[PATCH 01/18] Remove rtems_configuration_get_posix_api_configuration()
Fri Feb 14 16:02:26 UTC 2020
The corresponding data structure not longer exists. This function was
not tested and documented.
Close #3871.
 cpukit/include/rtems/config.h | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/cpukit/include/rtems/config.h b/cpukit/include/rtems/config.h
index c1d735f587..1c9b35da87 100644
--- a/cpukit/include/rtems/config.h
+++ b/cpukit/include/rtems/config.h
@@ -261,9 +261,6 @@ uint32_t rtems_configuration_get_maximum_extensions( void );
 #define rtems_configuration_get_rtems_api_configuration() \
         (&Configuration_RTEMS_API)
-#define rtems_configuration_get_posix_api_configuration() \
-        (&Configuration_POSIX_API)
 #ifdef __cplusplus
 #endif
2.16.4
