[PATCH 2/2] Add a message to run 'pytest' to run rest of test suite.
Amar Takhar
amar at rtems.org
Mon Mar 16 20:49:56 UTC 2020
On 2020-03-16 21:21 +0100, Sebastian Huber wrote:
> > https://lists.rtems.org/pipermail/devel/2020-March/058289.html
> I converted an example test from unittest to pytest:
There's no reason to use classes here you should use simple functions.
Classes are only useful if you want to maintain a state using a setup or
teardown. Look at test_macro.py for an example of this.
You should be using a setup similar to test_host.py which is just simple
functions it's less work and easier to read.
This is one of the best features of pytest. :)
BTW examples are in my rtemstoolkit patch.
> https://git.rtems.org/sebh/rtems-qual.git/commit/?id=823c74c5d68a5b0913eba2bd9202897cb883dcef
> Using plain assert statements is quite nice. Also the "tmpdir" fixture
> is really nice.
Yes, pytest has quite a few fixtures that make life extremely easy. Also just
using asserts really saves a lot of time and is easier to develop with. No need
to remember dozens of unique functions.
Amar.
