[PATCH 03/20] c-user: Move "Classic API Configuration"
Sebastian Huber
Mon Mar 9 09:02:46 UTC 2020
Update #3836.
c-user/config/classic-api-config.rst | 291 +++++++++++++++++++++++++++++++++++
c-user/config/index.rst | 289 +---------------------------------
2 files changed, 292 insertions(+), 288 deletions(-)
create mode 100644 c-user/config/classic-api-config.rst
diff --git a/c-user/config/classic-api-config.rst b/c-user/config/classic-api-config.rst
new file mode 100644
index 0000000..6c8f6ca
--- /dev/null
+++ b/c-user/config/classic-api-config.rst
@@ -0,0 +1,291 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Classic API Configuration
+This section defines the Classic API related system configuration parameters
+supported by ``<rtems/confdefs.h>``.
+.. index:: CONFIGURE_MAXIMUM_BARRIERS
+.. _CONFIGURE_MAXIMUM_BARRIERS:
+CONFIGURE_MAXIMUM_BARRIERS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_BARRIERS``
+DATA TYPE:
+ Unsigned integer (``uint32_t``).
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ The default value is 0.
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_BARRIERS`` is the maximum number of Classic API
+ Barriers that can be concurrently active.
+NOTES:
+ This object class can be configured in unlimited allocation mode.
+.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
+CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES`` is the maximum number of Classic API
+ Message Queues that can be concurrently active.
+NOTES:
+ This object class can be configured in unlimited allocation mode. You have
+ to account for the memory used to store the messages of each message queue,
+ see :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
+.. index:: CONFIGURE_MAXIMUM_PARTITIONS
+.. _CONFIGURE_MAXIMUM_PARTITIONS:
+CONFIGURE_MAXIMUM_PARTITIONS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_PARTITIONS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_PARTITIONS`` is the maximum number of Classic API
+ Partitions that can be concurrently active.
+NOTES:
+.. index:: CONFIGURE_MAXIMUM_PERIODS
+.. _CONFIGURE_MAXIMUM_PERIODS:
+CONFIGURE_MAXIMUM_PERIODS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_PERIODS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_PERIODS`` is the maximum number of Classic API Periods
+ that can be concurrently active.
+NOTES:
+.. index:: CONFIGURE_MAXIMUM_PORTS
+.. _CONFIGURE_MAXIMUM_PORTS:
+CONFIGURE_MAXIMUM_PORTS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_PORTS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_PORTS`` is the maximum number of Classic API Ports that
+ can be concurrently active.
+NOTES:
+.. index:: CONFIGURE_MAXIMUM_REGIONS
+.. _CONFIGURE_MAXIMUM_REGIONS:
+CONFIGURE_MAXIMUM_REGIONS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_REGIONS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_REGIONS`` is the maximum number of Classic API Regions
+NOTES:
+ None.
+.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
+.. _CONFIGURE_MAXIMUM_SEMAPHORES:
+CONFIGURE_MAXIMUM_SEMAPHORES
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_SEMAPHORES``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_SEMAPHORES`` is the maximum number of Classic API
+ Semaphores that can be concurrently active.
+NOTES:
+ In SMP configurations, the size of a Semaphore Control Block depends on the
+ scheduler count (see :ref:`ConfigurationSchedulerTable`). The semaphores
+ using the :ref:`MrsP` need a ceiling priority per scheduler.
+.. index:: CONFIGURE_MAXIMUM_TASKS
+.. _CONFIGURE_MAXIMUM_TASKS:
+CONFIGURE_MAXIMUM_TASKS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_TASKS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ The default value is ``0``.
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_TASKS`` is the maximum number of Classic API Tasks that
+NOTES:
+ The calculations for the required memory in the RTEMS Workspace for tasks
+ assume that each task has a minimum stack size and has floating point
+ support enabled. The configuration parameter
+ ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
+ *ABOVE* the minimum size required. See :ref:`Reserve Task/Thread Stack
+ Memory Above Minimum` for more information about
+ ``CONFIGURE_EXTRA_TASK_STACKS``.
+ The maximum number of POSIX threads is specified by
+ :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
+ A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
+ assumption that all tasks have floating point enabled. This would require
+ the addition of a new configuration parameter to specify the number of
+ tasks which enable floating point support.
+.. index:: CONFIGURE_MAXIMUM_TIMERS
+.. _CONFIGURE_MAXIMUM_TIMERS:
+CONFIGURE_MAXIMUM_TIMERS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_TIMERS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_TIMERS`` is the maximum number of Classic API Timers
+NOTES:
+.. index:: CONFIGURE_MAXIMUM_USER_EXTENSIONS
+.. _CONFIGURE_MAXIMUM_USER_EXTENSIONS:
+CONFIGURE_MAXIMUM_USER_EXTENSIONS
+CONSTANT:
+ ``CONFIGURE_MAXIMUM_USER_EXTENSIONS``
+DATA TYPE:
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+ ``CONFIGURE_MAXIMUM_USER_EXTENSIONS`` is the maximum number of Classic API
+ User Extensions that can be concurrently active.
