RTEMS Docs: Adding GSoC Getting Started Instructions
Niteesh G. S.
niteesh.gs at gmail.com
Tue Mar 17 08:11:37 UTC 2020
On Tue, Mar 17, 2020 at 2:28 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Mar 16, 2020 at 12:56 PM Niteesh G. S. <niteesh.gs at gmail.com>
> wrote:
> > I am interested in taking up #3907. I'll mostly be copying and updating
> the contents from the old wiki site.
> > I have the following plan in mind. I'll start working on it if you are
> happy with it.
> > Add a new gsoc section in the user manual with contents
> > from https://devel.rtems.org/wiki/GSoC (index.rst)
> > Under this section, we'll have the following
> > 1) GSoC getting started instructions (
> https://devel.rtems.org/wiki/GSoC/GettingStarted)
> > 2) Mentors list (https://devel.rtems.org/wiki/GSoC/Mentors)
> > 3) Previous year GSoC information under separate pages.
> I think it should be separated somewhat. This GSoC stuff is not right
> to put in the User Manual, except for the Getting Started guide. There
> is the full "Quick Start"
> https://docs.rtems.org/branches/master/user/start/index.html# that
> may be too complicated for new users, but that area of the user manual
> is probably where the simplified "GSoC" guide should live.
I'll start with adding the getting started instructions in the quick start
section and later start working on the
Learning with RTEMS section.
Regarding the getting started instructions, should we ask the user to refer
to the quick start section for
build instructions or should we repeat them? The old wiki tells to refer
the quick start guide for build
instructions but IMHO having all the instructions in one place will make it
easy for the newcomers.
> That said, I'd be OK with introducing a new "Learning with RTEMS"
> Manual that covers both SoC, GCI, and maybe can be expanded over time.
> As a kind of "beginner friendly / student-oriented" guide?
> > Niteesh
> > devel mailing list
> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200317/08e5a2cb/attachment-0001.html>
