Build Error while setting up RTEMS ARM BSP xilinx_zynq for qemu
Vijay Kumar Banerjee
vijay at rtems.org
Mon Apr 27 20:20:37 UTC 2020
On Tue, Apr 28, 2020, 1:45 AM Mritunjay Sharma <mritunjaysharma394 at gmail.com>
wrote:
> Hello everyone,
> This in reference to Ticket #3855 and my proposal for GSoC.
> As I have already cross-compiled and built EPICS7
> with RTEMS-5 for mvme6100, now I was trying to do the
> same for qemu/xilinx_zynq.
> However, while building with the below command:
> '''../source-builder/sb-set-builder
> --prefix=/home/mritunjay/development/rtems/5 \
> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu 5/rtems-arm'''
> I encountered this error:
> '''RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
> Build Set: 5/rtems-arm
> Build Set: 5/rtems-autotools.bset
> Build Set: 5/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-arm-rtems5-1
> building: autoconf-2.69-arm-rtems5-1
> sizes: autoconf-2.69-arm-rtems5-1: 7.501MB (installed: 0.000B)
> cleaning: autoconf-2.69-arm-rtems5-1
> config: tools/rtems-automake-1.12.6-1.cfg
> package: automake-1.12.6-arm-rtems5-1
> building: automake-1.12.6-arm-rtems5-1
> sizes: automake-1.12.6-arm-rtems5-1: 8.085MB (installed: 0.000B)
> cleaning: automake-1.12.6-arm-rtems5-1
> Build Sizes: usage: 8.085MB total: 144.775MB (sources: 144.756MB, patches:
> 19.412KB, installed 0.000B)
> Build Set: Time 0:00:10.271869
> Build Set: 5/rtems-autotools-base.bset
> sizes: autoconf-2.69-arm-rtems5-1: 10.532MB (installed: 3.034MB)
> reporting: tools/rtems-autoconf-2.69-1.cfg ->
> autoconf-2.69-arm-rtems5-1.txt
> autoconf-2.69-arm-rtems5-1.xml
> sizes: automake-1.12.6-arm-rtems5-1: 10.348MB (installed: 2.265MB)
> reporting: tools/rtems-automake-1.12.6-1.cfg ->
> automake-1.12.6-arm-rtems5-1.txt
> automake-1.12.6-arm-rtems5-1.xml
> staging: autoconf-2.69-arm-rtems5-1 ->
> /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging
> staging: automake-1.12.6-arm-rtems5-1 ->
> Build Sizes: usage: 15.830MB total: 150.073MB (sources: 144.756MB,
> patches: 19.412KB, installed 5.298MB)
> Build Set: Time 0:00:13.777473
> Build Set: Time 0:00:24.056142
> config: devel/expat-2.1.0-1.cfg
> package: expat-2.1.0-arm-rtems5-1
> building: expat-2.1.0-arm-rtems5-1
> error: building expat-2.1.0-arm-rtems5-1
> Build FAILED
> See error report: rsb-report-expat-2.1.0-arm-rtems5-1.txt
Hi Mritunjay,
Please see in this txt file, the error is visible there. You can attach
this file in the mail and send so we can see it and try to figure out a
solution
Best regards,
Vijay
> Build Set: Time 0:00:24.851451
> Build FAILED
> Please help me if any configuration changes have to be made,
> Thanks
> Mritunjay
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200428/39160178/attachment.html>
