Build Error while setting up RTEMS ARM BSP xilinx_zynq for qemu
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Mon Apr 27 20:24:05 UTC 2020
Thank you so much Vijay,
I am attaching the txt file as well as looking into it to find the error and
solution. Thanks for the help!
Regards,
Mritunjay
On Tue, Apr 28, 2020 at 1:50 AM Vijay Kumar Banerjee <vijay at rtems.org>
wrote:
> On Tue, Apr 28, 2020, 1:45 AM Mritunjay Sharma <
> mritunjaysharma394 at gmail.com> wrote:
>> Hello everyone,
>> This in reference to Ticket #3855 and my proposal for GSoC.
>> As I have already cross-compiled and built EPICS7
>> with RTEMS-5 for mvme6100, now I was trying to do the
>> same for qemu/xilinx_zynq.
>> However, while building with the below command:
>> '''../source-builder/sb-set-builder
>> --prefix=/home/mritunjay/development/rtems/5 \
>> --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu 5/rtems-arm'''
>> I encountered this error:
>> '''RTEMS Source Builder - Set Builder, 5 (96cdedce58e3)
>> Build Set: 5/rtems-arm
>> Build Set: 5/rtems-autotools.bset
>> Build Set: 5/rtems-autotools-internal.bset
>> config: tools/rtems-autoconf-2.69-1.cfg
>> package: autoconf-2.69-arm-rtems5-1
>> building: autoconf-2.69-arm-rtems5-1
>> sizes: autoconf-2.69-arm-rtems5-1: 7.501MB (installed: 0.000B)
>> cleaning: autoconf-2.69-arm-rtems5-1
>> config: tools/rtems-automake-1.12.6-1.cfg
>> package: automake-1.12.6-arm-rtems5-1
>> building: automake-1.12.6-arm-rtems5-1
>> sizes: automake-1.12.6-arm-rtems5-1: 8.085MB (installed: 0.000B)
>> cleaning: automake-1.12.6-arm-rtems5-1
>> Build Sizes: usage: 8.085MB total: 144.775MB (sources: 144.756MB,
>> patches: 19.412KB, installed 0.000B)
>> Build Set: Time 0:00:10.271869
>> Build Set: 5/rtems-autotools-base.bset
>> sizes: autoconf-2.69-arm-rtems5-1: 10.532MB (installed: 3.034MB)
>> reporting: tools/rtems-autoconf-2.69-1.cfg ->
>> autoconf-2.69-arm-rtems5-1.txt
>> autoconf-2.69-arm-rtems5-1.xml
>> sizes: automake-1.12.6-arm-rtems5-1: 10.348MB (installed: 2.265MB)
>> reporting: tools/rtems-automake-1.12.6-1.cfg ->
>> automake-1.12.6-arm-rtems5-1.txt
>> automake-1.12.6-arm-rtems5-1.xml
>> staging: autoconf-2.69-arm-rtems5-1 ->
>> /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging
>> staging: automake-1.12.6-arm-rtems5-1 ->
>> Build Sizes: usage: 15.830MB total: 150.073MB (sources: 144.756MB,
>> patches: 19.412KB, installed 5.298MB)
>> Build Set: Time 0:00:13.777473
>> Build Set: Time 0:00:24.056142
>> config: devel/expat-2.1.0-1.cfg
>> package: expat-2.1.0-arm-rtems5-1
>> building: expat-2.1.0-arm-rtems5-1
>> error: building expat-2.1.0-arm-rtems5-1
>> Build FAILED
>> See error report: rsb-report-expat-2.1.0-arm-rtems5-1.txt
> Hi Mritunjay,
> Please see in this txt file, the error is visible there. You can attach
> this file in the mail and send so we can see it and try to figure out a
> solution
> Best regards,
> Vijay
>> Build Set: Time 0:00:24.851451
>> Build FAILED
>> Please help me if any configuration changes have to be made,
>> Thanks
>> Mritunjay
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200428/be0adcf8/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building expat-2.1.0-arm-rtems5-1
Command Line: ../source-builder/sb-set-builder --prefix=/home/mritunjay/development/rtems/5 --host=arm-rtems5 --with-rtems-bsp=xilinx_zynq_a9_qemu 5/rtems-arm
Python: 2.7.17 (default, Apr 15 2020, 17:20:14) [GCC 7.5.0]
git://git.rtems.org/rtems-source-builder.git/origin/96cdedce58e32f07c174966676e8b7e8c6620634
Linux mritunjay-XPS-15-9570 5.3.0-46-generic #38~18.04.1-Ubuntu SMP Tue Mar 31 04:17:56 UTC 2020 x86_64
Tail of the build log:
script:140: export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
script:141: export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
script:142: export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
script:143: ./configure --build=x86_64-linux-gnu --host=arm-rtems5 --verbose --prefix=/home/mritunjay/development/rtems/5 --bindir=/home/mritunjay/development/rtems/5/bin --exec-prefix=/home/mritunjay/development/rtems/5 --includedir=/home/mritunjay/development/rtems/5/include --libdir=/home/mritunjay/development/rtems/5/lib --mandir=/home/mritunjay/development/rtems/5/share/man --infodir=/home/mritunjay/development/rtems/5/share/info
script:144: make -j 12 all
script:145: cd ${build_top}
script:146: echo "==> %install:"
script:147: build_top=$(pwd)
script:148: rm -rf $SB_BUILD_ROOT
script:149: cd expat-2.1.0
script:150: make DESTDIR=$SB_BUILD_ROOT install
script:151: cd ${build_top}
script: 1: #!/bin/sh
script: 2: # ___build_pre as set up in defaults.py
script: 3: # Save the original path away.
