AW: Description of rtems-libbsd testsuite applications
Fri Feb 14 10:44:11 UTC 2020
On 14/02/2020 11:30, Jan.Sommer at dlr.de wrote:
> Thanks for the suggestions.
> I have to figure out what some of the tests do anyway and writing it down somewhere will also prevent future-me to do it again.
> If I have some notes, is it ok to prepare a README.md inside the individual test's directory or do you prefer a single README inside the testsuite directory with a section per test?
I would start with a new test suite section in
https://github.com/RTEMS/rtems-libbsd/blob/master/README.md
with sub-sections for each documented test. Some tests belong together,
e.g. foobarserver and foobarclient.
