[PATCH] Added APA terms in glossary
Richi Dubey
richidubey at gmail.com
Sun Jun 21 09:18:04 UTC 2020
c-user/glossary.rst | 34 ++++++++++++++++++++++++++++++++++
1 file changed, 34 insertions(+)
diff --git a/c-user/glossary.rst b/c-user/glossary.rst
index 86350a8..63a4728 100644
--- a/c-user/glossary.rst
+++ b/c-user/glossary.rst
@@ -1,5 +1,6 @@
.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 2020 Richi Dubey (richidubey at gmail.com)
.. Copyright (C) 2017, 2019 embedded brains GmbH (http://www.embedded-brains.de)
.. Copyright (C) 1988, 1998 On-Line Applications Research Corporation (OAR)
@@ -16,6 +17,14 @@ Glossary
A term used to describe an object which has been created by an
application.
+ APA
+ This term is an acronym for Arbitrary Processor Affinity.
+ APA schedulers allow a thread to have an arbitrary affinity to a
+ processor set, rather than a restricted mapping to only one processor
+ of the set or the ability to run on all processors of the set.
+ It has two variants, :term:`Weak APA` and :term:`Strong APA`.
aperiodic task
A task which must execute only at irregular intervals and has only a soft
deadline.
@@ -777,6 +786,20 @@ Glossary
:term:`return value` to indicate a successful operation or error
conditions.
+ Strong APA
+ Strong APA is a specialization of :term:`APA`.
+ Schedulers which implement strong APA recursively search for a
+ processor in the :term:`thread`'s affinity set, whenever a thread
+ becomes ready for execution, followed by the processors in the
+ affinity set of threads that are assigned the processor in the
+ ready thread's affinity set. This is done to find a thread to
+ processor mapping that does not violate the priority ordering and
+ to provide a thread to processor mapping with a higher total
+ priority of the threads allocated a processor.
+ Similar analysis is done when a thread blocks.
+ See also :cite:`Cerqueira:2014:LPA`.
suspend
A term used to describe a task that is not competing for the CPU because it
has had a ``rtems_task_suspend`` directive.
@@ -905,6 +928,17 @@ Glossary
Message queues, regions, and semaphores have a wait queue associated with
them.
+ Weak APA
+ Weak APA is a specialization of :term:`APA`.
+ It refers to Linux's push and pull implementation of APA model.
+ When a :term:`thread` becomes ready for execution, it is
+ allocated a processor if there is an idle processor, or if a
+ processor is executing a lower priority thread in its affinity
+ set. Unlike :term:`Strong APA`, no thread is migrated from its
+ processor to find a thread to processor mapping.
YAML
This term is an acronym for `YAML Ain't Markup Language <https://yaml.org/>`_.
2.17.1
