rtems-test on BBB hardware (was Re: Enabling Buildbot 'responsible user' emails.)
Chris Johns
chrisj at rtems.org
Mon Feb 10 02:05:13 UTC 2020
On 8/2/20 11:13 am, Amar Takhar wrote:
> I was going to start with the Beaglebone and do TFTP to load the tests.
I suggest you start with getting rtems-run to run any of the built tests. You
will need ...
1. An SD card image with u-boot configured to TFTP netboot. The rtems-boot-image
tool can make this. You u-boot for the BBB.
2. The TFTP proxy tool running. This avoids all the tests and rtems-test having
to be on the same host plus with some changes rtems-test could run parallel jobs
on real hardware (currently not a priority for me to work on).
3. Serial console connections using ser2net. I have a RPi on a USB hub with a
quick power port that can run the RPi and all my consoles.
> I do
> have a board design using p-channel mosfets to be able to disconnect the power
> to each board out of band to handle hard locks. That's why I went with a custom
> power supply. Wish I had the 5-10k for the digital switchable power supplies
> I'm used to using. :)
I got a cheap one but they still cost. Sorting out the power control can be once
you can run an executable.
