[PATCH RTEMS 7/7] libtests/openfirmware: Added a testsuite for openfirmware
Christian Mauderer
oss at c-mauderer.de
Tue Aug 4 18:46:24 UTC 2020
Hello,
I think the big question is: Should we make that a public API and keep
it in cpukit or should we make it a BSP support code and move ti to the
bsps/shared section?
Sebastian and Gedare: Like Niteesh said: There have been some different
directions in the past. Which one should be the target?
Best regards
Christian
On 04/08/2020 20:36, Niteesh G. S. wrote:
> Ping.
> On Sun, Aug 2, 2020 at 2:44 PM Niteesh G. S. <niteesh.gs at gmail.com
> <mailto:niteesh.gs at gmail.com>> wrote:
> Hello,
> I went through some of my previous conversations to summarize the
> various directories
> suggested by people. Maybe this will help to come up with a conclusion.
> In my first porting commit, I placed the files under
> cpukit/libfreebsd this caused issues like
> accessing BSP dependent functions like bsp_fdt_get() therefore
> Christian suggested moving
> the files to bsps/shared.
> https://lists.rtems.org/pipermail/devel/2020-May/059959.html
> I then posted the patches on the mailing lists after moving the
> files to bsps/shared. After this
> Sebastian suggested moving these back to cpukit since they are BSP
> independent. And add
> an API to register FDTs since this would allow for unit testing. But
> later instead of API we
> started using linker wrappers.
> https://lists.rtems.org/pipermail/devel/2020-May/059978.html
> https://lists.rtems.org/pipermail/devel/2020-June/060025.html
> Gedare also suggested having the files in cpukit since this would
> allow for easier synchronization
> with FreeBSD.
> https://lists.rtems.org/pipermail/devel/2020-May/059807.html
> Thanks,
> Niteesh.
> On Thu, Jul 30, 2020 at 1:03 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
> On Wed, Jul 29, 2020 at 12:33 PM Christian Mauderer
> <oss at c-mauderer.de <mailto:oss at c-mauderer.de>> wrote:
> > On 29/07/2020 20:21, Gedare Bloom wrote:
> > > On Wed, Jul 29, 2020 at 12:10 PM Christian Mauderer
> > >> On 29/07/2020 19:55, Gedare Bloom wrote:
> > >>> On Wed, Jul 29, 2020 at 10:44 AM Christian Mauderer
> > >>>> On 29/07/2020 18:07, Gedare Bloom wrote:
> > >>>>> On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu
> <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>> wrote:
> > >>>>>> spec/build/testsuites/libtests/grp.yml | 3 +
> > >>>>>> .../testsuites/libtests/openfirmware01.yml | 20 +++
> > >>>>>> testsuites/libtests/openfirmware01/init.c | 147
> > >>>>>> .../openfirmware01/openfirmware01.doc | 29 ++++
> > >>>>>> .../openfirmware01/openfirmware01.scn | 2 +
> > >>>>>> testsuites/libtests/openfirmware01/some.c | 52
> > >>>>>> testsuites/libtests/openfirmware01/some.dts | 54
> > >>>>>> testsuites/libtests/openfirmware01/some.h | 15 ++
> > >>>>>> 8 files changed, 322 insertions(+)
> > >>>>>> create mode 100644
> spec/build/testsuites/libtests/openfirmware01.yml
> > >>>>>> create mode 100644
> > >>>>>> create mode 100644
> testsuites/libtests/openfirmware01/openfirmware01.doc
> > >>>>>> create mode 100644
> testsuites/libtests/openfirmware01/openfirmware01.scn
> > >>>>>> create mode 100644
> > >>>>>> create mode 100644
> > >>>>>> create mode 100644
> > >>>>>> diff --git a/spec/build/testsuites/libtests/grp.yml
> b/spec/build/testsuites/libtests/grp.yml
> > >>>>>> index f1de6cd75f..56e84d2c89 100644
> > >>>>>> --- a/spec/build/testsuites/libtests/grp.yml
> > >>>>>> +++ b/spec/build/testsuites/libtests/grp.yml
> > >>>>>> @@ -11,6 +11,7 @@ install: []
> > >>>>>> ldflags:
> > >>>>>> - -Wl,--wrap=printf
> > >>>>>> - -Wl,--wrap=puts
> > >>>>>> +- -Wl,--wrap=bsp_fdt_get
> > >>>>>> links:
> > >>>>>> - role: build-dependency
> > >>>>>> uid: optbin2c
> > >>>>>> @@ -312,6 +313,8 @@ links:
> > >>>>>> uid: write
> > >>>>>> uid: writev
> > >>>>>> +- role: build-dependency
> > >>>>>> + uid: openfirmware01
> > >>>>>> type: build
> > >>>>>> use-after:
> > >>>>>> - rtemstest
> > >>>>>> diff --git
