[PATCH rtems-docs] user/bsps: Moving all other M68K BSPs from Wiki to User
Tue Apr 7 06:27:35 UTC 2020
Is there something happening that is resulting in me seeing these as
threaded to the previous patch set?
Thanks
On 2020-04-07 07:32, Mritunjay Sharma wrote:
> Hi all,
> After this patch, you can safely remove all the Motorola M68xxx and
> Coldfire BSPs
> from the wiki except probably mvme162lx (It was not mentioned in the
> user/bsps/bsps-m68k.rst , does it also has to be added?)
> Thanks
> -Mritunjay
> On Tue, Apr 7, 2020 at 2:56 AM Mritunjay <mritunjaysharma394 at gmail.com
> <mailto:mritunjaysharma394 at gmail.com>> wrote:
>       user/bsps/bsps-m68k.rst | 829 +++++++++++++++++++++++++++++++++++++++-
>       1 file changed, 818 insertions(+), 11 deletions(-)
>     diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
>     index bdb516b..a035137 100644
>     --- a/user/bsps/bsps-m68k.rst
>     +++ b/user/bsps/bsps-m68k.rst
>     @@ -8,7 +8,22 @@ m68k (Motorola 68000 / ColdFire)
>       av5282
>     -TODO.
>     +Overview
>     +The Freescale ColdFire? Evaluation Board provides a reference
>     platform for
>     +engineers to develop a variety of embedded processing applications
>     requiring
>     +networking connectivity. The board hosts all the necessary hardware
>     and firmware
>     +needed to implement a networked interface using the Freescale
>     MCF5282 processor.
>     +By including all the necessary physical layer (PHY) devices, memory
>     and external
>     +expansion capability the designer can implement any bridging
>     application that
>     +requires 10/100 Ethernet, UARTs, CAN interface, QSPI, analog inputs
>     and/or
>     +memory-mapped peripherals. The AvBus expansion connector allows for
>     user defined
>     +add-on hardware, or can be utilized with over 20 compatible
>     evaluation and
>     +development boards from Avnet Electronics Marketing. These boards
>     can be mixed
>     +and matched to provide a variety of additional hardware and
>     firmware capability
>     +from PCI and PCI-X connectivity, RapidIO, memory and communications and
>     +video/audio functions.
>       csb360
>     @@ -18,27 +33,372 @@ TODO.
>       gen68340
>     -TODO.
>     +Overview
>     +The MC68340 is a high-performance 32-bit integrated processor with
>     direct memory
>     +access (DMA), combining an enhanced M68000-compatible processor,
>     32-bit DMA, and
>     +other peripheral subsystems on a single integrated circuit. The
>     MC68340 CPU32
>     +delivers 32-bit CISC processor performance from a lower cost 16-bit
>     memory
>     +system. The combination of peripherals offered in the MC68340 can
>     be found in a
>     +diverse range of microprocessor-based systems.Systems requiring
>     very high-speed
>     +block transfers of data can benefit from the MC68340.
>     +Organization
>     +The M68300 family of integrated processors and controllers is built
>     on an M68000
>     +core processor, an on-chip bus, and a selection of intelligent
>     peripherals
>     +appropriate for a set of applications. The CPU32 is a powerful central
>     +processor with nearly the performance of the MC68020. A system
>     integration
>     +module incorporates the external bus interface and many of the
>     smaller circuits
>     +that typically surround a microprocessor for address decoding,
>     wait-state
>     +insertion, interrupt prioritization, clock generation, arbitration,
>     watchdog
>     +timing, and power-on reset timing. Each member of the M68300 family is
>     +distinguished by its selection of peripherals. Peripherals are
>     chosen to address
>     +specific applications but are often useful in a wide variety of
>     applications.
>     +The peripherals may be highly sophisticated timing or protocol
>     engines that have
>     +their own processors, or they may be more traditional peripheral
>     functions, such
>     +as UARTs and timers. Since each major function is designed in a
>     standalone
>     +module, each module might be found in many different M68300 family
>     parts.
>     +Architecture
>     +The CPU32 is upward source- and object-code compatible with the
>     MC68000 and
>     +MC68010. It is downward source- and object-code compatible with the
>     MC68020.
