Build Linux: FAILED 5/bsps/atsamv on x86_64-linux-gnu (rtems-libbsd-v816a2f912f414f39467a6be901a96159f806c01d-x86_64-linux-gnu-1)
Tue Apr 7 05:01:39 UTC 2020
Hello,
I am not sure what we should do with this one. The libbsd is well
supported on this BSP, however, with default options, the BSP has not
enough memory to link all the libbsd tests. For this BSP you likely have
to specify some BSP options to build it for your target. I suggest to
remove this build set.
