15 plastic pin grid array (PPGA) with 0.1-in pin
> spacing.
> +System Integration Module
> +The MC68340 SIM40 provides the external bus interface for both the CPU32
> and the
> +DMA. It also eliminates much of the glue logic that typically supports the
> +microprocessor and its interface with the peripheral and memory system.
> The
> +SIM40 provides programmable circuits to perform address decoding and chip
> +selects, wait-state insertion, interrupt handling, clock generation, bus
> +arbitration, watchdog timing, discrete I/O, and power-on reset timing. A
> +boundary scan test capability is also provided.
> +External Bus Interface
> +The external bus interface (EBI) handles thetransfer of information
> between the
> +internal CPU32 or DMA controller and memory, peripherals, or other
> processing
> +elements in the external address space. Based on the MC68030 bus, the
> external
> +bus provides up to 32 address lines and 16 data lines. Address extensions
> +identify each bus cycle as CPU32 or DMA initiated, supervisor or user
> privilege
> +level, and instruction or data access. The data bus allows dynamic sizing
> for
> +8- or 16-bit bus accesses (plus 32 bits for DMA). Synchronous transfers
> from the
> +CPU32 or the DMA can be made in as little as two clock cycles.
> +Clock Synthesizer
> +The clock synthesizer generates the clock signals used by all internal
> +operations as well as a clock output used by external devices. The clock
> +synthesizer can operate with an inexpensive 32768-Hz watch crystal or an
> +external oscillator for reference, using an internal phase-locked loop and
> +voltage-controlled oscillator. At any time, software can select
> +clock frequencies from 131 kHz to 16.78 MHz or 25.16 MHz, favoring either
> low
> +power consumption or high performance. Alternately, an external clock can
> drive
> +the clock signal directly at the operating frequency. With its fully
> static
> +HCMOS design, it is possible to completely stop the system clock without
> losing
> +the contents of the internal registers.
>  gen68360
> -TODO.
> +Overview
> +The MC68360 Quad Integrated Communication Controller (QUICC™) is a
> versatile
> +one-chip integrated microprocessor and peripheral combination family that
> can be
> +used in a variety of controller applications.
> +The MC68360 particularly excels in communications activities. The QUICC
> can be
> +described as a next-generation MC68302, with higher performance in all
> areas of
> +device operation, increased flexibility, and higher integration. The term
> "quad"
> +comes from the fact that there are four serial communications controllers
> +(SCCs) on the device. However, there are actually seven serial channels
> which
> +include four SCCs, two serial management controllers (SMCs), and one
> serial
> +peripheral interface (SPI).
> +Features
> +CPU + Processor (8.3 MIPS at 33MHz)
> +* 32-bit version of the CPU32 core (fully compatible with CPU32)
> +* Up to 32-bit Data Bus (Dynamic Bus Sizing for 8- and 16-Bits) + 32
> Address
> +Lines
> +* Complete static design (0-33 MHz Operation)
> +* Slave mode to disable CPU32+ (allows use with external processors)
> +       * Multiple QUICCs can share one system bus (one master)
> +       * MC68040 companion mode allows QUICC to be an MC68040 companion
> chip and
> +       intelligent peripheral (29 MIPS at 33 MHz)
> +       * All QUICC features available in slave mode
> +* Memory controller (eight banks)
> +       * Contains complete Dynamic Random-Access Memory (DRAM) controller
> +       * Glueless interface to DRAM Single In-Line Memory Modules
> (SIMMs), Static
> +       Random-Access Memory (SRAM),
> +       * Electrically Programmable Read-Only Memory (EPROM), Flash EPROM,
> etc.