>     +Within the M68000 family, architectural differences are limited to the
>     +supervisory operating state. User state programs can be executed
>     unchanged on
>     +upward-compatible devices. The major CPU32 features are as follows:
>     +* 32-Bit Internal Data Path and Arithmetic Hardware
>     +* 32-Bit Address Bus Supported by 32-Bit Calculations
>     +* Rich Instruction Set
>     +* Eight 32-Bit General-Purpose Data Registers
>     +* Seven 32-Bit General-Purpose Address Registers
>     +* Separate User and Supervisor Stack Pointers
>     +* Separate User and Supervisor State Address Spaces
>     +* Separate Program and Data Address Spaces
>     +* Many Data Types
>     +* Flexible Addressing Modes
>     +* Full Interrupt Processing
>     +* Expansion Capability
>     +The CPU32 is an M68000 family processor specially designed for use
>     as a 32-bit
>     +core processor and for operation over the intermodule bus (IMB).
>     Designers used
>     +the MC68020 as a model and included advances of the later M68000 family
>     +processors, resulting in an instruction execution performance of 4 MIPS
>     +(VAX-equivalent) at 25.16 MHz. The powerful and flexible M68000
>     architecture is
>     +the basis of the CPU32. MC68000 (including the MC68HC000 and the
>     MC68EC000) and
>     +MC68010 user programs will run unmodified on the CPU32. The
>     programmer can use
>     +any of the eight 32-bit data registers for fast manipulation of
>     data and any of
>     +the eight 32-bit address registers for indexing data in memory. The
>     CPU32 can
>     +operate on data types of single bits, binary-coded decimal
>     (BCD)digits, and 8,
>     +16, and 32 bits. Peripherals and data in memory can reside anywhere
>     in the
>     +4-Gbyte linear address space. A supervisor operating mode protects
>     system-level
>     +resources from the more restricted user mode, allowing a true virtual
>     +environment to be developed.
>     +Physical
>     +The MC68340 is available as 0–16.78 MHz and 0–25.16 MHz, 0°C to
>     +70°C and
>     +-40°C to +85°C, and 5.0 V ±5% and 3.3 V ±0.3 supply voltages (reduced
>     +frequencies at 3.3 V). Thirty-two power and ground leads minimize
>     ground bounce
>     +and ensure proper isolation of different sections of the chip,
>     including the
>     +clock oscillator. A 144 pins are used for signals and power. The
>     MC68340 is
>     +available in a gull-wing ceramic quad flat pack (CQFP) with
>     25.6-mil (0.001-in)
>     +lead spacing or a 15 ´ 15 plastic pin grid array (PPGA) with 0.1-in
>     pin spacing.
>     +System Integration Module
>     +The MC68340 SIM40 provides the external bus interface for both the
>     CPU32 and the
>     +DMA. It also eliminates much of the glue logic that typically
>     supports the
>     +microprocessor and its interface with the peripheral and memory
>     system. The
>     +SIM40 provides programmable circuits to perform address decoding
>     and chip
>     +selects, wait-state insertion, interrupt handling, clock
>     generation, bus
>     +arbitration, watchdog timing, discrete I/O, and power-on reset
>     timing. A
>     +boundary scan test capability is also provided.
>     +External Bus Interface
>     +The external bus interface (EBI) handles thetransfer of information
>     between the
>     +internal CPU32 or DMA controller and memory, peripherals, or other
>     processing
>     +elements in the external address space. Based on the MC68030 bus,
>     the external
>     +bus provides up to 32 address lines and 16 data lines. Address
>     extensions
>     +identify each bus cycle as CPU32 or DMA initiated, supervisor or
>     user privilege
>     +level, and instruction or data access. The data bus allows dynamic
>     sizing for
>     +8- or 16-bit bus accesses (plus 32 bits for DMA). Synchronous
>     transfers from the
>     +CPU32 or the DMA can be made in as little as two clock cycles.
>     +Clock Synthesizer
>     +The clock synthesizer generates the clock signals used by all internal
>     +operations as well as a clock output used by external devices. The
>     clock
>     +synthesizer can operate with an inexpensive 32768-Hz watch crystal
>     or an
>     +external oscillator for reference, using an internal phase-locked
>     loop and
>     +voltage-controlled oscillator. At any time, software can select
>     +clock frequencies from 131 kHz to 16.78 MHz or 25.16 MHz, favoring
>     either low
>     +power consumption or high performance. Alternately, an external
>     clock can drive
>     +the clock signal directly at the operating frequency. With its
>     fully static
>     +HCMOS design, it is possible to completely stop the system clock
>     without losing
>     +the contents of the internal registers.
>       gen68360
>     -TODO.
>     +Overview
>     +The MC68360 Quad Integrated Communication Controller (QUICC™) is a
>     versatile
>     +one-chip integrated microprocessor and peripheral combination
>     family that can be
>     +used in a variety of controller applications.
>     +The MC68360 particularly excels in communications activities. The
>     QUICC can be
>     +described as a next-generation MC68302, with higher performance in
>     all areas of
>     +device operation, increased flexibility, and higher integration.