script: 4: export SB_ORIG_PATH=${PATH}
script: 5: # Directories
script: 6: SB_PREFIX="/home/mritunjay/development/rtems/5"
script: 7: SB_PREFIX_CLEAN=$(echo "/home/mritunjay/development/rtems/5" | /bin/sed -e 's/^\///')
script: 8: SB_SOURCE_DIR="/home/mritunjay/development/rtems/rsb/rtems/sources"
script: 9: SB_BUILD_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1"
script: 10: # host == build, use build; host != build, host uses host and build uses build
script: 11: SB_HOST_CPPFLAGS=""
script: 12: # Optionally do not add includes to c/cxx flags as newer configure's complain
script: 13: SB_HOST_CFLAGS="-O2 -g -pipe "
script: 14: SB_HOST_CXXFLAGS="-O2 -g -pipe "
script: 15: SB_HOST_LDFLAGS=" -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 16: SB_HOST_LIBS=""
script: 17: SB_BUILD_CFLAGS="-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 18: SB_BUILD_CXXFLAGS="-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/${SB_PREFIX_CLEAN}/include"
script: 19: SB_BUILD_LDFLAGS=" -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/${SB_PREFIX_CLEAN}/lib"
script: 20: SB_BUILD_LBS=""
script: 21: SB_CFLAGS="${SB_BUILD_CFLAGS} "
script: 22: SB_CXXFLAGS="${SB_BUILD_CXXFLAGS} "
script: 23: SB_ARCH="arm"
script: 24: SB_OS="linux"
script: 25: export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
script: 26: export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
script: 27: export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
script: 28: export SB_CFLAGS SB_CXXFLAGS
script: 29: # Documentation
script: 30: SB_DOC_DIR="/home/mritunjay/development/rtems/5/share/doc"
script: 31: export SB_DOC_DIR
script: 32: # Packages
script: 33: SB_PACKAGE_NAME="expat-2.1.0-arm-rtems5-1"
script: 34: SB_PACKAGE_BUILDNAME="expat-2.1.0-arm-rtems5-1"
script: 35: SB_PACKAGE_VERSION="2.1.0"
script: 36: SB_PACKAGE_RELEASE="1"
script: 37: export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
script: 38: # Build directories
script: 39: export SB_PREFIX
script: 40: SB_BUILD_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1"
script: 41: SB_BUILD_ROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000"
script: 42: SB_BUILD_ROOT_BINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000/${SB_PREFIX_CLEAN}/bin"
script: 43: export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
script: 44: SB_BUILD_CXC_DIR="/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1-cxc"
script: 45: SB_BUILD_CXC_ROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000-cxc"
script: 46: SB_BUILD_CXC_ROOT_BINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000-cxc/${SB_PREFIX_CLEAN}/bin"
script: 47: export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
script: 48: SB_TMPROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm"
script: 49: SB_TMPPREFIX="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/${SB_PREFIX_CLEAN}"
script: 50: SB_TMPBINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 51: export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
script: 52: SB_TMPCXCROOT="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm"
script: 53: SB_TMPCXCPREFIX="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/${SB_PREFIX_CLEAN}"
script: 54: SB_TMPCXCBINDIR="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/${SB_PREFIX_CLEAN}/bin"
script: 55: export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
script: 56: # Extra path support
script: 57: SB_EXTRAPATH="/home/mritunjay/development/rtems/rsb/source-builder"
script: 58: # The compiler flags
script: 59:
script: 60:
script: 61: export CFLAGS_FOR_TARGET
script: 62: export CXXFLAGS_FOR_TARGET
script: 63: # Set up the path. Put the CXC path first.
