GSoC 2020: Weekly Progress Update
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Fri Jun 19 21:55:10 UTC 2020
On Fri, Jun 19, 2020 at 11:45 AM Chris Johns <chrisj at rtems.org> wrote:
> On 17/6/20 3:11 pm, Mritunjay Sharma wrote:
> > Hello everyone,
> > Following up as decided to update the weekly progress report on irc
> > channel on every Wednesday, I am updating the progress on the mailing
> list as well.
> Thank you for this. I cannot make IRC on a regular basis and email is best
> for
> me. Please keep the posts coming.
> > ==Previous Work==
> > Trying to fix missing files like "install/sh" error
> > to make the ptpd build run.
> > ==Progress==
> > Earlier errors have been resolved but a new one popped up in the morning.
> > Modified source-builder/config/ptpd-2-1.cfg file again,
> > after Googling a little and following Heinz advice,
> > %source setup ptpd -q -n ptpd-%{ptpd_version}
> > %patch setup ptpd -p1
> > +autoreconf -vfi
> This is causing me problems. I wonder why. I get ...
> configure.ac:27: error: possibly undefined macro: AC_PROG_LIBTOOL
> I will take a look at the release tarballs .... tt looks like the release
> tarballs do not have generated autoconf files. Hmmm.
> > +automake --add-missing
> > cd ${build_top}
> > %build
> > After this I made the local ptpd-master again a tar ball and used it,
> > which fixed the earlier, but now another error has popped up which I
> > am trying to fix.
> > The error is as follows:
> "/home/mritunjay/development/rtems/rsb/rtems/build/ptpd-master-arm-rtems5-1/do-build:
> > 155:
> > ../ptpd-master/configure: not found
> > shell cmd failed: /bin/sh -ex
> > error: building ptpd-master-arm-rtems5-1
> > See error report: rsb-report-ptpd-master-arm-rtems5-1.txt
> > Build Set: Time 0:00:00.191542"
> > ==Blockers==
> > These configure errors are the main blockers.
> > ==Future options==
> > Looking forward to raise this with the ptpd community
> > and trying with the help of mentors to fix the problems
> > as soon as possible.
> I think we are wedged. For us to build a package for RTEMS we need access
> the
> RTEMS tools built by the RSB. Building these tools also builds a version of
> autoconf and automake we need to configure RTEMS. With the path set to
> include
> the RTEMS tools and so the RTEMS built autoconf and automake the PTPD
> INSTALL
> documented step of `autoreconf -vi` fails with the error above.
> I decided to test by hand using the following steps:
> wget https://github.com/ptpd/ptpd/archive/ptpd.2.3.1.tar.gz
> tar zxf ptpd.2.3.1.tar.gz
> cd ptpd-ptpd.2.3.1
> autoreconf -vi
> The generate has no isssue.
> I then added the RTEMS tools path back into my path. I also have the
> Xilinx Zynq
> QEMU BSP installed under my prefix so I entered ...
> LIBS="-lrtemsdefaultconfig"
> CFLAGS="-I/opt/work/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/include
> -qrtems
> -B/opt/work/rtems/5/arm-rtems5/lib/
> -B/opt/work/rtems/5/arm-rtems5/xilinx_zynq_a9_qemu/lib/ --specs bsp_specs
> -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O0 -g
> -ffunction-sections -fdata-sections" ./configure --host=arm-rtems5
> --disable-snmp --enable-slave-only --disable-pcap
> The configure completed without error. I do not think there is any point
> contacting the ptpd community just yet.
> The build however failed with ..
> ptpd.h:93:10: fatal error: netinet/ip.h: No such file or directory
> I suggest you step back from the RSB and build ptpd by hand. I have not
> looked
> into what is wrong and why I get this compile error.
Okay Chris, thank you for this suggestion, I will work on this and update
you.
I can tell you that I encountered the same error when I was building ptpd
with erc32 using RSB and then I was asked to add a different package that
contains netinet/ip.h and then build it first. I will get to you more on
this error
because I have worked on it earlier however while building it configure
errors
again started playing their tricks and when I started doing it with
xilinx_zynq_a9_qemu using RSB,
it never came but the errors as mentioned earlier came up.
Mritunjay
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200620/86ed1e88/attachment-0001.html>
