[PATCH 2/2] Psxtest : Fix String Turncation warning
Sebastian Huber
Wed Aug 12 15:18:55 UTC 2020
Please use
git format-patch -v2
to generate a second version of the patch. This [PATCH 2/2] is
confusing, for example where is [PATCH 1/2]?
On 12/08/2020 17:10, Aschref Ben-Thabet wrote:
> From: Aschref Ben Thabet<aschref.ben-thabet at embedded-brains.de>
> replace strncpy with strdup to silence this warning since it tries to
> allocate enough memory to hold the old string (plus a '\0' character
> to mark the end of the string).
> testsuites/psxtests/psxndbm01/init.c | 7 ++-----
> 1 file changed, 2 insertions(+), 5 deletions(-)
> diff --git a/testsuites/psxtests/psxndbm01/init.c b/testsuites/psxtests/psxndbm01/init.c
> index b524aff0df..d862f1d7f3 100644
> --- a/testsuites/psxtests/psxndbm01/init.c
> +++ b/testsuites/psxtests/psxndbm01/init.c
> @@ -216,11 +216,8 @@ rtems_task Init(rtems_task_argument ignored)
> get_phone_no = dbm_fetch( db, name2 );
> rtems_test_assert( strcmp( (const char*)get_phone_no.dptr, PHONE_NO2 ) == 0 );
> - puts( "Fetch non-existing record and confirm error." );
> - test_strings = (char*)malloc(6);
> - memcpy( test_strings, "Hello", 5 );
> - test_strings[5] = '\0';
> + puts( "Fetch non-existing record and confirm error." );
Sorry, for being pedantic, but please check your patches against
unnecessary white space changes.
In general, do not add white space at the end of lines.
> + test_strings = strdup( "Hello");
There is a missing space before the closing ).
