BSP for pico and microzed
Fri Jul 31 20:26:26 UTC 2020
On Fri, Jul 31, 2020 at 3:04 PM Jonathan Brandmeyer <
jbrandmeyer at planetiq.com> wrote:
> On Fri, Jul 31, 2020 at 11:43 AM Joel Sherrill <joel at rtems.org> wrote:
>> Hi
>> Do any of the existing Zynq variants work on those? I recall posts about
>> using them but not which variant was used.
> The zedboard BSP works as-is on the microzed.  However, you almost
> certainly want to set BSP_ZYNQ_RAM_LENGTH=1024M to get access to all of the
> DRAM.
> The BSP also works as-is on the 7020 and 7030 Zynq family members as well.
Thanks.
Anyone with suggestions on how to make this more obvious? Should we add a
couple more BSP variants here like we have in the SPARC BSPs to make things
clear to end users?
--joel
> Jonathan Brandmeyer
> PlanetiQ
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200731/203eecd2/attachment-0001.html>
