[PATCH RTEMS 7/7] libtests/openfirmware: Added a testsuite for openfirmware
Niteesh G. S. niteesh.gs at gmail.com
Sat Aug 8 08:01:54 UTC 2020
ping.
On Wed, Aug 5, 2020 at 12:16 AM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello,
> I think the big question is: Should we make that a public API and keep
> it in cpukit or should we make it a BSP support code and move ti to the
> bsps/shared section?
> Sebastian and Gedare: Like Niteesh said: There have been some different
> directions in the past. Which one should be the target?
> Best regards
> Christian
> On 04/08/2020 20:36, Niteesh G. S. wrote:
> > Ping.
> > On Sun, Aug 2, 2020 at 2:44 PM Niteesh G. S. <niteesh.gs at gmail.com
> > <mailto:niteesh.gs at gmail.com>> wrote:
> >     Hello,
> >     I went through some of my previous conversations to summarize the
> >     various directories
> >     suggested by people. Maybe this will help to come up with a
> conclusion.
> >     In my first porting commit, I placed the files under
> >     cpukit/libfreebsd this caused issues like
> >     accessing BSP dependent functions like bsp_fdt_get() therefore
> >     Christian suggested moving
> >     the files to bsps/shared.
> >     https://lists.rtems.org/pipermail/devel/2020-May/059959.html
> >     I then posted the patches on the mailing lists after moving the
> >     files to bsps/shared. After this
> >     Sebastian suggested moving these back to cpukit since they are BSP
> >     independent. And add
> >     an API to register FDTs since this would allow for unit testing. But
> >     later instead of API we
> >     started using linker wrappers.
> >     https://lists.rtems.org/pipermail/devel/2020-May/059978.html
> >     https://lists.rtems.org/pipermail/devel/2020-June/060025.html
> >     Gedare also suggested having the files in cpukit since this would
> >     allow for easier synchronization
> >     with FreeBSD.
> >     https://lists.rtems.org/pipermail/devel/2020-May/059807.html
> >     Thanks,
> >     Niteesh.
> >     On Thu, Jul 30, 2020 at 1:03 AM Gedare Bloom <gedare at rtems.org
> >     <mailto:gedare at rtems.org>> wrote:
> >         On Wed, Jul 29, 2020 at 12:33 PM Christian Mauderer
> >         <oss at c-mauderer.de <mailto:oss at c-mauderer.de>> wrote:
> >         > On 29/07/2020 20:21, Gedare Bloom wrote:
> >         > > On Wed, Jul 29, 2020 at 12:10 PM Christian Mauderer
> >         > >> On 29/07/2020 19:55, Gedare Bloom wrote:
> >         > >>> On Wed, Jul 29, 2020 at 10:44 AM Christian Mauderer
> >         > >>>> On 29/07/2020 18:07, Gedare Bloom wrote:
> >         > >>>>> On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu
> >         <niteesh.gs at gmail.com <mailto:niteesh.gs at gmail.com>> wrote:
> >         > >>>>>>  spec/build/testsuites/libtests/grp.yml        |   3 +
> >         > >>>>>>  .../testsuites/libtests/openfirmware01.yml    |  20 +++
> >         > >>>>>>  testsuites/libtests/openfirmware01/init.c     | 147
> >         > >>>>>>  .../openfirmware01/openfirmware01.doc         |  29
> >         > >>>>>>  .../openfirmware01/openfirmware01.scn         |   2 +
> >         > >>>>>>  testsuites/libtests/openfirmware01/some.c     |  52
> >         > >>>>>>  testsuites/libtests/openfirmware01/some.dts   |  54
> >         > >>>>>>  testsuites/libtests/openfirmware01/some.h     |  15 ++
> >         > >>>>>>  8 files changed, 322 insertions(+)
> >         > >>>>>>  create mode 100644
> >         spec/build/testsuites/libtests/openfirmware01.yml
> >         > >>>>>>  create mode 100644
> >         > >>>>>>  create mode 100644
> >         testsuites/libtests/openfirmware01/openfirmware01.doc
> >         > >>>>>>  create mode 100644
> >         testsuites/libtests/openfirmware01/openfirmware01.scn
> >         > >>>>>>  create mode 100644
> >         > >>>>>>  create mode 100644
> >         > >>>>>>  create mode 100644
> >         > >>>>>> diff --git a/spec/build/testsuites/libtests/grp.yml
> >         b/spec/build/testsuites/libtests/grp.yml
> >         > >>>>>> index f1de6cd75f..56e84d2c89 100644
> >         > >>>>>> --- a/spec/build/testsuites/libtests/grp.yml
> >         > >>>>>> +++ b/spec/build/testsuites/libtests/grp.yml
