[PATCH 10/20] c-user: Move "Block Device Cache Configuration"
Mon Mar 9 09:02:53 UTC 2020
Update #3836.
 c-user/config/bdbuf-config.rst | 338 +++++++++++++++++++++++++++++++++++++++++
 c-user/config/index.rst        | 336 +---------------------------------------
 2 files changed, 339 insertions(+), 335 deletions(-)
 create mode 100644 c-user/config/bdbuf-config.rst
diff --git a/c-user/config/bdbuf-config.rst b/c-user/config/bdbuf-config.rst
new file mode 100644
index 0000000..011d4ee
--- /dev/null
+++ b/c-user/config/bdbuf-config.rst
@@ -0,0 +1,338 @@
+.. SPDX-License-Identifier: CC-BY-SA-4.0
+.. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+Block Device Cache Configuration
+This section defines Block Device Cache (bdbuf) related configuration
+parameters.
+.. index:: CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+.. _CONFIGURE_APPLICATION_NEEDS_LIBBLOCK:
+CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+CONSTANT:
+    ``CONFIGURE_APPLICATION_NEEDS_LIBBLOCK``
+DATA TYPE:
+    Boolean feature macro.
+RANGE:
+    Defined or undefined.
+DEFAULT VALUE:
+    This is not defined by default.
+DESCRIPTION:
+    Provides a Block Device Cache configuration.
+NOTES:
+    Each option of the Block Device Cache configuration can be explicitly set
+    by the user with the configuration options below.  The Block Device Cache
+    is used for example by the RFS and DOSFS file systems.
+.. index:: CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
+.. _CONFIGURE_BDBUF_CACHE_MEMORY_SIZE:
+CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
+CONSTANT:
+    ``CONFIGURE_BDBUF_CACHE_MEMORY_SIZE``
+DATA TYPE:
+    Unsigned integer (``size_t``).
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is 32768 bytes.
+DESCRIPTION:
+    Size of the cache memory in bytes.
+NOTES:
+    None.
+.. index:: CONFIGURE_BDBUF_BUFFER_MAX_SIZE
+.. _CONFIGURE_BDBUF_BUFFER_MAX_SIZE:
+CONFIGURE_BDBUF_BUFFER_MAX_SIZE
+CONSTANT:
+    ``CONFIGURE_BDBUF_BUFFER_MAX_SIZE``
+DATA TYPE:
+    Unsigned integer (``uint32_t``).
+RANGE:
+    It must be positive and an integral multiple of the buffer minimum size.
+DEFAULT VALUE:
+    The default value is 4096 bytes.
+DESCRIPTION:
+    Defines the maximum size of a buffer in bytes.
+NOTES:
+    None.
+.. index:: CONFIGURE_BDBUF_BUFFER_MIN_SIZE
+.. _CONFIGURE_BDBUF_BUFFER_MIN_SIZE:
+CONFIGURE_BDBUF_BUFFER_MIN_SIZE
+CONSTANT:
+    ``CONFIGURE_BDBUF_BUFFER_MIN_SIZE``
+DATA TYPE:
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is 512 bytes.
+DESCRIPTION:
+    Defines the minimum size of a buffer in bytes.
+NOTES:
+    None.
+.. index:: CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
+.. _CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS:
+CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
+CONSTANT:
+    ``CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS``
+DATA TYPE:
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is 0.
+DESCRIPTION:
+    Defines the maximum blocks per read-ahead request.
+NOTES:
+    A value of 0 disables the read-ahead task (default).  The read-ahead task
+    will issue speculative read transfers if a sequential access pattern is
+    detected.  This can improve the performance on some systems.
+.. index:: CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
+.. _CONFIGURE_BDBUF_MAX_WRITE_BLOCKS:
+CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
+CONSTANT:
+    ``CONFIGURE_BDBUF_MAX_WRITE_BLOCKS``
+DATA TYPE:
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is 16.
+DESCRIPTION:
+    Defines the maximum blocks per write request.
+NOTES:
+    None.
+.. index:: CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
+.. _CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY:
+CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
+CONSTANT:
+    ``CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY``
+DATA TYPE:
+    Task priority (``rtems_task_priority``).
+RANGE:
+    Valid task priority.
+DEFAULT VALUE:
+    The default value is 15.
+DESCRIPTION:
+    Defines the read-ahead task priority.
+NOTES:
+    None.