>     The term "quad"
>     +comes from the fact that there are four serial communications
>     controllers
>     +(SCCs) on the device. However, there are actually seven serial
>     channels which
>     +include four SCCs, two serial management controllers (SMCs), and
>     one serial
>     +peripheral interface (SPI).
>     +Features
>     +CPU + Processor (8.3 MIPS at 33MHz)
>     +* 32-bit version of the CPU32 core (fully compatible with CPU32)
>     +* Up to 32-bit Data Bus (Dynamic Bus Sizing for 8- and 16-Bits) +
>     32 Address
>     +Lines
>     +* Complete static design (0-33 MHz Operation)
>     +* Slave mode to disable CPU32+ (allows use with external processors)
>     +       * Multiple QUICCs can share one system bus (one master)
>     +       * MC68040 companion mode allows QUICC to be an MC68040
>     companion chip and
>     +       intelligent peripheral (29 MIPS at 33 MHz)
>     +       * All QUICC features available in slave mode
>     +* Memory controller (eight banks)
>     +       * Contains complete Dynamic Random-Access Memory (DRAM)
>     controller
>     +       * Glueless interface to DRAM Single In-Line Memory Modules
>     (SIMMs), Static
>     +       Random-Access Memory (SRAM),
>     +       * Electrically Programmable Read-Only Memory (EPROM), Flash
>     EPROM, etc.
>     +       * Boot chip select available at Reset (options for 8-, 16-,
>     or 32-bit
>     +       memory)
>     +       * Special features for MC68040 including Burst Mode
>     +* Four general-purpose timers
>     +       * Four 16-bit timers or two 32-bit timers
>     +* Two Independent DMAs (IDMAs)
>     +* System Integration Module (SIM60)
>     +       * Bus monitor
>     +       * Breakpoint logic provides on-chip H/W breakpoints
>     +       * Spurious interrupt monitor
>     +       * External masters may use on-chip features such as chip selects
>     +* Periodic interrupt timer
>     +* On-chip bus arbitration with no overhead for internal masters
>     +* Low power stop mode
>     +* IEEE 1149.1 Test Access Port
>     +* RISC Communications Processor Module (CPM)
>     +* Many new commands (e.g., Graceful Stop Transmit, Close RxBD)
>     +* Supports continuos mode transmission and reception on all serial
>     channels
>     +* 2.5 kbytes of dual-port RAM
>     +* 14 Serial DMA (SDMA) channels
>     +* Three parallel I/O registers with open-drain capability
>     +* Each serial channel can have its own Pins (NMSI mode)
>     +* Four baud rate generators
>     +* Four SCCs
>     +* Ethernet/IEEE 802.3 optional on SCCs 1-2 at 25 MHz, SCCs 1-3 at 33 MHz
>     +* HDLC Bus
>     +* Universal Asynchronous Receiver Transmitter (UART)
>     +* Synchronous UART
>     +* Asynchronous HDLC (RAM microcode option) to support PPP (Point to
>     Point
>     +Protocol)
>     +* Two SMCs
>     +* UART
>     +* Transparent
>     +* General Circuit Interface (GCI) controller
>     +* One SPI
>     +* Time-Slot assignor
>     +* Supports two TDM channels
>     +* Parallel Interface Port (supports fast connection between QUICCs)
>     +Host controlled Board Setup
>     +Required equipment:
>     +* +5 V 5 A power supply
>     +* +12 V 1 A power supply (optional)
>     +* Host Computer, one of the following:
>     +* Sun - 4 (SBus interface)
>     +* IBM-PC/XT/AT
>     +* ADI board - compatible with the host computer
>     +* 37 line flat cable with female 37 pin D-type connectors on each end
>     +Stand alone Board Setup
>     +* VT100 compatible terminal
>     +* RS-232 cable with male 9 pin D-type connector on the QUADS side.
>     +Debugging BDM controller
>     +The slave QUICC enables the M68360QUADS to become BDM controller to
>     control
>     +other QUICC devices on the user application. The BDM feature
>     enables the user to
>     +download code and provides hardware and software debugging
>     capability of the
>     +user application. The 8 pin BDM connector P9 utilizes five pins of
>     the slave
>     +QUICC port B. These pins are configured as general purpose I/O pins.
>     +Debugging Ethernet controller
>     +The slave QUICC provides Ethernet port for the M68360QUADS by
>     connecting SCC1 to
>     +Motorola MC68160 EEST device (U35 in sheet 10). The MC68160
>     provides two
>     +Ethernet interfaces, twisted-pair on P8 and AUI on P7. The LEDs
>     LD3-LD8 are
>     +controlled by the EEST, and they provide indications about the
>     status of the
>     +Ethernet ports activity. The signals between the slave QUICC and
>     the MC68160
>     +appear on connector P10 for debugging purposes. P10 is a set of
>     wire holes.
