[PATCH 11/20] c-user: Move "BSP Related Configuration Options"
Mon Mar 9 09:02:54 UTC 2020
Update #3836.
 c-user/config/bsp-config.rst | 247 +++++++++++++++++++++++++++++++++++++++++++
 c-user/config/index.rst      | 245 +-----------------------------------------
 2 files changed, 248 insertions(+), 244 deletions(-)
 create mode 100644 c-user/config/bsp-config.rst
diff --git a/c-user/config/bsp-config.rst b/c-user/config/bsp-config.rst
new file mode 100644
index 0000000..a8988e7
--- /dev/null
+++ b/c-user/config/bsp-config.rst
@@ -0,0 +1,247 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+BSP Related Configuration Options
+This section describes configuration options related to the BSP.  Some
+configuration options may have a BSP-specific setting which is defined by
+``<bsp.h>``.  The BSP-specific settings can be disabled by the
+:ref:`CONFIGURE_DISABLE_BSP_SETTINGS` configuration option.
+.. index:: BSP_IDLE_TASK_BODY
+.. _BSP_IDLE_TASK_BODY:
+BSP_IDLE_TASK_BODY
+CONSTANT:
+    ``BSP_IDLE_TASK_BODY``
+DATA TYPE:
+    Function pointer.
+RANGE:
+    Undefined or valid function pointer.
+DEFAULT VALUE:
+    This option is BSP specific.
+DESCRIPTION:
+    If ``BSP_IDLE_TASK_BODY`` is defined by the BSP and
+    ``CONFIGURE_IDLE_TASK_BODY`` is not defined by the application, then this
+    BSP specific idle task body will be used.
+NOTES:
+    As it has knowledge of the specific CPU model, system controller logic, and
+    peripheral buses, a BSP specific IDLE task may be capable of turning
+    components off to save power during extended periods of no task activity
+.. index:: BSP_IDLE_TASK_STACK_SIZE
+.. _BSP_IDLE_TASK_STACK_SIZE:
+BSP_IDLE_TASK_STACK_SIZE
+CONSTANT:
+    ``BSP_IDLE_TASK_STACK_SIZE``
+DATA TYPE:
+    Unsigned integer (``size_t``).
+RANGE:
+    Undefined or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+    If ``BSP_IDLE_TASK_STACK_SIZE`` is defined by the BSP and
+    ``CONFIGURE_IDLE_TASK_STACK_SIZE`` is not defined by the application, then
+    this BSP suggested idle task stack size will be used.
+NOTES:
+    The order of precedence for configuring the IDLE task stack size is:
+    - RTEMS default minimum stack size.
+    - If defined, then ``CONFIGURE_MINIMUM_TASK_STACK_SIZE``.
+    - If defined, then the BSP specific ``BSP_IDLE_TASK_SIZE``.
+    - If defined, then the application specified ``CONFIGURE_IDLE_TASK_SIZE``.
+.. index:: BSP_INITIAL_EXTENSION
+.. _BSP_INITIAL_EXTENSION:
+BSP_INITIAL_EXTENSION
+CONSTANT:
+    ``BSP_INITIAL_EXTENSION``
+DATA TYPE:
+    List of user extension initializers (``rtems_extensions_table``).
+RANGE:
+    Undefined or a list of user extension initializers.
+DEFAULT VALUE:
+DESCRIPTION:
+    If ``BSP_INITIAL_EXTENSION`` is defined by the BSP, then this BSP specific
+    initial extension will be placed as the last entry in the initial extension
+    table.
+NOTES:
+    None.
+.. index:: BSP_INTERRUPT_STACK_SIZE
+.. _BSP_INTERRUPT_STACK_SIZE:
+BSP_INTERRUPT_STACK_SIZE
+CONSTANT:
+    ``BSP_INTERRUPT_STACK_SIZE``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    If ``BSP_INTERRUPT_STACK_SIZE`` is defined by the BSP and
+    ``CONFIGURE_INTERRUPT_STACK_SIZE`` is not defined by the application, then
+    this BSP specific interrupt stack size will be used.
+NOTES:
+    None.
+.. index:: BSP_MAXIMUM_DEVICES
+.. _BSP_MAXIMUM_DEVICES:
+BSP_MAXIMUM_DEVICES
+CONSTANT:
+    ``BSP_MAXIMUM_DEVICES``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    If ``BSP_MAXIMUM_DEVICES`` is defined by the BSP and
+    ``CONFIGURE_MAXIMUM_DEVICES`` is not defined by the application, then this
+    BSP specific maximum device count will be used.