> +       * Boot chip select available at Reset (options for 8-, 16-, or
> 32-bit
> +       memory)
> +       * Special features for MC68040 including Burst Mode
> +* Four general-purpose timers
> +       * Four 16-bit timers or two 32-bit timers
> +* Two Independent DMAs (IDMAs)
> +* System Integration Module (SIM60)
> +       * Bus monitor
> +       * Breakpoint logic provides on-chip H/W breakpoints
> +       * Spurious interrupt monitor
> +       * External masters may use on-chip features such as chip selects
> +* Periodic interrupt timer
> +* On-chip bus arbitration with no overhead for internal masters
> +* Low power stop mode
> +* IEEE 1149.1 Test Access Port
> +* RISC Communications Processor Module (CPM)
> +* Many new commands (e.g., Graceful Stop Transmit, Close RxBD)
> +* Supports continuos mode transmission and reception on all serial
> channels
> +* 2.5 kbytes of dual-port RAM
> +* 14 Serial DMA (SDMA) channels
> +* Three parallel I/O registers with open-drain capability
> +* Each serial channel can have its own Pins (NMSI mode)
> +* Four baud rate generators
> +* Four SCCs
> +* Ethernet/IEEE 802.3 optional on SCCs 1-2 at 25 MHz, SCCs 1-3 at 33 MHz
> +* HDLC Bus
> +* Universal Asynchronous Receiver Transmitter (UART)
> +* Synchronous UART
> +* Asynchronous HDLC (RAM microcode option) to support PPP (Point to Point
> +Protocol)
> +* Two SMCs
> +* UART
> +* Transparent
> +* General Circuit Interface (GCI) controller
> +* One SPI
> +* Time-Slot assignor
> +* Supports two TDM channels
> +* Parallel Interface Port (supports fast connection between QUICCs)
> +Host controlled Board Setup
> +Required equipment:
> +* +5 V 5 A power supply
> +* +12 V 1 A power supply (optional)
> +* Host Computer, one of the following:
> +* Sun - 4 (SBus interface)
> +* IBM-PC/XT/AT
> +* ADI board - compatible with the host computer
> +* 37 line flat cable with female 37 pin D-type connectors on each end
> +Stand alone Board Setup
> +* VT100 compatible terminal
> +* RS-232 cable with male 9 pin D-type connector on the QUADS side.
> +Debugging BDM controller
> +The slave QUICC enables the M68360QUADS to become BDM controller to
> control
> +other QUICC devices on the user application. The BDM feature enables the
> user to
> +download code and provides hardware and software debugging capability of
> the
> +user application. The 8 pin BDM connector P9 utilizes five pins of the
> slave
> +QUICC port B. These pins are configured as general purpose I/O pins.
> +Debugging Ethernet controller
> +The slave QUICC provides Ethernet port for the M68360QUADS by connecting
> SCC1 to
> +Motorola MC68160 EEST device (U35 in sheet 10). The MC68160 provides two
> +Ethernet interfaces, twisted-pair on P8 and AUI on P7. The LEDs LD3-LD8
> are
> +controlled by the EEST, and they provide indications about the status of
> the
> +Ethernet ports activity. The signals between the slave QUICC and the
> MC68160
> +appear on connector P10 for debugging purposes. P10 is a set of wire
> holes.
> +The socket U24 is installed for internal factory testing only. For proper
> +operation of the EEST, this socket must be empty.
> +References
> +* `User Manual <
> https://www.nxp.com/docs/en/reference-manual/MC68360UM.pdf>`_
>  genmcf548x
> -TODO.
> +Overview
> +The MCF548x family is based on the ColdFire V4e core, a complex which
> comprises
> +the ColdFire V4 central processor unit (CPU), an enhanced
> multiply-accumulate
> +unit (EMAC), a memory management unit (MMU), a double-precision floating
> point
> +unit (FPU) conforming to standard IEEE-754, and controllers for caches
> and local
> +data memories. The MCF548x family is capable of performing at an operating
> +frequency of up to 200 MHz or 308 MIPS.
> +To maximize throughput, the MCF548x family incorporates three independent
> +external bus interfaces:
> +* The general-purpose local bus (FlexBus) is used for system boot
> memories and
> +simple peripherals and has up to six chip selects.
> +* Program code and data can be stored in SDRAM connected to a dedicated
> 32-bit
> +double data rate (DDR) bus that can run at up to one-half of the CPU core
> +frequency. The glueless DDR SDRAM controller handles all address
> multiplexing,
> +input and output strobe timing, and memory bus clock generation.