>     +The socket U24 is installed for internal factory testing only. For
>     proper
>     +operation of the EEST, this socket must be empty.
>     +References
>     +* `User Manual
>     <https://www.nxp.com/docs/en/reference-manual/MC68360UM.pdf>`_
>       genmcf548x
>     -TODO.
>     +Overview
>     +The MCF548x family is based on the ColdFire V4e core, a complex
>     which comprises
>     +the ColdFire V4 central processor unit (CPU), an enhanced
>     multiply-accumulate
>     +unit (EMAC), a memory management unit (MMU), a double-precision
>     floating point
>     +unit (FPU) conforming to standard IEEE-754, and controllers for
>     caches and local
>     +data memories. The MCF548x family is capable of performing at an
>     operating
>     +frequency of up to 200 MHz or 308 MIPS.
>     +To maximize throughput, the MCF548x family incorporates three
>     independent
>     +external bus interfaces:
>     +* The general-purpose local bus (FlexBus) is used for system boot
>     memories and
>     +simple peripherals and has up to six chip selects.
>     +* Program code and data can be stored in SDRAM connected to a
>     dedicated 32-bit
>     +double data rate (DDR) bus that can run at up to one-half of the
>     CPU core
>     +frequency. The glueless DDR SDRAM controller handles all address
>     multiplexing,
>     +input and output strobe timing, and memory bus clock generation.
>     +* A 32-bit PCI bus compliant with the version 2.2 specification and
>     running at
>     +a typical frequency of 25 MHz or 50 MHz supports peripherals that
>     require high
>     +bandwidth, the ability to arbitrate for bus mastership, and access
>     to internal
>     +MCF548x memory resources.
>     +References
>     + * `User Manual
>     <https://www.nxp.com/docs/en/reference-manual/MCF5485RM.pdf>`_
>       mcf5206elite
>     -TODO.
>     +Overview
>     +The MCF5206e integrated microprocessor combines a Version 2 (V2)
>     ColdFire®
>     +processor core with several peripheral functions such as a DRAM
>     controller,
>     +timers, general-purpose I/O and serial interfaces, debug module,
>     and system
>     +integration. Designed for embedded control applications, the V2
>     ColdFire core
>     +delivers enhanced performance while maintaining
>     +low system costs. To speed program execution, the largeon-chip
>     instruction cache
>     +and SRAM provide one-cycle access to critical code and data. The
>     MCF5206e
>     +greatly reduces the time required for system design and
>     implementation by
>     +packaging common system functions on chip and providing glueless
>     interfaces to 8
>     +bit, 16 bit, and 32 bit DRAM, SRAM, ROM, and I/O devices.
>     +The MCF5206e is an enhanced version of the MCF5206 processor, with
>     the same
>     +peripheral set, DMA, MAC, Hardware Divide, larger cache, and larger
>     SRAM. It is
>     +pin compatible with the MCF5206, with the DMA pins muxed with Timer
>     0 pins.
>     +References
>     + * `User Manual
>       mcf52235
>     -TODO.
>     +Overview
>     +The MCF52235 represents a family of highly-integrated 32-bit
>     microcontrollers
>     +based on the V2 ColdFire microarchitecture. Featuring up to 32
>     Kbytes of
>     +internal SRAM and 256 Kbytes of flash memory, four 32-bit timers
>     with DMA
>     +request capability, a 4-channel DMA controller, fast Ethernet
>     controller,
>     +a CAN module, an I2C™ module, 3 UARTs and a queued SPI, the MC52235
>     family has
>     +been designed for general-purpose industrial control applications.
>     +This 32-bit device is based on the Version 2 ColdFire? core
>     operating at a
>     +frequency up to 60 MHz, offering high performance and low power
>     consumption.
>     +On-chip memories connected tightly to the processor core include up
>     to 256
>     +Kbytes of Flash and 32 Kbytes of static random access memory (SRAM).
>     +This BSP was heavily based on the MCF5235 BSP.
