[PATCH rtems-libbsd v2 12/14] ehci_imx: Add to build.
Christian Mauderer christian.mauderer at embedded-brains.de
Thu Apr 16 08:31:51 UTC 2020
On 16/04/2020 10:27, Vijay Kumar Banerjee wrote:
> On Thu, Apr 16, 2020 at 1:51 PM Christian Mauderer
> <christian.mauderer at embedded-brains.de
> <mailto:christian.mauderer at embedded-brains.de>> wrote:
>     On 16/04/2020 09:41, Christian Mauderer wrote:
>     > On 16/04/2020 09:21, Vijay Kumar Banerjee wrote:
>     >> On Thu, Apr 16, 2020 at 12:41 PM Christian Mauderer
>     <mailto:christian.mauderer at embedded-brains.de>>> wrote:
>     >>     Hello Vijay,
>     >>     On 16/04/2020 09:04, Vijay Kumar Banerjee wrote:
>     >>     > Hi Christian,
>     >>     > I'm not able to build libbsd with this patch. I'm getting the
>     >>     following
>     >>     > error:
>     >>     > ../../freebsd/sys/dev/usb/controller/ehci_imx.c:70:10:
>     fatal error:
>     >>     > arm/freescale/imx/imx_ccmvar.h: No such file or directory
>     >>     >  #include <arm/freescale/imx/imx_ccmvar.h>
>     >>     > From git blame I got to know that this file was introduced
>     by the
>     >>     commit
>     >>     > from this patch.
>     >>     > Am I missing something or is it really a bug?
>     >>     Thanks for the report. On what BSP and which exact commit did
>     you try to
>     >>     build? I had no trouble building the patch set from a clean
>     checkout
>     >>     yesterday before committing it.
>     >> I did a pull from the upstream master and tried the build on
>     >> arm/beagleboneblack
>     >> I see that the header file is not present in the freebsd/ directory
>     >> rtems-libbsd $>find -iname imx_ccmvar.h
>     >> ./freebsd-org/sys/arm/freescale/imx/imx_ccmvar.h
>     > Hello Vijay,
>     > that's quite clearly a bug that I introduced. I'll create a patch.
>     > The imx_ccmvar.h is a file that is provided by the BSP I used for
>     testing.
>     > Best regards
>     > Christian
>     I've sent a patch. Can you test it?
> Sure. I don't see the patch on the list yet, I'll test it as soon as it
> comes :)
Odd. It's already sent out and I CCd you directly. But the archive
hasn't seen it either. To be sure, I attached the patch here.
>     >>     > Sorry for commenting on the patch that has already been
>     committed,
>     >>     > please let me know of
>     >>     > the preferred way to comment on a commit if this is not the
>     right way.
>     >>     No problem. That's exactly the right way to do it. If there
>     is a bug it
>     >>     has to be solved and everyone should know that someone is
>     having a look
>     >>     at it.
>     >>     Best regards
>     >>     Christian
embedded brains GmbH
Herr Christian Mauderer
Dornierstr. 4
D-82178 Puchheim
Germany
Phone: +49-89-18 94 741 - 18
Fax:   +49-89-18 94 741 - 08
PGP: Public key available on request.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200416/93a07236/attachment-0001.bin>
