RTEMS 5 Release status
Sebastian Huber
Wed Apr 29 05:57:24 UTC 2020
On 29/04/2020 02:28, Chris Johns wrote:
> Release Change Notes
> Joel has asked for a high level list of changes to be added to the
> release information. He would like this to be a community effort.
> We have the detailed release notes created from the Trac tickets for
> the release so this is suppose to be something high level.
> Please create or add to a file called rtems-notes-5.txt as markdown in
> the releases repo ...
> https://git.rtems.org/rtems-release/
> Either push the changes or send a patch to this list and I will merge
> them. I will add support to place this text in the generated README
> once it exists. If there is no file at the time of the release no
> support will be added.
I added the file based with some initial content
https://git.rtems.org/rtems-release/tree/rtems-notes-5.txt
on the 4.11 release notes
https://devel.rtems.org/wiki/Release/4.11
We should create the notes for RTEMS 6.1 right after the 5.1 release. I
have trouble to remember all the things which changed in the RTEMS 5
development cycle. It would be better to update the notes in parallel
with the development.