> a/spec/build/testsuites/libtests/openfirmware01.yml
> b/spec/build/testsuites/libtests/openfirmware01.yml
> > >>>>>> new file mode 100644
> > >>>>>> index 0000000000..8feb69eb1e
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/spec/build/testsuites/libtests/openfirmware01.yml
> > >>>>>> @@ -0,0 +1,20 @@
> > >>>>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> > >>>>>> +build-type: test-program
> > >>>>>> +cflags: []
> > >>>>>> +copyrights:
> > >>>>>> +- Copyright (C) 2020 Niteesh G S
> > >>>>>> +cppflags: []
> > >>>>>> +cxxflags: []
> > >>>>>> +enabled-by: true
> > >>>>>> +features: c cprogram
> > >>>>>> +includes: []
> > >>>>>> +ldflags: []
> > >>>>>> +links: []
> > >>>>>> +source:
> > >>>>>> +- testsuites/libtests/openfirmware01/init.c
> > >>>>>> +- testsuites/libtests/openfirmware01/some.c
> > >>>>>> +stlib: []
> > >>>>>> +target: testsuites/libtests/openfirmware01.exe
> > >>>>>> +type: build
> > >>>>>> +use-after: []
> > >>>>>> +use-before: []
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/init.c
> b/testsuites/libtests/openfirmware01/init.c
> > >>>>>> index 0000000000..fc38e6c513
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/init.c
> > >>>>>> @@ -0,0 +1,147 @@
> > >>>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
> > >>>>>> + * Copyright (C) <2020> Niteesh G S
> > >>>>>> + * Redistribution and use in source and binary forms,
> with or without
> > >>>>>> + * modification, are permitted provided that the
> following conditions
> > >>>>>> + * are met:
> > >>>>>> + * 1. Redistributions of source code must retain the
> above copyright
> > >>>>>> + * notice, this list of conditions and the
> following disclaimer.
> > >>>>>> + * 2. Redistributions in binary form must reproduce
> the above copyright
> following disclaimer in the
> > >>>>>> + * documentation and/or other materials provided
> with the distribution.
> > >>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS
> AND CONTRIBUTORS "AS IS"
> > >>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING,
> BUT NOT LIMITED TO, THE
> > >>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
> FOR A PARTICULAR PURPOSE
> > >>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> OWNER OR CONTRIBUTORS BE
> > >>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> SPECIAL, EXEMPLARY, OR
> > >>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
> TO, PROCUREMENT OF
> > >>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
> PROFITS; OR BUSINESS
> > >>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
> LIABILITY, WHETHER IN
> > >>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
> NEGLIGENCE OR OTHERWISE)
> > >>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
> EVEN IF ADVISED OF THE
> > >>>>>> + * POSSIBILITY OF SUCH DAMAGE.
> > >>>>>> +#ifdef HAVE_CONFIG_H
> > >>>>>> +#include "config.h"
> > >>>>>> +#endif
> > >>>>>> +#include <tmacros.h>
> > >>>>>> +#include <stdio.h>
> > >>>>>> +#include <stdlib.h>
> > >>>>>> +#include <libfdt.h>
> > >>>>>> +#include <sys/endian.h>
> > >>>>>> +#include <dev/ofw/openfirm.h>
> > >>>>>> +#include "some.h"
> > >>>>>> +#define BUF_SIZE 100
> > >>>>>> +const char rtems_test_name[] = "OpenFirmWare 01";
> > >>>>>> +const void *__wrap_bsp_fdt_get(void);
> > >>>>>> +const void *__real_bsp_fdt_get(void);
> > >>>>>> + if (some_bin != NULL) {
> > >>>>>> + return &some_bin[0];
> > >>>>>> + return __real_bsp_fdt_get();
> > >>>>>> +static void Init(rtems_task_argument arg)
> > >>>>>> + int rv;
> > >>>>>> + phandle_t d;
> > >>>>>> + phandle_t l;
> > >>>>>> + phandle_t t;
> > >>>>>> + phandle_t root;
> > >>>>>> + phandle_t temp;
> > >>>>>> + uint32_t *arr;
> > >>>>>> + char buf[BUF_SIZE];
> > >>>>>> + char *bufp;
> > >>>>>> + ssize_t buf_len;
> > >>>>>> + TEST_BEGIN();
> > >>>>>> + buf_len = sizeof(buf);
> > >>>>>> + * Cannot use fdt_path_offset to compare because
> > >>>>>> + * the OF interface uses the offset from the ftdp
> > >>>>>> + * to the node as phandle.