+.. index:: CONFIGURE_BDBUF_TASK_STACK_SIZE
+.. _CONFIGURE_BDBUF_TASK_STACK_SIZE:
+CONFIGURE_BDBUF_TASK_STACK_SIZE
+CONSTANT:
+    ``CONFIGURE_BDBUF_TASK_STACK_SIZE``
+DATA TYPE:
+RANGE:
+    Zero or positive.
+DEFAULT VALUE:
+    The default value is RTEMS_MINIMUM_STACK_SIZE.
+DESCRIPTION:
+    Defines the task stack size of the Block Device Cache tasks in bytes.
+NOTES:
+    None.
+.. index:: CONFIGURE_SWAPOUT_BLOCK_HOLD
+.. _CONFIGURE_SWAPOUT_BLOCK_HOLD:
+CONFIGURE_SWAPOUT_BLOCK_HOLD
+CONSTANT:
+    ``CONFIGURE_SWAPOUT_BLOCK_HOLD``
+DATA TYPE:
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is 1000 milliseconds.
+DESCRIPTION:
+    Defines the swapout task maximum block hold time in milliseconds.
+NOTES:
+    None.
+.. index:: CONFIGURE_SWAPOUT_SWAP_PERIOD
+.. _CONFIGURE_SWAPOUT_SWAP_PERIOD:
+CONFIGURE_SWAPOUT_SWAP_PERIOD
+CONSTANT:
+    ``CONFIGURE_SWAPOUT_SWAP_PERIOD``
+DATA TYPE:
+RANGE:
+    Positive.
+DEFAULT VALUE:
+    The default value is 250 milliseconds.
+DESCRIPTION:
+    Defines the swapout task swap period in milliseconds.
+NOTES:
+    None.
+.. index:: CONFIGURE_SWAPOUT_TASK_PRIORITY
+.. _CONFIGURE_SWAPOUT_TASK_PRIORITY:
+CONFIGURE_SWAPOUT_TASK_PRIORITY
+CONSTANT:
+    ``CONFIGURE_SWAPOUT_TASK_PRIORITY``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    Defines the swapout task priority.
+NOTES:
+    None.
+.. index:: CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
+.. _CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY:
+CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
+CONSTANT:
+    ``CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY``
+DATA TYPE:
+RANGE:
+DEFAULT VALUE:
+DESCRIPTION:
+    Defines the swapout worker task priority.
+NOTES:
+    None.
+.. index:: CONFIGURE_SWAPOUT_WORKER_TASKS
+.. _CONFIGURE_SWAPOUT_WORKER_TASKS:
+CONFIGURE_SWAPOUT_WORKER_TASKS
+CONSTANT:
+    ``CONFIGURE_SWAPOUT_WORKER_TASKS``
+DATA TYPE:
+RANGE:
+    Zero or positive.
+DEFAULT VALUE:
+DESCRIPTION:
+    Defines the swapout worker task count.
+NOTES:
+    None.
diff --git a/c-user/config/index.rst b/c-user/config/index.rst
index 1d559e6..8450ba6 100644
--- a/c-user/config/index.rst
+++ b/c-user/config/index.rst
@@ -20,341 +20,7 @@ Configuring a System
     stack-alloc-config
     msgq-buffer-config
     filesystem-config
-Block Device Cache Configuration
-This section defines Block Device Cache (bdbuf) related configuration
-parameters.
-.. index:: CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
-.. _CONFIGURE_APPLICATION_NEEDS_LIBBLOCK:
-CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
-CONSTANT:
-    ``CONFIGURE_APPLICATION_NEEDS_LIBBLOCK``
-DATA TYPE:
-    Boolean feature macro.
-RANGE:
-    Defined or undefined.
-DEFAULT VALUE:
-    This is not defined by default.
-DESCRIPTION:
-    Provides a Block Device Cache configuration.
-NOTES:
-    Each option of the Block Device Cache configuration can be explicitly set
-    by the user with the configuration options below.  The Block Device Cache
-    is used for example by the RFS and DOSFS file systems.
-.. index:: CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
-.. _CONFIGURE_BDBUF_CACHE_MEMORY_SIZE:
-CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_CACHE_MEMORY_SIZE``
-DATA TYPE:
-    Unsigned integer (``size_t``).
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 32768 bytes.
-DESCRIPTION:
-    Size of the cache memory in bytes.
-NOTES:
-    None.
-.. index:: CONFIGURE_BDBUF_BUFFER_MAX_SIZE
-.. _CONFIGURE_BDBUF_BUFFER_MAX_SIZE:
-CONFIGURE_BDBUF_BUFFER_MAX_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_BUFFER_MAX_SIZE``
-DATA TYPE:
-    Unsigned integer (``uint32_t``).