>     +Key features
>     +* Version 2 ColdFire variable-length RISC processor core
>     +* System debug support
>     +* On-chip memories
>     +* Power management
>     +* Fast Ethernet Controller (FEC)
>     +* On-chip Ethernet Transceiver (EPHY)
>     +* FlexCAN 2.0B module
>     +* Three universal asynchronous/synchronous receiver transmitters
>     (UARTs)
>     +* I2C module
>     +* Queued serial peripheral interface (QSPI)
>     +* Fast analog-to-digital converter (ADC)
>     +* Four 32-bit DMA timers
>     +* Four-channel general purpose timers
>     +* Pulse-width modulation timer
>     +* Real-Time Clock (RTC)
>     +* Two periodic interrupt timers (PITs)
>     +* Software watchdog timer
>     +* Clock Generation Features
>     +* Dual Interrupt Controllers (INTC0/INTC1)
>     +* DMA controller
>     +* Reset
>     +* Chip integration module (CIM)
>     +* General purpose I/O interface
>     +* JTAG support for system level board testing
>     +Board Setup
>     +To setup, we will display the firmware settings using the boot
>     monitor's "state"
>     + command:
>     +.. code-block:: none
>     +       INET> state
>     +       iface 0- IP addr:192.168.1.99  subnet:255.255.255.0
>     gateway:192.168.1.1
>     +       current tick count 4204
>     +       Task wakeups:netmain: 27
>     +       nettick: 2102
>     +       keyboard: 2099
>       mcf5225x
>     @@ -48,7 +408,35 @@ TODO.
>       mcf5235
>     -TODO.
>     +Overview
>     +The MCF5235EVB is a Motorola evaluation board that is based on the
>     Coldfire
>     +MCF5235 32-bit processor. The board includes 32 Mbytes of SDRAM,
>     2Mbytes of
>     +flash, the MCF5235 processor with a max core frequency of 150MHz,
>     Ethernet
>     +support, and CAN bus support. This BSP has also been tested to work
>     with the
>     +Coldfire MCF5270 processor with a max core frequency of 100MHz.
>     +This BSP has also been tested to work with the newer Freescale M5235BCC
>     +evaluation board and with the Axiom Manufacturing CMM-5235 Board.
>     +The BSP provides support to run applications from both RAM when
>     debugging and
>     +from Flash when the application is complete.
>     +Board Setup
>     +Here is the setup for the Axiom M5235BCC in the RTEMS Lab:
>     +       dBUG> show
>     +       base: 16 baud: 19200
>     +       server: 192.168.1.92 client: 192.168.1.241
>     +       gateway: 192.168.1.14 netmask: 255.255.255.0
>     +       filename: /mcf5235.exe filetype: ELF
>     +       ethaddr: 00:20:DD:00:00:11
>     +Downloading and Executing
>       mcf5329
>     @@ -75,12 +463,133 @@ TODO.
>       mvme147
>     -TODO.
>     +Overview
>     +The MVME147 is a double-high VMEmodule based on the MC68030
>     microprocessor. It
>     +is best utilized in a 32-bit VMEbus system with both P1 and P2
>     backplanes. The
>     +module has high functionality with large onboard shared RAM, serial
>     ports, and
>     +Centronics printer port. The module provides a SCSI bus controller
>     with DMA,
>     +floating-point coprocessor, tick timer, watchdog timer, and time-of-day
>     +clock/calendar with battery backup, 4KB of static RAM with battery
>     backup, four
>     +ROM sockets, and A32/D32 VMEbus interface with system controller
>     functions.
>     +Key Features
>     +* 16, 25, or 33.33 MHz MC68030 enhanced 32-bit microprocessor
>     +* 16, 25, or 33.33 MHz MC68882 floating-point coprocessor
>     +* 4, 8, 16, or 32MB of shared DRAM, with programmable parity
>     +* 4K x 8 SRAM and time-of-day clock with battery backup
>     +* Four 28/32-pin ROM/PROM/EPROM/EEPROM sockets, 16 bits wide
>     +* A32/D32 VMEbus master/slave interface with system controller function
>     +* Four EIA-232-D serial communications ports
>     +* Centronics compatible printer port
>     +* Two 16-bit timers and watchdog timer
>     +* SCSI bus interface with DMA
>     +* Ethernet transceiver interface
>     +* 4-level requester, 7-level interrupter, and 7-level interrupt
>     handler for
>     +VMEbus
>     +* On-board debugger and diagnostic firmware
>     +Board Setup
>     +Set jumpers on your MVME147 module. Ensure that ROM devices are
>     properly
>     +installed in the sockets. Install your MVME147 module in the
>     chassis. Set
>     +jumpers on the transition board; connect and install the transition
>     board, P2
>     +adapter module, and optional SCSI device cables. Connect a console
>     terminal to
>     +the MVME712. Connect any other optional devices or equipment you
>     will be using.
>     +Power up the system. Note that the debugger prompt appears.
