[PATCH 2/2] Add a message to run 'pytest' to run rest of test suite.
Sebastian Huber
Mon Mar 16 20:21:53 UTC 2020
On 16/03/2020 21:01, Sebastian Huber wrote:
> On 16/03/2020 20:26, Amar Takhar wrote:
>> I should have also added some of my own reasons why pytest is better
>> for writing
>> tests in Python:
>> - Fantastic exception handling makes it far easier to debug test
>> and code.
>> PDB works seamlessly.
>> - Far less overhead in creating initial tests.
>> - Trivial fixture support
>> - Paramaterised tests -- this is incredibly essential / useful.
>> Another feature that's not often mentioned is pytest discovers tests
>> all on its
>> own. You can put a test anywhere labled test_*.py and it will work.
>> You can
>> run pytest anywhere in the source as well.
>> The above are starkly different from unittest where these features
>> don't exist
>> or are difficult / have a large overhead to implement.
> Ok, I guess I have to adjust my draft of the Python guidelines:
> https://lists.rtems.org/pipermail/devel/2020-March/058289.html
I converted an example test from unittest to pytest:
https://git.rtems.org/sebh/rtems-qual.git/commit/?id=823c74c5d68a5b0913eba2bd9202897cb883dcef
Using plain assert statements is quite nice. Also the "tmpdir" fixture
is really nice.
Chris, what do you think about using pytest in favour of the standard
Python unitttest?
