[PATCH v2] user/bsps: Moving all other M68K BSPs from Wiki to User Manual
Mritunjay
mritunjaysharma394 at gmail.com
Mon Apr 13 19:09:12 UTC 2020
Tried to fix the patch as per suggestions. Please review.
user/bsps/bsps-m68k.rst | 1048 ++++++++++++++++++++++++++++++++++-----
1 file changed, 924 insertions(+), 124 deletions(-)
diff --git a/user/bsps/bsps-m68k.rst b/user/bsps/bsps-m68k.rst
index bdb516b..5ca9079 100644
--- a/user/bsps/bsps-m68k.rst
+++ b/user/bsps/bsps-m68k.rst
@@ -8,7 +8,22 @@ m68k (Motorola 68000 / ColdFire)
av5282
-TODO.
+Overview
+The Freescale ColdFire Evaluation Board provides a reference platform for
+engineers to develop a variety of embedded processing applications requiring
+networking connectivity. The board hosts all the necessary hardware and firmware
+needed to implement a networked interface using the Freescale MCF5282 processor.
+By including all the necessary physical layer (PHY) devices, memory and external
+expansion capability the designer can implement any bridging application that
+requires 10/100 Ethernet, UARTs, CAN interface, QSPI, analog inputs and/or
+memory-mapped peripherals. The AvBus expansion connector allows for user defined
+add-on hardware, or can be utilized with over 20 compatible evaluation and
+development boards from Avnet Electronics Marketing. These boards can be mixed
+and matched to provide a variety of additional hardware and firmware capability
+from PCI and PCI-X connectivity, RapidIO, memory and communications and
+video/audio functions.
csb360
@@ -18,27 +33,365 @@ TODO.
gen68340
-TODO.
+Overview
+The MC68340 is a high-performance 32-bit integrated processor with direct memory
+access (DMA), combining an enhanced M68000-compatible processor, 32-bit DMA, and
+other peripheral subsystems on a single integrated circuit. The MC68340 CPU32
+delivers 32-bit CISC processor performance from a lower cost 16-bit memory
+system. The combination of peripherals offered in the MC68340 can be found in a
+diverse range of microprocessor-based systems.Systems requiring very high-speed
+block transfers of data can benefit from the MC68340.
+Organization
+The M68300 family of integrated processors and controllers is built on an M68000
+core processor, an on-chip bus, and a selection of intelligent peripherals
+appropriate for a set of applications. The CPU32 is a powerful central
+processor with nearly the performance of the MC68020. A system integration
+module incorporates the external bus interface and many of the smaller circuits
+that typically surround a microprocessor for address decoding, wait-state
+insertion, interrupt prioritization, clock generation, arbitration, watchdog
+timing, and power-on reset timing. Each member of the M68300 family is
+distinguished by its selection of peripherals. Peripherals are chosen to address
+specific applications but are often useful in a wide variety of applications.
+The peripherals may be highly sophisticated timing or protocol engines that have
+their own processors, or they may be more traditional peripheral functions, such
+as UARTs and timers. Since each major function is designed in a standalone
+module, each module might be found in many different M68300 family parts.
+Architecture
+The CPU32 is upward source- and object-code compatible with the MC68000 and
+MC68010. It is downward source- and object-code compatible with the MC68020.
+Within the M68000 family, architectural differences are limited to the
+supervisory operating state. User state programs can be executed unchanged on
+upward-compatible devices. The major CPU32 features are as follows:
+* 32-Bit Internal Data Path and Arithmetic Hardware
+* 32-Bit Address Bus Supported by 32-Bit Calculations
+* Rich Instruction Set
+* Eight 32-Bit General-Purpose Data Registers
+* Seven 32-Bit General-Purpose Address Registers
+* Separate User and Supervisor Stack Pointers
+* Separate User and Supervisor State Address Spaces
+* Separate Program and Data Address Spaces
+* Many Data Types
+* Flexible Addressing Modes
+* Full Interrupt Processing
+* Expansion Capability
+The CPU32 is an M68000 family processor specially designed for use as a 32-bit
+core processor and for operation over the intermodule bus (IMB). Designers used
+the MC68020 as a model and included advances of the later M68000 family
+processors, resulting in an instruction execution performance of 4 MIPS
+(VAX-equivalent) at 25.16 MHz. The powerful and flexible M68000 architecture is
+the basis of the CPU32. MC68000 (including the MC68HC000 and the MC68EC000) and
+MC68010 user programs will run unmodified on the CPU32. The programmer can use
+any of the eight 32-bit data registers for fast manipulation of data and any of
+the eight 32-bit address registers for indexing data in memory. The CPU32 can
+operate on data types of single bits, binary-coded decimal (BCD)digits, and 8,
+16, and 32 bits. Peripherals and data in memory can reside anywhere in the
+4-Gbyte linear address space. A supervisor operating mode protects system-level
+resources from the more restricted user mode, allowing a true virtual
+environment to be developed.