> >         > >>>>>> @@ -11,6 +11,7 @@ install: []
> >         > >>>>>>  ldflags:
> >         > >>>>>>  - -Wl,--wrap=printf
> >         > >>>>>>  - -Wl,--wrap=puts
> >         > >>>>>> +- -Wl,--wrap=bsp_fdt_get
> >         > >>>>>>  links:
> >         > >>>>>>  - role: build-dependency
> >         > >>>>>>    uid: optbin2c
> >         > >>>>>> @@ -312,6 +313,8 @@ links:
> >         > >>>>>>    uid: write
> >         > >>>>>>    uid: writev
> >         > >>>>>> +- role: build-dependency
> >         > >>>>>> +  uid: openfirmware01
> >         > >>>>>>  type: build
> >         > >>>>>>  use-after:
> >         > >>>>>>  - rtemstest
> >         > >>>>>> diff --git
> >         a/spec/build/testsuites/libtests/openfirmware01.yml
> >         b/spec/build/testsuites/libtests/openfirmware01.yml
> >         > >>>>>> new file mode 100644
> >         > >>>>>> index 0000000000..8feb69eb1e
> >         > >>>>>> --- /dev/null
> >         > >>>>>> +++ b/spec/build/testsuites/libtests/openfirmware01.yml
> >         > >>>>>> @@ -0,0 +1,20 @@
> >         > >>>>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> >         > >>>>>> +build-type: test-program
> >         > >>>>>> +cflags: []
> >         > >>>>>> +copyrights:
> >         > >>>>>> +- Copyright (C) 2020 Niteesh G S
> >         > >>>>>> +cppflags: []
> >         > >>>>>> +cxxflags: []
> >         > >>>>>> +enabled-by: true
> >         > >>>>>> +features: c cprogram
> >         > >>>>>> +includes: []
> >         > >>>>>> +ldflags: []
> >         > >>>>>> +links: []
> >         > >>>>>> +source:
> >         > >>>>>> +- testsuites/libtests/openfirmware01/init.c
> >         > >>>>>> +- testsuites/libtests/openfirmware01/some.c
> >         > >>>>>> +stlib: []
> >         > >>>>>> +target: testsuites/libtests/openfirmware01.exe
> >         > >>>>>> +type: build
> >         > >>>>>> +use-after: []
> >         > >>>>>> +use-before: []
> >         > >>>>>> diff --git a/testsuites/libtests/openfirmware01/init.c
> >         b/testsuites/libtests/openfirmware01/init.c
> >         > >>>>>> index 0000000000..fc38e6c513
> >         > >>>>>> --- /dev/null
> >         > >>>>>> +++ b/testsuites/libtests/openfirmware01/init.c
> >         > >>>>>> @@ -0,0 +1,147 @@
> >         > >>>>>> +/* SPDX-License-Identifier: BSD-2-Clause */
> >         > >>>>>> + * Copyright (C) <2020> Niteesh G S
> >         > >>>>>> + * Redistribution and use in source and binary forms,
> >         with or without
> >         > >>>>>> + * modification, are permitted provided that the
> >         following conditions
> >         > >>>>>> + * are met:
> >         > >>>>>> + * 1. Redistributions of source code must retain the
> >         above copyright
> >         > >>>>>> + *    notice, this list of conditions and the
> >         following disclaimer.
> >         > >>>>>> + * 2. Redistributions in binary form must reproduce
> >         the above copyright
> >         following disclaimer in the
> >         > >>>>>> + *    documentation and/or other materials provided
> >         with the distribution.
> >         > >>>>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS
> >         AND CONTRIBUTORS "AS IS"
> >         > >>>>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING,
> >         BUT NOT LIMITED TO, THE
> >         > >>>>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
> >         FOR A PARTICULAR PURPOSE
> >         > >>>>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
> >         OWNER OR CONTRIBUTORS BE
> >         > >>>>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
> >         SPECIAL, EXEMPLARY, OR
> >         > >>>>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED
> >         TO, PROCUREMENT OF
> >         > >>>>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
> >         PROFITS; OR BUSINESS
> >         > >>>>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
> >         LIABILITY, WHETHER IN
> >         > >>>>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING
> >         NEGLIGENCE OR OTHERWISE)
> >         > >>>>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
> >         EVEN IF ADVISED OF THE
> >         > >>>>>> + * POSSIBILITY OF SUCH DAMAGE.