> +* A 32-bit PCI bus compliant with the version 2.2 specification and
> running at
> +a typical frequency of 25 MHz or 50 MHz supports peripherals that require
> high
> +bandwidth, the ability to arbitrate for bus mastership, and access to
> internal
> +MCF548x memory resources.
> +References
> + * `User Manual <
> https://www.nxp.com/docs/en/reference-manual/MCF5485RM.pdf>`_
>  mcf5206elite
> -TODO.
> +Overview
> +The MCF5206e integrated microprocessor combines a Version 2 (V2) ColdFire®
> +processor core with several peripheral functions such as a DRAM
> controller,
> +timers, general-purpose I/O and serial interfaces, debug module, and
> system
> +integration. Designed for embedded control applications, the V2 ColdFire
> core
> +delivers enhanced performance while maintaining
> +low system costs. To speed program execution, the largeon-chip
> instruction cache
> +and SRAM provide one-cycle access to critical code and data. The MCF5206e
> +greatly reduces the time required for system design and implementation by
> +packaging common system functions on chip and providing glueless
> interfaces to 8
> +bit, 16 bit, and 32 bit DRAM, SRAM, ROM, and I/O devices.
> +The MCF5206e is an enhanced version of the MCF5206 processor, with the
> same
> +peripheral set, DMA, MAC, Hardware Divide, larger cache, and larger SRAM.
> It is
> +pin compatible with the MCF5206, with the DMA pins muxed with Timer 0
> pins.
> +References
> + * `User Manual <
>  mcf52235
> -TODO.
> +Overview
> +The MCF52235 represents a family of highly-integrated 32-bit
> microcontrollers
> +based on the V2 ColdFire microarchitecture. Featuring up to 32 Kbytes of
> +internal SRAM and 256 Kbytes of flash memory, four 32-bit timers with DMA
> +request capability, a 4-channel DMA controller, fast Ethernet controller,
> +a CAN module, an I2C™ module, 3 UARTs and a queued SPI, the MC52235
> family has
> +been designed for general-purpose industrial control applications.
> +This 32-bit device is based on the Version 2 ColdFire? core operating at a
> +frequency up to 60 MHz, offering high performance and low power
> consumption.
> +On-chip memories connected tightly to the processor core include up to 256
> +Kbytes of Flash and 32 Kbytes of static random access memory (SRAM).
> +This BSP was heavily based on the MCF5235 BSP.
> +Key features
> +* Version 2 ColdFire variable-length RISC processor core
> +* System debug support
> +* On-chip memories
> +* Power management
> +* Fast Ethernet Controller (FEC)
> +* On-chip Ethernet Transceiver (EPHY)
> +* FlexCAN 2.0B module
> +* Three universal asynchronous/synchronous receiver transmitters (UARTs)
> +* I2C module
> +* Queued serial peripheral interface (QSPI)
> +* Fast analog-to-digital converter (ADC)
> +* Four 32-bit DMA timers
> +* Four-channel general purpose timers
> +* Pulse-width modulation timer
> +* Real-Time Clock (RTC)
> +* Two periodic interrupt timers (PITs)
> +* Software watchdog timer
> +* Clock Generation Features
> +* Dual Interrupt Controllers (INTC0/INTC1)
> +* DMA controller
> +* Reset
> +* Chip integration module (CIM)
> +* General purpose I/O interface
> +* JTAG support for system level board testing
> +Board Setup
> +To setup, we will display the firmware settings using the boot monitor's
> "state"
> + command:
> +.. code-block:: none
> +       INET> state
> +       iface 0- IP addr:192.168.1.99  subnet:255.255.255.0
> gateway:192.168.1.1
> +       current tick count 4204
> +       Task wakeups:netmain: 27
> +       nettick: 2102
> +       keyboard: 2099
>  mcf5225x
> @@ -48,7 +408,35 @@ TODO.
>  mcf5235
> -TODO.