+Physical
+The MC68340 is available as 0–16.78 MHz and 0–25.16 MHz, 0°C to +70°C and
+-40°C to +85°C, and 5.0 V ±5% and 3.3 V ±0.3 supply voltages (reduced
+frequencies at 3.3 V). Thirty-two power and ground leads minimize ground bounce
+and ensure proper isolation of different sections of the chip, including the
+clock oscillator. A 144 pins are used for signals and power. The MC68340 is
+available in a gull-wing ceramic quad flat pack (CQFP) with 25.6-mil (0.001-in)
+lead spacing or a 15 ´ 15 plastic pin grid array (PPGA) with 0.1-in pin spacing.
+System Integration Module
+The MC68340 SIM40 provides the external bus interface for both the CPU32 and the
+DMA. It also eliminates much of the glue logic that typically supports the
+microprocessor and its interface with the peripheral and memory system. The
+SIM40 provides programmable circuits to perform address decoding and chip
+selects, wait-state insertion, interrupt handling, clock generation, bus
+arbitration, watchdog timing, discrete I/O, and power-on reset timing. A
+boundary scan test capability is also provided.
+External Bus Interface
+The external bus interface (EBI) handles thetransfer of information between the
+internal CPU32 or DMA controller and memory, peripherals, or other processing
+elements in the external address space. Based on the MC68030 bus, the external
+bus provides up to 32 address lines and 16 data lines. Address extensions
+identify each bus cycle as CPU32 or DMA initiated, supervisor or user privilege
+level, and instruction or data access. The data bus allows dynamic sizing for
+8- or 16-bit bus accesses (plus 32 bits for DMA). Synchronous transfers from the
+CPU32 or the DMA can be made in as little as two clock cycles.
+Clock Synthesizer
+The clock synthesizer generates the clock signals used by all internal
+operations as well as a clock output used by external devices. The clock
+synthesizer can operate with an inexpensive 32768-Hz watch crystal or an
+external oscillator for reference, using an internal phase-locked loop and
+voltage-controlled oscillator. At any time, software can select
+clock frequencies from 131 kHz to 16.78 MHz or 25.16 MHz, favoring either low
+power consumption or high performance. Alternately, an external clock can drive
+the clock signal directly at the operating frequency. With its fully static
+HCMOS design, it is possible to completely stop the system clock without losing
+the contents of the internal registers.
gen68360
-TODO.
+Overview
+The MC68360 Quad Integrated Communication Controller (QUICC) is a versatile
+one-chip integrated microprocessor and peripheral combination family that can be
+used in a variety of controller applications.
+The MC68360 particularly excels in communications activities. The QUICC can be
+described as a next-generation MC68302, with higher performance in all areas of
+device operation, increased flexibility, and higher integration. The term "quad"
+comes from the fact that there are four serial communications controllers
+(SCCs) on the device. However, there are actually seven serial channels which
+include four SCCs, two serial management controllers (SMCs), and one serial
+peripheral interface (SPI).
+Features
+CPU + Processor (8.3 MIPS at 33MHz)
+* 32-bit version of the CPU32 core (fully compatible with CPU32)
+* Up to 32-bit Data Bus (Dynamic Bus Sizing for 8- and 16-Bits) + 32 Address
+ Lines
+* Complete static design (0-33 MHz Operation)
+* Slave mode to disable CPU32+ (allows use with external processors)
+ * Multiple QUICCs can share one system bus (one master)
+ * MC68040 companion mode allows QUICC to be an MC68040 companion chip and
+ intelligent peripheral (29 MIPS at 33 MHz)
+ * All QUICC features available in slave mode
+* Memory controller (eight banks)
+ * Contains complete Dynamic Random-Access Memory (DRAM) controller
+ * Glueless interface to DRAM Single In-Line Memory Modules (SIMMs), Static
+ Random-Access Memory (SRAM)
+ * Electrically Programmable Read-Only Memory (EPROM), Flash EPROM, etc.