>     Initialize the
>     +clock. Examine and/or change environmental parameters. Program the
>     PCCchip and
>     +VMEchip.
>     +See `manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf
>     <http://ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>>`_ for further
>     +information.
>     +There are various ways to enter a user program into system memory
>     for execution.
>     +One way is to create the program using the Memory Modify (MM)
>     command with the
>     +assembler/disassembler option. You enter the program one source
>     line at a time.
>     +After each source line is entered, it is assembled and the object
>     code loads
>     +into memory. Refer to the MVME147 BUG 147Bug Debugging Package
>     User's Manual for
>     +complete details of the 147Bug Assembler/Disassembler?. Another way
>     to enter a
>     +program is to download an object file from a host system. The
>     program must be in
>     +S-record format (described in the MVME147BUG 147Bug Debugging
>     Package User's
>     +Manual) and may have been assembled or compiled on the host system.
>     Alternately,
>     +the program may have been previously created using the 147Bug MM
>     command as
>     +outlined above and stored to the host using the Dump (DU) command. A
>     +communication link must exist between the host system and the
>     MVME147. The file
>     +is downloaded from the host to MVME147 memory by the Load (LO) command.
>     +References
>     + * `User Manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf
>       mvme147s
>     -TODO.
>     +Overview
>     +The MVME 147s is extremely similar to the Mvme147. The main
>     difference between
>     +them is that the 147s also has only 2KB of static RAM while the 147
>     has 4KB.
>     +Another small difference between them is the time-of-day clock. The
>     MVME147s has
>     + a Mostek MK48T02 while the MVME147 has an M48T18.
>     +The MVME147S is a double-high VMEmodule and is best utilized in a
>     32-bit VMEbus
>     +system with both P1 and P2 backplanes. The module has high
>     functionality with
>     +large onboard shared RAM, serial ports, and Centronics printer
>     port. The module
>     +provides a SCSI bus controller with DMA, floating-point
>     +watchdog timer, and time-of-day clock/calendar with battery backup,
>     2KB of
>     +static RAM with battery backup, four ROM sockets, and A32/D32
>     VMEbus interface
>     +with system controller functions are also provided. The MVME147S
>     can be operated
>     +as part of a VMEbus system with other VMEmodules such as RAM
>     modules, CPU
>     +modules, graphics modules, and analog I/O modules.
>     +Board Setup
>     +To select the desired configuration and ensure proper operation of
>     the MVME147S
>     +module, certain changes may be made before installation. These
>     changes are made
>     +through jumper arrangements on the headers. The module has been
>     factory tested
>     +and is shipped with factory-installed jumper configurations. The
>     module is
>     +operational with the factory-installed jumpers. The module is
>     configured to
>     +provide the system functions required for a VMEbus system. It is
>     necessary to
>     +make changes in the jumper arrangements for the following conditions:
>     +System controller select (J3) Factory use only (J5, J6) ROM
>     configuration select
>     + (J1, J2) Serial port 4 clock configuration select (J8, J9)
>     +See `manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf
>     <http://www.ing.iac.es/~docs/external/vme/147s_d3.pdf>>`_ for further
>     +information.
>     for execution.
>     command with the
>     line at a time.
>     code loads
>     User's Manual for
>     to enter a
>     program must be in
>     Package User's
>     +Alternately, the program may have been previously created using the
>     147Bug MM
>     +command as outlined above and stored to the host using the Dump
>     (DU) command.
>     +A communication link must exist between the host system and the
>     MVME147. The
>     +file is downloaded from the host to MVME147 memory by the Load (LO)
>     command.
>     +References
>     +* `User Manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf
>       mvme162
>     @@ -264,9 +773,307 @@ The program will automatically run when
>     download is complete.
>       mvme167
>     -TODO.
>     +Overview
>     +The MVME167 is a double-high VMEmodule based on the MC68040
>     microprocessor.The
>     +MVME167 has 4/8/16/32/64 MB of parity-protected DRAM
>     or4/8/16/32/64/128/256 MB
>     +of ECC-protected DRAM, 8KB of static RAM and time of day clock (with
>     +battery backup), Ethernet transceiver interface, four serial ports with
>     +EIA-232-D interface, four tick timers, watchdog timer, four ROM
>     sockets, SCSI
>     +bus interface with DMA, Centronics printer port,
>     A16/A24/A32/D8/D16/D32/D64
>     +VMEbus master/slave interface, 128KB of static RAM (with optional
>     battery
>     +backup),and VMEbus system controller.
