[PATCH rtems-docs] user/bsps: Moving all other M68K BSPs from Wiki to User
Gedare Bloom
gedare at rtems.org
Mon Apr 6 21:46:14 UTC 2020
On Mon, Apr 6, 2020 at 3:26 PM Mritunjay <mritunjaysharma394 at gmail.com> wrote:
> user/bsps/bsps-m68k.rst | 829 +++++++++++++++++++++++++++++++++++++++-
> 1 file changed, 818 insertions(+), 11 deletions(-)
> diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
> index bdb516b..a035137 100644
> --- a/user/bsps/bsps-m68k.rst
> +++ b/user/bsps/bsps-m68k.rst
> @@ -8,7 +8,22 @@ m68k (Motorola 68000 / ColdFire)
> av5282
> -TODO.
> +Overview
> +The Freescale ColdFire? Evaluation Board provides a reference platform for
Please make sure to read the text after you copy-paste and reformat
it. You should also build the docs and read, at least the html.
> +engineers to develop a variety of embedded processing applications requiring
> +networking connectivity. The board hosts all the necessary hardware and firmware
> +needed to implement a networked interface using the Freescale MCF5282 processor.
> +By including all the necessary physical layer (PHY) devices, memory and external
> +expansion capability the designer can implement any bridging application that
> +requires 10/100 Ethernet, UARTs, CAN interface, QSPI, analog inputs and/or
> +memory-mapped peripherals. The AvBus expansion connector allows for user defined
> +add-on hardware, or can be utilized with over 20 compatible evaluation and
> +development boards from Avnet Electronics Marketing. These boards can be mixed
> +and matched to provide a variety of additional hardware and firmware capability
> +from PCI and PCI-X connectivity, RapidIO, memory and communications and
> +video/audio functions.
> csb360
> @@ -18,27 +33,372 @@ TODO.
> gen68340
> -TODO.
> +Overview
> +The MC68340 is a high-performance 32-bit integrated processor with direct memory
> +access (DMA), combining an enhanced M68000-compatible processor, 32-bit DMA, and
> +other peripheral subsystems on a single integrated circuit. The MC68340 CPU32
> +delivers 32-bit CISC processor performance from a lower cost 16-bit memory
> +system. The combination of peripherals offered in the MC68340 can be found in a
> +diverse range of microprocessor-based systems.Systems requiring very high-speed
space after period
> +block transfers of data can benefit from the MC68340.
> +Organization
need one more -?
> +The M68300 family of integrated processors and controllers is built on an M68000
> +core processor, an on-chip bus, and a selection of intelligent peripherals
> +appropriate for a set of applications. The CPU32 is a powerful central
> +processor with nearly the performance of the MC68020. A system integration
> +module incorporates the external bus interface and many of the smaller circuits
> +that typically surround a microprocessor for address decoding, wait-state
> +insertion, interrupt prioritization, clock generation, arbitration, watchdog
> +timing, and power-on reset timing. Each member of the M68300 family is
> +distinguished by its selection of peripherals. Peripherals are chosen to address
> +specific applications but are often useful in a wide variety of applications.
> +The peripherals may be highly sophisticated timing or protocol engines that have
> +their own processors, or they may be more traditional peripheral functions, such
> +as UARTs and timers. Since each major function is designed in a standalone
> +module, each module might be found in many different M68300 family parts.
> +Architecture
Need one more -?
> +The CPU32 is upward source- and object-code compatible with the MC68000 and
> +MC68010. It is downward source- and object-code compatible with the MC68020.