> +Overview
> +The MCF5235EVB is a Motorola evaluation board that is based on the
> Coldfire
> +MCF5235 32-bit processor. The board includes 32 Mbytes of SDRAM, 2Mbytes
> of
> +flash, the MCF5235 processor with a max core frequency of 150MHz, Ethernet
> +support, and CAN bus support. This BSP has also been tested to work with
> the
> +Coldfire MCF5270 processor with a max core frequency of 100MHz.
> +This BSP has also been tested to work with the newer Freescale M5235BCC
> +evaluation board and with the Axiom Manufacturing CMM-5235 Board.
> +The BSP provides support to run applications from both RAM when debugging
> and
> +from Flash when the application is complete.
> +Board Setup
> +Here is the setup for the Axiom M5235BCC in the RTEMS Lab:
> +       dBUG> show
> +       base: 16 baud: 19200
> +       server: 192.168.1.92 client: 192.168.1.241
> +       gateway: 192.168.1.14 netmask: 255.255.255.0
> +       filename: /mcf5235.exe filetype: ELF
> +       ethaddr: 00:20:DD:00:00:11
> +Downloading and Executing
>  mcf5329
> @@ -75,12 +463,133 @@ TODO.
>  mvme147
> -TODO.
> +Overview
> +The MVME147 is a double-high VMEmodule based on the MC68030
> microprocessor. It
> +is best utilized in a 32-bit VMEbus system with both P1 and P2
> backplanes. The
> +module has high functionality with large onboard shared RAM, serial
> ports, and
> +Centronics printer port. The module provides a SCSI bus controller with
> DMA,
> +floating-point coprocessor, tick timer, watchdog timer, and time-of-day
> +clock/calendar with battery backup, 4KB of static RAM with battery
> backup, four
> +ROM sockets, and A32/D32 VMEbus interface with system controller
> functions.
> +Key Features
> +* 16, 25, or 33.33 MHz MC68030 enhanced 32-bit microprocessor
> +* 16, 25, or 33.33 MHz MC68882 floating-point coprocessor
> +* 4, 8, 16, or 32MB of shared DRAM, with programmable parity
> +* 4K x 8 SRAM and time-of-day clock with battery backup
> +* Four 28/32-pin ROM/PROM/EPROM/EEPROM sockets, 16 bits wide
> +* A32/D32 VMEbus master/slave interface with system controller function
> +* Four EIA-232-D serial communications ports
> +* Centronics compatible printer port
> +* Two 16-bit timers and watchdog timer
> +* SCSI bus interface with DMA
> +* Ethernet transceiver interface
> +* 4-level requester, 7-level interrupter, and 7-level interrupt handler
> for
> +VMEbus
> +* On-board debugger and diagnostic firmware
> +Board Setup
> +Set jumpers on your MVME147 module. Ensure that ROM devices are properly
> +installed in the sockets. Install your MVME147 module in the chassis. Set
> +jumpers on the transition board; connect and install the transition
> board, P2
> +adapter module, and optional SCSI device cables. Connect a console
> terminal to
> +the MVME712. Connect any other optional devices or equipment you will be
> using.
> +Power up the system. Note that the debugger prompt appears. Initialize the
> +clock. Examine and/or change environmental parameters. Program the
> PCCchip and
> +VMEchip.
> +See `manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>`_ for
> further
> +information.
> +There are various ways to enter a user program into system memory for
> execution.
> +One way is to create the program using the Memory Modify (MM) command
> with the
> +assembler/disassembler option. You enter the program one source line at a
> time.
> +After each source line is entered, it is assembled and the object code
> loads
> +into memory. Refer to the MVME147 BUG 147Bug Debugging Package User's
> Manual for
> +complete details of the 147Bug Assembler/Disassembler?. Another way to
> enter a
> +program is to download an object file from a host system. The program
> must be in
> +S-record format (described in the MVME147BUG 147Bug Debugging Package
> User's
> +Manual) and may have been assembled or compiled on the host system.
> Alternately,
> +the program may have been previously created using the 147Bug MM command
> as
> +outlined above and stored to the host using the Dump (DU) command. A
> +communication link must exist between the host system and the MVME147.