+ * Boot chip select available at Reset (options for 8-, 16-, or 32-bit
+ memory)
+ * Special features for MC68040 including Burst Mode
+* Four general-purpose timers
+ * Four 16-bit timers or two 32-bit timers
+* Two Independent DMAs (IDMAs)
+* System Integration Module (SIM60)
+ * Bus monitor
+ * Breakpoint logic provides on-chip H/W breakpoints
+ * Spurious interrupt monitor
+ * External masters may use on-chip features such as chip selects
+* Periodic interrupt timer
+* On-chip bus arbitration with no overhead for internal masters
+* Low power stop mode
+* IEEE 1149.1 Test Access Port
+* RISC Communications Processor Module (CPM)
+* Many new commands (e.g., Graceful Stop Transmit, Close RxBD)
+* Supports continuos mode transmission and reception on all serial channels
+* 2.5 kbytes of dual-port RAM
+* 14 Serial DMA (SDMA) channels
+* Three parallel I/O registers with open-drain capability
+* Each serial channel can have its own Pins (NMSI mode)
+* Four baud rate generators
+* Four SCCs
+* Ethernet/IEEE 802.3 optional on SCCs 1-2 at 25 MHz, SCCs 1-3 at 33 MHz
+* HDLC Bus
+* Universal Asynchronous Receiver Transmitter (UART)
+* Synchronous UART
+* Asynchronous HDLC (RAM microcode option) to support PPP (Point to Point
+ Protocol)
+* Two SMCs
+* UART
+* Transparent
+* General Circuit Interface (GCI) controller
+* One SPI
+* Time-Slot assignor
+* Supports two TDM channels
+* Parallel Interface Port (supports fast connection between QUICCs)
+Host controlled Board Setup
+Required equipment:
+* +5 V 5 A power supply
+* +12 V 1 A power supply (optional)
+* Host Computer, one of the following:
+* Sun - 4 (SBus interface)
+* IBM-PC/XT/AT
+* ADI board - compatible with the host computer
+* 37 line flat cable with female 37 pin D-type connectors on each end
+Stand alone Board Setup
+* VT100 compatible terminal
+* RS-232 cable with male 9 pin D-type connector on the QUADS side.
+Debugging BDM controller
+The slave QUICC enables the M68360QUADS to become BDM controller to control
+other QUICC devices on the user application. The BDM feature enables the user to
+download code and provides hardware and software debugging capability of the
+user application. The 8 pin BDM connector P9 utilizes five pins of the slave
+QUICC port B. These pins are configured as general purpose I/O pins.
+Debugging Ethernet controller
+The slave QUICC provides Ethernet port for the M68360QUADS by connecting SCC1 to
+Motorola MC68160 EEST device (U35 in sheet 10). The MC68160 provides two
+Ethernet interfaces, twisted-pair on P8 and AUI on P7. The LEDs LD3-LD8 are
+controlled by the EEST, and they provide indications about the status of the
+Ethernet ports activity. The signals between the slave QUICC and the MC68160
+appear on connector P10 for debugging purposes. P10 is a set of wire holes.
+The socket U24 is installed for internal factory testing only. For proper
+operation of the EEST, this socket must be empty.
+References
+* `User Manual <https://www.nxp.com/docs/en/reference-manual/MC68360UM.pdf>`_
genmcf548x
-TODO.
+Overview
+The MCF548x family is based on the ColdFire V4e core, a complex which comprises
+the ColdFire V4 central processor unit (CPU), an enhanced multiply-accumulate
+unit (EMAC), a memory management unit (MMU), a double-precision floating point
+unit (FPU) conforming to standard IEEE-754, and controllers for caches and local
+data memories. The MCF548x family is capable of performing at an operating
+frequency of up to 200 MHz or 308 MIPS.
+To maximize throughput, the MCF548x family incorporates three independent
+external bus interfaces:
+* The general-purpose local bus (FlexBus) is used for system boot memories and
+ simple peripherals and has up to six chip selects.
+* Program code and data can be stored in SDRAM connected to a dedicated 32-bit
+ double data rate (DDR) bus that can run at up to one-half of the CPU core
+ frequency. The glueless DDR SDRAM controller handles all address multiplexing,
+ input and output strobe timing, and memory bus clock generation.
+* A 32-bit PCI bus compliant with the version 2.2 specification and running at
+ a typical frequency of 25 MHz or 50 MHz supports peripherals that require high
+ bandwidth, the ability to arbitrate for bus mastership, and access to internal
+ MCF548x memory resources.
+References
+* `User Manual <https://www.nxp.com/docs/en/reference-manual/MCF5485RM.pdf>`_
mcf5206elite
-TODO.
+Overview
+The MCF5206e integrated microprocessor combines a Version 2 (V2) ColdFire
+processor core with several peripheral functions such as a DRAM controller,
+timers, general-purpose I/O and serial interfaces, debug module, and system
+integration. Designed for embedded control applications, the V2 ColdFire core
+delivers enhanced performance while maintaining
+low system costs. To speed program execution, the largeon-chip instruction cache
+and SRAM provide one-cycle access to critical code and data. The MCF5206e
+greatly reduces the time required for system design and implementation by
+packaging common system functions on chip and providing glueless interfaces to 8
+bit, 16 bit, and 32 bit DRAM, SRAM, ROM, and I/O devices.
+The MCF5206e is an enhanced version of the MCF5206 processor, with the same
+peripheral set, DMA, MAC, Hardware Divide, larger cache, and larger SRAM. It is
+pin compatible with the MCF5206, with the DMA pins muxed with Timer 0 pins.
+References
mcf52235
-TODO.
+Overview
+The MCF52235 represents a family of highly-integrated 32-bit microcontrollers
+based on the V2 ColdFire microarchitecture. Featuring up to 32 Kbytes of
+internal SRAM and 256 Kbytes of flash memory, four 32-bit timers with DMA
+request capability, a 4-channel DMA controller, fast Ethernet controller,
+a CAN module, an I2C module, 3 UARTs and a queued SPI, the MC52235 family has
+been designed for general-purpose industrial control applications.