> +Within the M68000 family, architectural differences are limited to the
> +supervisory operating state. User state programs can be executed unchanged on
> +upward-compatible devices. The major CPU32 features are as follows:
> +* 32-Bit Internal Data Path and Arithmetic Hardware
> +* 32-Bit Address Bus Supported by 32-Bit Calculations
> +* Rich Instruction Set
> +* Eight 32-Bit General-Purpose Data Registers
> +* Seven 32-Bit General-Purpose Address Registers
> +* Separate User and Supervisor Stack Pointers
> +* Separate User and Supervisor State Address Spaces
> +* Separate Program and Data Address Spaces
> +* Many Data Types
> +* Flexible Addressing Modes
> +* Full Interrupt Processing
> +* Expansion Capability
> +The CPU32 is an M68000 family processor specially designed for use as a 32-bit
> +core processor and for operation over the intermodule bus (IMB). Designers used
> +the MC68020 as a model and included advances of the later M68000 family
> +processors, resulting in an instruction execution performance of 4 MIPS
> +(VAX-equivalent) at 25.16 MHz. The powerful and flexible M68000 architecture is
> +the basis of the CPU32. MC68000 (including the MC68HC000 and the MC68EC000) and
> +MC68010 user programs will run unmodified on the CPU32. The programmer can use
> +any of the eight 32-bit data registers for fast manipulation of data and any of
> +the eight 32-bit address registers for indexing data in memory. The CPU32 can
> +operate on data types of single bits, binary-coded decimal (BCD)digits, and 8,
> +16, and 32 bits. Peripherals and data in memory can reside anywhere in the
> +4-Gbyte linear address space. A supervisor operating mode protects system-level
> +resources from the more restricted user mode, allowing a true virtual
> +environment to be developed.
> +Physical
one too many "-"?
> +The MC68340 is available as 0–16.78 MHz and 0–25.16 MHz, 0°C to +70°C and
The – should be -? I suspect – is not going to typeset correctly (I
don't think it is ASCII). Same with the \degree symbols. May need to
figure out how to generate those with rst.
I didn't try to build the docs yet with your patch though. Did you?
> +-40°C to +85°C, and 5.0 V ±5% and 3.3 V ±0.3 supply voltages (reduced
and the +/-
> +frequencies at 3.3 V). Thirty-two power and ground leads minimize ground bounce
> +and ensure proper isolation of different sections of the chip, including the
> +clock oscillator. A 144 pins are used for signals and power. The MC68340 is
> +available in a gull-wing ceramic quad flat pack (CQFP) with 25.6-mil (0.001-in)
> +lead spacing or a 15 ´ 15 plastic pin grid array (PPGA) with 0.1-in pin spacing.
> +System Integration Module
One too many "-"?
> +The MC68340 SIM40 provides the external bus interface for both the CPU32 and the
> +DMA. It also eliminates much of the glue logic that typically supports the
> +microprocessor and its interface with the peripheral and memory system. The
> +SIM40 provides programmable circuits to perform address decoding and chip
> +selects, wait-state insertion, interrupt handling, clock generation, bus
> +arbitration, watchdog timing, discrete I/O, and power-on reset timing. A
> +boundary scan test capability is also provided.
> +External Bus Interface
> +The external bus interface (EBI) handles thetransfer of information between the
space needed
> +internal CPU32 or DMA controller and memory, peripherals, or other processing
> +elements in the external address space. Based on the MC68030 bus, the external
> +bus provides up to 32 address lines and 16 data lines. Address extensions
> +identify each bus cycle as CPU32 or DMA initiated, supervisor or user privilege
> +level, and instruction or data access. The data bus allows dynamic sizing for
> +8- or 16-bit bus accesses (plus 32 bits for DMA). Synchronous transfers from the
> +CPU32 or the DMA can be made in as little as two clock cycles.
> +Clock Synthesizer
> +The clock synthesizer generates the clock signals used by all internal
> +operations as well as a clock output used by external devices. The clock
> +synthesizer can operate with an inexpensive 32768-Hz watch crystal or an
> +external oscillator for reference, using an internal phase-locked loop and
> +voltage-controlled oscillator. At any time, software can select
> +clock frequencies from 131 kHz to 16.78 MHz or 25.16 MHz, favoring either low
> +power consumption or high performance. Alternately, an external clock can drive
> +the clock signal directly at the operating frequency. With its fully static
> +HCMOS design, it is possible to completely stop the system clock without losing
> +the contents of the internal registers.
> gen68360
> -TODO.
> +Overview
> +The MC68360 Quad Integrated Communication Controller (QUICC™) is a versatile
TM by whom? also the TM symbol probably won't typeset?
> +one-chip integrated microprocessor and peripheral combination family that can be
> +used in a variety of controller applications.
