BSP for pico and microzed
Christian Mauderer
oss at c-mauderer.de
Fri Jul 31 20:35:07 UTC 2020
On 31/07/2020 22:26, Joel Sherrill wrote:
> On Fri, Jul 31, 2020 at 3:04 PM Jonathan Brandmeyer
> <jbrandmeyer at planetiq.com <mailto:jbrandmeyer at planetiq.com>> wrote:
> On Fri, Jul 31, 2020 at 11:43 AM Joel Sherrill <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
> Hi
> Do any of the existing Zynq variants work on those? I recall
> posts about using them but not which variant was used.
> The zedboard BSP works as-is on the microzed. However, you almost
> certainly want to set BSP_ZYNQ_RAM_LENGTH=1024M to get access to all
> of the DRAM.
> The BSP also works as-is on the 7020 and 7030 Zynq family members as
> well.
> Thanks.
> Anyone with suggestions on how to make this more obvious? Should we add
> a couple more BSP variants here like we have in the SPARC BSPs to make
> things clear to end users?
> --joel
Hello Joel,
first a confirmation from my side: I had to do with a customer board
that used a Picozed 7030 just recently. It worked well. If you need a
more detailed configure line, I can look it up.
I don't think that adding more BSP variants would be an optimal solution
if no adaption is necessary for a specific variant. That will only lead
to a longer build time if you want to build all BSPs.
How about adding a bit more information like a list of boards the BSP
can handle in the user manual? We have a big Board Support Packages
section for that:
https://docs.rtems.org/branches/master/user/bsps/index.html
I did something like that when I extended the imx BSP to support
i.mx6ul/ull too:
https://docs.rtems.org/branches/master/user/bsps/bsps-arm.html#id11
Best regards
Christian
> Jonathan Brandmeyer
> PlanetiQ
> devel mailing list
> devel at rtems.org
