[PATCH v2 37/44] config: Add <rtems/confdefs/console.h>
Fri Feb 21 10:52:49 UTC 2020
Remove all comments and copyrightable content from the moved content.
Use BSD-2-Clause license for new file.
Update #3053.
Update #3875.
 cpukit/headers.am                       |  1 +
 cpukit/include/rtems/confdefs.h         | 25 +---------
 cpukit/include/rtems/confdefs/console.h | 85 +++++++++++++++++++++++++++++++++
 3 files changed, 87 insertions(+), 24 deletions(-)
 create mode 100644 cpukit/include/rtems/confdefs/console.h
diff --git a/cpukit/headers.am b/cpukit/headers.am
index 7a9cf1adae..2456c42f94 100644
--- a/cpukit/headers.am
+++ b/cpukit/headers.am
@@ -186,6 +186,7 @@ include_rtems_HEADERS += include/rtems/watchdogdrv.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/bdbuf.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/bsp.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/clock.h
+include_rtems_confdefs_HEADERS += include/rtems/confdefs/console.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/extensions.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/inittask.h
 include_rtems_confdefs_HEADERS += include/rtems/confdefs/initthread.h
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 4ae6580754..052f958b1a 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -50,6 +50,7 @@
 #include <rtems/confdefs/obsolete.h>
 #include <rtems/confdefs/bdbuf.h>
 #include <rtems/confdefs/clock.h>
+#include <rtems/confdefs/console.h>
 #include <rtems/confdefs/extensions.h>
 #include <rtems/confdefs/inittask.h>
 #include <rtems/confdefs/initthread.h>
@@ -177,30 +178,6 @@ extern "C" {
   #include <rtems/console.h>
 #endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-  #include <rtems/console.h>
-  #ifdef CONFIGURE_INIT
-    RTEMS_SYSINIT_ITEM(
-      _Console_simple_Initialize,
-      RTEMS_SYSINIT_DEVICE_DRIVERS,
-      RTEMS_SYSINIT_ORDER_SECOND
-  #endif
-#endif
-#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
-      _Console_simple_task_Initialize,
-  #endif
-#endif
 #ifdef CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
   #include <rtems/btimer.h>
 #endif
diff --git a/cpukit/include/rtems/confdefs/console.h b/cpukit/include/rtems/confdefs/console.h
new file mode 100644
index 0000000000..d89d776241
--- /dev/null
+++ b/cpukit/include/rtems/confdefs/console.h
@@ -0,0 +1,85 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * @file
+ * @ingroup RTEMSApplicationConfiguration
+ * @brief Evaluate Console Driver Configuration Options
+#ifndef _RTEMS_CONFDEFS_SIMPLECONSOLE_H
+#define _RTEMS_CONFDEFS_SIMPLECONSOLE_H
+#ifndef __CONFIGURATION_TEMPLATE_h
+#error "Do not include this file directly, use <rtems/confdefs.h> instead"
+#endif
+#ifdef CONFIGURE_INIT
+#if defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER) \
+  && defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
+  #error "CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER and CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER are mutually exclusive"
+#endif
+  || defined(CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER)
+#include <rtems/console.h>
+#include <rtems/sysinit.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+  RTEMS_SYSINIT_ITEM(
+    _Console_simple_Initialize,
+    RTEMS_SYSINIT_DEVICE_DRIVERS,
+    RTEMS_SYSINIT_ORDER_SECOND
+#endif
+#ifdef CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+    _Console_simple_task_Initialize,
+#endif
+#ifdef __cplusplus
+#endif
+#endif /* CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+  || CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER */
+#endif /* CONFIGURE_INIT */
+#endif /* _RTEMS_CONFDEFS_SIMPLECONSOLE_H */
2.16.4