> +The MC68360 particularly excels in communications activities. The QUICC can be
> +described as a next-generation MC68302, with higher performance in all areas of
> +device operation, increased flexibility, and higher integration. The term "quad"
> +comes from the fact that there are four serial communications controllers
> +(SCCs) on the device. However, there are actually seven serial channels which
> +include four SCCs, two serial management controllers (SMCs), and one serial
> +peripheral interface (SPI).
> +Features
> +CPU + Processor (8.3 MIPS at 33MHz)
> +* 32-bit version of the CPU32 core (fully compatible with CPU32)
> +* Up to 32-bit Data Bus (Dynamic Bus Sizing for 8- and 16-Bits) + 32 Address
> +Lines
> +* Complete static design (0-33 MHz Operation)
> +* Slave mode to disable CPU32+ (allows use with external processors)
> + * Multiple QUICCs can share one system bus (one master)
> + * MC68040 companion mode allows QUICC to be an MC68040 companion chip and
> + intelligent peripheral (29 MIPS at 33 MHz)
delete blank line?
> + * All QUICC features available in slave mode
> +* Memory controller (eight banks)
> + * Contains complete Dynamic Random-Access Memory (DRAM) controller
> + * Glueless interface to DRAM Single In-Line Memory Modules (SIMMs), Static
> + Random-Access Memory (SRAM),
ditto
> + * Electrically Programmable Read-Only Memory (EPROM), Flash EPROM, etc.
> + * Boot chip select available at Reset (options for 8-, 16-, or 32-bit
> + memory)
ditto
> + * Special features for MC68040 including Burst Mode
> +* Four general-purpose timers
> + * Four 16-bit timers or two 32-bit timers
> +* Two Independent DMAs (IDMAs)
> +* System Integration Module (SIM60)
> + * Bus monitor
> + * Breakpoint logic provides on-chip H/W breakpoints
> + * Spurious interrupt monitor
> + * External masters may use on-chip features such as chip selects
> +* Periodic interrupt timer
> +* On-chip bus arbitration with no overhead for internal masters
> +* Low power stop mode
> +* IEEE 1149.1 Test Access Port
> +* RISC Communications Processor Module (CPM)
> +* Many new commands (e.g., Graceful Stop Transmit, Close RxBD)
> +* Supports continuos mode transmission and reception on all serial channels
> +* 2.5 kbytes of dual-port RAM
> +* 14 Serial DMA (SDMA) channels
> +* Three parallel I/O registers with open-drain capability
> +* Each serial channel can have its own Pins (NMSI mode)
> +* Four baud rate generators
> +* Four SCCs
> +* Ethernet/IEEE 802.3 optional on SCCs 1-2 at 25 MHz, SCCs 1-3 at 33 MHz
> +* HDLC Bus
> +* Universal Asynchronous Receiver Transmitter (UART)
> +* Synchronous UART
> +* Asynchronous HDLC (RAM microcode option) to support PPP (Point to Point
> +Protocol)
> +* Two SMCs
> +* UART
> +* Transparent
> +* General Circuit Interface (GCI) controller
> +* One SPI
> +* Time-Slot assignor
> +* Supports two TDM channels
> +* Parallel Interface Port (supports fast connection between QUICCs)
> +Host controlled Board Setup
> +Required equipment:
> +* +5 V 5 A power supply
> +* +12 V 1 A power supply (optional)
> +* Host Computer, one of the following:
> +* Sun - 4 (SBus interface)
> +* IBM-PC/XT/AT
> +* ADI board - compatible with the host computer
> +* 37 line flat cable with female 37 pin D-type connectors on each end
> +Stand alone Board Setup
> +* VT100 compatible terminal
> +* RS-232 cable with male 9 pin D-type connector on the QUADS side.
> +Debugging BDM controller
> +The slave QUICC enables the M68360QUADS to become BDM controller to control
> +other QUICC devices on the user application. The BDM feature enables the user to
> +download code and provides hardware and software debugging capability of the
> +user application. The 8 pin BDM connector P9 utilizes five pins of the slave
> +QUICC port B. These pins are configured as general purpose I/O pins.