> >         > >>>>>> +#ifdef HAVE_CONFIG_H
> >         > >>>>>> +#include "config.h"
> >         > >>>>>> +#endif
> >         > >>>>>> +#include <tmacros.h>
> >         > >>>>>> +#include <stdio.h>
> >         > >>>>>> +#include <stdlib.h>
> >         > >>>>>> +#include <libfdt.h>
> >         > >>>>>> +#include <sys/endian.h>
> >         > >>>>>> +#include <dev/ofw/openfirm.h>
> >         > >>>>>> +#include "some.h"
> >         > >>>>>> +#define BUF_SIZE 100
> >         > >>>>>> +const char rtems_test_name[] = "OpenFirmWare 01";
> >         > >>>>>> +const void *__wrap_bsp_fdt_get(void);
> >         > >>>>>> +const void *__real_bsp_fdt_get(void);
> >         > >>>>>> +    if (some_bin != NULL) {
> >         > >>>>>> +        return &some_bin[0];
> >         > >>>>>> +    return __real_bsp_fdt_get();
> >         > >>>>>> +static void Init(rtems_task_argument arg)
> >         > >>>>>> +    int rv;
> >         > >>>>>> +    phandle_t d;
> >         > >>>>>> +    phandle_t l;
> >         > >>>>>> +    phandle_t t;
> >         > >>>>>> +    phandle_t root;
> >         > >>>>>> +    phandle_t temp;
> >         > >>>>>> +    uint32_t *arr;
> >         > >>>>>> +    char buf[BUF_SIZE];
> >         > >>>>>> +    char *bufp;
> >         > >>>>>> +    ssize_t buf_len;
> >         > >>>>>> +    TEST_BEGIN();
> >         > >>>>>> +    buf_len = sizeof(buf);
> >         > >>>>>> +     * Cannot use fdt_path_offset to compare because
> >         > >>>>>> +     * the OF interface uses the offset from the ftdp
> >         > >>>>>> +     * to the node as phandle.
> >         > >>>>>> +    root = OF_finddevice("/");
> >         > >>>>>> +    rtems_test_assert(root == 56);
> >         > >>>>>> +    root = OF_peer(0);
> >         > >>>>>> +    d = OF_child(root);
> >         > >>>>>> +    temp = OF_finddevice("/d");
> >         > >>>>>> +    rtems_test_assert(d == temp);
> >         > >>>>>> +    temp = OF_parent(d);
> >         > >>>>>> +    rtems_test_assert(root == temp);
> >         > >>>>>> +    rv = OF_getprop(d, "e", buf, buf_len);
> >         > >>>>>> +    rtems_test_assert(rv != -1);
> >         > >>>>>> +    rtems_test_assert(strcmp(buf, "f") == 0);
> >         > >>>>>> +    rv = OF_hasprop(d, "g");
> >         > >>>>>> +    rtems_test_assert(rv == 1);
> >         > >>>>>> +    rv = OF_getproplen(root, "model");
> >         > >>>>>> +    rtems_test_assert(rv == 2);
> >         > >>>>>> +    rv = OF_nextprop(d, "e", buf, buf_len);
> >         > >>>>>> +    rtems_test_assert(strcmp(buf, "g") == 0);
> >         > >>>>>> +    l = OF_finddevice("/m at 1248");
> >         > >>>>>> +    rv = OF_searchprop(l, "model", buf, buf_len);
> >         > >>>>>> +    rtems_test_assert(strcmp(buf, "c") == 0);
> >         > >>>>>> +    rv = OF_getprop_alloc(root, "compatible", (void
> >         **)&bufp);
> >         > >>>>>> +    rtems_test_assert(strcmp(bufp, "a,b") == 0);
> >         > >>>>>> +    OF_prop_free(bufp);
> >         > >>>>>> +    rv = OF_getprop_alloc_multi(l, "n", sizeof(*arr),
> >         (void **)&arr);
> >         > >>>>>> +    rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
> >         > >>>>>> +    rtems_test_assert(arr[1] == htobe32(0x12345678));
> >         > >>>>>> +    rv = OF_getencprop_alloc_multi(l, "n",
> >         sizeof(*arr), (void **)&arr);
> >         > >>>>>> +    rtems_test_assert(arr[0] == 0xdeadbeef);
> >         > >>>>>> +    rtems_test_assert(arr[1] == 0x12345678);
> >         > >>>>>> +    t = OF_finddevice("/t");
> >         > >>>>>> +    rv = OF_nextprop(t, "u", buf, buf_len);
> >         > >>>>>> +    rtems_test_assert(rv == 0);
> >         > >>>>> ok, so these are intended to be application-visible. The
> >         interface is
> >         > >>>>> not standard though, as far as I know. So, I think we
> >         need to ensure
> >         > >>>>> we provide an RTEMS-friendly namespace for this OF API,
> >         and make sure
> >         > >>>>> the header files are properly arranged for
> >         visibility/layering.