> > >>>>>> + root = OF_finddevice("/");
> > >>>>>> + rtems_test_assert(root == 56);
> > >>>>>> + root = OF_peer(0);
> > >>>>>> + d = OF_child(root);
> > >>>>>> + temp = OF_finddevice("/d");
> > >>>>>> + rtems_test_assert(d == temp);
> > >>>>>> + temp = OF_parent(d);
> > >>>>>> + rtems_test_assert(root == temp);
> > >>>>>> + rv = OF_getprop(d, "e", buf, buf_len);
> > >>>>>> + rtems_test_assert(rv != -1);
> > >>>>>> + rtems_test_assert(strcmp(buf, "f") == 0);
> > >>>>>> + rv = OF_hasprop(d, "g");
> > >>>>>> + rtems_test_assert(rv == 1);
> > >>>>>> + rv = OF_getproplen(root, "model");
> > >>>>>> + rtems_test_assert(rv == 2);
> > >>>>>> + rv = OF_nextprop(d, "e", buf, buf_len);
> > >>>>>> + rtems_test_assert(strcmp(buf, "g") == 0);
> > >>>>>> + l = OF_finddevice("/m at 1248");
> > >>>>>> + rv = OF_searchprop(l, "model", buf, buf_len);
> > >>>>>> + rtems_test_assert(strcmp(buf, "c") == 0);
> > >>>>>> + rv = OF_getprop_alloc(root, "compatible", (void
> **)&bufp);
> > >>>>>> + rtems_test_assert(strcmp(bufp, "a,b") == 0);
> > >>>>>> + OF_prop_free(bufp);
> > >>>>>> + rv = OF_getprop_alloc_multi(l, "n", sizeof(*arr),
> (void **)&arr);
> > >>>>>> + rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
> > >>>>>> + rtems_test_assert(arr[1] == htobe32(0x12345678));
> > >>>>>> + rv = OF_getencprop_alloc_multi(l, "n",
> sizeof(*arr), (void **)&arr);
> > >>>>>> + rtems_test_assert(arr[0] == 0xdeadbeef);
> > >>>>>> + rtems_test_assert(arr[1] == 0x12345678);
> > >>>>>> + t = OF_finddevice("/t");
> > >>>>>> + rv = OF_nextprop(t, "u", buf, buf_len);
> > >>>>>> + rtems_test_assert(rv == 0);
> > >>>>> ok, so these are intended to be application-visible. The
> interface is
> > >>>>> not standard though, as far as I know. So, I think we
> need to ensure
> > >>>>> we provide an RTEMS-friendly namespace for this OF API,
> and make sure
> > >>>>> the header files are properly arranged for
> visibility/layering.
> > >>>>> Everything else seems fine to me in a quick glance.
> > >>>> Hello Gedare,
> > >>>> the interface is ported from FreeBSD. It's an internal
> one in FreeBSD
> > >>>> but I think it is useful for application drivers too.
> > >>>> What would you suggest regarding the namespace. I'm not a
> big fan of
> > >>>> changing imported FreeBSD code.
> > >>> Background: The problem we have to avoid is polluting the user
> > >>> namespace. Software in kernel space, such as FreeBSD and other
> > >>> monolithic kernels, don't have that problem.
> > >>> I haven't studied the usage closely, I guess the pinmux is
> the main
> > >>> thing, but I'd like to understand if the FreeBSD symbols
> need to be
> > >>> exposed.
> > >>> Would it be feasible to introduce an rtems-branded API for
> this stuff,
> > >>> and provide a wrapper in libbsd for compatibility? Imagine
> something
> > >>> like....
> > >>> <rtems/dev/openfirmware.h>
> > >>> rtems_openfirmware_finddevice(char *s);
> > >>> freebsd-compat:
> > >>> #define OF_finddevice rtems_openfirmware_finddevice
> > >>> You could even then reuse other ofw interfaces, like:
> > >>> linux-compat:
> > >>> #define of_finddevice rtems_openfirmware_finddevice
> > >>> Just for example.
> > >>> This way, we only pollute the namespace if someone pulls
> in the bsd library.
> > >>> If the FreeBSD symbols have to be available inside RTEMS
> to support
> > >>> drivers without libbsd, then I would rather see the
> symbols converted
> > >>> to macros that link to namespace-friendly functions instead.
