[PATCH] 5/bsps: Remove build set for atsamv
Sebastian Huber
Tue Apr 7 13:39:48 UTC 2020
It is not possible to build libbsd with the standard settings of this
BSP. The BSP is also highly configurable and it is unlikely that the
RSB built configuration runs on a custom board.
rtems/config/5/bsps/atsamv.bset | 10 ----------
1 file changed, 10 deletions(-)
delete mode 100644 rtems/config/5/bsps/atsamv.bset
diff --git a/rtems/config/5/bsps/atsamv.bset b/rtems/config/5/bsps/atsamv.bset
deleted file mode 100644
index 4bde317..0000000
--- a/rtems/config/5/bsps/atsamv.bset
+++ /dev/null
@@ -1,10 +0,0 @@
-%define mail_single_report 1
-%define with_rtems_bsp atsamv
-%define rtems_target arm-rtems5
-%define rtems_host %{rtems_target}
-5/rtems-arm
-5/rtems-kernel
-5/rtems-libbsd
-5/rtems-packages
2.16.4
