[PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
Wed Apr 8 20:08:59 UTC 2020
On Wed, Apr 8, 2020 at 1:35 PM <Jan.Sommer at dlr.de> wrote:
> Could you give me some direction where we would add the documentation and what is missing?
> The pc-run.ini is basically a copy of the xilinx_zynq_zedboard.ini with just a different tester.
> Or do you mean the change in the run.cfg?
Sorry this inquiry more relates to your other thread that led you to
find this solution. You mentioned that you did not find the solution
easily in the docs, so figuring out how to make it easier to
understand how to do this would be great. Not needed to apply your
patch though.
> Von: Gedare Bloom [mailto:gedare at rtems.org]
> Gesendet: Mittwoch, 8. April 2020 19:07
> An: Sommer, Jan
> Cc: devel at rtems.org
> Betreff: Re: [PATCH 0/2] [rtems-tools] Allow telnet tty devices for run.cfg
> These look alright to me, although I wonder if we need some bsp doc for this setup?
> On Wed, Apr 8, 2020, 9:23 AM Jan Sommer <jan.sommer at dlr.de> wrote:
> Here are the changes I did for our local setup.
> The first patch enableds telnet tty devices for run.cfg setups
> The second add a run configuration for the pc BSP
> Jan Sommer (2):
>   tester: Allow telnet tty devices for run.cfg
>   tester: Add configuration pc-run.ini
>  tester/rtems/testing/bsps/pc-run.ini | 41 ++++++++++++++++++++++++++++++++++++
>  tester/rtems/testing/run.cfg         |  4 +++-
>  2 files changed, 44 insertions(+), 1 deletion(-)
>  create mode 100644 tester/rtems/testing/bsps/pc-run.ini
> 2.12.3
> _____________________________________________
> devel mailing list
> devel at rtems.org