> +Debugging Ethernet controller
> +The slave QUICC provides Ethernet port for the M68360QUADS by connecting SCC1 to
> +Motorola MC68160 EEST device (U35 in sheet 10). The MC68160 provides two
> +Ethernet interfaces, twisted-pair on P8 and AUI on P7. The LEDs LD3-LD8 are
> +controlled by the EEST, and they provide indications about the status of the
> +Ethernet ports activity. The signals between the slave QUICC and the MC68160
> +appear on connector P10 for debugging purposes. P10 is a set of wire holes.
> +The socket U24 is installed for internal factory testing only. For proper
> +operation of the EEST, this socket must be empty.
> +References
> +* `User Manual <https://www.nxp.com/docs/en/reference-manual/MC68360UM.pdf>`_
> genmcf548x
> -TODO.
> +Overview
> +The MCF548x family is based on the ColdFire V4e core, a complex which comprises
> +the ColdFire V4 central processor unit (CPU), an enhanced multiply-accumulate
> +unit (EMAC), a memory management unit (MMU), a double-precision floating point
> +unit (FPU) conforming to standard IEEE-754, and controllers for caches and local
> +data memories. The MCF548x family is capable of performing at an operating
> +frequency of up to 200 MHz or 308 MIPS.
> +To maximize throughput, the MCF548x family incorporates three independent
> +external bus interfaces:
> +* The general-purpose local bus (FlexBus) is used for system boot memories and
> +simple peripherals and has up to six chip selects.
> +* Program code and data can be stored in SDRAM connected to a dedicated 32-bit
> +double data rate (DDR) bus that can run at up to one-half of the CPU core
> +frequency. The glueless DDR SDRAM controller handles all address multiplexing,
> +input and output strobe timing, and memory bus clock generation.
> +* A 32-bit PCI bus compliant with the version 2.2 specification and running at
> +a typical frequency of 25 MHz or 50 MHz supports peripherals that require high
> +bandwidth, the ability to arbitrate for bus mastership, and access to internal
> +MCF548x memory resources.
> +References
> + * `User Manual <https://www.nxp.com/docs/en/reference-manual/MCF5485RM.pdf>`_
> mcf5206elite
> -TODO.
> +Overview
> +The MCF5206e integrated microprocessor combines a Version 2 (V2) ColdFire®
R by whom, and typesetting?
> +processor core with several peripheral functions such as a DRAM controller,
> +timers, general-purpose I/O and serial interfaces, debug module, and system
> +integration. Designed for embedded control applications, the V2 ColdFire core
> +delivers enhanced performance while maintaining
> +low system costs. To speed program execution, the largeon-chip instruction cache
> +and SRAM provide one-cycle access to critical code and data. The MCF5206e
> +greatly reduces the time required for system design and implementation by
> +packaging common system functions on chip and providing glueless interfaces to 8
> +bit, 16 bit, and 32 bit DRAM, SRAM, ROM, and I/O devices.
> +The MCF5206e is an enhanced version of the MCF5206 processor, with the same
> +peripheral set, DMA, MAC, Hardware Divide, larger cache, and larger SRAM. It is
> +pin compatible with the MCF5206, with the DMA pins muxed with Timer 0 pins.
> +References
> mcf52235
> -TODO.
> +Overview
> +The MCF52235 represents a family of highly-integrated 32-bit microcontrollers
> +based on the V2 ColdFire microarchitecture. Featuring up to 32 Kbytes of
> +internal SRAM and 256 Kbytes of flash memory, four 32-bit timers with DMA
> +request capability, a 4-channel DMA controller, fast Ethernet controller,
> +a CAN module, an I2C™ module, 3 UARTs and a queued SPI, the MC52235 family has
> +been designed for general-purpose industrial control applications.
> +This 32-bit device is based on the Version 2 ColdFire? core operating at a
> +frequency up to 60 MHz, offering high performance and low power consumption.
> +On-chip memories connected tightly to the processor core include up to 256
> +Kbytes of Flash and 32 Kbytes of static random access memory (SRAM).
> +This BSP was heavily based on the MCF5235 BSP.
