legacy stack or libbsd
Chris Johns
chrisj at rtems.org
Wed Aug 5 00:40:30 UTC 2020
On 5/8/20 10:23 am, Chris Johns wrote:
> On 5/8/20 2:04 am, Heinz Junkes wrote:
>> Because the libbsd stack does not support some things yet (e.g. ntp)
> I have PTP running on libbsd. I currently have no time (ha) to clean up the work
> and create a patch. It requires some extra support in the score.
>> I have to call different
>> functions at rtems_init in EPICS. Therefore, when building EPICS for a target, I need
>> to know which stack the target was built with.
> The rtems_waf waf checks the header file. The compile check is:
> https://git.rtems.org/rtems_waf/tree/rtems.py#n355
I should also add rtems_waf detects libbsd with the following header check ...
https://git.rtems.org/rtems_waf/tree/rtems_bsd.py#n88
