SPDX License Identifier Only and Full Copy?
Joel Sherrill
joel at rtems.org
Mon Feb 24 15:00:38 UTC 2020
On Mon, Feb 24, 2020 at 6:46 AM Andrew Butterfield <
Andrew.Butterfield at scss.tcd.ie> wrote:
> Hi Joel,
> any test files we develop (at Lero/TCD) will be generated by python
> tools,
> so we could include file level Doxygen quite easily, if that is helpful.
If we have a desired pattern for test cases, that would be good to define
before
you generate more code. At least the file blocks are good to have.
For sure, I hate to get even further behind on this.
On another project, I tried to use Doxygen to capture the tests and defined
special group named UnitTests and then used @test followed by a paragraph
and bullet list of all the test cases.
It seems like Doxygen would have a really good way to do this but I haven't
found it. :(
--joel
> Regards, Andrew
> On 24 Feb 2020, at 12:22, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Feb 24, 2020, 6:03 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hello Andrew,
>> On 24/02/2020 10:48, Andrew Butterfield wrote:
>> > Hi Sebastian,
>> > a quick question
>> > - does the Doxygen block requirement also apply to test programs
>> (xxtest/init.c),
>> > either hand-written or model-generated?
>> we currently don't use Doxygen in the tests. There is some test
>> documentation in the *.doc files of the test suite. I would like to
>> improve the test documentation with the test specification items, but
>> this is a future topic.
>> It is probably a good approach to add some documentation to generated
>> files if it is available at a higher level.
> It would be good if the tests had at least file level Doxygen. But that's
> a lot of retrofitting.
> Andrew may not realise that Doxygen is newer than RTEMS and that all
> Doxygen comments are later additions or conversions of the previous comment
> format.
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> http://www.scss.tcd.ie/Andrew.Butterfield/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200224/9f41b2c0/attachment-0001.html>