+This 32-bit device is based on the Version 2 ColdFire core operating at a
+frequency up to 60 MHz, offering high performance and low power consumption.
+On-chip memories connected tightly to the processor core include up to 256
+Kbytes of Flash and 32 Kbytes of static random access memory (SRAM).
+This BSP was heavily based on the MCF5235 BSP.
+Key features
+* Version 2 ColdFire variable-length RISC processor core
+* System debug support
+* On-chip memories
+* Power management
+* Fast Ethernet Controller (FEC)
+* On-chip Ethernet Transceiver (EPHY)
+* FlexCAN 2.0B module
+* Three universal asynchronous/synchronous receiver transmitters (UARTs)
+* I2C module
+* Queued serial peripheral interface (QSPI)
+* Fast analog-to-digital converter (ADC)
+* Four 32-bit DMA timers
+* Four-channel general purpose timers
+* Pulse-width modulation timer
+* Real-Time Clock (RTC)
+* Two periodic interrupt timers (PITs)
+* Software watchdog timer
+* Clock Generation Features
+* Dual Interrupt Controllers (INTC0/INTC1)
+* DMA controller
+* Reset
+* Chip integration module (CIM)
+* General purpose I/O interface
+* JTAG support for system level board testing
+Board Setup
+To setup, we will display the firmware settings using the boot monitor's "state"
+command:
+.. code-block:: none
+ INET> state
+ iface 0- IP addr:192.168.1.99 subnet:255.255.255.0 gateway:192.168.1.1
+ current tick count 4204
+ Task wakeups:netmain: 27
+ nettick: 2102
+ keyboard: 2099
mcf5225x
@@ -48,7 +401,36 @@ TODO.
mcf5235
-TODO.
+Overview
+The MCF5235EVB is a Motorola evaluation board that is based on the Coldfire
+MCF5235 32-bit processor. The board includes 32 Mbytes of SDRAM, 2Mbytes of
+flash, the MCF5235 processor with a max core frequency of 150MHz, Ethernet
+support, and CAN bus support. This BSP has also been tested to work with the
+Coldfire MCF5270 processor with a max core frequency of 100MHz.
+This BSP has also been tested to work with the newer Freescale M5235BCC
+evaluation board and with the Axiom Manufacturing CMM-5235 Board.
+The BSP provides support to run applications from both RAM when debugging and
+from Flash when the application is complete.
+Board Setup
+Here is the setup for the Axiom M5235BCC in the RTEMS Lab:
+ dBUG> show
+ base: 16 baud: 19200
+ server: 192.168.1.92 client: 192.168.1.241
+ gateway: 192.168.1.14 netmask: 255.255.255.0
+ filename: /mcf5235.exe filetype: ELF
+ ethaddr: 00:20:DD:00:00:11
+Downloading and Executing
mcf5329
@@ -75,12 +457,132 @@ TODO.
mvme147
-TODO.
+Overview
+The MVME147 is a double-high VMEmodule based on the MC68030 microprocessor. It
+is best utilized in a 32-bit VMEbus system with both P1 and P2 backplanes. The
+module has high functionality with large onboard shared RAM, serial ports, and
+Centronics printer port. The module provides a SCSI bus controller with DMA,
+floating-point coprocessor, tick timer, watchdog timer, and time-of-day
+clock/calendar with battery backup, 4KB of static RAM with battery backup, four
+ROM sockets, and A32/D32 VMEbus interface with system controller functions.
+Key Features
+* 16, 25, or 33.33 MHz MC68030 enhanced 32-bit microprocessor
+* 16, 25, or 33.33 MHz MC68882 floating-point coprocessor
+* 4, 8, 16, or 32MB of shared DRAM, with programmable parity
+* 4K x 8 SRAM and time-of-day clock with battery backup
+* Four 28/32-pin ROM/PROM/EPROM/EEPROM sockets, 16 bits wide
+* A32/D32 VMEbus master/slave interface with system controller function
+* Four EIA-232-D serial communications ports
+* Centronics compatible printer port
+* Two 16-bit timers and watchdog timer
+* SCSI bus interface with DMA
+* Ethernet transceiver interface
+* 4-level requester, 7-level interrupter, and 7-level interrupt handler for
+ VMEbus
+* On-board debugger and diagnostic firmware
+Board Setup
+Set jumpers on your MVME147 module. Ensure that ROM devices are properly
+installed in the sockets. Install your MVME147 module in the chassis. Set
+jumpers on the transition board; connect and install the transition board, P2
+adapter module, and optional SCSI device cables. Connect a console terminal to
+the MVME712. Connect any other optional devices or equipment you will be using.
+Power up the system. Note that the debugger prompt appears. Initialize the
+clock. Examine and/or change environmental parameters. Program the PCCchip and
+VMEchip.
