[PATCH rtems-libbsd v2 12/14] ehci_imx: Add to build.
Vijay Kumar Banerjee vijay at rtems.org
Thu Apr 16 08:27:14 UTC 2020
On Thu, Apr 16, 2020 at 1:51 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 16/04/2020 09:41, Christian Mauderer wrote:
> > On 16/04/2020 09:21, Vijay Kumar Banerjee wrote:
> >> On Thu, Apr 16, 2020 at 12:41 PM Christian Mauderer
> >> <christian.mauderer at embedded-brains.de
> >> <mailto:christian.mauderer at embedded-brains.de>> wrote:
> >>     Hello Vijay,
> >>     On 16/04/2020 09:04, Vijay Kumar Banerjee wrote:
> >>     > Hi Christian,
> >>     > I'm not able to build libbsd with this patch. I'm getting the
> >>     following
> >>     > error:
> >>     > ../../freebsd/sys/dev/usb/controller/ehci_imx.c:70:10: fatal
> error:
> >>     > arm/freescale/imx/imx_ccmvar.h: No such file or directory
> >>     >  #include <arm/freescale/imx/imx_ccmvar.h>
> >>     > From git blame I got to know that this file was introduced by the
> >>     commit
> >>     > from this patch.
> >>     > Am I missing something or is it really a bug?
> >>     Thanks for the report. On what BSP and which exact commit did you
> try to
> >>     build? I had no trouble building the patch set from a clean checkout
> >>     yesterday before committing it.
> >> I did a pull from the upstream master and tried the build on
> >> arm/beagleboneblack
> >> I see that the header file is not present in the freebsd/ directory
> >> rtems-libbsd $>find -iname imx_ccmvar.h
> >> ./freebsd-org/sys/arm/freescale/imx/imx_ccmvar.h
> > Hello Vijay,
> > that's quite clearly a bug that I introduced. I'll create a patch.
> > The imx_ccmvar.h is a file that is provided by the BSP I used for
> testing.
> > Best regards
> > Christian
> I've sent a patch. Can you test it?
> Sure. I don't see the patch on the list yet, I'll test it as soon as it
comes :)
> >>     > Sorry for commenting on the patch that has already been committed,
> >>     > please let me know of
> >>     > the preferred way to comment on a commit if this is not the right
> way.
> >>     No problem. That's exactly the right way to do it. If there is a
> bug it
> >>     has to be solved and everyone should know that someone is having a
> look
> >>     at it.
> >>     Best regards
> >>     Christian
> >>     > Best regards,
> >>     > Vijay
> >>     > On Tue, Apr 14, 2020 at 8:21 PM Christian Mauderer
> >>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> >>     >      libbsd.py                            | 2 ++
> >>     >      rtemsbsd/include/bsp/nexus-devices.h | 5 +++++
> >>     >      2 files changed, 7 insertions(+)
> >>     >     diff --git a/libbsd.py b/libbsd.py
> >>     >     index 4f8fb4d2..ed6493b2 100644
> >>     >     --- a/libbsd.py
> >>     >     +++ b/libbsd.py
> >>     >     @@ -5028,6 +5028,8 @@ class imx(builder.Module):
> >>     >              self.addKernelSpaceSourceFiles(
> >>     >                      'sys/arm/freescale/imx/imx6_ccm.c',
> >>     >     +                'sys/arm/freescale/imx/imx6_usbphy.c',
> >>     >     +                'sys/dev/usb/controller/ehci_imx.c',
> >>     >                  mm.generator['source']()
> >>     >     diff --git a/rtemsbsd/include/bsp/nexus-devices.h
> >>     >     b/rtemsbsd/include/bsp/nexus-devices.h
> >>     >     index 0a210bd9..d2ceab8e 100644
> >>     >     --- a/rtemsbsd/include/bsp/nexus-devices.h
> >>     >     +++ b/rtemsbsd/include/bsp/nexus-devices.h
> >>     >     @@ -128,6 +128,11 @@ RTEMS_BSD_DEFINE_NEXUS_DEVICE(ofwbus, 0,
> >>     0, NULL);
> >>     >      SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
> >>     >      SYSINIT_DRIVER_REFERENCE(ccm, simplebus);
> >>     >     +SYSINIT_DRIVER_REFERENCE(ehci, simplebus);
> >>     >     +SYSINIT_DRIVER_REFERENCE(usbphy, simplebus);
> >>     >     +SYSINIT_DRIVER_REFERENCE(usbus, ehci);
> >>     >     +RTEMS_BSD_DRIVER_USB;
> >>     >     +RTEMS_BSD_DRIVER_USB_MASS;
> >>     >      SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
> >>     >      SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
> >>     >     2.16.4
> >>     >     _______________________________________________
> >>     >     devel mailing list
> >>     >     devel at rtems.org <mailto:devel at rtems.org>
> >>     <mailto:devel at rtems.org <mailto:devel at rtems.org>>
> >>     >     http://lists.rtems.org/mailman/listinfo/devel
> >>     embedded brains GmbH
> >>     Herr Christian Mauderer
> >>     Dornierstr. 4
> >>     D-82178 Puchheim
> >>     Germany
> >>     email: christian.mauderer at embedded-brains.de
> >>     Phone: +49-89-18 94 741 - 18
> >>     Fax:   +49-89-18 94 741 - 08
> >>     PGP: Public key available on request.
> >>     Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des
> EHUG.
> Dornierstr. 4
> D-82178 Puchheim
> Germany
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200416/9d854c7a/attachment.html>