> The file
> +is downloaded from the host to MVME147 memory by the Load (LO) command.
> +References
> + * `User Manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>`_
>  mvme147s
> -TODO.
> +Overview
> +The MVME 147s is extremely similar to the Mvme147. The main difference
> between
> +them is that the 147s also has only 2KB of static RAM while the 147 has
> 4KB.
> +Another small difference between them is the time-of-day clock. The
> MVME147s has
> + a Mostek MK48T02 while the MVME147 has an M48T18.
> +The MVME147S is a double-high VMEmodule and is best utilized in a 32-bit
> VMEbus
> +system with both P1 and P2 backplanes. The module has high functionality
> with
> +large onboard shared RAM, serial ports, and Centronics printer port. The
> module
> +provides a SCSI bus controller with DMA, floating-point coprocessor, tick
> timer,
> +watchdog timer, and time-of-day clock/calendar with battery backup, 2KB of
> +static RAM with battery backup, four ROM sockets, and A32/D32 VMEbus
> interface
> +with system controller functions are also provided. The MVME147S can be
> operated
> +as part of a VMEbus system with other VMEmodules such as RAM modules, CPU
> +modules, graphics modules, and analog I/O modules.
> +Board Setup
> +To select the desired configuration and ensure proper operation of the
> MVME147S
> +module, certain changes may be made before installation. These changes
> are made
> +through jumper arrangements on the headers. The module has been factory
> tested
> +and is shipped with factory-installed jumper configurations. The module is
> +operational with the factory-installed jumpers. The module is configured
> to
> +provide the system functions required for a VMEbus system. It is
> necessary to
> +make changes in the jumper arrangements for the following conditions:
> +System controller select (J3) Factory use only (J5, J6) ROM configuration
> select
> + (J1, J2) Serial port 4 clock configuration select (J8, J9)
> +See `manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf>`_ for further
> +information.
> execution.
> with the
> time.
> loads
> Manual for
> enter a
> must be in
> User's
> +Alternately, the program may have been previously created using the
> 147Bug MM
> +command as outlined above and stored to the host using the Dump (DU)
> command.
> +A communication link must exist between the host system and the MVME147.
> The
> +file is downloaded from the host to MVME147 memory by the Load (LO)
> command.
> +References
> +* `User Manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf>`_
>  mvme162
> @@ -264,9 +773,307 @@ The program will automatically run when download is
> complete.
>  mvme167
> -TODO.
> +Overview
> +The MVME167 is a double-high VMEmodule based on the MC68040
> microprocessor.The
> +MVME167 has 4/8/16/32/64 MB of parity-protected DRAM
> or4/8/16/32/64/128/256 MB
> +of ECC-protected DRAM, 8KB of static RAM and time of day clock (with
> +battery backup), Ethernet transceiver interface, four serial ports with
> +EIA-232-D interface, four tick timers, watchdog timer, four ROM sockets,
> SCSI
> +bus interface with DMA, Centronics printer port,
> A16/A24/A32/D8/D16/D32/D64
> +VMEbus master/slave interface, 128KB of static RAM (with optional battery
> +backup),and VMEbus system controller.
> +Firmware Setup
> +The mvme167 BSP by default (i.e., unless you tamper with the linkcmds) is
> linked
> +at 0x00800000 and the firmware has to be properly configured so that
> loading and
> +executing at that address is possible: # The board's RAM must be mapped
> +starting at address 0x00800000 (and not zero as may seem more natural and
> which
> +IIRC is 167Bug's default). ## Use 167Bug's 'env' command to set the 'Base
> +Address of Local Memory' to 00800000. ## Use 167Bug's 'niot' command to
> set the
> +download and execution address to 00800000. # By default, the 167Bug
> firmware
> +uses the lowest 64k block of RAM it finds for internal data and this
> conflicts
> +with RTEMS' needs. 167Bug won't allow you to download the RTEMS image to
> +0x00800000 unless you instruct 167Bug to use another area (e.g., static
> RAM) for
> +it's internal data. ## Use 167Bug's 'env' command to set both, the 'Memory
> +Search Starting Address' and 'Memory Search Ending Address' to zero.