script: 64: if test -n "${SB_TMPBINDIR}" ; then
script: 65: PATH="${SB_TMPBINDIR}:$PATH"
script: 66: fi
script: 67: if test -n "${SB_TMPCXCBINDIR}" ; then
script: 68: PATH="${SB_TMPCXCBINDIR}:$PATH"
script: 69: fi
script: 70: if test -n "${SB_EXTRAPATH}" ; then
script: 71: PATH="${SB_EXTRAPATH}:$PATH"
script: 72: fi
script: 73: PATH="/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging/bin:$PATH"
script: 74:
script: 75: export PATH
script: 76: # Default environment set up.
script: 77: LANG=C
script: 78: export LANG
script: 79: unset DISPLAY || :
script: 80: umask 022
script: 81: cd "/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1"
script: 82: echo "=> expat-2.1.0-arm-rtems5-1: CLEAN"
script: 83: echo "==> %clean:"
removing: /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1
making dir: /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1
write script: /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1/do-build
write script: /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1/do-clean
run: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1/do-build
+ export SB_ORIG_PATH=/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ SB_PREFIX=/home/mritunjay/development/rtems/5
+ echo /home/mritunjay/development/rtems/5
+ /bin/sed -e s/^\///
+ SB_PREFIX_CLEAN=home/mritunjay/development/rtems/5
+ SB_SOURCE_DIR=/home/mritunjay/development/rtems/rsb/rtems/sources
+ SB_BUILD_DIR=/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1
+ SB_HOST_CPPFLAGS=
+ SB_HOST_CFLAGS=-O2 -g -pipe
+ SB_HOST_CXXFLAGS=-O2 -g -pipe
+ SB_HOST_LDFLAGS= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/lib
+ SB_HOST_LIBS=
+ SB_BUILD_CFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ SB_BUILD_CXXFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ SB_BUILD_LDFLAGS= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/lib
+ SB_BUILD_LBS=
+ SB_CFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ SB_CXXFLAGS=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ SB_ARCH=arm
+ SB_OS=linux
+ export SB_SOURCE_DIR SB_BUILD_DIR SB_ARCH SB_OS
+ export SB_HOST_CPPFLAGS SB_HOST_CFLAGS SB_HOST_CXXFLAGS SB_HOST_LDFLAGS SB_HOST_LIBS
+ export SB_BUILD_CFLAGS SB_BUILD_CXXFLAGS SB_BUILD_LDFLAGS SB_BUILD_LIBS
+ export SB_CFLAGS SB_CXXFLAGS
+ SB_DOC_DIR=/home/mritunjay/development/rtems/5/share/doc
+ export SB_DOC_DIR
+ SB_PACKAGE_NAME=expat-2.1.0-arm-rtems5-1
+ SB_PACKAGE_BUILDNAME=expat-2.1.0-arm-rtems5-1
+ SB_PACKAGE_VERSION=2.1.0
+ SB_PACKAGE_RELEASE=1
+ export SB_PACKAGE_NAME SB_PACKAGE_VERSION SB_PACKAGE_RELEASE
+ export SB_PREFIX
+ SB_BUILD_ROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000
+ SB_BUILD_ROOT_BINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000/home/mritunjay/development/rtems/5/bin
+ export SB_BUILD_ROOT SB_BUILD_DIR SB_BUILD_ROOT_BINDIR
+ SB_BUILD_CXC_DIR=/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1-cxc
+ SB_BUILD_CXC_ROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000-cxc
+ SB_BUILD_CXC_ROOT_BINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000-cxc/home/mritunjay/development/rtems/5/bin
+ export SB_BUILD_CXC_ROOT SB_BUILD_CXC_DIR SB_BUILD_CXC_ROOT_BINDIR
+ SB_TMPROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm
=> expat-2.1.0-arm-rtems5-1: BUILD
==> %prep:
