[PATCH 00/18] Start with splitting up confdefs.h
Sebastian Huber
Fri Feb 14 16:02:25 UTC 2020
This is the first round of patches to split up confdefs.h. See also:
https://devel.rtems.org/ticket/3875
Sebastian Huber (18):
Remove rtems_configuration_get_posix_api_configuration()
config: Remove unused configuration constant
monitor: Use proper API for all config constants
config: Remove CONFIGURE_HAS_OWN_INIT_TASK_TABLE
config: Simplify initialization task config
rtems: Simplify _RTEMS_tasks_Initialize_user_task()
config: Bring back RTEMS 4.11 configuration table
posix: Remove <rtems/posix/ptimer.h>
config: Remove CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE
config: Add _Watchdog_Microseconds_per_tick
config: Add _Watchdog_Ticks_per_timeslice
config: Add _Thread_Idle_stack_size
config: Add _Thread_Idle_body
config: Add _Workspace_Size
config: Add _Workspace_Is_unified
config: Add _SMP_Processor_configure_maximum
config: Add _SMP_Is_enabled
config: Add <rtems/confdefs/obsolete.h>
cpukit/Makefile.am | 7 +
cpukit/header-dirs.am | 2 +
cpukit/headers.am | 5 +-
cpukit/include/rtems/confdefs.h | 355 ++++++--------------------
cpukit/include/rtems/confdefs/obsolete.h | 199 +++++++++++++++
cpukit/include/rtems/config.h | 115 +--------
cpukit/include/rtems/posix/config.h | 60 -----
cpukit/include/rtems/posix/pthread.h | 25 +-
cpukit/include/rtems/posix/pthreadimpl.h | 1 -
cpukit/include/rtems/posix/ptimer.h | 88 -------
cpukit/include/rtems/rtems/config.h | 74 +++++-
cpukit/include/rtems/rtems/tasksdata.h | 19 +-
cpukit/include/rtems/score/smp.h | 26 ++
cpukit/include/rtems/score/threadidledata.h | 83 ++++++
cpukit/include/rtems/score/watchdogticks.h | 26 ++
cpukit/include/rtems/score/wkspacedata.h | 73 ++++++
cpukit/libmisc/monitor/mon-config.c | 15 +-
cpukit/libmisc/monitor/mon-itask.c | 8 +-
cpukit/posix/src/pthreadinitthreads.c | 75 +++---
cpukit/posix/src/timersettime.c | 1 -
cpukit/rtems/src/getapiconfig.c | 64 +++++
cpukit/rtems/src/taskinitdefault.c | 34 +++
cpukit/rtems/src/taskinitusers.c | 103 +++-----
cpukit/score/src/threadcreateidle.c | 6 +-
cpukit/score/src/threadidledefault.c | 34 +++
cpukit/score/src/threadidlestacksizedefault.c | 34 +++
cpukit/score/src/watchdogticksdefault.c | 41 +++
cpukit/score/src/watchdogtimeslicedefault.c | 35 +++
cpukit/score/src/wkspaceisunifieddefault.c | 34 +++
testsuites/psxtests/psxfatal01/init.c | 22 +-
testsuites/psxtests/psxfatal02/init.c | 40 +--
testsuites/sptests/sp54/init.c | 26 +-
testsuites/sptests/spfatal01/init.c | 33 +--
testsuites/sptests/spfatal02/init.c | 20 +-
testsuites/sptests/spfatal04/init.c | 20 --
testsuites/sptests/spfatal05/init.c | 20 --
testsuites/sptests/spfatal06/init.c | 24 +-
testsuites/sptests/spsysinit01/init.c | 21 ++
38 files changed, 1014 insertions(+), 854 deletions(-)
create mode 100644 cpukit/include/rtems/confdefs/obsolete.h
delete mode 100644 cpukit/include/rtems/posix/config.h
delete mode 100644 cpukit/include/rtems/posix/ptimer.h
create mode 100644 cpukit/include/rtems/score/threadidledata.h
create mode 100644 cpukit/include/rtems/score/wkspacedata.h
create mode 100644 cpukit/rtems/src/getapiconfig.c
create mode 100644 cpukit/rtems/src/taskinitdefault.c
create mode 100644 cpukit/score/src/threadidledefault.c
create mode 100644 cpukit/score/src/threadidlestacksizedefault.c
create mode 100644 cpukit/score/src/watchdogticksdefault.c
create mode 100644 cpukit/score/src/watchdogtimeslicedefault.c
create mode 100644 cpukit/score/src/wkspaceisunifieddefault.c
2.16.4