> +The 'search' area is the address-range that is scanned by 167Bug when it
> tries
> +to find an area for it's internal data. If it finds no RAM (since
> start==end)
> +then it uses static RAM and 00800000 and up can be used by RTEMS.
> +These are the 'env' settings:
> +       MPU Clock Speed =25Mhz
> +       167-Bug>env
> +       Bug or System environment [B/S] = B?
> +       Field Service Menu Enable [Y/N] = N?
> +       Remote Start Method Switch [G/M/B/N] = B?
> +       Probe System for Supported I/O Controllers [Y/N] = Y?
> +       Negate VMEbus SYSFAIL* Always [Y/N] = N?
> +       Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> +       Local SCSI Bus Negotiations Type [A/S/N]       = A?
> +       Ignore CFGA Block on a Hard Disk Boot [Y/N]    = Y?
> +       Auto Boot Enable [Y/N]   = N?
> +       Auto Boot at power-up only [Y/N] = Y?
> +       Auto Boot Controller LUN = 00?
> +       Auto Boot Device LUN     = 00?
> +       Auto Boot Abort Delay    = 15?
> +       Auto Boot Default String [NULL for a empty string] = ?
> +       ROM Boot Enable [Y/N]            = N?
> +       ROM Boot at power-up only [Y/N]  = Y?
> +       ROM Boot Enable search of VMEbus [Y/N] = N?
> +       ROM Boot Abort Delay             = 0?
> +       ROM Boot Direct Starting Address = FF800000?
> +       ROM Boot Direct Ending Address   = FFBFFFFC?
> +       Network Auto Boot Enable [Y/N]   = N?
> +       Network Auto Boot at power-up only [Y/N] = Y?
> +       Network Auto Boot Controller LUN = 00?
> +       Network Auto Boot Device LUN     = 00?
> +       Network Auto Boot Abort Delay    = 5?
> +       Network Auto Boot Configuration Parameters Pointer (NVRAM) =
> FFFC0000?
> +       Memory Search Starting Address   = 00000000?
> +       Memory Search Ending Address     = 00000000?
> +       Memory Search Increment Size     = 00010000?
> +       Memory Search Delay Enable [Y/N] = N?
> +       Memory Search Delay Address      = FFFFCE0F?
> +       Memory Size Enable [Y/N]         = Y?
> +       Memory Size Starting Address     = 00000000?
> +       Memory Size Ending Address       = 01000000?
> +       Base Address of Local Memory     = 00800000?
> +       Size of Local Memory Board #0    = 00800000?
> +       Size of Local Memory Board #1    = 00000000?
> +       Slave Enable #1 [Y/N] = Y?
> +       Slave Starting Address #1 = 00000000?
> +       Slave Ending Address #1   = 007FFFFF?
> +       Slave Address Translation Address #1 = 00000000?
> +       Slave Address Translation Select #1  = FF800000?
> +       Slave Control #1 = 00FF?
> +       Slave Enable #2 [Y/N] = N?
> +       Slave Starting Address #2 = FFE00000?
> +       Slave Ending Address #2   = FFE1FFFF?
> +       Slave Address Translation Address #2 = 00000000?
> +       Slave Address Translation Select #2  = 00000000?
> +       Slave Control #2 = 01EF?
> +       Master Enable #1 [Y/N] = Y?
> +       Master Starting Address #1 = 01000000?
> +       Master Ending Address #1   = EFFFFFFF?
> +       Master Control #1 = 0D?
> +       Master Enable #2 [Y/N] = N?
> +       Master Starting Address #2 = 00000000?
> +       Master Ending Address #2   = 00000000?
> +       Master Control #2 = 00?
> +       Master Enable #3 [Y/N] = N?
> +       Master Starting Address #3 = 00800000?
> +       Master Ending Address #3   = 00FFFFFF?
> +       Master Control #3 = 3D?