+ SB_TMPPREFIX=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5
+ SB_TMPBINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/bin
+ export SB_TMPROOT SB_TMPPREFIX SB_TMPBINDIR
+ SB_TMPCXCROOT=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm
+ SB_TMPCXCPREFIX=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/home/mritunjay/development/rtems/5
+ SB_TMPCXCBINDIR=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/home/mritunjay/development/rtems/5/bin
+ export SB_TMPCXCROOT SB_TMPCXCPREFIX SB_TMPCXCBINDIR
+ SB_EXTRAPATH=/home/mritunjay/development/rtems/rsb/source-builder
+ export CFLAGS_FOR_TARGET
+ export CXXFLAGS_FOR_TARGET
+ test -n /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ test -n /home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/home/mritunjay/development/rtems/5/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ test -n /home/mritunjay/development/rtems/rsb/source-builder
+ PATH=/home/mritunjay/development/rtems/rsb/source-builder:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ PATH=/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-staging/bin:/home/mritunjay/development/rtems/rsb/source-builder:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000-cxc/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/bin:/home/mritunjay/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ export PATH
+ LANG=C
+ export LANG
+ unset DISPLAY
+ umask 022
+ cd /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1
+ echo => expat-2.1.0-arm-rtems5-1: BUILD
+ echo ==> %prep:
+ pwd
+ build_top=/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1
+ /bin/rm -rf expat-2.1.0
+ /bin/gzip -dc /home/mritunjay/development/rtems/rsb/rtems/sources/expat-2.1.0.tar.gz
+ /bin/tar -xvv -f -
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/
-rw-rw-r-- karl/karl 1208 2005-12-29 10:43 expat-2.1.0/COPYING
-rwxrwxr-x karl/karl 3299 2012-03-05 20:08 expat-2.1.0/CMakeLists.txt
-rwxrwxr-x karl/karl 1990 2004-09-30 08:17 expat-2.1.0/expat.dsw
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/conftools/
-rwxrwxr-x karl/karl 2480 2006-04-08 01:59 expat-2.1.0/conftools/PrintPath
-rwxrwxr-x karl/karl 726 2000-09-18 21:56 expat-2.1.0/conftools/mkinstalldirs
-rw-rw-r-- karl/karl 1442 2009-01-19 02:56 expat-2.1.0/conftools/expat.m4
-rwxr-xr-x karl/karl 35206 2012-03-25 00:42 expat-2.1.0/conftools/config.sub
-rwxr-xr-x karl/karl 13663 2012-03-25 00:42 expat-2.1.0/conftools/install-sh
-rwxr-xr-x karl/karl 282967 2012-03-25 00:42 expat-2.1.0/conftools/ltmain.sh
-rw-rw-r-- karl/karl 2964 2001-10-02 01:33 expat-2.1.0/conftools/ac_c_bigendian_cross.m4
-rwxr-xr-x karl/karl 44504 2012-03-25 00:42 expat-2.1.0/conftools/config.guess
-rwxrwxr-x karl/karl 1266 2002-05-18 05:56 expat-2.1.0/conftools/get-version.sh
-rw-rw-r-- karl/karl 5790 2012-03-11 11:24 expat-2.1.0/README
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/examples/
-rw-rw-r-- karl/karl 2415 2007-06-03 20:30 expat-2.1.0/examples/outline.c
-rw-rw-r-- karl/karl 1617 2007-06-03 20:30 expat-2.1.0/examples/elements.c
-rw-rw-r-- karl/karl 3556 2012-02-21 08:13 expat-2.1.0/examples/elements.dsp
-rw-rw-r-- karl/karl 3504 2012-02-21 08:13 expat-2.1.0/examples/outline.dsp
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/bcb5/