+NOTES:
+    This option is specific to the device file system (devFS) and should not be
+    confused with the ``CONFIGURE_MAXIMUM_DRIVERS`` option.  This parameter
+    only impacts the devFS and thus is only used by ``<rtems/confdefs.h>`` when
+    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM`` is specified.
+.. index:: CONFIGURE_BSP_PREREQUISITE_DRIVERS
+.. _CONFIGURE_BSP_PREREQUISITE_DRIVERS:
+CONFIGURE_BSP_PREREQUISITE_DRIVERS
+CONSTANT:
+    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS``
+DATA TYPE:
+    List of device driver initializers (``rtems_driver_address_table``).
+RANGE:
+    Undefined or array of device drivers.
+DEFAULT VALUE:
+DESCRIPTION:
+    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS`` is defined if the BSP has device
+    drivers it needs to include in the Device Driver Table.  This should be
+    defined to the set of device driver entries that will be placed in the
+    table at the *FRONT* of the Device Driver Table and initialized before any
+    other drivers *INCLUDING* any application prerequisite drivers.
+NOTES:
+    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS`` is typically used by BSPs to
+    configure common infrastructure such as bus controllers or probe for
+    devices.
+.. index:: CONFIGURE_DISABLE_BSP_SETTINGS
+.. _CONFIGURE_DISABLE_BSP_SETTINGS:
+CONFIGURE_DISABLE_BSP_SETTINGS
+CONSTANT:
+    ``CONFIGURE_DISABLE_BSP_SETTINGS``
+DATA TYPE:
+    Boolean feature macro.
+RANGE:
+    Defined or undefined.
+DEFAULT VALUE:
+    This is not defined by default.
+DESCRIPTION:
+    All BSP specific configuration settings can be disabled by the application
+    with the ``CONFIGURE_DISABLE_BSP_SETTINGS`` option.
+NOTES:
+    None.
+.. index:: CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+.. _CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK:
+CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+CONSTANT:
+    ``CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    This configuration parameter is defined by a BSP to indicate that it does
+    not allocate all available memory to the C Program Heap used by the Malloc
+    Family of routines.
+    If defined, when ``malloc()`` is unable to allocate memory, it will call
+    the BSP supplied ``sbrk()`` to obtain more memory.
+NOTES:
+    This parameter should not be defined by the application. Only the BSP knows
+    how it allocates memory to the C Program Heap.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index 8450ba6..821263d 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -21,250 +21,7 @@ Configuring a System
     msgq-buffer-config
     filesystem-config
     bdbuf-config
-BSP Related Configuration Options
-This section describes configuration options related to the BSP.  Some
-configuration options may have a BSP-specific setting which is defined by
-``<bsp.h>``.  The BSP-specific settings can be disabled by the
-:ref:`CONFIGURE_DISABLE_BSP_SETTINGS` configuration option.
-.. index:: BSP_IDLE_TASK_BODY
-.. _BSP_IDLE_TASK_BODY:
-BSP_IDLE_TASK_BODY
-CONSTANT:
-    ``BSP_IDLE_TASK_BODY``
-DATA TYPE:
-    Function pointer.
-RANGE:
-    Undefined or valid function pointer.
-DEFAULT VALUE:
-    This option is BSP specific.
-DESCRIPTION:
-    If ``BSP_IDLE_TASK_BODY`` is defined by the BSP and
-    ``CONFIGURE_IDLE_TASK_BODY`` is not defined by the application, then this
-    BSP specific idle task body will be used.
-NOTES:
-    As it has knowledge of the specific CPU model, system controller logic, and
-    peripheral buses, a BSP specific IDLE task may be capable of turning
-    components off to save power during extended periods of no task activity
-.. index:: BSP_IDLE_TASK_STACK_SIZE
-.. _BSP_IDLE_TASK_STACK_SIZE:
-BSP_IDLE_TASK_STACK_SIZE
-CONSTANT:
-    ``BSP_IDLE_TASK_STACK_SIZE``
-DATA TYPE:
-    Unsigned integer (``size_t``).
-RANGE:
-    Undefined or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    If ``BSP_IDLE_TASK_STACK_SIZE`` is defined by the BSP and
-    ``CONFIGURE_IDLE_TASK_STACK_SIZE`` is not defined by the application, then
-    this BSP suggested idle task stack size will be used.