+See `manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>`_ for further
+information.
+There are various ways to enter a user program into system memory for execution.
+One way is to create the program using the Memory Modify (MM) command with the
+assembler/disassembler option. You enter the program one source line at a time.
+After each source line is entered, it is assembled and the object code loads
+into memory. Refer to the MVME147 BUG 147Bug Debugging Package User's Manual for
+complete details of the 147Bug Assembler/Disassembler. Another way to enter a
+program is to download an object file from a host system. The program must be in
+S-record format (described in the MVME147BUG 147Bug Debugging Package User's
+Manual) and may have been assembled or compiled on the host system. Alternately,
+the program may have been previously created using the 147Bug MM command as
+outlined above and stored to the host using the Dump (DU) command. A
+communication link must exist between the host system and the MVME147. The file
+is downloaded from the host to MVME147 memory by the Load (LO) command.
+References
+* `User Manual <ppd.fnal.gov/experiments/e907/TPC/DAQ/147aih.pdf>`_
mvme147s
-TODO.
+Overview
+The MVME 147s is extremely similar to the Mvme147. The main difference between
+them is that the 147s also has only 2KB of static RAM while the 147 has 4KB.
+Another small difference between them is the time-of-day clock. The MVME147s has
+a Mostek MK48T02 while the MVME147 has an M48T18.
+The MVME147S is a double-high VMEmodule and is best utilized in a 32-bit VMEbus
+system with both P1 and P2 backplanes. The module has high functionality with
+large onboard shared RAM, serial ports, and Centronics printer port. The module
+provides a SCSI bus controller with DMA, floating-point coprocessor, tick timer,
+watchdog timer, and time-of-day clock/calendar with battery backup, 2KB of
+static RAM with battery backup, four ROM sockets, and A32/D32 VMEbus interface
+with system controller functions are also provided. The MVME147S can be operated
+as part of a VMEbus system with other VMEmodules such as RAM modules, CPU
+modules, graphics modules, and analog I/O modules.
+Board Setup
+To select the desired configuration and ensure proper operation of the MVME147S
+module, certain changes may be made before installation. These changes are made
+through jumper arrangements on the headers. The module has been factory tested
+and is shipped with factory-installed jumper configurations. The module is
+operational with the factory-installed jumpers. The module is configured to
+provide the system functions required for a VMEbus system. It is necessary to
+make changes in the jumper arrangements for the following conditions:
+System controller select (J3) Factory use only (J5, J6) ROM configuration select
+ (J1, J2) Serial port 4 clock configuration select (J8, J9)
+See `manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf>`_ for further
+information.
+Alternately, the program may have been previously created using the 147Bug MM
+command as outlined above and stored to the host using the Dump (DU) command.
+A communication link must exist between the host system and the MVME147. The
+file is downloaded from the host to MVME147 memory by the Load (LO) command.
+References
+* `User Manual <www.ing.iac.es/~docs/external/vme/147s_d3.pdf>`_
mvme162
@@ -112,99 +614,99 @@ The env settings are:
MPU Clock Speed =25Mhz
162-Bug>env
- Bug or System environment [B/S] = B?
- Field Service Menu Enable [Y/N] = N?
- Remote Start Method Switch [G/M/B/N] = B?
- Probe System for Supported I/O Controllers [Y/N] = Y?
- Negate VMEbus SYSFAIL* Always [Y/N] = N?
- Local SCSI Bus Reset on Debugger Startup [Y/N] = N?
- Local SCSI Bus Negotiations Type [A/S/N] = A?
- Industry Pack Reset on Debugger Startup [Y/N] = Y?
- Ignore CFGA Block on a Hard Disk Boot [Y/N] = Y?
- Auto Boot Enable [Y/N] = N?
- Auto Boot at power-up only [Y/N] = Y?
- Auto Boot Controller LUN = 00?
- Auto Boot Device LUN = 00?
- Auto Boot Abort Delay = 15?
- Auto Boot Default String [NULL for a empty string] = ?
- ROM Boot Enable [Y/N] = N?
- ROM Boot at power-up only [Y/N] = Y?
- ROM Boot Enable search of VMEbus [Y/N] = N?
- ROM Boot Abort Delay = 0?
- ROM Boot Direct Starting Address = FF800000?
- ROM Boot Direct Ending Address = FFDFFFFC?
- Network Auto Boot Enable [Y/N] = N?
- Network Auto Boot at power-up only [Y/N] = Y?
- Network Auto Boot Controller LUN = 00?
- Network Auto Boot Device LUN = 00?
- Network Auto Boot Abort Delay = 5?
- Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00?
- Memory Search Starting Address = 00000000?
- Memory Search Ending Address = 01000000?
- Memory Search Increment Size = 00010000?
- Memory Search Delay Enable [Y/N] = N?
- Memory Search Delay Address = FFFFD20F?
- Memory Size Enable [Y/N] = Y?