> +Key features
> +* Version 2 ColdFire variable-length RISC processor core
> +* System debug support
> +* On-chip memories
> +* Power management
> +* Fast Ethernet Controller (FEC)
> +* On-chip Ethernet Transceiver (EPHY)
> +* FlexCAN 2.0B module
> +* Three universal asynchronous/synchronous receiver transmitters (UARTs)
> +* I2C module
> +* Queued serial peripheral interface (QSPI)
> +* Fast analog-to-digital converter (ADC)
> +* Four 32-bit DMA timers
> +* Four-channel general purpose timers
> +* Pulse-width modulation timer
> +* Real-Time Clock (RTC)
> +* Two periodic interrupt timers (PITs)
> +* Software watchdog timer
> +* Clock Generation Features
> +* Dual Interrupt Controllers (INTC0/INTC1)
> +* DMA controller
> +* Reset
> +* Chip integration module (CIM)
> +* General purpose I/O interface
> +* JTAG support for system level board testing
> +Board Setup
> +To setup, we will display the firmware settings using the boot monitor's "state"
> + command:
> +.. code-block:: none
> + INET> state
> + iface 0- IP addr:192.168.1.99 subnet:255.255.255.0 gateway:192.168.1.1
> + current tick count 4204
> + Task wakeups:netmain: 27
> + nettick: 2102
> + keyboard: 2099
> mcf5225x
> @@ -48,7 +408,35 @@ TODO.
> mcf5235
> -TODO.
> +Overview
> +The MCF5235EVB is a Motorola evaluation board that is based on the Coldfire
> +MCF5235 32-bit processor. The board includes 32 Mbytes of SDRAM, 2Mbytes of
> +flash, the MCF5235 processor with a max core frequency of 150MHz, Ethernet
> +support, and CAN bus support. This BSP has also been tested to work with the
> +Coldfire MCF5270 processor with a max core frequency of 100MHz.
> +This BSP has also been tested to work with the newer Freescale M5235BCC
> +evaluation board and with the Axiom Manufacturing CMM-5235 Board.
> +The BSP provides support to run applications from both RAM when debugging and
> +from Flash when the application is complete.
> +Board Setup
> +Here is the setup for the Axiom M5235BCC in the RTEMS Lab:
> + dBUG> show
> + base: 16 baud: 19200
> + server: 192.168.1.92 client: 192.168.1.241
> + gateway: 192.168.1.14 netmask: 255.255.255.0
> + filename: /mcf5235.exe filetype: ELF
> + ethaddr: 00:20:DD:00:00:11
> +Downloading and Executing
One too many "-"?
> mcf5329
> @@ -75,12 +463,133 @@ TODO.
> mvme147
> -TODO.
> +Overview
> +The MVME147 is a double-high VMEmodule based on the MC68030 microprocessor. It
> +is best utilized in a 32-bit VMEbus system with both P1 and P2 backplanes. The
> +module has high functionality with large onboard shared RAM, serial ports, and
> +Centronics printer port. The module provides a SCSI bus controller with DMA,
> +floating-point coprocessor, tick timer, watchdog timer, and time-of-day
> +clock/calendar with battery backup, 4KB of static RAM with battery backup, four
> +ROM sockets, and A32/D32 VMEbus interface with system controller functions.
> +Key Features
> +* 16, 25, or 33.33 MHz MC68030 enhanced 32-bit microprocessor
> +* 16, 25, or 33.33 MHz MC68882 floating-point coprocessor
> +* 4, 8, 16, or 32MB of shared DRAM, with programmable parity
> +* 4K x 8 SRAM and time-of-day clock with battery backup
> +* Four 28/32-pin ROM/PROM/EPROM/EEPROM sockets, 16 bits wide
> +* A32/D32 VMEbus master/slave interface with system controller function
> +* Four EIA-232-D serial communications ports
> +* Centronics compatible printer port
> +* Two 16-bit timers and watchdog timer
> +* SCSI bus interface with DMA
> +* Ethernet transceiver interface
> +* 4-level requester, 7-level interrupter, and 7-level interrupt handler for
> +VMEbus
> +* On-board debugger and diagnostic firmware
> +Board Setup
> +Set jumpers on your MVME147 module. Ensure that ROM devices are properly
> +installed in the sockets. Install your MVME147 module in the chassis. Set
> +jumpers on the transition board; connect and install the transition board, P2
> +adapter module, and optional SCSI device cables. Connect a console terminal to
> +the MVME712. Connect any other optional devices or equipment you will be using.