-rw-rw-r-- karl/karl 4822 2002-12-07 14:29 expat-2.1.0/bcb5/expat_static.mak
-rw-rw-r-- karl/karl 5044 2002-12-07 14:29 expat-2.1.0/bcb5/outline.mak
-rw-rw-r-- karl/karl 247 2002-12-07 14:29 expat-2.1.0/bcb5/xmlwf.bpf
-rw-rw-r-- karl/karl 1606 2002-12-07 14:29 expat-2.1.0/bcb5/all_projects.bpg
-rw-rw-r-- karl/karl 5173 2003-10-24 06:09 expat-2.1.0/bcb5/expatw.mak
-rw-rw-r-- karl/karl 5140 2003-10-24 06:09 expat-2.1.0/bcb5/expat.mak
-rw-rw-r-- karl/karl 3783 2002-12-07 14:29 expat-2.1.0/bcb5/xmlwf.bpr
-rw-rw-r-- karl/karl 5495 2004-01-07 22:42 expat-2.1.0/bcb5/libexpatw_mtd.def
-rw-rw-r-- karl/karl 216 2002-12-08 09:07 expat-2.1.0/bcb5/expatw.bpf
-rw-rw-r-- karl/karl 534 2003-01-17 03:37 expat-2.1.0/bcb5/makefile.mak
-rw-rw-r-- karl/karl 3463 2002-12-07 14:29 expat-2.1.0/bcb5/outline.bpr
-rw-rw-r-- karl/karl 4427 2002-12-09 22:53 expat-2.1.0/bcb5/expatw.bpr
-rw-rw-r-- karl/karl 215 2002-12-08 09:07 expat-2.1.0/bcb5/expat.bpf
-rw-rw-r-- karl/karl 553 2002-12-09 22:53 expat-2.1.0/bcb5/setup.bat
-rw-rw-r-- karl/karl 153 2002-12-07 14:29 expat-2.1.0/bcb5/outline.bpf
-rw-rw-r-- karl/karl 4576 2002-12-07 14:29 expat-2.1.0/bcb5/elements.bpr
-rw-rw-r-- karl/karl 5078 2002-12-07 14:29 expat-2.1.0/bcb5/elements.mak
-rw-rw-r-- karl/karl 155 2002-12-07 14:29 expat-2.1.0/bcb5/elements.bpf
-rw-rw-r-- karl/karl 4301 2003-10-24 06:09 expat-2.1.0/bcb5/README.txt
-rw-rw-r-- karl/karl 181 2002-12-07 14:29 expat-2.1.0/bcb5/expat_static.bpf
-rw-rw-r-- karl/karl 4855 2002-12-09 22:53 expat-2.1.0/bcb5/expatw_static.mak
-rw-rw-r-- karl/karl 181 2002-12-07 14:29 expat-2.1.0/bcb5/expatw_static.bpf
-rw-rw-r-- karl/karl 5495 2004-01-07 22:42 expat-2.1.0/bcb5/libexpat_mtd.def
-rw-rw-r-- karl/karl 3601 2002-12-07 14:29 expat-2.1.0/bcb5/expat_static.bpr
-rw-rw-r-- karl/karl 4535 2002-12-09 22:53 expat-2.1.0/bcb5/expatw_static.bpr
-rw-rw-r-- karl/karl 4039 2002-12-08 09:07 expat-2.1.0/bcb5/expat.bpr
-rw-rw-r-- karl/karl 5145 2002-12-07 14:29 expat-2.1.0/bcb5/xmlwf.mak
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/m4/
-rw-r--r-- karl/karl 11950 2012-03-25 00:42 expat-2.1.0/m4/ltoptions.m4
-rw-r--r-- karl/karl 6126 2012-03-25 00:42 expat-2.1.0/m4/lt~obsolete.m4
-rw-r--r-- karl/karl 281744 2012-03-25 00:42 expat-2.1.0/m4/libtool.m4
-rw-r--r-- karl/karl 4372 2012-03-25 00:42 expat-2.1.0/m4/ltsugar.m4
-rw-r--r-- karl/karl 686 2012-03-25 00:42 expat-2.1.0/m4/ltversion.m4
-rwxrwxr-x karl/karl 1512 2012-03-05 20:08 expat-2.1.0/ConfigureChecks.cmake
-rw-rw-r-- karl/karl 11379 2012-03-25 00:36 expat-2.1.0/Changes
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/
-rwxrwxr-x karl/karl 6737 2009-08-08 09:18 expat-2.1.0/amiga/expat_68k_handler_stubs.c
-rw-rw-r-- karl/karl 1395 2009-08-08 09:18 expat-2.1.0/amiga/expat_base.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/libraries/
-rw-rw-r-- karl/karl 16516 2007-06-03 20:23 expat-2.1.0/amiga/include/libraries/expat.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/interfaces/
-rw-rw-r-- karl/karl 7930 2005-12-24 12:15 expat-2.1.0/amiga/include/interfaces/expat.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/proto/
-rw-rw-r-- karl/karl 1335 2007-06-03 20:21 expat-2.1.0/amiga/include/proto/expat.h
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/amiga/include/inline4/