> >         > >>>>> Everything else seems fine to me in a quick glance.
> >         > >>>> Hello Gedare,
> >         > >>>> the interface is ported from FreeBSD. It's an internal
> >         one in FreeBSD
> >         > >>>> but I think it is useful for application drivers too.
> >         > >>>> What would you suggest regarding the namespace. I'm not a
> >         big fan of
> >         > >>>> changing imported FreeBSD code.
> >         > >>> Background: The problem we have to avoid is polluting the
> user
> >         > >>> namespace. Software in kernel space, such as FreeBSD and
> other
> >         > >>> monolithic kernels, don't have that problem.
> >         > >>> I haven't studied the usage closely, I guess the pinmux is
> >         the main
> >         > >>> thing, but I'd like to understand if the FreeBSD symbols
> >         need to be
> >         > >>> exposed.
> >         > >>> Would it be feasible to introduce an rtems-branded API for
> >         this stuff,
> >         > >>> and provide a wrapper in libbsd for compatibility? Imagine
> >         something
> >         > >>> like....
> >         > >>> <rtems/dev/openfirmware.h>
> >         > >>> rtems_openfirmware_finddevice(char *s);
> >         > >>> freebsd-compat:
> >         > >>> #define OF_finddevice rtems_openfirmware_finddevice
> >         > >>> You could even then reuse other ofw interfaces, like:
> >         > >>> linux-compat:
> >         > >>> #define of_finddevice rtems_openfirmware_finddevice
> >         > >>> Just for example.
> >         > >>> This way, we only pollute the namespace if someone pulls
> >         in the bsd library.
> >         > >>> If the FreeBSD symbols have to be available inside RTEMS
> >         to support
> >         > >>> drivers without libbsd, then I would rather see the
> >         symbols converted
> >         > >>> to macros that link to namespace-friendly functions
> instead.
> >         > >>> Gedare
> >         > >> The main problem was that the openfirmware stuff is ported
> >         from FreeBSD
> >         > >> and someone (don't remember exactly who, possible that it
> >         was me)
> >         > >> suggestet that the ported files should be placed in cpukit
> >         rather than
> >         > >> in the BSP section. With that it's quite hard to use the
> >         interfaces in a
> >         > >> BSP driver without installing some headers.
> >         > > Let's step back for one minute and determine the
> >         requirements for the
> >         > > ofw support.
> >         > > Clearly it needs to be available for BSP code to use.
> >         > > Does it need to be available for user application (non-BSP)
> >         code?
> >         > Not really. Maybe could be usefull for closed BSPs with
> >         drivers that are
> >         > not put back to RTEMS. But as an open source project I don't
> >         think that
> >         > we have to take these into account as long as non of us needs
> >         the feature.
> >         Then we don't need a public API. That is a bit easier. Closed
> >         BSPs can
> >         poke under the hood if they need to, and we don't need to really
> >         care
> >         as you say.
> >         > > Does it need to be available for any driver frameworks in
> >         cpukit?
> >         > Not as far as I can tell. Of course it would be possible to
> >         say that it
> >         > _is_ a driver framework.
> >         Right, but if the code base itself does not need to be accessed
> from
> >         within cpukit, then it doesn't need to be in the cpukit.
> >         > > Does it need to be available for libbsd?
> >         > Can be usefull to reduce the duplication of code in libbsd and
> >         RTEMS.
> >         In this case though, libbsd could still provide the headers, if
> the
> >         code can be found/linked through the installed rtems. So, it
> >         seems to
> >         me that we don't need to have public headers at all. Then, this
> >         entire
> >         piece of code can reside in the bsps/ layer and can be
> >         namespaced like
> >         other bsp code if necessary.