> > >>> Gedare
> > >> The main problem was that the openfirmware stuff is ported
> from FreeBSD
> > >> and someone (don't remember exactly who, possible that it
> was me)
> > >> suggestet that the ported files should be placed in cpukit
> rather than
> > >> in the BSP section. With that it's quite hard to use the
> interfaces in a
> > >> BSP driver without installing some headers.
> > > Let's step back for one minute and determine the
> requirements for the
> > > ofw support.
> > > Clearly it needs to be available for BSP code to use.
> > > Does it need to be available for user application (non-BSP)
> code?
> > Not really. Maybe could be usefull for closed BSPs with
> drivers that are
> > not put back to RTEMS. But as an open source project I don't
> think that
> > we have to take these into account as long as non of us needs
> the feature.
> Then we don't need a public API. That is a bit easier. Closed
> BSPs can
> poke under the hood if they need to, and we don't need to really
> care
> as you say.
> > > Does it need to be available for any driver frameworks in
> cpukit?
> > Not as far as I can tell. Of course it would be possible to
> say that it
> > _is_ a driver framework.
> Right, but if the code base itself does not need to be accessed from
> within cpukit, then it doesn't need to be in the cpukit.
> > > Does it need to be available for libbsd?
> > Can be usefull to reduce the duplication of code in libbsd and
> RTEMS.
> In this case though, libbsd could still provide the headers, if the
> code can be found/linked through the installed rtems. So, it
> seems to
> me that we don't need to have public headers at all. Then, this
> entire
> piece of code can reside in the bsps/ layer and can be
> namespaced like
> other bsp code if necessary.
> > > I think answers to those 3 questions will help to decide what
> > > direction to proceed.
> > >>>> Best regards
> > >>>> Christian
> > >>>>>> + TEST_END();
> > >>>>>> + rtems_test_exit(0);
> > >>>>>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> > >>>>>> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> > >>>>>> +#define CONFIGURE_MAXIMUM_TASKS 1
> > >>>>>> +#define CONFIGURE_INITIAL_EXTENSIONS
> RTEMS_TEST_INITIAL_EXTENSION
> > >>>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> > >>>>>> +#include <rtems/confdefs.h>
> > >>>>>> \ No newline at end of file
> > >>>>>> diff --git
> a/testsuites/libtests/openfirmware01/openfirmware01.doc
> b/testsuites/libtests/openfirmware01/openfirmware01.doc
> > >>>>>> index 0000000000..a9d2085798
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/openfirmware01.doc
> > >>>>>> @@ -0,0 +1,29 @@
> > >>>>>> +This file describes the directives and concepts tested
> by this test set.
> > >>>>>> +test set name: openfirmware01
> > >>>>>> +directives:
> > >>>>>> + - OF_peer
> > >>>>>> + - OF_child
> > >>>>>> + - OF_parent
> > >>>>>> + - OF_getproplen
> > >>>>>> + - OF_getprop
> > >>>>>> + - OF_getencprop
> > >>>>>> + - OF_hasprop
> > >>>>>> + - OF_searchprop
> > >>>>>> + - OF_searchencprop
> > >>>>>> + - OF_getprop_alloc
> > >>>>>> + - OF_getprop_alloc_multi
> > >>>>>> + - OF_getencprop_alloc
> > >>>>>> + - OF_getencprop_alloc_multi
> > >>>>>> + - OF_prop_free
> > >>>>>> + - OF_nextprop
> > >>>>>> + - OF_setprop
> > >>>>>> + - OF_canon
> > >>>>>> + - OF_finddevice
> > >>>>>> + - OF_package_to_path
> > >>>>>> +concepts:
> > >>>>>> + - Ensure that some openfimware functions work as
> expected.
> > >>>>>> diff --git
> a/testsuites/libtests/openfirmware01/openfirmware01.scn
> b/testsuites/libtests/openfirmware01/openfirmware01.scn
> > >>>>>> index 0000000000..38abbdfc45
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/openfirmware01.scn
> > >>>>>> @@ -0,0 +1,2 @@
> > >>>>>> +*** BEGIN OF TEST OPENFIRMWARE 1 ***
> > >>>>>> +*** END OF TEST OPENFIRMWARE 1 ***
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.c
> b/testsuites/libtests/openfirmware01/some.c
> > >>>>>> index 0000000000..5eed911204
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.c
> > >>>>>> @@ -0,0 +1,52 @@
> > >>>>>> + * Declarations for C structure representing binary
> file some.bin
> > >>>>>> + * WARNING: Automatically generated -- do not edit!