-NOTES:
-    The order of precedence for configuring the IDLE task stack size is:
-    - RTEMS default minimum stack size.
-    - If defined, then ``CONFIGURE_MINIMUM_TASK_STACK_SIZE``.
-    - If defined, then the BSP specific ``BSP_IDLE_TASK_SIZE``.
-    - If defined, then the application specified ``CONFIGURE_IDLE_TASK_SIZE``.
-.. index:: BSP_INITIAL_EXTENSION
-.. _BSP_INITIAL_EXTENSION:
-BSP_INITIAL_EXTENSION
-CONSTANT:
-    ``BSP_INITIAL_EXTENSION``
-DATA TYPE:
-    List of user extension initializers (``rtems_extensions_table``).
-RANGE:
-    Undefined or a list of user extension initializers.
-DEFAULT VALUE:
-DESCRIPTION:
-    If ``BSP_INITIAL_EXTENSION`` is defined by the BSP, then this BSP specific
-    initial extension will be placed as the last entry in the initial extension
-    table.
-NOTES:
-    None.
-.. index:: BSP_INTERRUPT_STACK_SIZE
-.. _BSP_INTERRUPT_STACK_SIZE:
-BSP_INTERRUPT_STACK_SIZE
-CONSTANT:
-    ``BSP_INTERRUPT_STACK_SIZE``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    If ``BSP_INTERRUPT_STACK_SIZE`` is defined by the BSP and
-    ``CONFIGURE_INTERRUPT_STACK_SIZE`` is not defined by the application, then
-    this BSP specific interrupt stack size will be used.
-NOTES:
-    None.
-.. index:: BSP_MAXIMUM_DEVICES
-.. _BSP_MAXIMUM_DEVICES:
-BSP_MAXIMUM_DEVICES
-CONSTANT:
-    ``BSP_MAXIMUM_DEVICES``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    If ``BSP_MAXIMUM_DEVICES`` is defined by the BSP and
-    ``CONFIGURE_MAXIMUM_DEVICES`` is not defined by the application, then this
-    BSP specific maximum device count will be used.
-NOTES:
-    This option is specific to the device file system (devFS) and should not be
-    confused with the ``CONFIGURE_MAXIMUM_DRIVERS`` option.  This parameter
-    only impacts the devFS and thus is only used by ``<rtems/confdefs.h>`` when
-    ``CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM`` is specified.
-.. index:: CONFIGURE_BSP_PREREQUISITE_DRIVERS
-.. _CONFIGURE_BSP_PREREQUISITE_DRIVERS:
-CONFIGURE_BSP_PREREQUISITE_DRIVERS
-CONSTANT:
-    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS``
-DATA TYPE:
-    List of device driver initializers (``rtems_driver_address_table``).
-RANGE:
-    Undefined or array of device drivers.
-DEFAULT VALUE:
-DESCRIPTION:
-    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS`` is defined if the BSP has device
-    drivers it needs to include in the Device Driver Table.  This should be
-    defined to the set of device driver entries that will be placed in the
-    table at the *FRONT* of the Device Driver Table and initialized before any
-    other drivers *INCLUDING* any application prerequisite drivers.
-NOTES:
-    ``CONFIGURE_BSP_PREREQUISITE_DRIVERS`` is typically used by BSPs to
-    configure common infrastructure such as bus controllers or probe for
-    devices.
-.. index:: CONFIGURE_DISABLE_BSP_SETTINGS
-.. _CONFIGURE_DISABLE_BSP_SETTINGS:
-CONFIGURE_DISABLE_BSP_SETTINGS
-CONSTANT:
-    ``CONFIGURE_DISABLE_BSP_SETTINGS``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    All BSP specific configuration settings can be disabled by the application
-    with the ``CONFIGURE_DISABLE_BSP_SETTINGS`` option.
-NOTES:
-    None.
-.. index:: CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
-.. _CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK:
-CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
-CONSTANT:
-    ``CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    This configuration parameter is defined by a BSP to indicate that it does
-    not allocate all available memory to the C Program Heap used by the Malloc
-    Family of routines.
-    If defined, when ``malloc()`` is unable to allocate memory, it will call
-    the BSP supplied ``sbrk()`` to obtain more memory.
-NOTES:
-    This parameter should not be defined by the application. Only the BSP knows
-    how it allocates memory to the C Program Heap.
+    bsp-config
 Idle Task Configuration
2.16.4