>     +Firmware Setup
>     +The mvme167 BSP by default (i.e., unless you tamper with the
>     linkcmds) is linked
>     +at 0x00800000 and the firmware has to be properly configured so
>     that loading and
>     +executing at that address is possible: # The board's RAM must be mapped
>     +starting at address 0x00800000 (and not zero as may seem more
>     natural and which
>     +IIRC is 167Bug's default). ## Use 167Bug's 'env' command to set the
>     'Base
>     +Address of Local Memory' to 00800000. ## Use 167Bug's 'niot'
>     command to set the
>     +download and execution address to 00800000. # By default, the
>     167Bug firmware
>     +uses the lowest 64k block of RAM it finds for internal data and
>     this conflicts
>     +with RTEMS' needs. 167Bug won't allow you to download the RTEMS
>     image to
>     +0x00800000 unless you instruct 167Bug to use another area (e.g.,
>     static RAM) for
>     +it's internal data. ## Use 167Bug's 'env' command to set both, the
>     'Memory
>     +Search Starting Address' and 'Memory Search Ending Address' to zero.
>     +The 'search' area is the address-range that is scanned by 167Bug
>     when it tries
>     +to find an area for it's internal data. If it finds no RAM (since
>     start==end)
>     +then it uses static RAM and 00800000 and up can be used by RTEMS.
>     +These are the 'env' settings:
>     +       MPU Clock Speed =25Mhz
>     +       167-Bug>env
>     +       Bug or System environment [B/S] = B?
>     +       Field Service Menu Enable [Y/N] = N?
>     +       Remote Start Method Switch [G/M/B/N] = B?
>     +       Probe System for Supported I/O Controllers [Y/N] = Y?
>     +       Negate VMEbus SYSFAIL* Always [Y/N] = N?
>     +       Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
>     +       Local SCSI Bus Negotiations Type [A/S/N]       = A?
>     +       Ignore CFGA Block on a Hard Disk Boot [Y/N]    = Y?
>     +       Auto Boot Enable [Y/N]   = N?
>     +       Auto Boot at power-up only [Y/N] = Y?
>     +       Auto Boot Controller LUN = 00?
>     +       Auto Boot Device LUN     = 00?
>     +       Auto Boot Abort Delay    = 15?
>     +       Auto Boot Default String [NULL for a empty string] = ?
>     +       ROM Boot Enable [Y/N]            = N?
>     +       ROM Boot at power-up only [Y/N]  = Y?
>     +       ROM Boot Enable search of VMEbus [Y/N] = N?
>     +       ROM Boot Abort Delay             = 0?
>     +       ROM Boot Direct Starting Address = FF800000?
>     +       ROM Boot Direct Ending Address   = FFBFFFFC?
>     +       Network Auto Boot Enable [Y/N]   = N?
>     +       Network Auto Boot at power-up only [Y/N] = Y?
>     +       Network Auto Boot Controller LUN = 00?
>     +       Network Auto Boot Device LUN     = 00?
>     +       Network Auto Boot Abort Delay    = 5?
>     +       Network Auto Boot Configuration Parameters Pointer (NVRAM) =
>     FFFC0000?
>     +       Memory Search Starting Address   = 00000000?
>     +       Memory Search Ending Address     = 00000000?
>     +       Memory Search Increment Size     = 00010000?
>     +       Memory Search Delay Enable [Y/N] = N?
>     +       Memory Search Delay Address      = FFFFCE0F?
>     +       Memory Size Enable [Y/N]         = Y?
>     +       Memory Size Starting Address     = 00000000?
>     +       Memory Size Ending Address       = 01000000?
>     +       Base Address of Local Memory     = 00800000?
>     +       Size of Local Memory Board #0    = 00800000?
>     +       Size of Local Memory Board #1    = 00000000?
>     +       Slave Enable #1 [Y/N] = Y?
>     +       Slave Starting Address #1 = 00000000?
>     +       Slave Ending Address #1   = 007FFFFF?
>     +       Slave Address Translation Address #1 = 00000000?
>     +       Slave Address Translation Select #1  = FF800000?
>     +       Slave Control #1 = 00FF?
>     +       Slave Enable #2 [Y/N] = N?
>     +       Slave Starting Address #2 = FFE00000?
>     +       Slave Ending Address #2   = FFE1FFFF?
>     +       Slave Address Translation Address #2 = 00000000?
>     +       Slave Address Translation Select #2  = 00000000?
>     +       Slave Control #2 = 01EF?
>     +       Master Enable #1 [Y/N] = Y?
>     +       Master Starting Address #1 = 01000000?
>     +       Master Ending Address #1   = EFFFFFFF?
>     +       Master Control #1 = 0D?
>     +       Master Enable #2 [Y/N] = N?
>     +       Master Starting Address #2 = 00000000?