-rw-rw-r-- karl/karl 6557 2005-12-24 12:15 expat-2.1.0/amiga/include/inline4/expat.h
-rw-rw-r-- karl/karl 42000 2009-08-08 09:18 expat-2.1.0/amiga/expat_68k.c
-rw-rw-r-- karl/karl 21979 2009-02-01 02:27 expat-2.1.0/amiga/expat_vectors.c
-rwxrwxr-x karl/karl 4133 2009-08-08 09:18 expat-2.1.0/amiga/expat_68k.h
-rw-rw-r-- karl/karl 10427 2009-08-08 09:18 expat-2.1.0/amiga/Makefile
-rw-rw-r-- karl/karl 3136 2009-08-08 09:18 expat-2.1.0/amiga/README.txt
-rwxrwxr-x karl/karl 1744 2009-08-08 09:18 expat-2.1.0/amiga/launch.c
-rw-rw-r-- karl/karl 10742 2005-12-24 12:09 expat-2.1.0/amiga/expat.xml
-rwxrwxr-x karl/karl 5839 2009-08-08 09:18 expat-2.1.0/amiga/expat_lib.c
-rwxrwxr-x karl/karl 565580 2012-03-25 00:42 expat-2.1.0/configure
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/doc/
-rw-rw-r-- karl/karl 94947 2012-03-10 23:57 expat-2.1.0/doc/reference.html
-rw-rw-r-- karl/karl 2368 2007-06-05 20:35 expat-2.1.0/doc/valid-xhtml10.png
-rw-rw-r-- karl/karl 1027 2007-06-05 20:35 expat-2.1.0/doc/expat.png
-rw-rw-r-- karl/karl 1340 2004-07-23 08:58 expat-2.1.0/doc/style.css
-rw-rw-r-- karl/karl 7895 2007-04-30 06:23 expat-2.1.0/doc/xmlwf.1
-rw-rw-r-- karl/karl 13690 2009-01-19 03:25 expat-2.1.0/doc/xmlwf.sgml
-rw-rw-r-- karl/karl 231 2009-01-19 09:05 expat-2.1.0/expat.pc.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/win32/
-rw-rw-r-- karl/karl 1195 2007-05-03 07:45 expat-2.1.0/win32/MANIFEST.txt
-rw-rw-r-- karl/karl 2804 2012-03-04 21:23 expat-2.1.0/win32/README.txt
-rw-rw-r-- karl/karl 4337 2012-03-04 21:23 expat-2.1.0/win32/expat.iss
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/tests/
-rw-rw-r-- karl/karl 49164 2012-03-04 05:15 expat-2.1.0/tests/runtests.c
-rw-rw-r-- karl/karl 3038 2004-04-30 08:48 expat-2.1.0/tests/chardata.c
-rwxrwxr-x karl/karl 3557 2008-08-03 23:49 expat-2.1.0/tests/xmltest.sh
-rw-rw-r-- karl/karl 2336 2012-02-21 09:19 expat-2.1.0/tests/minicheck.h
-rw-rw-r-- karl/karl 185 2005-01-28 10:49 expat-2.1.0/tests/runtestspp.cpp
-rw-rw-r-- karl/karl 570 2012-02-26 20:06 expat-2.1.0/tests/README.txt
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/tests/benchmark/
-rw-rw-r-- karl/karl 820 2004-09-30 08:17 expat-2.1.0/tests/benchmark/benchmark.dsw
-rw-rw-r-- karl/karl 2999 2012-02-21 09:15 expat-2.1.0/tests/benchmark/benchmark.dsp
-rw-rw-r-- karl/karl 546 2006-01-02 00:23 expat-2.1.0/tests/benchmark/README.txt
-rw-rw-r-- karl/karl 2798 2007-06-03 20:30 expat-2.1.0/tests/benchmark/benchmark.c
-rw-rw-r-- karl/karl 791 2004-09-30 10:28 expat-2.1.0/tests/chardata.h
-rw-rw-r-- karl/karl 4219 2006-07-01 20:24 expat-2.1.0/tests/minicheck.c
-rwxrwxr-x karl/karl 2735 2012-03-05 20:08 expat-2.1.0/expat_config.h.cmake
-rwxrwxr-x karl/karl 1768 2012-03-05 20:08 expat-2.1.0/CMake.README
-rw-rw-r-- karl/karl 2518 2012-03-05 20:08 expat-2.1.0/MANIFEST
-rw-rw-r-- karl/karl 2728 2012-03-25 00:42 expat-2.1.0/expat_config.h.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/vms/
-rw-rw-r-- karl/karl 2080 2004-01-29 05:41 expat-2.1.0/vms/descrip.mms
-rw-rw-r-- karl/karl 1199 2003-11-02 23:43 expat-2.1.0/vms/expat_config.h
-rw-rw-r-- karl/karl 576 2002-06-05 09:43 expat-2.1.0/vms/README.vms
-rw-rw-r-- karl/karl 7036 2012-03-19 03:48 expat-2.1.0/Makefile.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/xmlwf/
-rwxrwxr-x karl/karl 509 2005-12-25 22:24 expat-2.1.0/xmlwf/xmlfile.h
