[PATCH] score: Clarify CPU_USE_LIBC_INIT_FINI_ARRAY option
Sebastian Huber
Tue Jun 30 07:51:55 UTC 2020
Update #4018.
cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h | 7 ++++---
1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
index 84125aa16b..50313bbd61 100644
--- a/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/no_cpu/include/rtems/score/cpu.h
@@ -250,9 +250,10 @@ extern "C" {
#define CPU_MAXIMUM_PROCESSORS 32
- * The following define determines whether or not this CPU port will use
- * libc global constructors and destructors instead of _init/_fini functions
- * depending on .ctors and .dtors linker sections.
+ * The following define determines whether or not this CPU port will use the C
+ * library support to run the global constructors and destructors on
+ * architectures that use .init_array and .fini_array sections. If defined to
+ * FALSE, then the _init() and _fini() functions will be used.
#define CPU_USE_LIBC_INIT_FINI_ARRAY TRUE
2.26.2