> +Power up the system. Note that the debugger prompt appears. Initialize the
> +clock. Examine and/or change environmental parameters. Program the PCCchip and
> +VMEchip.
> +See `manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>`_ for further
> +information.
> +There are various ways to enter a user program into system memory for execution.
> +One way is to create the program using the Memory Modify (MM) command with the
> +assembler/disassembler option. You enter the program one source line at a time.
> +After each source line is entered, it is assembled and the object code loads
> +into memory. Refer to the MVME147 BUG 147Bug Debugging Package User's Manual for
> +complete details of the 147Bug Assembler/Disassembler?. Another way to enter a
stray '?'
> +program is to download an object file from a host system. The program must be in
> +S-record format (described in the MVME147BUG 147Bug Debugging Package User's
> +Manual) and may have been assembled or compiled on the host system. Alternately,
> +the program may have been previously created using the 147Bug MM command as
> +outlined above and stored to the host using the Dump (DU) command. A
> +communication link must exist between the host system and the MVME147. The file
> +is downloaded from the host to MVME147 memory by the Load (LO) command.
> +References
> + * `User Manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>`_
> mvme147s
> -TODO.
> +Overview
> +The MVME 147s is extremely similar to the Mvme147. The main difference between
> +them is that the 147s also has only 2KB of static RAM while the 147 has 4KB.
> +Another small difference between them is the time-of-day clock. The MVME147s has
> + a Mostek MK48T02 while the MVME147 has an M48T18.
> +The MVME147S is a double-high VMEmodule and is best utilized in a 32-bit VMEbus
> +system with both P1 and P2 backplanes. The module has high functionality with
> +large onboard shared RAM, serial ports, and Centronics printer port. The module
> +provides a SCSI bus controller with DMA, floating-point coprocessor, tick timer,
> +watchdog timer, and time-of-day clock/calendar with battery backup, 2KB of
> +static RAM with battery backup, four ROM sockets, and A32/D32 VMEbus interface
> +with system controller functions are also provided. The MVME147S can be operated
> +as part of a VMEbus system with other VMEmodules such as RAM modules, CPU
> +modules, graphics modules, and analog I/O modules.
> +Board Setup
> +To select the desired configuration and ensure proper operation of the MVME147S
> +module, certain changes may be made before installation. These changes are made
> +through jumper arrangements on the headers. The module has been factory tested
> +and is shipped with factory-installed jumper configurations. The module is
> +operational with the factory-installed jumpers. The module is configured to
> +provide the system functions required for a VMEbus system. It is necessary to
> +make changes in the jumper arrangements for the following conditions:
> +System controller select (J3) Factory use only (J5, J6) ROM configuration select
> + (J1, J2) Serial port 4 clock configuration select (J8, J9)
> +See `manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf>`_ for further
> +information.
> +Alternately, the program may have been previously created using the 147Bug MM
> +command as outlined above and stored to the host using the Dump (DU) command.
> +A communication link must exist between the host system and the MVME147. The
> +file is downloaded from the host to MVME147 memory by the Load (LO) command.
> +References
> +* `User Manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf>`_
> mvme162
> @@ -264,9 +773,307 @@ The program will automatically run when download is complete.
> mvme167
> -TODO.
> +Overview
> +The MVME167 is a double-high VMEmodule based on the MC68040 microprocessor.The
> +MVME167 has 4/8/16/32/64 MB of parity-protected DRAM or4/8/16/32/64/128/256 MB
> +of ECC-protected DRAM, 8KB of static RAM and time of day clock (with
> +battery backup), Ethernet transceiver interface, four serial ports with
> +EIA-232-D interface, four tick timers, watchdog timer, four ROM sockets, SCSI
> +bus interface with DMA, Centronics printer port, A16/A24/A32/D8/D16/D32/D64
> +VMEbus master/slave interface, 128KB of static RAM (with optional battery
> +backup),and VMEbus system controller.
