[PATCH 04/20] c-user: Move "Classic API Initialization Task Configuration"
Sebastian Huber
Mon Mar 9 09:02:47 UTC 2020
Update #3836.
c-user/config/classic-init-task-config.rst | 234 +++++++++++++++++++++++++++++
c-user/config/index.rst | 232 +---------------------------
2 files changed, 235 insertions(+), 231 deletions(-)
create mode 100644 c-user/config/classic-init-task-config.rst
diff --git a/c-user/config/classic-init-task-config.rst b/c-user/config/classic-init-task-config.rst
new file mode 100644
index 0000000..cbbec9a
--- /dev/null
+++ b/c-user/config/classic-init-task-config.rst
@@ -0,0 +1,234 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Classic API Initialization Task Configuration
+The ``<rtems/confdefs.h>`` configuration system can automatically generate an
+Initialization Tasks Table named ``Initialization_tasks`` with a single entry.
+The following parameters control the generation of that table.
+.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
+.. _CONFIGURE_INIT_TASK_ARGUMENTS:
+CONFIGURE_INIT_TASK_ARGUMENTS
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_ARGUMENTS``
+DATA TYPE:
+ RTEMS Task Argument (``rtems_task_argument``).
+RANGE:
+ Complete range of the type.
+DEFAULT VALUE:
+ The default value is 0.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_ARGUMENTS`` is the task argument of the single
+ initialization task defined by the Classic API Initialization Tasks Table.
+NOTES:
+ None.
+.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
+.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
+CONFIGURE_INIT_TASK_ATTRIBUTES
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_ATTRIBUTES``
+DATA TYPE:
+ RTEMS Attributes (``rtems_attribute``).
+RANGE:
+ Valid task attribute sets.
+DEFAULT VALUE:
+ The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_ATTRIBUTES`` is the task attributes of the single
+NOTES:
+ None.
+.. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
+.. _CONFIGURE_INIT_TASK_ENTRY_POINT:
+CONFIGURE_INIT_TASK_ENTRY_POINT
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_ENTRY_POINT``
+DATA TYPE:
+ Task entry function pointer (``rtems_task_entry``).
+RANGE:
+ Valid task entry function pointer.
+DEFAULT VALUE:
+ The default value is ``Init``.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_ENTRY_POINT`` is the entry point (a.k.a. function
+ name) of the single initialization task defined by the Classic API
+ Initialization Tasks Table.
+NOTES:
+ The user must implement the function ``Init`` or the function name provided
+ in this configuration parameter.
+.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
+.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
+CONFIGURE_INIT_TASK_INITIAL_MODES
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_INITIAL_MODES``
+DATA TYPE:
+ RTEMS Mode (``rtems_mode``).
+RANGE:
+ Valid task mode sets.
+DEFAULT VALUE:
+ The default value is ``RTEMS_NO_PREEMPT``.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_INITIAL_MODES`` is the initial execution mode of the
+ single initialization task defined by the Classic API Initialization Tasks
+ Table.
+NOTES:
+ None.
+.. index:: CONFIGURE_INIT_TASK_NAME
+.. _CONFIGURE_INIT_TASK_NAME:
+CONFIGURE_INIT_TASK_NAME
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_NAME``
+DATA TYPE:
+ RTEMS Name (``rtems_name``).
+RANGE:
+ Any value.
+DEFAULT VALUE:
+ The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_NAME`` is the name of the single initialization task
+ defined by the Classic API Initialization Tasks Table.
+NOTES:
+ None.
+.. index:: CONFIGURE_INIT_TASK_PRIORITY
+.. _CONFIGURE_INIT_TASK_PRIORITY:
+CONFIGURE_INIT_TASK_PRIORITY
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_PRIORITY``
+DATA TYPE:
+ RTEMS Task Priority (``rtems_task_priority``).
+RANGE:
+ One (1) to the maximum user priority value of the scheduler.