> >         > > I think answers to those 3 questions will help to decide what
> >         > > direction to proceed.
> >         > >>>> Best regards
> >         > >>>> Christian
> >         > >>>>>> +    TEST_END();
> >         > >>>>>> +    rtems_test_exit(0);
> >         > >>>>>> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> >         > >>>>>> +#define
> CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> >         > >>>>>> +#define CONFIGURE_MAXIMUM_TASKS 1
> >         > >>>>>> +#define CONFIGURE_INITIAL_EXTENSIONS
> >         RTEMS_TEST_INITIAL_EXTENSION
> >         > >>>>>> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> >         > >>>>>> +#include <rtems/confdefs.h>
> >         > >>>>>> \ No newline at end of file
> >         > >>>>>> diff --git
> >         a/testsuites/libtests/openfirmware01/openfirmware01.doc
> >         b/testsuites/libtests/openfirmware01/openfirmware01.doc
> >         > >>>>>> index 0000000000..a9d2085798
> >         > >>>>>> --- /dev/null
> >         > >>>>>> @@ -0,0 +1,29 @@
> >         > >>>>>> +This file describes the directives and concepts tested
> >         by this test set.
> >         > >>>>>> +test set name: openfirmware01
> >         > >>>>>> +directives:
> >         > >>>>>> +  - OF_peer
> >         > >>>>>> +  - OF_child
> >         > >>>>>> +  - OF_parent
> >         > >>>>>> +  - OF_getproplen
> >         > >>>>>> +  - OF_getprop
> >         > >>>>>> +  - OF_getencprop
> >         > >>>>>> +  - OF_hasprop
> >         > >>>>>> +  - OF_searchprop
> >         > >>>>>> +  - OF_searchencprop
> >         > >>>>>> +  - OF_getprop_alloc
> >         > >>>>>> +  - OF_getprop_alloc_multi
> >         > >>>>>> +  - OF_getencprop_alloc
> >         > >>>>>> +  - OF_getencprop_alloc_multi
> >         > >>>>>> +  - OF_prop_free
> >         > >>>>>> +  - OF_nextprop
> >         > >>>>>> +  - OF_setprop
> >         > >>>>>> +  - OF_canon
> >         > >>>>>> +  - OF_finddevice
> >         > >>>>>> +  - OF_package_to_path
> >         > >>>>>> +concepts:
> >         > >>>>>> +  - Ensure that some openfimware functions work as
> >         expected.
> >         > >>>>>> diff --git
> >         a/testsuites/libtests/openfirmware01/openfirmware01.scn
> >         b/testsuites/libtests/openfirmware01/openfirmware01.scn
> >         > >>>>>> index 0000000000..38abbdfc45
> >         > >>>>>> --- /dev/null
> >         > >>>>>> @@ -0,0 +1,2 @@
> >         > >>>>>> +*** BEGIN OF TEST OPENFIRMWARE 1 ***
> >         > >>>>>> +*** END OF TEST OPENFIRMWARE 1 ***
> >         > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.c
> >         b/testsuites/libtests/openfirmware01/some.c
> >         > >>>>>> index 0000000000..5eed911204
> >         > >>>>>> --- /dev/null
> >         > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.c
> >         > >>>>>> @@ -0,0 +1,52 @@
> >         > >>>>>> + *  Declarations for C structure representing binary
> >         file some.bin
> >         > >>>>>> + *  WARNING: Automatically generated -- do not edit!