> +Firmware Setup
> +The mvme167 BSP by default (i.e., unless you tamper with the linkcmds) is linked
> +at 0x00800000 and the firmware has to be properly configured so that loading and
> +executing at that address is possible: # The board's RAM must be mapped
> +starting at address 0x00800000 (and not zero as may seem more natural and which
> +IIRC is 167Bug's default). ## Use 167Bug's 'env' command to set the 'Base
> +Address of Local Memory' to 00800000. ## Use 167Bug's 'niot' command to set the
> +download and execution address to 00800000. # By default, the 167Bug firmware
> +uses the lowest 64k block of RAM it finds for internal data and this conflicts
> +with RTEMS' needs. 167Bug won't allow you to download the RTEMS image to
> +0x00800000 unless you instruct 167Bug to use another area (e.g., static RAM) for
> +it's internal data. ## Use 167Bug's 'env' command to set both, the 'Memory
> +Search Starting Address' and 'Memory Search Ending Address' to zero.
> +The 'search' area is the address-range that is scanned by 167Bug when it tries
> +to find an area for it's internal data. If it finds no RAM (since start==end)
> +then it uses static RAM and 00800000 and up can be used by RTEMS.
> +These are the 'env' settings:
> + MPU Clock Speed =25Mhz
> + 167-Bug>env
> + Bug or System environment [B/S] = B?
> + Field Service Menu Enable [Y/N] = N?
> + Remote Start Method Switch [G/M/B/N] = B?
> + Probe System for Supported I/O Controllers [Y/N] = Y?
> + Negate VMEbus SYSFAIL* Always [Y/N] = N?
> + Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
> + Local SCSI Bus Negotiations Type [A/S/N] = A?
> + Ignore CFGA Block on a Hard Disk Boot [Y/N] = Y?
> + Auto Boot Enable [Y/N] = N?
> + Auto Boot at power-up only [Y/N] = Y?
> + Auto Boot Controller LUN = 00?
> + Auto Boot Device LUN = 00?
> + Auto Boot Abort Delay = 15?
> + Auto Boot Default String [NULL for a empty string] = ?
> + ROM Boot Enable [Y/N] = N?
> + ROM Boot at power-up only [Y/N] = Y?
> + ROM Boot Enable search of VMEbus [Y/N] = N?
> + ROM Boot Abort Delay = 0?
> + ROM Boot Direct Starting Address = FF800000?
> + ROM Boot Direct Ending Address = FFBFFFFC?
> + Network Auto Boot Enable [Y/N] = N?
> + Network Auto Boot at power-up only [Y/N] = Y?
> + Network Auto Boot Controller LUN = 00?
> + Network Auto Boot Device LUN = 00?
> + Network Auto Boot Abort Delay = 5?
> + Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFFC0000?
> + Memory Search Starting Address = 00000000?
> + Memory Search Ending Address = 00000000?
> + Memory Search Increment Size = 00010000?
> + Memory Search Delay Enable [Y/N] = N?
> + Memory Search Delay Address = FFFFCE0F?
> + Memory Size Enable [Y/N] = Y?
> + Memory Size Starting Address = 00000000?
> + Memory Size Ending Address = 01000000?
> + Base Address of Local Memory = 00800000?
> + Size of Local Memory Board #0 = 00800000?
> + Size of Local Memory Board #1 = 00000000?
> + Slave Enable #1 [Y/N] = Y?
> + Slave Starting Address #1 = 00000000?
> + Slave Ending Address #1 = 007FFFFF?
> + Slave Address Translation Address #1 = 00000000?
> + Slave Address Translation Select #1 = FF800000?
> + Slave Control #1 = 00FF?
> + Slave Enable #2 [Y/N] = N?
> + Slave Starting Address #2 = FFE00000?
> + Slave Ending Address #2 = FFE1FFFF?
> + Slave Address Translation Address #2 = 00000000?
> + Slave Address Translation Select #2 = 00000000?
> + Slave Control #2 = 01EF?
> + Master Enable #1 [Y/N] = Y?
> + Master Starting Address #1 = 01000000?
> + Master Ending Address #1 = EFFFFFFF?
> + Master Control #1 = 0D?
> + Master Enable #2 [Y/N] = N?