- Memory Size Starting Address = 00000000?
- Memory Size Ending Address = 01000000?
- Base Address of Dynamic Memory = 00000000?
- Size of Parity Memory = 00000000?
- Size of ECC Memory Board #0 = 01000000?
- Size of ECC Memory Board #1 = 00000000?
- Base Address of Static Memory = FFE00000?
- Size of Static Memory = 00020000?
- Slave Enable #1 [Y/N] = Y?
- Slave Starting Address #1 = 00000000?
- Slave Ending Address #1 = 00FFFFFF?
- Slave Address Translation Address #1 = 00000000?
- Slave Address Translation Select #1 = 00000000?
- Slave Control #1 = 03FF?
- Slave Enable #2 [Y/N] = N?
- Slave Starting Address #2 = 00000000?
- Slave Ending Address #2 = 00000000?
- Slave Address Translation Address #2 = 00000000?
- Slave Address Translation Select #2 = 00000000?
- Slave Control #2 = 0000?
- Master Enable #1 [Y/N] = Y?
- Master Starting Address #1 = 01000000?
- Master Ending Address #1 = EFFFFFFF?
- Master Control #1 = 0D?
- Master Enable #2 [Y/N] = N?
- Master Starting Address #2 = 00000000?
- Master Ending Address #2 = 00000000?
- Master Control #2 = 00?
- Master Enable #3 [Y/N] = N?
- Master Starting Address #3 = 00000000?
- Master Ending Address #3 = 00000000?
- Master Control #3 = 00?
- Master Enable #4 [Y/N] = N?
- Master Starting Address #4 = 00000000?
- Master Ending Address #4 = 00000000?
- Master Address Translation Address #4 = 00000000?
- Master Address Translation Select #4 = 00000000?
- Master Control #4 = 00?
- Short I/O (VMEbus A16) Enable [Y/N] = Y?
- Short I/O (VMEbus A16) Control = 01?
- F-Page (VMEbus A24) Enable [Y/N] = Y?
- F-Page (VMEbus A24) Control = 02?
- ROM Access Time Code = 03?
- FLASH Access Time Code = 02?
- MCC Vector Base = 05?
- VMEC2 Vector Base #1 = 06?
- VMEC2 Vector Base #2 = 07?
- VMEC2 GCSR Group Base Address = D2?
- VMEC2 GCSR Board Base Address = 00?
- VMEbus Global Time Out Code = 01?
- Local Bus Time Out Code = 02?
- VMEbus Access Time Out Code = 02?
- IP A Base Address = 00000000?
- IP B Base Address = 00000000?
- IP C Base Address = 00000000?
- IP D Base Address = 00000000?
- IP D/C/B/A Memory Size = 00000000?
- IP D/C/B/A General Control = 00000000?
- IP D/C/B/A Interrupt 0 Control = 00000000?
- IP D/C/B/A Interrupt 1 Control = 00000000?
+ Bug or System environment [B/S] = B
+ Field Service Menu Enable [Y/N] = N
+ Remote Start Method Switch [G/M/B/N] = B
+ Probe System for Supported I/O Controllers [Y/N] = Y
+ Negate VMEbus SYSFAIL* Always [Y/N] = N
+ Local SCSI Bus Reset on Debugger Startup [Y/N] = N
+ Local SCSI Bus Negotiations Type [A/S/N] = A
+ Industry Pack Reset on Debugger Startup [Y/N] = Y
+ Ignore CFGA Block on a Hard Disk Boot [Y/N] = Y
+ Auto Boot Enable [Y/N] = N
+ Auto Boot at power-up only [Y/N] = Y
+ Auto Boot Controller LUN = 00
+ Auto Boot Device LUN = 00
+ Auto Boot Abort Delay = 15
+ Auto Boot Default String [NULL for a empty string] =
+ ROM Boot Enable [Y/N] = N
+ ROM Boot at power-up only [Y/N] = Y
+ ROM Boot Enable search of VMEbus [Y/N] = N
+ ROM Boot Abort Delay = 0
+ ROM Boot Direct Starting Address = FF800000
+ ROM Boot Direct Ending Address = FFDFFFFC
+ Network Auto Boot Enable [Y/N] = N
+ Network Auto Boot at power-up only [Y/N] = Y
+ Network Auto Boot Controller LUN = 00
+ Network Auto Boot Device LUN = 00
+ Network Auto Boot Abort Delay = 5
+ Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFE0FF00
+ Memory Search Starting Address = 00000000
+ Memory Search Ending Address = 01000000
+ Memory Search Increment Size = 00010000
+ Memory Search Delay Enable [Y/N] = N
+ Memory Search Delay Address = FFFFD20F
+ Memory Size Enable [Y/N] = Y
+ Memory Size Starting Address = 00000000
+ Memory Size Ending Address = 01000000
+ Base Address of Dynamic Memory = 00000000
+ Size of Parity Memory = 00000000
+ Size of ECC Memory Board #0 = 01000000