>     +       Master Ending Address #2   = 00000000?
>     +       Master Control #2 = 00?
>     +       Master Enable #3 [Y/N] = N?
>     +       Master Starting Address #3 = 00800000?
>     +       Master Ending Address #3   = 00FFFFFF?
>     +       Master Control #3 = 3D?
>     +       Master Enable #4 [Y/N] = N?
>     +       Master Starting Address #4 = 00000000?
>     +       Master Ending Address #4   = 00000000?
>     +       Master Address Translation Address #4 = 00000000?
>     +       Master Address Translation Select #4  = 00000000?
>     +       Master Control #4 = 00?
>     +       Short I/O (VMEbus A16) Enable [Y/N] = Y?
>     +       Short I/O (VMEbus A16) Control      = 01?
>     +       F-Page (VMEbus A24) Enable [Y/N]    = Y?
>     +       F-Page (VMEbus A24) Control         = 02?
>     +       ROM Speed Bank A Code         = 05?
>     +       ROM Speed Bank B Code         = 05?
>     +       Static RAM Speed Code         = 01?
>     +       PCC2 Vector Base              = 05?
>     +       VMEC2 Vector Base #1          = 06?
>     +       VMEC2 Vector Base #2          = 07?
>     +       VMEC2 GCSR Group Base Address = CC?
>     +       VMEC2 GCSR Board Base Address = 00?
>     +       VMEbus Global Time Out Code   = 01?
>     +       Local Bus Time Out Code       = 00?
>     +       VMEbus Access Time Out Code   = 02?
>     +       167-Bug>
>     +NIOT (Network I/O Teach) is a 167-Bug's debugger command commonly
>     +used to setup the Server/Client IP Addresses for the TFTP Transfer.
>     +The NIOT command goes something like this:
>     +       167-Bug>niot
>     +       Controller LUN =00?
>     +       Device LUN     =00?
>     +       Node Control Memory Address =FFE10000?
>     +       Client IP Address      =0.0.0.0?
>     +       Server IP Address      =0.0.0.0?
>     +       Subnet IP Address Mask =0.0.0.0?
>     +       Broadcast IP Address   =0.0.0.0?
>     +       Gateway IP Address     =0.0.0.0?
>     +       Boot File Name ("NULL" for None)     =?
>     +       Argument File Name ("NULL" for None) =?
>     +       Boot File Load Address         =00800000?
>     +       Boot File Execution Address    =00800000?
>     +       Boot File Execution Delay      =00000000?
>     +       Boot File Length               =00000000?
>     +       Boot File Byte Offset          =00000000?
>     +       BOOTP/RARP Request Retry       =00?
>     +       TFTP/ARP Request Retry         =00?
>     +       Trace Character Buffer Address =00000000?
>     +       BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
>     +       BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =Y?
>     +       167-Bug>
>     +RTEMS Lab Board Setup
>     +The firmware setup instructions above are true for the RTEMS Lab
>     board except
>     +for the memory search addresses. Set these as follows:
>     +       Memory Search Starting Address   = FFE00000?
>     +       Memory Search Ending Address     = FFE10000?
>     +These are the RTEMS Lab board settings:
>     +       167-Bug>env
>     +       Auto Boot Default String [Y(NULL String)/(String)] = ?
>     +       Network Auto Boot at power-up only [Y/N] = N?
>     FFFC0000?
>     +       Size of Local Memory Board #0    = 01000000?
>     +       Slave Ending Address #2   = FFE10000?
>     +       Master Control #3 = 30?
>     +       167-Bug>niot
>     +       Device LUN     =00?
>     +       Subnet IP Address Mask =255.255.255.0?
>     +       Broadcast IP Address   =255.255.255.255?
>     +       BOOTP/RARP Reply Update Control: Yes/No (Y/N)       =N?
>     +References
>     +* `User Manual
>     <https://prep.fnal.gov/catalog/hardware_info/motorola/mvme167_d3.pdf>`_
>       uC5282
>     -TODO.
>     +Overview
>     +The uC5282 is a compact, embedded microprocessor module ideal for
>     networked
>     +control and communication applications. The device is available in
>     a standard
>     +144pin soDIMM edge connector format to allow fast integration into
>     products.
>     +The module is based on the Freescale® ColdFire® MCF5282
>     microprocessor and
>     +includes all required system memory and physical terminations to
>     enable most
>     +applications without the need for external circuitry. The uC5282
>     features
>     +Ethernet, CAN and serial communications systems as well as standard
>     peripheral
>     +device connectivity using I2C, QSPI or data/address logic.
>     +References
>     +* `User Manual
>     2.17.1