> + Master Starting Address #2 = 00000000?
> + Master Ending Address #2 = 00000000?
> + Master Control #2 = 00?
> + Master Enable #3 [Y/N] = N?
> + Master Starting Address #3 = 00800000?
> + Master Ending Address #3 = 00FFFFFF?
> + Master Control #3 = 3D?
> + Master Enable #4 [Y/N] = N?
> + Master Starting Address #4 = 00000000?
> + Master Ending Address #4 = 00000000?
> + Master Address Translation Address #4 = 00000000?
> + Master Address Translation Select #4 = 00000000?
> + Master Control #4 = 00?
> + Short I/O (VMEbus A16) Enable [Y/N] = Y?
> + Short I/O (VMEbus A16) Control = 01?
> + F-Page (VMEbus A24) Enable [Y/N] = Y?
> + F-Page (VMEbus A24) Control = 02?
> + ROM Speed Bank A Code = 05?
> + ROM Speed Bank B Code = 05?
> + Static RAM Speed Code = 01?
> + PCC2 Vector Base = 05?
> + VMEC2 Vector Base #1 = 06?
> + VMEC2 Vector Base #2 = 07?
> + VMEC2 GCSR Group Base Address = CC?
> + VMEC2 GCSR Board Base Address = 00?
> + VMEbus Global Time Out Code = 01?
> + Local Bus Time Out Code = 00?
> + VMEbus Access Time Out Code = 02?
> + 167-Bug>
> +NIOT (Network I/O Teach) is a 167-Bug's debugger command commonly
> +used to setup the Server/Client IP Addresses for the TFTP Transfer.
> +The NIOT command goes something like this:
> + 167-Bug>niot
> + Controller LUN =00?
> + Device LUN =00?
> + Node Control Memory Address =FFE10000?
> + Client IP Address =0.0.0.0?
> + Server IP Address =0.0.0.0?
> + Subnet IP Address Mask =0.0.0.0?
> + Broadcast IP Address =0.0.0.0?
> + Gateway IP Address =0.0.0.0?
> + Boot File Name ("NULL" for None) =?
> + Argument File Name ("NULL" for None) =?
> + Boot File Load Address =00800000?
> + Boot File Execution Address =00800000?
> + Boot File Execution Delay =00000000?
> + Boot File Length =00000000?
> + Boot File Byte Offset =00000000?
> + BOOTP/RARP Request Retry =00?
> + TFTP/ARP Request Retry =00?
> + Trace Character Buffer Address =00000000?
> + BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
> + BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
> + 167-Bug>
> +RTEMS Lab Board Setup
> +The firmware setup instructions above are true for the RTEMS Lab board except
> +for the memory search addresses. Set these as follows:
> + Memory Search Starting Address = FFE00000?
> + Memory Search Ending Address = FFE10000?
> +These are the RTEMS Lab board settings:
> + 167-Bug>env
> + Auto Boot Default String [Y(NULL String)/(String)] = ?
> + Network Auto Boot at power-up only [Y/N] = N?
> + Size of Local Memory Board #0 = 01000000?
> + Slave Ending Address #2 = FFE10000?
> + Master Control #3 = 30?
> + 167-Bug>niot
> + Device LUN =00?
> + Subnet IP Address Mask =255.255.255.0?
> + Broadcast IP Address =255.255.255.255?
> + BOOTP/RARP Reply Update Control: Yes/No (Y/N) =N?
> +References
> +* `User Manual <https://prep.fnal.gov/catalog/hardware_info/motorola/mvme167_d3.pdf>`_
> uC5282
> -TODO.
> +Overview
> +The uC5282 is a compact, embedded microprocessor module ideal for networked
> +control and communication applications. The device is available in a standard
> +144pin soDIMM edge connector format to allow fast integration into products.
> +The module is based on the Freescale® ColdFire® MCF5282 microprocessor and
(R)
> +includes all required system memory and physical terminations to enable most
> +applications without the need for external circuitry. The uC5282 features
> +Ethernet, CAN and serial communications systems as well as standard peripheral
> +device connectivity using I2C, QSPI or data/address logic.
> +References
> 2.17.1
> devel mailing list
> devel at rtems.org