+ Size of ECC Memory Board #1 = 00000000
+ Base Address of Static Memory = FFE00000
+ Size of Static Memory = 00020000
+ Slave Enable #1 [Y/N] = Y
+ Slave Starting Address #1 = 00000000
+ Slave Ending Address #1 = 00FFFFFF
+ Slave Address Translation Address #1 = 00000000
+ Slave Address Translation Select #1 = 00000000
+ Slave Control #1 = 03FF
+ Slave Enable #2 [Y/N] = N
+ Slave Starting Address #2 = 00000000
+ Slave Ending Address #2 = 00000000
+ Slave Address Translation Address #2 = 00000000
+ Slave Address Translation Select #2 = 00000000
+ Slave Control #2 = 0000
+ Master Enable #1 [Y/N] = Y
+ Master Starting Address #1 = 01000000
+ Master Ending Address #1 = EFFFFFFF
+ Master Control #1 = 0D
+ Master Enable #2 [Y/N] = N
+ Master Starting Address #2 = 00000000
+ Master Ending Address #2 = 00000000
+ Master Control #2 = 00
+ Master Enable #3 [Y/N] = N
+ Master Starting Address #3 = 00000000
+ Master Ending Address #3 = 00000000
+ Master Control #3 = 00
+ Master Enable #4 [Y/N] = N
+ Master Starting Address #4 = 00000000
+ Master Ending Address #4 = 00000000
+ Master Address Translation Address #4 = 00000000
+ Master Address Translation Select #4 = 00000000
+ Master Control #4 = 00
+ Short I/O (VMEbus A16) Enable [Y/N] = Y
+ Short I/O (VMEbus A16) Control = 01
+ F-Page (VMEbus A24) Enable [Y/N] = Y
+ F-Page (VMEbus A24) Control = 02
+ ROM Access Time Code = 03
+ FLASH Access Time Code = 02
+ MCC Vector Base = 05
+ VMEC2 Vector Base #1 = 06
+ VMEC2 Vector Base #2 = 07
+ VMEC2 GCSR Group Base Address = D2
+ VMEC2 GCSR Board Base Address = 00
+ VMEbus Global Time Out Code = 01
+ Local Bus Time Out Code = 02
+ VMEbus Access Time Out Code = 02
+ IP A Base Address = 00000000
+ IP B Base Address = 00000000
+ IP C Base Address = 00000000
+ IP D Base Address = 00000000
+ IP D/C/B/A Memory Size = 00000000
+ IP D/C/B/A General Control = 00000000
+ IP D/C/B/A Interrupt 0 Control = 00000000
+ IP D/C/B/A Interrupt 1 Control = 00000000
To setup the Server/Client IP Addresses for the TFTP Transfer, we will use the
NIOT command. NIOT (Network I/O Teach) is a 162-Bug's debugger command commonly
@@ -215,26 +717,26 @@ The NIOT command goes something like this:
162-Bug>niot
- Controller LUN =00?
- Device LUN =00?
- Node Control Memory Address =FFE10000?
- Client IP Address =192.168.1.245?
- Server IP Address =192.168.1.92?
- Subnet IP Address Mask =255.255.255.0?
- Broadcast IP Address =192.168.1.255?
- Gateway IP Address =0.0.0.0?
- Boot File Name ("NULL" for None) =/mvme162.img?
- Argument File Name ("NULL" for None) =?
- Boot File Load Address =00020000?
- Boot File Execution Address =00020000?
- Boot File Execution Delay =00000000?
- Boot File Length =00000000?
- Boot File Byte Offset =00000000?
- BOOTP/RARP Request Retry =00?
- TFTP/ARP Request Retry =00?
- Trace Character Buffer Address =00000000?
- BOOTP/RARP Request Control: Always/When-Needed (A/W)=A?
- BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y?
+ Controller LUN =00
+ Device LUN =00
+ Node Control Memory Address =FFE10000
+ Client IP Address =192.168.1.245
+ Server IP Address =192.168.1.92
+ Subnet IP Address Mask =255.255.255.0
+ Broadcast IP Address =192.168.1.255
+ Gateway IP Address =0.0.0.0
+ Boot File Name ("NULL" for None) =/mvme162.img
+ Argument File Name ("NULL" for None) =
+ Boot File Load Address =00020000
+ Boot File Execution Address =00020000
+ Boot File Execution Delay =00000000
+ Boot File Length =00000000
+ Boot File Byte Offset =00000000
+ BOOTP/RARP Request Retry =00
+ TFTP/ARP Request Retry =00
+ Trace Character Buffer Address =00000000
+ BOOTP/RARP Request Control: Always/When-Needed (A/W)=A
+ BOOTP/RARP Reply Update Control: Yes/No (Y/N) =Y
@@ -264,9 +766,307 @@ The program will automatically run when download is complete.
mvme167
-TODO.