> >         > >>>>>> +#include <sys/types.h>
> >         > >>>>>> +const unsigned char some_bin[] = {
> >         > >>>>>> +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8,
> >         0x00, 0x00, 0x00, 0x38,
> >         > >>>>>> +  0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28,
> >         0x00, 0x00, 0x00, 0x11,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00,
> >         0x00, 0x00, 0x00, 0x48,
> >         > >>>>>> +  0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> >         0x00, 0x00, 0x00, 0x01,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         0x00, 0x00, 0x00, 0x04,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> >         0x00, 0x00, 0x00, 0x1a,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00,
> >         > >>>>>> +  0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c,
> >         > >>>>>> +  0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02,
> >         > >>>>>> +  0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> >         0x61, 0x6c, 0x69, 0x61,
> >         > >>>>>> +  0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         0x00, 0x00, 0x00, 0x08,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31,
> >         0x32, 0x34, 0x38, 0x00,
> >         0x6d, 0x40, 0x31, 0x32,
> >         > >>>>>> +  0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef,
> >         0x12, 0x34, 0x56, 0x78,
> >         0x00, 0x00, 0x00, 0x34,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01,
> >         > >>>>>> +  0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02,
> >         > >>>>>> +  0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00,
> >         0x74, 0x00, 0x00, 0x00,
> >         0x00, 0x00, 0x00, 0x46,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02,
> >         > >>>>>> +  0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70,
> >         0x61, 0x74, 0x69, 0x62,
> >         > >>>>>> +  0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72,
> >         0x65, 0x73, 0x73, 0x2d,
> >         > >>>>>> +  0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73,
> >         0x69, 0x7a, 0x65, 0x2d,
> >         > >>>>>> +  0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f,
> >         0x64, 0x65, 0x6c, 0x00,
> >         > >>>>>> +  0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00,
> >         0x6c, 0x69, 0x6e, 0x75,
> >         > >>>>>> +  0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c,
> >         0x65, 0x00, 0x70, 0x00,
> >         > >>>>>> +  0x72, 0x00, 0x75, 0x00,
> >         > >>>>>> +const size_t some_bin_size = sizeof(some_bin);
> >         > >>>>>> diff --git
> >         a/testsuites/libtests/openfirmware01/some.dts
> >         b/testsuites/libtests/openfirmware01/some.dts
> >         > >>>>>> index 0000000000..ac15825b17
> >         > >>>>>> --- /dev/null
> >         > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.dts
> >         > >>>>>> @@ -0,0 +1,54 @@
> >         > >>>>>> + * Copyright (c) 2015 embedded brains GmbH.  All
> >         rights reserved.
> >         > >>>>>> + *  embedded brains GmbH
> >         > >>>>>> + *  Dornierstr. 4
> >         > >>>>>> + *  82178 Puchheim
> >         > >>>>>> + *  Germany
> >         > >>>>>> + *  <rtems at embedded-brains.de
> >         <mailto:rtems at embedded-brains.de>>
> >         > >>>>>> + * The license and distribution terms for this file
> may be
> >         > >>>>>> + * found in the file LICENSE in this distribution or at
> >         > >>>>>> + * http://www.rtems.org/license/LICENSE.
> >         > >>>>>> +/dts-v1/;
> >         > >>>>>> +       compatible = "a,b";
> >         > >>>>>> +       #address-cells = <1>;
> >         > >>>>>> +       #size-cells = <2>;
> >         > >>>>>> +       model = "c";
> >         > >>>>>> +       d {
> >         > >>>>>> +               e = "f";
> >         > >>>>>> +               g;
> >         > >>>>>> +               h at 0 {
> >         > >>>>>> +               h at 1 {
> >         > >>>>>> +                       w = <123>;
> >         > >>>>>> +       aliases {
> >         > >>>>>> +               k = "/m at 1248";
> >         > >>>>>> +       l: m at 1248 {
> >         > >>>>>> +               n = <0xdeadbeef 0x12345678>;
> >         > >>>>>> +               o {
> >         > >>>>>> +                       p;
> >         > >>>>>> +               q {
> >         > >>>>>> +                       r = "s";
> >         > >>>>>> +       t {
> >         > >>>>>> +               u = <&l>;
> >         > >>>>>> diff --git a/testsuites/libtests/openfirmware01/some.h
> >         b/testsuites/libtests/openfirmware01/some.h
> >         > >>>>>> index 0000000000..e2e0135e68
> >         > >>>>>> --- /dev/null
> >         > >>>>>> +++ b/testsuites/libtests/openfirmware01/some.h
> >         > >>>>>> @@ -0,0 +1,15 @@
> >         > >>>>>> + *  Extern declarations for C structure representing
> >         binary file some.bin
> >         > >>>>>> +#ifndef __some_h
> >         > >>>>>> +#define __some_h
> >         > >>>>>> +extern const unsigned char some_bin[];
> >         > >>>>>> +extern const size_t some_bin_size;
> >         > >>>>>> +#endif
> >         > >>>>>> 2.17.1
> >         > >>>>> _______________________________________________
> >         > >>>>> devel mailing list
> >         > >>>>> devel at rtems.org <mailto:devel at rtems.org>
> >         > >>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200808/c76df84f/attachment-0001.html>