-RANGE:
-    It must be positive and an integral multiple of the buffer minimum size.
-DEFAULT VALUE:
-    The default value is 4096 bytes.
-DESCRIPTION:
-    Defines the maximum size of a buffer in bytes.
-NOTES:
-    None.
-.. index:: CONFIGURE_BDBUF_BUFFER_MIN_SIZE
-.. _CONFIGURE_BDBUF_BUFFER_MIN_SIZE:
-CONFIGURE_BDBUF_BUFFER_MIN_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_BUFFER_MIN_SIZE``
-DATA TYPE:
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 512 bytes.
-DESCRIPTION:
-    Defines the minimum size of a buffer in bytes.
-NOTES:
-    None.
-.. index:: CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
-.. _CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS:
-CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
-CONSTANT:
-    ``CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS``
-DATA TYPE:
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 0.
-DESCRIPTION:
-    Defines the maximum blocks per read-ahead request.
-NOTES:
-    A value of 0 disables the read-ahead task (default).  The read-ahead task
-    will issue speculative read transfers if a sequential access pattern is
-    detected.  This can improve the performance on some systems.
-.. index:: CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
-.. _CONFIGURE_BDBUF_MAX_WRITE_BLOCKS:
-CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
-CONSTANT:
-    ``CONFIGURE_BDBUF_MAX_WRITE_BLOCKS``
-DATA TYPE:
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 16.
-DESCRIPTION:
-    Defines the maximum blocks per write request.
-NOTES:
-    None.
-.. index:: CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
-.. _CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY:
-CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
-CONSTANT:
-    ``CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY``
-DATA TYPE:
-    Task priority (``rtems_task_priority``).
-RANGE:
-    Valid task priority.
-DEFAULT VALUE:
-    The default value is 15.
-DESCRIPTION:
-    Defines the read-ahead task priority.
-NOTES:
-    None.
-.. index:: CONFIGURE_BDBUF_TASK_STACK_SIZE
-.. _CONFIGURE_BDBUF_TASK_STACK_SIZE:
-CONFIGURE_BDBUF_TASK_STACK_SIZE
-CONSTANT:
-    ``CONFIGURE_BDBUF_TASK_STACK_SIZE``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-    The default value is RTEMS_MINIMUM_STACK_SIZE.
-DESCRIPTION:
-    Defines the task stack size of the Block Device Cache tasks in bytes.
-NOTES:
-    None.
-.. index:: CONFIGURE_SWAPOUT_BLOCK_HOLD
-.. _CONFIGURE_SWAPOUT_BLOCK_HOLD:
-CONFIGURE_SWAPOUT_BLOCK_HOLD
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_BLOCK_HOLD``
-DATA TYPE:
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 1000 milliseconds.
-DESCRIPTION:
-    Defines the swapout task maximum block hold time in milliseconds.
-NOTES:
-    None.
-.. index:: CONFIGURE_SWAPOUT_SWAP_PERIOD
-.. _CONFIGURE_SWAPOUT_SWAP_PERIOD:
-CONFIGURE_SWAPOUT_SWAP_PERIOD
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_SWAP_PERIOD``
-DATA TYPE:
-RANGE:
-    Positive.
-DEFAULT VALUE:
-    The default value is 250 milliseconds.
-DESCRIPTION:
-    Defines the swapout task swap period in milliseconds.
-NOTES:
-    None.
-.. index:: CONFIGURE_SWAPOUT_TASK_PRIORITY
-.. _CONFIGURE_SWAPOUT_TASK_PRIORITY:
-CONFIGURE_SWAPOUT_TASK_PRIORITY
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_TASK_PRIORITY``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    Defines the swapout task priority.
-NOTES:
-    None.
-.. index:: CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
-.. _CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY:
-CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY``
-DATA TYPE:
-RANGE:
-DEFAULT VALUE:
-DESCRIPTION:
-    Defines the swapout worker task priority.
-NOTES:
-    None.
-.. index:: CONFIGURE_SWAPOUT_WORKER_TASKS
-.. _CONFIGURE_SWAPOUT_WORKER_TASKS:
-CONFIGURE_SWAPOUT_WORKER_TASKS
-CONSTANT:
-    ``CONFIGURE_SWAPOUT_WORKER_TASKS``
-DATA TYPE:
-RANGE:
-    Zero or positive.
-DEFAULT VALUE:
-DESCRIPTION:
-    Defines the swapout worker task count.
-NOTES:
-    None.
+    bdbuf-config
 BSP Related Configuration Options
2.16.4