> > >>>>>> +#include <sys/types.h>
> > >>>>>> +const unsigned char some_bin[] = {
> > >>>>>> + 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8,
> 0x00, 0x00, 0x00, 0x38,
> > >>>>>> + 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28,
> 0x00, 0x00, 0x00, 0x11,
> > >>>>>> + 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x48,
> > >>>>>> + 0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x01,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> 0x00, 0x00, 0x00, 0x04,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00,
> > >>>>>> + 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b,
> > >>>>>> + 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> 0x00, 0x00, 0x00, 0x1a,
> > >>>>>> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00,
> > >>>>>> + 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00,
> > >>>>>> + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c,
> > >>>>>> + 0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02,
> > >>>>>> + 0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b,
> > >>>>>> + 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> 0x61, 0x6c, 0x69, 0x61,
> > >>>>>> + 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
> 0x00, 0x00, 0x00, 0x08,
> > >>>>>> + 0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31,
> 0x32, 0x34, 0x38, 0x00,
> 0x6d, 0x40, 0x31, 0x32,
> > >>>>>> + 0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef,
> 0x12, 0x34, 0x56, 0x78,
> 0x00, 0x00, 0x00, 0x34,
> > >>>>>> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01,
> > >>>>>> + 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02,
> > >>>>>> + 0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> > >>>>>> + 0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00,
> 0x74, 0x00, 0x00, 0x00,
> 0x00, 0x00, 0x00, 0x46,
> > >>>>>> + 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02,
> > >>>>>> + 0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70,
> 0x61, 0x74, 0x69, 0x62,
> > >>>>>> + 0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72,
> 0x65, 0x73, 0x73, 0x2d,
> > >>>>>> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73,
> 0x69, 0x7a, 0x65, 0x2d,
> > >>>>>> + 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f,
> 0x64, 0x65, 0x6c, 0x00,
> > >>>>>> + 0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00,
> 0x6c, 0x69, 0x6e, 0x75,
> > >>>>>> + 0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c,
> 0x65, 0x00, 0x70, 0x00,
> > >>>>>> + 0x72, 0x00, 0x75, 0x00,
> > >>>>>> +const size_t some_bin_size = sizeof(some_bin);
> > >>>>>> diff --git
> a/testsuites/libtests/openfirmware01/some.dts
> b/testsuites/libtests/openfirmware01/some.dts
> > >>>>>> index 0000000000..ac15825b17
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.dts
> > >>>>>> @@ -0,0 +1,54 @@
> > >>>>>> + * Copyright (c) 2015 embedded brains GmbH. All
> rights reserved.
> > >>>>>> + * embedded brains GmbH
> > >>>>>> + * Dornierstr. 4
> > >>>>>> + * 82178 Puchheim
> > >>>>>> + * Germany
> > >>>>>> + * <rtems at embedded-brains.de
> <mailto:rtems at embedded-brains.de>>
> > >>>>>> + * The license and distribution terms for this file may be
> > >>>>>> + * found in the file LICENSE in this distribution or at
> > >>>>>> + * http://www.rtems.org/license/LICENSE.
> > >>>>>> +/dts-v1/;
> > >>>>>> + compatible = "a,b";
> > >>>>>> + #address-cells = <1>;
> > >>>>>> + #size-cells = <2>;
> > >>>>>> + model = "c";
> > >>>>>> + d {
> > >>>>>> + e = "f";
> > >>>>>> + g;
> > >>>>>> + h at 0 {
> > >>>>>> + h at 1 {
> > >>>>>> + w = <123>;
> > >>>>>> + aliases {
> > >>>>>> + k = "/m at 1248";
> > >>>>>> + l: m at 1248 {
> > >>>>>> + n = <0xdeadbeef 0x12345678>;
> > >>>>>> + o {
> > >>>>>> + p;
> > >>>>>> + q {
> > >>>>>> + r = "s";
> > >>>>>> + t {
> > >>>>>> + u = <&l>;
> > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.h
> b/testsuites/libtests/openfirmware01/some.h
> > >>>>>> index 0000000000..e2e0135e68
> > >>>>>> --- /dev/null
> > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.h
> > >>>>>> @@ -0,0 +1,15 @@
> > >>>>>> + * Extern declarations for C structure representing
> binary file some.bin
> > >>>>>> +#ifndef __some_h
> > >>>>>> +#define __some_h
> > >>>>>> +extern const unsigned char some_bin[];
> > >>>>>> +extern const size_t some_bin_size;
> > >>>>>> +#endif
> > >>>>>> 2.17.1
> > >>>>> _______________________________________________
> > >>>>> devel mailing list
> > >>>>> devel at rtems.org <mailto:devel at rtems.org>
> > >>>>> http://lists.rtems.org/mailman/listinfo/devel