+NOTES:
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index acbdbe2..d11343a 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -13,294 +13,7 @@ Configuring a System
intro
general-config
-Classic API Configuration
-This section defines the Classic API related system configuration parameters
-supported by ``<rtems/confdefs.h>``.
-.. index:: CONFIGURE_MAXIMUM_BARRIERS
-.. _CONFIGURE_MAXIMUM_BARRIERS:
-CONFIGURE_MAXIMUM_BARRIERS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_BARRIERS``
-DATA TYPE:
- Unsigned integer (``uint32_t``).
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- The default value is 0.
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_BARRIERS`` is the maximum number of Classic API
- Barriers that can be concurrently active.
-NOTES:
- This object class can be configured in unlimited allocation mode.
-.. index:: CONFIGURE_MAXIMUM_MESSAGE_QUEUES
-.. _CONFIGURE_MAXIMUM_MESSAGE_QUEUES:
-CONFIGURE_MAXIMUM_MESSAGE_QUEUES
-CONSTANT:
- ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES`` is the maximum number of Classic API
- Message Queues that can be concurrently active.
-NOTES:
- This object class can be configured in unlimited allocation mode. You have
- to account for the memory used to store the messages of each message queue,
- see :ref:`CONFIGURE_MESSAGE_BUFFER_MEMORY`.
-.. index:: CONFIGURE_MAXIMUM_PARTITIONS
-.. _CONFIGURE_MAXIMUM_PARTITIONS:
-CONFIGURE_MAXIMUM_PARTITIONS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_PARTITIONS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PARTITIONS`` is the maximum number of Classic API
- Partitions that can be concurrently active.
-NOTES:
-.. index:: CONFIGURE_MAXIMUM_PERIODS
-.. _CONFIGURE_MAXIMUM_PERIODS:
-CONFIGURE_MAXIMUM_PERIODS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_PERIODS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PERIODS`` is the maximum number of Classic API Periods
- that can be concurrently active.
-NOTES:
-.. index:: CONFIGURE_MAXIMUM_PORTS
-.. _CONFIGURE_MAXIMUM_PORTS:
-CONFIGURE_MAXIMUM_PORTS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_PORTS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_PORTS`` is the maximum number of Classic API Ports that
- can be concurrently active.
-NOTES:
-.. index:: CONFIGURE_MAXIMUM_REGIONS
-.. _CONFIGURE_MAXIMUM_REGIONS:
-CONFIGURE_MAXIMUM_REGIONS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_REGIONS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_REGIONS`` is the maximum number of Classic API Regions
-NOTES:
- None.
-.. index:: CONFIGURE_MAXIMUM_SEMAPHORES
-.. _CONFIGURE_MAXIMUM_SEMAPHORES:
-CONFIGURE_MAXIMUM_SEMAPHORES
-CONSTANT:
- ``CONFIGURE_MAXIMUM_SEMAPHORES``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_SEMAPHORES`` is the maximum number of Classic API
- Semaphores that can be concurrently active.
-NOTES:
- In SMP configurations, the size of a Semaphore Control Block depends on the
- scheduler count (see :ref:`ConfigurationSchedulerTable`). The semaphores
- using the :ref:`MrsP` need a ceiling priority per scheduler.
-.. index:: CONFIGURE_MAXIMUM_TASKS
-.. _CONFIGURE_MAXIMUM_TASKS:
-CONFIGURE_MAXIMUM_TASKS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_TASKS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- The default value is ``0``.
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_TASKS`` is the maximum number of Classic API Tasks that
-NOTES:
- The calculations for the required memory in the RTEMS Workspace for tasks
- assume that each task has a minimum stack size and has floating point
- support enabled. The configuration parameter
- ``CONFIGURE_EXTRA_TASK_STACKS`` is used to specify task stack requirements
- *ABOVE* the minimum size required. See :ref:`Reserve Task/Thread Stack
- Memory Above Minimum` for more information about
- ``CONFIGURE_EXTRA_TASK_STACKS``.
- The maximum number of POSIX threads is specified by
- :ref:`CONFIGURE_MAXIMUM_POSIX_THREADS <CONFIGURE_MAXIMUM_POSIX_THREADS>`.
- A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
- assumption that all tasks have floating point enabled. This would require
- the addition of a new configuration parameter to specify the number of
- tasks which enable floating point support.
-.. index:: CONFIGURE_MAXIMUM_TIMERS
-.. _CONFIGURE_MAXIMUM_TIMERS:
-CONFIGURE_MAXIMUM_TIMERS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_TIMERS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_TIMERS`` is the maximum number of Classic API Timers
-NOTES:
-.. index:: CONFIGURE_MAXIMUM_USER_EXTENSIONS
-.. _CONFIGURE_MAXIMUM_USER_EXTENSIONS:
-CONFIGURE_MAXIMUM_USER_EXTENSIONS
-CONSTANT:
- ``CONFIGURE_MAXIMUM_USER_EXTENSIONS``
-DATA TYPE:
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
- ``CONFIGURE_MAXIMUM_USER_EXTENSIONS`` is the maximum number of Classic API
- User Extensions that can be concurrently active.
-NOTES:
+ classic-api-config
Classic API Initialization Task Configuration
2.16.4
