[PATCH rtems-libbsd v2 12/14] ehci_imx: Add to build.
Vijay Kumar Banerjee
vijay at rtems.org
Thu Apr 16 08:44:01 UTC 2020
On Thu, Apr 16, 2020 at 2:08 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> On 16/04/2020 10:27, Vijay Kumar Banerjee wrote:
> > On Thu, Apr 16, 2020 at 1:51 PM Christian Mauderer
> > <christian.mauderer at embedded-brains.de
> > <mailto:christian.mauderer at embedded-brains.de>> wrote:
> > On 16/04/2020 09:41, Christian Mauderer wrote:
> > > On 16/04/2020 09:21, Vijay Kumar Banerjee wrote:
> > >> On Thu, Apr 16, 2020 at 12:41 PM Christian Mauderer
> > <mailto:christian.mauderer at embedded-brains.de>>> wrote:
> > >> Hello Vijay,
> > >> On 16/04/2020 09:04, Vijay Kumar Banerjee wrote:
> > >> > Hi Christian,
> > >> > I'm not able to build libbsd with this patch. I'm getting
> the
> > >> following
> > >> > error:
> > >> > ../../freebsd/sys/dev/usb/controller/ehci_imx.c:70:10:
> > fatal error:
> > >> > arm/freescale/imx/imx_ccmvar.h: No such file or directory
> > >> > #include <arm/freescale/imx/imx_ccmvar.h>
> > >> > From git blame I got to know that this file was introduced
> > by the
> > >> commit
> > >> > from this patch.
> > >> > Am I missing something or is it really a bug?
> > >> Thanks for the report. On what BSP and which exact commit did
> > you try to
> > >> build? I had no trouble building the patch set from a clean
> > checkout
> > >> yesterday before committing it.
> > >> I did a pull from the upstream master and tried the build on
> > >> arm/beagleboneblack
> > >> I see that the header file is not present in the freebsd/
> directory
> > >> rtems-libbsd $>find -iname imx_ccmvar.h
> > >> ./freebsd-org/sys/arm/freescale/imx/imx_ccmvar.h
> > > Hello Vijay,
> > > that's quite clearly a bug that I introduced. I'll create a patch.
> > > The imx_ccmvar.h is a file that is provided by the BSP I used for
> > testing.
> > > Best regards
> > > Christian
> > I've sent a patch. Can you test it?
> > Sure. I don't see the patch on the list yet, I'll test it as soon as it
> > comes :)
> Odd. It's already sent out and I CCd you directly. But the archive
> hasn't seen it either. To be sure, I attached the patch here.
> This patch fixed the issue and the build completes successfully. Thanks.
I'll also comment on the patch when it hits the list.
> > >> > Sorry for commenting on the patch that has already been
> > committed,
> > >> > please let me know of
> > >> > the preferred way to comment on a commit if this is not the
> > right way.
> > >> No problem. That's exactly the right way to do it. If there
> > is a bug it
> > >> has to be solved and everyone should know that someone is
> > having a look
> > >> at it.
> > >> Best regards
> > >> Christian
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax: +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200416/7f9475f6/attachment.html>