+Overview
+The MVME167 is a double-high VMEmodule based on the MC68040 microprocessor.The
+MVME167 has 4/8/16/32/64 MB of parity-protected DRAM or4/8/16/32/64/128/256 MB
+of ECC-protected DRAM, 8KB of static RAM and time of day clock (with
+battery backup), Ethernet transceiver interface, four serial ports with
+EIA-232-D interface, four tick timers, watchdog timer, four ROM sockets, SCSI
+bus interface with DMA, Centronics printer port, A16/A24/A32/D8/D16/D32/D64
+VMEbus master/slave interface, 128KB of static RAM (with optional battery
+backup),and VMEbus system controller.
+Firmware Setup
+The mvme167 BSP by default (i.e., unless you tamper with the linkcmds) is linked
+at 0x00800000 and the firmware has to be properly configured so that loading and
+executing at that address is possible: # The board's RAM must be mapped
+starting at address 0x00800000 (and not zero as may seem more natural and which
+IIRC is 167Bug's default). ## Use 167Bug's 'env' command to set the 'Base
+Address of Local Memory' to 00800000. ## Use 167Bug's 'niot' command to set the
+download and execution address to 00800000. # By default, the 167Bug firmware
+uses the lowest 64k block of RAM it finds for internal data and this conflicts
+with RTEMS' needs. 167Bug won't allow you to download the RTEMS image to
+0x00800000 unless you instruct 167Bug to use another area (e.g., static RAM) for
+it's internal data. ## Use 167Bug's 'env' command to set both, the 'Memory
+Search Starting Address' and 'Memory Search Ending Address' to zero.
+The 'search' area is the address-range that is scanned by 167Bug when it tries
+to find an area for it's internal data. If it finds no RAM (since start==end)
+then it uses static RAM and 00800000 and up can be used by RTEMS.
+These are the 'env' settings:
+ MPU Clock Speed =25Mhz
+ 167-Bug>env
+ ROM Boot Direct Ending Address = FFBFFFFC
+ Network Auto Boot Configuration Parameters Pointer (NVRAM) = FFFC0000
+ Memory Search Ending Address = 00000000
+ Memory Search Delay Address = FFFFCE0F
+ Base Address of Local Memory = 00800000
+ Size of Local Memory Board #0 = 00800000
+ Size of Local Memory Board #1 = 00000000
+ Slave Ending Address #1 = 007FFFFF
+ Slave Address Translation Select #1 = FF800000
+ Slave Control #1 = 00FF
+ Slave Starting Address #2 = FFE00000
+ Slave Ending Address #2 = FFE1FFFF
+ Slave Control #2 = 01EF
+ Master Starting Address #3 = 00800000
+ Master Ending Address #3 = 00FFFFFF
+ Master Control #3 = 3D
+ ROM Speed Bank A Code = 05
+ ROM Speed Bank B Code = 05
+ Static RAM Speed Code = 01
+ PCC2 Vector Base = 05
+ VMEC2 GCSR Group Base Address = CC
+ Local Bus Time Out Code = 00
+ 167-Bug>
+NIOT (Network I/O Teach) is a 167-Bug's debugger command commonly
+used to setup the Server/Client IP Addresses for the TFTP Transfer.
+The NIOT command goes something like this:
+ 167-Bug>niot
+ Device LUN =00
+ Client IP Address =0.0.0.0
+ Server IP Address =0.0.0.0
+ Subnet IP Address Mask =0.0.0.0
+ Broadcast IP Address =0.0.0.0
+ Boot File Load Address =00800000
+ Boot File Execution Address =00800000
+ 167-Bug>
+RTEMS Lab Board Setup
+The firmware setup instructions above are true for the RTEMS Lab board except
+for the memory search addresses. Set these as follows:
+ Memory Search Starting Address = FFE00000
+ Memory Search Ending Address = FFE10000
+These are the RTEMS Lab board settings:
+ 167-Bug>env
+ Auto Boot Default String [Y(NULL String)/(String)] =
+ Network Auto Boot at power-up only [Y/N] = N
+ Size of Local Memory Board #0 = 01000000
+ Slave Ending Address #2 = FFE10000
+ Master Control #3 = 30
+ 167-Bug>niot
+ Device LUN =00
+ Broadcast IP Address =255.255.255.255
+ BOOTP/RARP Reply Update Control: Yes/No (Y/N) =N
+References
+* `User Manual <https://prep.fnal.gov/catalog/hardware_info/motorola/mvme167_d3.pdf>`_
uC5282
-TODO.
+Overview
+The uC5282 is a compact, embedded microprocessor module ideal for networked
+control and communication applications. The device is available in a standard
+144pin soDIMM edge connector format to allow fast integration into products.
+The module is based on the Freescale ColdFire MCF5282 microprocessor and
+includes all required system memory and physical terminations to enable most
+applications without the need for external circuitry. The uC5282 features
+Ethernet, CAN and serial communications systems as well as standard peripheral
+device connectivity using I2C, QSPI or data/address logic.
+References
2.17.1