-rwxrwxr-x karl/karl 224 2002-07-01 20:48 expat-2.1.0/xmlwf/xmlurl.h
-rwxrwxr-x karl/karl 1790 2009-11-12 22:21 expat-2.1.0/xmlwf/readfilemap.c
-rwxrwxr-x karl/karl 2143 2002-07-01 20:43 expat-2.1.0/xmlwf/win32filemap.c
-rwxrwxr-x karl/karl 1274 2006-06-28 08:25 expat-2.1.0/xmlwf/unixfilemap.c
-rwxrwxr-x karl/karl 493 2002-07-01 20:43 expat-2.1.0/xmlwf/xmlmime.h
-rwxrwxr-x karl/karl 2912 2002-07-01 20:43 expat-2.1.0/xmlwf/ct.c
-rwxrwxr-x karl/karl 4130 2012-02-21 07:46 expat-2.1.0/xmlwf/xmlwf.dsp
-rwxrwxr-x karl/karl 500 2002-07-01 20:43 expat-2.1.0/xmlwf/filemap.h
-rwxrwxr-x karl/karl 1355 2006-08-05 22:30 expat-2.1.0/xmlwf/codepage.c
-rwxrwxr-x karl/karl 6082 2007-06-03 20:30 expat-2.1.0/xmlwf/xmlfile.c
-rwxrwxr-x karl/karl 3218 2002-07-01 20:43 expat-2.1.0/xmlwf/xmlmime.c
-rwxrwxr-x karl/karl 21212 2009-01-19 05:49 expat-2.1.0/xmlwf/xmlwf.c
-rwxrwxr-x karl/karl 8813 2002-08-24 03:17 expat-2.1.0/xmlwf/xmlwin32url.cxx
-rwxrwxr-x karl/karl 825 2000-04-21 09:50 expat-2.1.0/xmlwf/xmltchar.h
-rwxrwxr-x karl/karl 196 2002-07-01 20:43 expat-2.1.0/xmlwf/codepage.h
-rw-rw-r-- karl/karl 4652 2012-03-04 05:15 expat-2.1.0/configure.in
drwxrwxr-x karl/karl 0 2012-03-25 00:42 expat-2.1.0/lib/
-rw-rw-r-- karl/karl 3144 2006-11-26 23:04 expat-2.1.0/lib/xmltok_ns.c
-rw-rw-r-- karl/karl 797 2007-06-03 20:27 expat-2.1.0/lib/amigaconfig.h
-rw-rw-r-- karl/karl 11184 2005-12-23 20:15 expat-2.1.0/lib/xmltok.h
-rw-rw-r-- karl/karl 3364 2006-06-02 17:47 expat-2.1.0/lib/expat_external.h
-rw-rw-r-- karl/karl 1830 2002-07-02 02:14 expat-2.1.0/lib/iasciitab.h
-rw-rw-r-- karl/karl 4599 2002-07-08 22:36 expat-2.1.0/lib/Makefile.MPW
-rw-rw-r-- karl/karl 2028 2007-05-11 22:50 expat-2.1.0/lib/libexpat.def
-rw-rw-r-- karl/karl 709 2005-12-16 23:11 expat-2.1.0/lib/winconfig.h
-rw-rw-r-- karl/karl 7050 2000-09-18 21:56 expat-2.1.0/lib/nametab.h
-rw-rw-r-- karl/karl 2028 2006-11-26 23:05 expat-2.1.0/lib/internal.h
-rw-rw-r-- karl/karl 32475 2009-01-31 11:51 expat-2.1.0/lib/xmlrole.c
-rw-rw-r-- karl/karl 4971 2012-02-21 08:15 expat-2.1.0/lib/expatw.dsp
-rw-rw-r-- karl/karl 1760 2002-07-02 02:14 expat-2.1.0/lib/asciitab.h
-rw-rw-r-- karl/karl 1763 2002-07-02 02:14 expat-2.1.0/lib/utf8tab.h
-rw-rw-r-- karl/karl 2028 2007-05-11 22:50 expat-2.1.0/lib/libexpatw.def
-rw-rw-r-- karl/karl 197613 2012-03-11 10:43 expat-2.1.0/lib/xmlparse.c
-rw-rw-r-- karl/karl 41405 2009-01-31 11:51 expat-2.1.0/lib/xmltok.c
-rw-rw-r-- karl/karl 1985 2007-05-08 07:55 expat-2.1.0/lib/ascii.h
-rw-rw-r-- karl/karl 661 2000-09-22 02:50 expat-2.1.0/lib/xmltok_impl.h
-rw-rw-r-- karl/karl 1813 2002-07-02 02:14 expat-2.1.0/lib/latin1tab.h
-rw-rw-r-- karl/karl 4325 2007-05-03 07:43 expat-2.1.0/lib/expatw_static.dsp
-rw-rw-r-- karl/karl 1325 2003-11-02 23:44 expat-2.1.0/lib/macconfig.h
-rw-rw-r-- karl/karl 4901 2012-02-21 08:15 expat-2.1.0/lib/expat.dsp
-rw-rw-r-- karl/karl 3023 2002-11-13 03:15 expat-2.1.0/lib/xmlrole.h
-rw-rw-r-- karl/karl 44554 2012-02-21 08:29 expat-2.1.0/lib/xmltok_impl.c
-rw-rw-r-- karl/karl 4254 2012-02-21 08:15 expat-2.1.0/lib/expat_static.dsp
-rw-rw-r-- karl/karl 41752 2012-03-04 00:38 expat-2.1.0/lib/expat.h
-rw-rw-r-- karl/karl 304569 2012-03-25 00:42 expat-2.1.0/aclocal.m4
+ tar_exit=0
+ cd expat-2.1.0
+ /bin/chmod -R a+rX,g-w,o-w .