+DEFAULT VALUE:
+ The default value is 1, which is the highest priority in the Classic API.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_PRIORITY`` is the initial priority of the single
+NOTES:
+ None.
+.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
+.. _CONFIGURE_INIT_TASK_STACK_SIZE:
+CONFIGURE_INIT_TASK_STACK_SIZE
+CONSTANT:
+ ``CONFIGURE_INIT_TASK_STACK_SIZE``
+DATA TYPE:
+ Unsigned integer (``size_t``).
+RANGE:
+ Zero or positive.
+DEFAULT VALUE:
+ The default value is RTEMS_MINIMUM_STACK_SIZE.
+DESCRIPTION:
+ ``CONFIGURE_INIT_TASK_STACK_SIZE`` is the stack size of the single
+NOTES:
+ If the stack size specified is greater than the configured minimum, it must
+ be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``. See :ref:`Reserve
+ Task/Thread Stack Memory Above Minimum` for more information about
+ ``CONFIGURE_EXTRA_TASK_STACKS``.
+.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
+.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
+CONFIGURE_RTEMS_INIT_TASKS_TABLE
+CONSTANT:
+ ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``
+DATA TYPE:
+ Boolean feature macro.
+RANGE:
+ Defined or undefined.
+DEFAULT VALUE:
+ This is not defined by default.
+DESCRIPTION:
+ ``CONFIGURE_RTEMS_INIT_TASKS_TABLE`` is defined if the user wishes to use a
+ Classic RTEMS API Initialization Task Table. The table built by
+ ``<rtems/confdefs.h>`` specifies the parameters for a single task. This is
+ sufficient for applications which initialization the system from a single
+ task.
+ By default, this field is not defined as the user MUST select their own API
+ for initialization tasks.
+NOTES:
+ The application may choose to use the initialization tasks or threads table
+ from another API.
+ A compile time error will be generated if the user does not configure any
+ initialization tasks or threads.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index d11343a..254deed 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -14,237 +14,7 @@ Configuring a System
intro
general-config
classic-api-config
-Classic API Initialization Task Configuration
-The ``<rtems/confdefs.h>`` configuration system can automatically generate an
-Initialization Tasks Table named ``Initialization_tasks`` with a single entry.
-The following parameters control the generation of that table.
-.. index:: CONFIGURE_INIT_TASK_ARGUMENTS
-.. _CONFIGURE_INIT_TASK_ARGUMENTS:
-CONFIGURE_INIT_TASK_ARGUMENTS
-CONSTANT:
- ``CONFIGURE_INIT_TASK_ARGUMENTS``
-DATA TYPE:
- RTEMS Task Argument (``rtems_task_argument``).
-RANGE:
- Complete range of the type.
-DEFAULT VALUE:
- The default value is 0.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_ARGUMENTS`` is the task argument of the single
- initialization task defined by the Classic API Initialization Tasks Table.
-NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_ATTRIBUTES
-.. _CONFIGURE_INIT_TASK_ATTRIBUTES:
-CONFIGURE_INIT_TASK_ATTRIBUTES
-CONSTANT:
- ``CONFIGURE_INIT_TASK_ATTRIBUTES``
-DATA TYPE:
- RTEMS Attributes (``rtems_attribute``).
-RANGE:
- Valid task attribute sets.
-DEFAULT VALUE:
- The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_ATTRIBUTES`` is the task attributes of the single
-NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_ENTRY_POINT
-.. _CONFIGURE_INIT_TASK_ENTRY_POINT:
-CONFIGURE_INIT_TASK_ENTRY_POINT
-CONSTANT:
- ``CONFIGURE_INIT_TASK_ENTRY_POINT``
-DATA TYPE:
- Task entry function pointer (``rtems_task_entry``).
-RANGE:
- Valid task entry function pointer.
-DEFAULT VALUE:
- The default value is ``Init``.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_ENTRY_POINT`` is the entry point (a.k.a. function
- name) of the single initialization task defined by the Classic API
- Initialization Tasks Table.
