Beaglebone Black USB-OTG/FDT Support GSOC
John kongtcheu johnkongtcheu at gmail.com
Sun Mar 8 17:32:41 UTC 2020
Thank you for the information. I have already done the hello world project,
(I just forwarded it to you to take a look) and I took a break for a little
bit, because of school work. Regarding, working on peripherals I was
wondering if there any spots on working on GPIO work and ADC conversion as
those are also two jobs I would be greatly interested in. Also thank you
again for your advice on the USB-OTG work and I will also do my research
regarding that topic.
On Sun, Mar 8, 2020 at 12:53 PM Christian Mauderer <list at c-mauderer.de>
wrote:
> On 08/03/2020 15:58, John kongtcheu wrote:
> > Dear Dev Mailing list,
> > I'm interested in work regarding peripherals and it seems like working
> > on the beaglebone black projects would be something I would be be good
> > at. I have experience working in embedded systems before, and I have my
> > own BBB. I was curious if there was anyone willing to mentor for this
> > project or if this project is a good idea at all.
> > Thank you,
> Hello John,
> welcome to RTEMS. Please note that we require students to send in some
> proof that they can build and run RTEMS on the hardware for the project.
> See the GSoC Getting Started guide in the wiki.
> Regarding your suggested project: I would love to see the USB-OTG
> support working. But note that we already have a proposal to extend the
> FDT support in BBB. And I'm not sure whether USB-OTG is really enough
> for a whole GSoC.
> Adding the USB-OTG support will be mostly a libbsd project and won't be
> too peripheral oriented. It is more a question about how to analyze how
> to set up an OTG device in FreeBSD and find out how that can be
> implemented in RTEMS using libbsd.
> Maybe you want to start by taking a short look at FreeBSD and how to set
> up a USB-OTG device there. Depending on that there might could be topics
> that are similar that would be a good match for the project. For example
> if it is done via rc.conf: I think there are quite some other stuff that
> could be added to rc.conf too (e.g. WLAN support; see Trac ticket #3222).
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200308/d4a09d3d/attachment.html>