+ SB_CXC=no
==> clean %{buildroot}: /home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000
+ echo ==> clean %{buildroot}: /home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000
+ /bin/rm -rf /home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000
+ /bin/mkdir -p /home/mritunjay/development/rtems/rsb/rtems/build/tmp/expat-2.1.0-arm-rtems5-1-1000
+ echo ==> %build:
==> %build:
+ pwd
+ cd expat-2.1.0
+ test x86_64-linux-gnu != arm-rtems5
+ echo arm-rtems5-gcc
+ sed -e s,-std=gnu99 ,,
+ CC=arm-rtems5-gcc
+ echo arm-rtems5-g++
+ CXX=arm-rtems5-g++
+ CPPFLAGS=
+ CFLAGS=-O2 -g -pipe
+ CXXFLAGS=-O2 -g -pipe
+ LDFLAGS= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/lib
+ LDLIBS=
+ LIBS=
+ CPPFLAGS_FOR_HOST=
+ CFLAGS_FOR_HOST=-O2 -g -pipe
+ CXXFLAGS_FOR_HOST=-O2 -g -pipe
+ LDFLAGS_FOR_HOST= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/lib
+ LDLIBS_FOR_HOST=
+ LIBS_FOR_HOST=
+ echo gcc -O2 -g -pipe
+ CC_FOR_HOST=gcc -O2 -g -pipe
+ echo g++ -O2 -g -pipe
+ CXX_FOR_HOST=g++ -O2 -g -pipe
+ CFLAGS_FOR_BUILD=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ CXXFLAGS_FOR_BUILD=-O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ LDFLAGS_FOR_BUILD= -L/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/lib
+ LDLIBS_FOR_BUILD=
+ LIBS_FOR_BUILD=
+ echo gcc -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ CC_FOR_BUILD=gcc -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ echo g++ -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ CXX_FOR_BUILD=g++ -O2 -g -pipe -I/home/mritunjay/development/rtems/rsb/rtems/build/tmp/sb-1000/5/rtems-arm/home/mritunjay/development/rtems/5/include
+ export CC CXX CPPFLAGS CFLAGS CXXFLAGS LDFLAGS LIBS LDLIBS
+ export CC_FOR_HOST CXX_FOR_HOST CPPFLAGS_FOR_HOST CFLAGS_FOR_HOST CXXFLAGS_FOR_HOST LDFLAGS_FOR_HOST LDLIBS_FOR_HOST LIBS_FOR_HOST
+ export CC_FOR_BUILD CXX_FOR_BUILD CFLAGS_FOR_BUILD CXXFLAGS_FOR_BUILD LDFLAGS_FOR_BUILD LDLIBS_FOR_BUILS LIBS_FOR_BUILS
+ ./configure --build=x86_64-linux-gnu --host=arm-rtems5 --verbose --prefix=/home/mritunjay/development/rtems/5 --bindir=/home/mritunjay/development/rtems/5/bin --exec-prefix=/home/mritunjay/development/rtems/5 --includedir=/home/mritunjay/development/rtems/5/include --libdir=/home/mritunjay/development/rtems/5/lib --mandir=/home/mritunjay/development/rtems/5/share/man --infodir=/home/mritunjay/development/rtems/5/share/info
checking build system type... x86_64-pc-linux-gnu
checking host system type... arm-unknown-rtems5
checking how to print strings... printf
checking for arm-rtems5-gcc... arm-rtems5-gcc
checking whether the C compiler works... no
configure: error: in `/home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1/expat-2.1.0':
configure: error: C compiler cannot create executables
See `config.log' for more details
shell cmd failed: /bin/sh -ex /home/mritunjay/development/rtems/rsb/rtems/build/expat-2.1.0-arm-rtems5-1/do-build