-NOTES:
- The user must implement the function ``Init`` or the function name provided
- in this configuration parameter.
-.. index:: CONFIGURE_INIT_TASK_INITIAL_MODES
-.. _CONFIGURE_INIT_TASK_INITIAL_MODES:
-CONFIGURE_INIT_TASK_INITIAL_MODES
-CONSTANT:
- ``CONFIGURE_INIT_TASK_INITIAL_MODES``
-DATA TYPE:
- RTEMS Mode (``rtems_mode``).
-RANGE:
- Valid task mode sets.
-DEFAULT VALUE:
- The default value is ``RTEMS_NO_PREEMPT``.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_INITIAL_MODES`` is the initial execution mode of the
- single initialization task defined by the Classic API Initialization Tasks
- Table.
-NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_NAME
-.. _CONFIGURE_INIT_TASK_NAME:
-CONFIGURE_INIT_TASK_NAME
-CONSTANT:
- ``CONFIGURE_INIT_TASK_NAME``
-DATA TYPE:
- RTEMS Name (``rtems_name``).
-RANGE:
- Any value.
-DEFAULT VALUE:
- The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_NAME`` is the name of the single initialization task
- defined by the Classic API Initialization Tasks Table.
-NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_PRIORITY
-.. _CONFIGURE_INIT_TASK_PRIORITY:
-CONFIGURE_INIT_TASK_PRIORITY
-CONSTANT:
- ``CONFIGURE_INIT_TASK_PRIORITY``
-DATA TYPE:
- RTEMS Task Priority (``rtems_task_priority``).
-RANGE:
- One (1) to the maximum user priority value of the scheduler.
-DEFAULT VALUE:
- The default value is 1, which is the highest priority in the Classic API.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_PRIORITY`` is the initial priority of the single
-NOTES:
- None.
-.. index:: CONFIGURE_INIT_TASK_STACK_SIZE
-.. _CONFIGURE_INIT_TASK_STACK_SIZE:
-CONFIGURE_INIT_TASK_STACK_SIZE
-CONSTANT:
- ``CONFIGURE_INIT_TASK_STACK_SIZE``
-DATA TYPE:
- Unsigned integer (``size_t``).
-RANGE:
- Zero or positive.
-DEFAULT VALUE:
- The default value is RTEMS_MINIMUM_STACK_SIZE.
-DESCRIPTION:
- ``CONFIGURE_INIT_TASK_STACK_SIZE`` is the stack size of the single
-NOTES:
- If the stack size specified is greater than the configured minimum, it must
- be accounted for in ``CONFIGURE_EXTRA_TASK_STACKS``. See :ref:`Reserve
- Task/Thread Stack Memory Above Minimum` for more information about
- ``CONFIGURE_EXTRA_TASK_STACKS``.
-.. index:: CONFIGURE_RTEMS_INIT_TASKS_TABLE
-.. _CONFIGURE_RTEMS_INIT_TASKS_TABLE:
-CONFIGURE_RTEMS_INIT_TASKS_TABLE
-CONSTANT:
- ``CONFIGURE_RTEMS_INIT_TASKS_TABLE``
-DATA TYPE:
- Boolean feature macro.
-RANGE:
- Defined or undefined.
-DEFAULT VALUE:
- This is not defined by default.
-DESCRIPTION:
- ``CONFIGURE_RTEMS_INIT_TASKS_TABLE`` is defined if the user wishes to use a
- Classic RTEMS API Initialization Task Table. The table built by
- ``<rtems/confdefs.h>`` specifies the parameters for a single task. This is
- sufficient for applications which initialization the system from a single
- task.
- By default, this field is not defined as the user MUST select their own API
- for initialization tasks.
-NOTES:
- The application may choose to use the initialization tasks or threads table
- from another API.
- A compile time error will be generated if the user does not configure any
- initialization tasks or threads.
+ classic-init-task-config
POSIX API Configuration
2.16.4
