SPDX License Identifier Only and Full Copy?
Chris Johns
chrisj at rtems.org
Wed Feb 26 04:51:12 UTC 2020
On 26/2/20 3:46 pm, Gedare Bloom wrote:
> On Tue, Feb 25, 2020 at 9:18 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 26/2/20 3:06 pm, Gedare Bloom wrote:
>>> On Tue, Feb 25, 2020 at 6:57 PM Chris Johns <chrisj at rtems.org> wrote:
>>>> On 24/2/20 6:52 pm, Sebastian Huber wrote:
>>>>> Hello,
>>>>> I updated the File Template section:
>>>>> https://docs.rtems.org/branches/master/eng/coding-file-hdr.html
>>>>> Please have a look at it and check if it is all right for you.
>>>> Does there need to be something about code copied into the source tree?
>>>> Chris
>>> Do you mean 3rd party code / code that is not licensed with 2-BSD?
>> Take this file ...
>> https://git.rtems.org/rtems/tree/cpukit/dtc/README.license
>> Does the procedure need to manage the process a user follows to add a file like
>> this? The procedure in the link covers code written by the user which is great
>> but not code that is imported. Should it?
>> Chris
> OK, I think of this as 3rd party code. This case is important to
> capture in our processes, and I'm glad you pointed it out. We always
> strive to minimize changes to 3rd party code to enhance
> maintainability. However, I could see there are benefits to adding our
> own header information to 3rd party source files, in order to capture
> their license information in SPDX for automated compliance checking,
> if nothing else.
Yes there are conflicting requirements here. Maybe the procedure could suggest
working with the upstream project adding the head?