> +       Master Enable #4 [Y/N] = N?
> +       Master Starting Address #4 = 00000000?
> +       Master Ending Address #4   = 00000000?
> +       Master Address Translation Address #4 = 00000000?
> +       Master Address Translation Select #4  = 00000000?
> +       Master Control #4 = 00?
> +       Short I/O (VMEbus A16) Enable [Y/N] = Y?
> +       Short I/O (VMEbus A16) Control      = 01?
> +       F-Page (VMEbus A24) Enable [Y/N]    = Y?
> +       F-Page (VMEbus A24) Control         = 02?
> +       ROM Speed Bank A Code         = 05?
> +       ROM Speed Bank B Code         = 05?
> +       Static RAM Speed Code         = 01?
> +       PCC2 Vector Base              = 05?
> +       VMEC2 Vector Base #1          = 06?
> +       VMEC2 Vector Base #2          = 07?
> +       VMEC2 GCSR Group Base Address = CC?
> +       VMEC2 GCSR Board Base Address = 00?
> +       VMEbus Global Time Out Code   = 01?
> +       Local Bus Time Out Code       = 00?
> +       VMEbus Access Time Out Code   = 02?
> +       167-Bug>
> +NIOT (Network I/O Teach) is a 167-Bug's debugger command commonly
> +used to setup the Server/Client IP Addresses for the TFTP Transfer.
> +The NIOT command goes something like this:
> +       167-Bug>niot
> +       Controller LUN =00?
> +       Device LUN     =00?
> +       Node Control Memory Address =FFE10000?
> +       Client IP Address      =0.0.0.0?
> +       Server IP Address      =0.0.0.0?
> +       Subnet IP Address Mask =0.0.0.0?
> +       Broadcast IP Address   =0.0.0.0?
> +       Gateway IP Address     =0.0.0.0?
> +       Boot File Name ("NULL" for None)     =?
> +       Argument File Name ("NULL" for None) =?
> +       Boot File Load Address         =00800000?
> +       Boot File Execution Address    =00800000?
> +       Boot File Execution Delay      =00000000?
> +       Boot File Length               =00000000?
> +       Boot File Byte Offset          =00000000?
> +       BOOTP/RARP Request Retry       =00?
> +       TFTP/ARP Request Retry         =00?
> +       Trace Character Buffer Address =00000000?
> +       BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> +       BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
> +       167-Bug>
> +RTEMS Lab Board Setup
> +The firmware setup instructions above are true for the RTEMS Lab board
> except
> +for the memory search addresses. Set these as follows:
> +       Memory Search Starting Address   = FFE00000?
> +       Memory Search Ending Address     = FFE10000?
> +These are the RTEMS Lab board settings:
> +       167-Bug>env
> +       Auto Boot Default String [Y(NULL String)/(String)] = ?
> +       Network Auto Boot at power-up only [Y/N] = N?
> FFFC0000?
> +       Size of Local Memory Board #0    = 01000000?
> +       Slave Ending Address #2   = FFE10000?
> +       Master Control #3 = 30?
> +       167-Bug>niot
> +       Device LUN     =00?
> +       Subnet IP Address Mask =255.255.255.0?
> +       Broadcast IP Address   =255.255.255.255?
> +       BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =N?
> +References
> +* `User Manual <
> https://prep.fnal.gov/catalog/hardware_info/motorola/mvme167_d3.pdf>`_
>  uC5282
> -TODO.
> +Overview
> +The uC5282 is a compact, embedded microprocessor module ideal for
> networked
> +control and communication applications. The device is available in a
> standard
> +144pin soDIMM edge connector format to allow fast integration into
> products.
> +The module is based on the Freescale® ColdFire® MCF5282 microprocessor and
> +includes all required system memory and physical terminations to enable
> most
> +applications without the need for external circuitry. The uC5282 features
> +Ethernet, CAN and serial communications systems as well as standard
> peripheral
> +device connectivity using I2C, QSPI or data/address logic.
> +References
> +* `User Manual <
> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200407/f1a90000/attachment-0001.html>
