Strong APA Scheduler : First Draft
Richi Dubey
richidubey at gmail.com
Fri Jul 24 05:58:01 UTC 2020
Hi Andrew,
Your suggestion helps and I am going to work on it today. Thank you.
On Thu, Jul 23, 2020 at 8:14 PM Andrew Butterfield <
Andrew.Butterfield at cs.tcd.ie> wrote:
> Hi Richi,
> a quick answer to 1 below
> On 23 Jul 2020, at 15:20, Richi Dubey <richidubey at gmail.com> wrote:
> 1)Both the algorithms require the use of a FIFO Queue to support the
> insert and dequeue operations.
> I believe we can use chains and use the chain_append() and combination of
> _Chain_Extract and _Chain_First or just _Chain_First and node->next to
> achieve the FIFO requirements.
> You might want to look at chain_get() - it removes the first element, so
> does a FIFO protocol in tandem with chain_append()
> Regards,
> Andrew
> devel mailing list
> devel at rtems.org
> Andrew Butterfield Tel: +353-1-896-2517 Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
> http://www.scss.tcd.ie/Andrew.Butterfield/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200724/5a43baa1/attachment.html>
